[PATCH 3/5] bsps/x86_64: Add paging support with 1GiB super pages
Amaan Cheval amaan.cheval at gmail.com
Mon Aug 13 11:27:22 UTC 2018
Updates #2898.
 bsps/x86_64/amd64/start/bspstart.c            |   2 +
 bsps/x86_64/amd64/start/page.c                | 172 ++++++++++++++++++
 bsps/x86_64/headers.am                        |   5 +
 bsps/x86_64/include/libcpu/page.h             |  68 +++++++
 c/src/lib/libbsp/x86_64/amd64/Makefile.am     |   1 +
 .../cpu/x86_64/include/rtems/score/cpu_asm.h  |  13 ++
 6 files changed, 261 insertions(+)
 create mode 100644 bsps/x86_64/amd64/start/page.c
 create mode 100644 bsps/x86_64/headers.am
 create mode 100644 bsps/x86_64/include/libcpu/page.h
diff --git a/bsps/x86_64/amd64/start/bspstart.c b/bsps/x86_64/amd64/start/bspstart.c
index 784748ce3f..5a5b46bcec 100644
--- a/bsps/x86_64/amd64/start/bspstart.c
+++ b/bsps/x86_64/amd64/start/bspstart.c
@@ -26,7 +26,9 @@
 #include <bsp.h>
 #include <bsp/bootcard.h>
+#include <libcpu/page.h>
 void bsp_start(void)
+  paging_init();
diff --git a/bsps/x86_64/amd64/start/page.c b/bsps/x86_64/amd64/start/page.c
new file mode 100644
index 0000000000..64bdf21707
--- /dev/null
+++ b/bsps/x86_64/amd64/start/page.c
@@ -0,0 +1,172 @@
+ * This file sets up page sizes to 1GiB (i.e. huge pages, using only the PML4
+ * and PDPT, skipping the PDT, and PT).
+ * We set up identity-page mapping for the 512 GiBs addressable by using static
+ * PML4 and PDPT tables.
+ * Section 4.5 "4-Level Paging" of Volume 3 of the Intel Software Developer
+ * Manual guides a lot of the code used in this file.
+ * Copyright (c) 2018.
+ * Amaan Cheval <amaan.cheval at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <stdio.h>
+#include <assert.h>
+#include <bsp.h>
+#include <rtems.h>
+#include <rtems/score/cpu.h>
+uint64_t amd64_pml4[NUM_PAGE_TABLE_ENTRIES] RTEMS_ALIGNED(4096);
+uint64_t amd64_pdpt[NUM_PAGE_TABLE_ENTRIES] RTEMS_ALIGNED(4096);
+bool paging_1gib_pages_supported(void)
+   * If CPUID.80000001H:EDX.Page1GB [bit 26] = 1, 1-GByte pages are supported
+   * with 4-level paging.
+  uint32_t a, b, c, d;
+  cpuid(0x80000001, &a, &b, &c, &d);
+  return (d >> 26) & 1;
+uint8_t get_maxphysaddr(void)
+   * CPUID.80000008H:EAX[15:8] reports the linear-address width supported by the
+   * processor. Generally, this value is 48 if CPUID.80000001H:EDX.LM [bit 29] =
+   * 1 and 32 otherwise.
+  cpuid(0x80000008, &a, &b, &c, &d);
+  uint8_t maxphysaddr = (a >> 8) & 0xff;
+  /* This width is referred to as MAXPHYADDR. MAXPHYADDR is at most 52. */
+  assert(maxphysaddr <= 52);
+  return maxphysaddr;
+uint64_t get_mask_for_bits(uint8_t start, uint8_t end)
+   * Create a mask that lets you select bits start:end when logically ANDed with
+   * a value. For eg.
+   *   get_mask_for_bits(48, 64) = 0xffff000000000000
+  uint64_t mask = (((uint64_t) 1 << (end - start)) - 1) << start;
+  return mask;
+RTEMS_INLINE_ROUTINE void assert_0s_from_bit(uint64_t entry, uint8_t bit_pos)
+  /* Confirm that bit_pos:64 are all 0s */
+  assert((entry & get_mask_for_bits(bit_pos, 64)) == 0);
+uint64_t create_cr3_entry(
+  uint64_t phys_addr, uint8_t maxphysaddr, uint64_t flags
+  /* Confirm PML4 address is aligned on a 4KiB boundary */
+  assert((phys_addr & 0xfff) == 0);
+  uint64_t entry = (phys_addr & get_mask_for_bits(12, maxphysaddr)) | flags;
+  /* Confirm that bits maxphysaddr:64 are 0s */
+  assert_0s_from_bit(entry, maxphysaddr);
+  return entry;
+uint64_t create_pml4_entry(
+  /* Confirm address we're writing is aligned on a 4KiB boundary */
+   * Confirm that bits maxphysaddr:64 are 0s; there are other usable bits there
+   * such as PAGE_FLAGS_NO_EXECUTE, but we're asserting that those aren't set
+   * either.
