[PATCH] score: Do not inline _Thread_Dispatch_enable()
Fri Aug 10 06:14:28 UTC 2018
This function is slighly too complex for inlining with two if
statements.  The caller already needs a stack frame due to the potential
call to _Thread_Do_dispatch().  In _Thread_Dispatch_enable() the call to
_Thread_Do_dispatch() can be optimized to a tail call.
A text size comparision
  (text size after patch - text size before patch)
   / text size before patch
on sparc/erc32 with SMP enabled showed these results:
  Minimum -0.000697892 (fsdosfsname01.exe)
  Median -0.00745021 (psxtimes01.exe)
  Maximum -0.0233032 (spscheduler01.exe)
  Minimum -3312 (ada_sp09.exe)
  Median -1024 (tm15.exe)
  Maximum -592 (spglobalcon01.exe)
 cpukit/include/rtems/score/threaddispatch.h | 29 ++---------------------------
 cpukit/score/src/threaddispatch.c           | 27 +++++++++++++++++++++++++++
 2 files changed, 29 insertions(+), 27 deletions(-)
diff --git a/cpukit/include/rtems/score/threaddispatch.h b/cpukit/include/rtems/score/threaddispatch.h
index 69696f4044..f5d5c48035 100644
--- a/cpukit/include/rtems/score/threaddispatch.h
+++ b/cpukit/include/rtems/score/threaddispatch.h
@@ -205,36 +205,11 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable( void )
  * @brief Enables thread dispatching.
- * May perfrom a thread dispatch if necessary as a side-effect.
+ * May perform a thread dispatch if necessary as a side-effect.
  * @param[in] cpu_self The current processor.
-RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
-  uint32_t disable_level = cpu_self->thread_dispatch_disable_level;
-  if ( disable_level == 1 ) {
-    ISR_Level level;
-    _ISR_Local_disable( level );
-    if (
-      cpu_self->dispatch_necessary
-#if defined(RTEMS_SCORE_ROBUST_THREAD_DISPATCH)
-        || !_ISR_Is_enabled( level )
-#endif
-      _Thread_Do_dispatch( cpu_self, level );
-    } else {
-      cpu_self->thread_dispatch_disable_level = 0;
-      _Profiling_Thread_dispatch_enable( cpu_self, 0 );
-      _ISR_Local_enable( level );
-  } else {
-    _Assert( disable_level > 0 );
-    cpu_self->thread_dispatch_disable_level = disable_level - 1;
+void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self );
  * @brief Unnests thread dispatching.
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 9cd1e294ed..d6207bc898 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -267,3 +267,30 @@ void _Thread_Dispatch_direct( Per_CPU_Control *cpu_self )
+  uint32_t disable_level = cpu_self->thread_dispatch_disable_level;
+  if ( disable_level == 1 ) {
+    ISR_Level level;
+    _ISR_Local_disable( level );
+    if (
+      cpu_self->dispatch_necessary
+#if defined(RTEMS_SCORE_ROBUST_THREAD_DISPATCH)
+        || !_ISR_Is_enabled( level )
+#endif
+      _Thread_Do_dispatch( cpu_self, level );
+    } else {
+      cpu_self->thread_dispatch_disable_level = 0;
+      _Profiling_Thread_dispatch_enable( cpu_self, 0 );
+      _ISR_Local_enable( level );
+  } else {
+    _Assert( disable_level > 0 );
+    cpu_self->thread_dispatch_disable_level = disable_level - 1;
2.13.7
