Tickets: Milestone vs. Version
Fri Aug 10 20:33:29 UTC 2018
On Fri, Aug 10, 2018 at 2:10 AM, Chris Johns <chrisj at rtems.org> wrote:
> Release Terminology
> - A release is the creation of any generated files and their packaging together
> with the source in a repository that makes the package available as a file.
> - A release branch is a git branch pushed to the repositories used to create
> release. There is a release branch for each version of RTEMS.
> - A release is a git tag on a release branch with the tags pushed to the
> repositories.
This may be a separate discussion. Here you defined 'release' twice,
so I'm a bit unclear about your proposed terminology.
Gedare
