[PATCH 4/5] bsps/x86_64: Add support for RTEMS interrupts
Amaan Cheval amaan.cheval at gmail.com
Mon Aug 13 11:27:23 UTC 2018
Updates #2898.
 bsps/x86_64/amd64/interrupts/idt.c            | 151 ++++++++++++++
 bsps/x86_64/amd64/interrupts/isr_handler.S    | 191 ++++++++++++++++++
 bsps/x86_64/amd64/start/bspstart.c            |   2 +
 bsps/x86_64/headers.am                        |   4 +
 bsps/x86_64/include/bsp/irq.h                 |  46 +++++
 c/src/lib/libbsp/x86_64/amd64/Makefile.am     |   4 +
 cpukit/score/cpu/x86_64/cpu.c                 |  17 +-
 cpukit/score/cpu/x86_64/headers.am            |   1 +
 .../cpu/x86_64/include/rtems/score/cpu.h      | 107 ++++++++--
 .../cpu/x86_64/include/rtems/score/cpu_asm.h  |  18 ++
 .../cpu/x86_64/include/rtems/score/idt.h      | 131 ++++++++++++
 .../cpu/x86_64/x86_64-context-initialize.c    |   9 +-
 12 files changed, 648 insertions(+), 33 deletions(-)
 create mode 100644 bsps/x86_64/amd64/interrupts/idt.c
 create mode 100644 bsps/x86_64/amd64/interrupts/isr_handler.S
 create mode 100644 bsps/x86_64/include/bsp/irq.h
 create mode 100644 cpukit/score/cpu/x86_64/include/rtems/score/idt.h
diff --git a/bsps/x86_64/amd64/interrupts/idt.c b/bsps/x86_64/amd64/interrupts/idt.c
new file mode 100644
index 0000000000..e5964e36a1
--- /dev/null
+++ b/bsps/x86_64/amd64/interrupts/idt.c
@@ -0,0 +1,151 @@
+ * Copyright (c) 2018.
+ * Amaan Cheval <amaan.cheval at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <stdint.h>
+#include <rtems.h>
+#include <rtems/score/idt.h>
+#include <rtems/score/basedefs.h>
+#include <rtems/score/x86_64.h>
+#include <rtems/score/cpuimpl.h>
+#include <bsp/irq-generic.h>
+ * The IDT maps every interrupt vector to an interrupt_descriptor based on the
+ * vector number.
+interrupt_descriptor amd64_idt[IDT_SIZE] RTEMS_ALIGNED(8) = { { 0 } };
+struct idt_record idtr = {
+  .limit = (IDT_SIZE * 16) - 1,
+  .base = (uintptr_t) amd64_idt
+ * IRQs that the RTEMS Interrupt Manager will manage
+ * @see DISTINCT_INTERRUPT_ENTRY
+static uintptr_t rtemsIRQs[BSP_IRQ_VECTOR_NUMBER] = {
+  (uintptr_t) rtems_irq_prologue_0,
+  (uintptr_t) rtems_irq_prologue_1,
+  (uintptr_t) rtems_irq_prologue_2,
+  (uintptr_t) rtems_irq_prologue_3,
+  (uintptr_t) rtems_irq_prologue_4,
+  (uintptr_t) rtems_irq_prologue_5,
+  (uintptr_t) rtems_irq_prologue_6,
+  (uintptr_t) rtems_irq_prologue_7,
+  (uintptr_t) rtems_irq_prologue_8,
+  (uintptr_t) rtems_irq_prologue_9,
+  (uintptr_t) rtems_irq_prologue_10,
+  (uintptr_t) rtems_irq_prologue_11,
+  (uintptr_t) rtems_irq_prologue_12,
+  (uintptr_t) rtems_irq_prologue_13,
+  (uintptr_t) rtems_irq_prologue_14,
+  (uintptr_t) rtems_irq_prologue_15,
+  (uintptr_t) rtems_irq_prologue_16,
+  (uintptr_t) rtems_irq_prologue_17,
+  (uintptr_t) rtems_irq_prologue_18,
+  (uintptr_t) rtems_irq_prologue_19,
+  (uintptr_t) rtems_irq_prologue_20,
+  (uintptr_t) rtems_irq_prologue_21,
+  (uintptr_t) rtems_irq_prologue_22,