+  return entry;
+uint64_t create_pdpt_entry(
+  /* Confirm physical address is a 1GiB aligned page address */
+  assert((phys_addr & 0x3fffffff) == 0);
+  uint64_t entry = (phys_addr & get_mask_for_bits(30, maxphysaddr)) | flags;
+   * such as the protection key and PAGE_FLAGS_NO_EXECUTE, but we're asserting
+   * that those aren't set either.
+  return entry;
+void paging_init(void)
+  if ( !paging_1gib_pages_supported() ) {
+    printf("warning: 1 GiB pages aren't supported - trying anyway.\n");
+  const uint8_t maxphysaddr = get_maxphysaddr();
+  DBG_PRINTF("maxphysaddr = %d\n", maxphysaddr);
+  const uint64_t gib = (1 << 30);
+  for (uint32_t i = 0; i < NUM_PAGE_TABLE_ENTRIES; i++) {
+    amd64_pdpt[i] = create_pdpt_entry(
+      /* This is the i-th GiB for identity-mapping */
+      (uint64_t) i * gib,
+      maxphysaddr,
+      /* Setting huge page in the PDPTE gives us 1 GiB pages */
+      PAGE_FLAGS_DEFAULTS | PAGE_FLAGS_HUGE_PAGE
+    amd64_pml4[i] = create_pml4_entry(
+      (uint64_t) amd64_pdpt,
+      maxphysaddr,
+  amd64_set_cr3(
+    create_cr3_entry(
+      (uint64_t) &amd64_pml4,
+      maxphysaddr,
+      PAGE_FLAGS_WRITE_THROUGH
diff --git a/bsps/x86_64/headers.am b/bsps/x86_64/headers.am
index 0000000000..6f79bca7c0
--- /dev/null
+++ b/bsps/x86_64/headers.am
@@ -0,0 +1,5 @@
+## This file was generated by "./boostrap -H".
+include_libcpudir = $(includedir)/libcpu
+include_libcpu_HEADERS =
+include_libcpu_HEADERS += ../../../../../bsps/x86_64/include/libcpu/page.h
diff --git a/bsps/x86_64/include/libcpu/page.h b/bsps/x86_64/include/libcpu/page.h
index 0000000000..1903ae975e
--- /dev/null
+++ b/bsps/x86_64/include/libcpu/page.h
@@ -0,0 +1,68 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _LIBCPU_AMD64_PAGE_H
+#define _LIBCPU_AMD64_PAGE_H
+#ifndef ASM
+#define NUM_PAGE_TABLE_ENTRIES 512
+extern uint64_t amd64_pml4[NUM_PAGE_TABLE_ENTRIES];
+extern uint64_t amd64_pdpt[NUM_PAGE_TABLE_ENTRIES];
+bool paging_1gib_pages_supported(void);
+uint8_t get_maxphysaddr(void);
+uint64_t get_mask_for_bits(uint8_t start, uint8_t end);
+void paging_init(void);
+#define PAGE_FLAGS_PRESENT          (1 << 0)
+#define PAGE_FLAGS_WRITABLE         (1 << 1)
+#define PAGE_FLAGS_USER_ACCESSIBLE  (1 << 2)
+#define PAGE_FLAGS_WRITE_THROUGH    (1 << 3)
+#define PAGE_FLAGS_NO_CACHE         (1 << 4)
+#define PAGE_FLAGS_ACCESSED         (1 << 5)
+#define PAGE_FLAGS_DIRTY            (1 << 6)
+#define PAGE_FLAGS_HUGE_PAGE        (1 << 7)
+#define PAGE_FLAGS_GLOBAL           (1 << 8)
+#define PAGE_FLAGS_NO_EXECUTE       (1 << 63)
+#define PAGE_FLAGS_DEFAULTS                                              \
+  (PAGE_FLAGS_PRESENT | PAGE_FLAGS_WRITABLE | PAGE_FLAGS_USER_ACCESSIBLE \
+   | PAGE_FLAGS_WRITE_THROUGH | PAGE_FLAGS_NO_CACHE | PAGE_FLAGS_GLOBAL)
+#endif /* !ASM */
+#endif
diff --git a/c/src/lib/libbsp/x86_64/amd64/Makefile.am b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
index aa40f6224f..93c4e90fbc 100644
--- a/c/src/lib/libbsp/x86_64/amd64/Makefile.am
+++ b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
@@ -23,6 +23,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/start/bspstart.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/start/start.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/start/page.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
index ac43a6366d..5d4b608eb8 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
@@ -45,6 +45,19 @@ RTEMS_INLINE_ROUTINE void outport_byte(uint16_t port, uint8_t val)
   __asm__ volatile ( "outb %0, %1" : : "a" (val), "Nd" (port) );
+RTEMS_INLINE_ROUTINE void amd64_set_cr3(uint64_t segment)
+  __asm__ volatile ( "movq %0, %%cr3" : "=r" (segment) : "0" (segment) );
+RTEMS_INLINE_ROUTINE void cpuid(
+  uint32_t code, uint32_t *eax, uint32_t *ebx, uint32_t *ecx, uint32_t *edx
+  __asm__ volatile ( "cpuid"
+                     : "=a" (*eax), "=b" (*ebx), "=c" (*ecx), "=d" (*edx)
+                     : "a" (code) );
 #endif /* !ASM */
 #endif
2.18.0
