[PATCH 1/5] bsps/x86_64: Reorganize header files and compile-options
Amaan Cheval amaan.cheval at gmail.com
Mon Aug 13 11:27:20 UTC 2018
Updates #2898.
 bsps/x86_64/amd64/config/amd64.cfg            |  3 ++
 cpukit/score/cpu/x86_64/headers.am            |  1 +
 cpukit/score/cpu/x86_64/include/rtems/asm.h   | 10 ++++
 .../cpu/x86_64/include/rtems/score/cpu.h      |  5 +-
 .../cpu/x86_64/include/rtems/score/cpu_asm.h  | 50 +++++++++++++++++++
 .../cpu/x86_64/include/rtems/score/cpuimpl.h  | 16 +-----
 .../cpu/x86_64/include/rtems/score/x86_64.h   | 13 ++++-
 .../score/cpu/x86_64/x86_64-context-switch.S  |  8 +--
 8 files changed, 84 insertions(+), 22 deletions(-)
 create mode 100644 cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
diff --git a/bsps/x86_64/amd64/config/amd64.cfg b/bsps/x86_64/amd64/config/amd64.cfg
index 3c4492d9d3..ad861cb867 100644
--- a/bsps/x86_64/amd64/config/amd64.cfg
+++ b/bsps/x86_64/amd64/config/amd64.cfg
@@ -11,3 +11,6 @@ CPU_CFLAGS  = -mno-red-zone
 # way we can avoid linker-time relocation errors spawning from values being
 # larger than their optimized container sizes.
 CPU_CFLAGS += -mcmodel=large
+CPU_CFLAGS += -Werror=return-type
+LDFLAGS = -Wl,--gc-sections
diff --git a/cpukit/score/cpu/x86_64/headers.am b/cpukit/score/cpu/x86_64/headers.am
index b3792d00b1..d23c39d99b 100644
--- a/cpukit/score/cpu/x86_64/headers.am
+++ b/cpukit/score/cpu/x86_64/headers.am
@@ -11,6 +11,7 @@ include_rtems_HEADERS += include/rtems/asm.h
 include_rtems_scoredir = $(includedir)/rtems/score
 include_rtems_score_HEADERS =
 include_rtems_score_HEADERS += include/rtems/score/cpu.h
+include_rtems_score_HEADERS += include/rtems/score/cpu_asm.h
 include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
 include_rtems_score_HEADERS += include/rtems/score/x86_64.h
diff --git a/cpukit/score/cpu/x86_64/include/rtems/asm.h b/cpukit/score/cpu/x86_64/include/rtems/asm.h
index 36699140b7..76efc07db3 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/asm.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/asm.h
@@ -84,6 +84,16 @@
 #define r14 REG (r14)
 #define r15 REG (r15)
+ * Order of register usage for function arguments as per the calling convention
+#define REG_ARG0 rdi
+#define REG_ARG1 rsi
+#define REG_ARG2 rdx
+#define REG_ARG3 rcx
+#define REG_ARG4 r8
+#define REG_ARG5 r9
 // XXX: eax, ax, etc., segment registers
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
index 5c40af7647..557d11109d 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
@@ -40,6 +40,7 @@ extern "C" {
 #endif
+#include <rtems/score/cpu_asm.h>
 #include <rtems/score/x86_64.h>
 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
@@ -54,7 +55,7 @@ extern "C" {
 #define CPU_PROVIDES_IDLE_THREAD_BODY    FALSE
 #define CPU_STACK_GROWS_UP               FALSE
-#define CPU_STRUCTURE_ALIGNMENT __attribute__((aligned ( 64 )))
+#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED(64)
 #define CPU_CACHE_LINE_BYTES 64
 #define CPU_MODES_INTERRUPT_MASK   0x00000001
 #define CPU_MAXIMUM_PROCESSORS 32
@@ -104,7 +105,7 @@ typedef struct {
     uint32_t   special_interrupt_register;
 } CPU_Interrupt_frame;
-#endif /* ASM */
+#endif /* !ASM */
 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
new file mode 100644
index 0000000000..ac43a6366d
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
@@ -0,0 +1,50 @@
+ * Copyright (c) 2018.
+ * Amaan Cheval <amaan.cheval at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_CPU_ASM_H
+#define _RTEMS_SCORE_CPU_ASM_H
+#if !ASM
+#include <rtems/score/basedefs.h>
+RTEMS_INLINE_ROUTINE uint8_t inport_byte(uint16_t port)
+  uint8_t ret;
+  __asm__ volatile ( "inb %1, %0"
+                     : "=a" (ret)
+                     : "Nd" (port) );
+  return ret;
+RTEMS_INLINE_ROUTINE void outport_byte(uint16_t port, uint8_t val)
+  __asm__ volatile ( "outb %0, %1" : : "a" (val), "Nd" (port) );
+#endif /* !ASM */
+#endif
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
index 722edeb00e..a3a40faf66 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
@@ -28,20 +28,6 @@
 extern "C" {
 #endif
-static inline uint8_t inport_byte(uint16_t port)
-  uint8_t ret;
-  __asm__ volatile ( "inb %1, %0"
-                     : "=a" (ret)
-                     : "Nd" (port) );
-  return ret;
-static inline void outport_byte(uint16_t port, uint8_t val)
-  __asm__ volatile ( "outb %0, %1" : : "a" (val), "Nd" (port) );
 RTEMS_INLINE_ROUTINE void _CPU_Context_volatile_clobber( uintptr_t pattern )
   /* TODO */
@@ -68,6 +54,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif
-#endif /* ASM */
+#endif /* !ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
index 853e45ab5d..f4710c4b8f 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
@@ -32,11 +32,20 @@ extern "C" {
 #endif
 #define CPU_NAME "x86-64"
-#define CPU_MODEL_NAME "XXX: x86-64 generic"
+#define CPU_MODEL_NAME "amd64"
-#define COM1_BASE_IO 0x3F8
+#define COM1_BASE_IO    0x3F8
 #define COM1_CLOCK_RATE (115200 * 16)
+#define EFLAGS_INTR_ENABLE 0x200
+#if DEBUG
+#define DBG_PRINTF(format, args...)             \
+  printf(format, ## args)
+#else
+#endif
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/cpu/x86_64/x86_64-context-switch.S b/cpukit/score/cpu/x86_64/x86_64-context-switch.S
index cb451e9acb..5ff78d23e0 100644
--- a/cpukit/score/cpu/x86_64/x86_64-context-switch.S
+++ b/cpukit/score/cpu/x86_64/x86_64-context-switch.S
@@ -46,8 +46,10 @@ BEGIN_CODE
 .p2align  1
 PUBLIC(_CPU_Context_switch)
-.set RUNCONTEXT_ARG,   rdi                   /* save context argument */
-.set HEIRCONTEXT_ARG,  rsi                   /* restore context argument */
+/* save context argument */
+.set RUNCONTEXT_ARG,   REG_ARG0
+/* restore context argument */
+.set HEIRCONTEXT_ARG,  REG_ARG1
 SYM(_CPU_Context_switch):
   movq    RUNCONTEXT_ARG, rax  /* rax = running threads context */
@@ -88,7 +90,7 @@ restore:
 PUBLIC(_CPU_Context_restore)
-.set NEWCONTEXT_ARG,   rdi       /* context to restore argument */
+.set NEWCONTEXT_ARG,   REG_ARG0       /* context to restore argument */
 SYM(_CPU_Context_restore):
   movq      NEWCONTEXT_ARG, rax  /* rax = running threads context */
2.18.0