+  (uintptr_t) rtems_irq_prologue_23,
+  (uintptr_t) rtems_irq_prologue_24,
+  (uintptr_t) rtems_irq_prologue_25,
+  (uintptr_t) rtems_irq_prologue_26,
+  (uintptr_t) rtems_irq_prologue_27,
+  (uintptr_t) rtems_irq_prologue_28,
+  (uintptr_t) rtems_irq_prologue_29,
+  (uintptr_t) rtems_irq_prologue_30,
+  (uintptr_t) rtems_irq_prologue_31,
+  (uintptr_t) rtems_irq_prologue_32
+void lidt(struct idt_record *ptr)
+  __asm__ volatile ("lidt %0" :: "m"(*ptr));
+interrupt_descriptor amd64_create_interrupt_descriptor(
+  uintptr_t handler, uint8_t types_and_attributes
+  interrupt_descriptor entry = {
+    .offset_0 = handler & 0xffff,
+    .segment_selector = amd64_get_cs(),
+    .interrupt_stack_table = 0,
+    .type_and_attributes = types_and_attributes,
+    .offset_1 = (handler >> 16) & 0xffff,
+    .offset_2 = handler >> 32,
+    .reserved_zero = 0,
+  return entry;
+uintptr_t amd64_get_handler_from_idt(uint32_t vector)
+  interrupt_descriptor entry = amd64_idt[vector];
+  uintptr_t handler = entry.offset_0 | (entry.offset_1 << 16) |
+    ((uint64_t) entry.offset_2 << 32);
+  return handler;
+void amd64_install_raw_interrupt(
+  uint32_t vector, uintptr_t new_handler, uintptr_t *old_handler
+  *old_handler = amd64_get_handler_from_idt(vector);
+  interrupt_descriptor new_desc = amd64_create_interrupt_descriptor(
+    new_handler,
+    IDT_INTERRUPT_GATE | IDT_PRESENT
+  amd64_idt[vector] = new_desc;
+void amd64_dispatch_isr(rtems_vector_number vector)
+  bsp_interrupt_handler_dispatch(vector);
+rtems_status_code bsp_interrupt_facility_initialize(void)
+  uintptr_t old;
+  for (uint32_t i = 0; i < BSP_IRQ_VECTOR_NUMBER; i++) {
+    amd64_install_raw_interrupt(i, rtemsIRQs[i], &old);
+  lidt(&idtr);
+  return RTEMS_SUCCESSFUL;
+void bsp_interrupt_vector_disable(rtems_vector_number vector)
+  /* XXX */
+void bsp_interrupt_vector_enable(rtems_vector_number vector)
+  /* XXX */
diff --git a/bsps/x86_64/amd64/interrupts/isr_handler.S b/bsps/x86_64/amd64/interrupts/isr_handler.S
index 0000000000..fc2c9a9e76
--- /dev/null
+++ b/bsps/x86_64/amd64/interrupts/isr_handler.S
@@ -0,0 +1,191 @@
+ * This file contains the _ISR_Handler that acts as the common handler for all
+ * vectors to be managed by the RTEMS interrupt manager.
+ * are met:
+ * SUCH DAMAGE.
+#include <rtems/asm.h>
+#include <rtems/score/cpu.h>
+#include <rtems/score/percpu.h>
+#ifndef CPU_STACK_ALIGNMENT
+#error "Missing header? CPU_STACK_ALIGNMENT not defined"
+#endif
+BEGIN_CODE
+PUBLIC(apic_spurious_handler)
+SYM(apic_spurious_handler):
+  iretq
+ * These are callee-saved registers, which means we can use them in our
+ * interrupts as persistent scratch registers (i.e. calls will not destroy
+ * them), as long as we also save and restore it for the interrupted task.
+.set SCRATCH_REG0, rbp
+.set SCRATCH_REG1, rbx
+ * We need to set a distinct handler for every interrupt vector so that
+ * we can pass the vector number to _ISR_Handler correctly.
+#define DISTINCT_INTERRUPT_ENTRY(vector)   \
+  .p2align 4                             ; \
+  PUBLIC(rtems_irq_prologue_ ## vector)  ; \
+SYM(rtems_irq_prologue_ ## vector):      ; \
+  pushq REG_ARG0                         ; \
+  movq  $vector, REG_ARG0                ; \
+  pushq SCRATCH_REG0                     ; \
+  pushq SCRATCH_REG1                     ; \
+  jmp   SYM(_ISR_Handler)
+DISTINCT_INTERRUPT_ENTRY(0)
+DISTINCT_INTERRUPT_ENTRY(1)
+DISTINCT_INTERRUPT_ENTRY(2)
+DISTINCT_INTERRUPT_ENTRY(3)
+DISTINCT_INTERRUPT_ENTRY(4)
+DISTINCT_INTERRUPT_ENTRY(5)
+DISTINCT_INTERRUPT_ENTRY(6)
+DISTINCT_INTERRUPT_ENTRY(7)
+DISTINCT_INTERRUPT_ENTRY(8)
+DISTINCT_INTERRUPT_ENTRY(9)
+DISTINCT_INTERRUPT_ENTRY(10)
+DISTINCT_INTERRUPT_ENTRY(11)
+DISTINCT_INTERRUPT_ENTRY(12)
+DISTINCT_INTERRUPT_ENTRY(13)
+DISTINCT_INTERRUPT_ENTRY(14)
+DISTINCT_INTERRUPT_ENTRY(15)
+DISTINCT_INTERRUPT_ENTRY(16)
+DISTINCT_INTERRUPT_ENTRY(17)
+DISTINCT_INTERRUPT_ENTRY(18)
+DISTINCT_INTERRUPT_ENTRY(19)
+DISTINCT_INTERRUPT_ENTRY(20)
+DISTINCT_INTERRUPT_ENTRY(21)
+DISTINCT_INTERRUPT_ENTRY(22)
+DISTINCT_INTERRUPT_ENTRY(23)
+DISTINCT_INTERRUPT_ENTRY(24)
+DISTINCT_INTERRUPT_ENTRY(25)
+DISTINCT_INTERRUPT_ENTRY(26)
+DISTINCT_INTERRUPT_ENTRY(27)
+DISTINCT_INTERRUPT_ENTRY(28)
+DISTINCT_INTERRUPT_ENTRY(29)
+DISTINCT_INTERRUPT_ENTRY(30)
+DISTINCT_INTERRUPT_ENTRY(31)
+DISTINCT_INTERRUPT_ENTRY(32)
+SYM(_ISR_Handler):
+.save_cpu_interrupt_frame:
+.set SAVED_RSP, SCRATCH_REG0
+  movq rsp, SAVED_RSP
+  /* Make space for CPU_Interrupt_frame */
+  subq $CPU_INTERRUPT_FRAME_SIZE, rsp
+.set ALIGNMENT_MASK, ~(CPU_STACK_ALIGNMENT - 1)
+  andq $ALIGNMENT_MASK, rsp
+  // XXX: Save interrupt mask?
+  /* Save caller-saved registers to CPU_Interrupt_frame */
+  movq rax,         (8 * CPU_SIZEOF_POINTER)(rsp)
+  movq rcx,         (7 * CPU_SIZEOF_POINTER)(rsp)
+  movq rdx,         (6 * CPU_SIZEOF_POINTER)(rsp)
+  movq rsi,         (5 * CPU_SIZEOF_POINTER)(rsp)
+  movq r8,          (4 * CPU_SIZEOF_POINTER)(rsp)
+  movq r9,          (3 * CPU_SIZEOF_POINTER)(rsp)
+  movq r10,         (2 * CPU_SIZEOF_POINTER)(rsp)
+  movq r11,         (1 * CPU_SIZEOF_POINTER)(rsp)
+  /* Save the initial rsp */
+  movq SAVED_RSP,   (0 * CPU_SIZEOF_POINTER)(rsp)
+.switch_stack_if_needed:
+  /* Save current aligned rsp so we can find CPU_Interrupt_frame again later */
+   * Switch to interrupt stack if necessary; it's necessary if this is the
+   * outermost interrupt, which means we've been using the task's stack so far
+#ifdef RTEMS_SMP
+  /* XXX: We should call _CPU_SMP_Get_current_processor here */
+#endif
+.set Per_CPU_Info, SCRATCH_REG1
+  movq $SYM(_Per_CPU_Information), Per_CPU_Info
+  cmpq $0, PER_CPU_ISR_NEST_LEVEL(Per_CPU_Info)
+  jne  .skip_switch
+.switch_stack:
+  movq PER_CPU_INTERRUPT_STACK_HIGH(Per_CPU_Info), rsp
+.skip_switch:
+  incq PER_CPU_ISR_NEST_LEVEL(Per_CPU_Info)
+  incq PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(Per_CPU_Info)
+.call_isr_dispatch:
+  /* REG_ARG0 already includes the vector number, so we can simply call */
+  call amd64_dispatch_isr
+.restore_stack:
+  /* If this is the outermost stack, this restores the task stack */
+  movq SAVED_RSP, rsp
+  decq PER_CPU_ISR_NEST_LEVEL(Per_CPU_Info)
+  decq PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(Per_CPU_Info)
+  /* XXX: Bug in QEMU causing ZF to not be set by decq necessitating the cmpb */
+  cmpb $0, PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(Per_CPU_Info)
+  /* If dispatch is non-zero, it is disabled, so skip scheduling it */
+  jne  .restore_cpu_interrupt_frame
+.schedule_dispatch:
+  cmpb $0, PER_CPU_DISPATCH_NEEDED(Per_CPU_Info)
+  je   .restore_cpu_interrupt_frame
+  call _Thread_Dispatch
+.restore_cpu_interrupt_frame:
+  /* Restore registers from CPU_Interrupt_frame */
+  movq (8 * CPU_SIZEOF_POINTER)(rsp), rax
+  movq (7 * CPU_SIZEOF_POINTER)(rsp), rcx
+  movq (6 * CPU_SIZEOF_POINTER)(rsp), rdx
+  movq (5 * CPU_SIZEOF_POINTER)(rsp), rsi
+  movq (4 * CPU_SIZEOF_POINTER)(rsp), r8
+  movq (3 * CPU_SIZEOF_POINTER)(rsp), r9
+  movq (2 * CPU_SIZEOF_POINTER)(rsp), r10
+  movq (1 * CPU_SIZEOF_POINTER)(rsp), r11
+  /* Restore the rsp value from just before _ISR_Handler was called */
+  movq (0 * CPU_SIZEOF_POINTER)(rsp), SAVED_RSP
+  /* Restore args DISTINCT_INTERRUPT_ENTRY pushed to task stack */
+  popq SCRATCH_REG1
+  popq SCRATCH_REG0
+  popq REG_ARG0
+  iretq
+END_CODE
+END
diff --git a/bsps/x86_64/amd64/start/bspstart.c b/bsps/x86_64/amd64/start/bspstart.c
index 5a5b46bcec..d1e1e4b2f2 100644
--- a/bsps/x86_64/amd64/start/bspstart.c
+++ b/bsps/x86_64/amd64/start/bspstart.c
@@ -27,8 +27,10 @@
 #include <bsp.h>
 #include <bsp/bootcard.h>
 #include <libcpu/page.h>
 void bsp_start(void)
   paging_init();
+  bsp_interrupt_initialize();
diff --git a/bsps/x86_64/headers.am b/bsps/x86_64/headers.am
index 6f79bca7c0..ce203e0dc3 100644
--- a/bsps/x86_64/headers.am
+++ b/bsps/x86_64/headers.am
@@ -1,5 +1,9 @@
 ## This file was generated by "./boostrap -H".
+include_bspdir = $(includedir)/bsp
+include_bsp_HEADERS =
+include_bsp_HEADERS += ../../../../../bsps/x86_64/include/bsp/irq.h
 include_libcpudir = $(includedir)/libcpu
 include_libcpu_HEADERS =
 include_libcpu_HEADERS += ../../../../../bsps/x86_64/include/libcpu/page.h
diff --git a/bsps/x86_64/include/bsp/irq.h b/bsps/x86_64/include/bsp/irq.h
index 0000000000..f8be997e8f
--- /dev/null
+++ b/bsps/x86_64/include/bsp/irq.h
@@ -0,0 +1,46 @@
+ * This file contains the mandatory defines to support the irq.h and
+ * irq-generic.c interfaces (initialized finally with bsp_interrupt_initialize).
+ * are met:
+ * SUCH DAMAGE.
+#ifndef LIBBSP_GENERIC_AMD64_IRQ_H
+#define LIBBSP_GENERIC_AMD64_IRQ_H
+#ifndef ASM
+#include <rtems.h>
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#define BSP_INTERRUPT_VECTOR_MIN  0x0
+#define BSP_IRQ_VECTOR_NUMBER     34
+#define BSP_INTERRUPT_VECTOR_MAX  BSP_IRQ_VECTOR_NUMBER
+#endif /* !ASM */
+#endif /* LIBBSP_GENERIC_RISCV_IRQ_H */
diff --git a/c/src/lib/libbsp/x86_64/amd64/Makefile.am b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
index 93c4e90fbc..d4102cdfb4 100644
--- a/c/src/lib/libbsp/x86_64/amd64/Makefile.am
+++ b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
@@ -27,6 +27,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/start/page.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/interrupts/idt.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/interrupts/isr_handler.S
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
 # clock
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/clock/clock-simidle.c
 # console
@@ -39,5 +42,6 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/cache/nocache.c
 include $(top_srcdir)/../../../../automake/local.am
+include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
 include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
 include $(srcdir)/../../../../../../bsps/x86_64/amd64/headers.am
diff --git a/cpukit/score/cpu/x86_64/cpu.c b/cpukit/score/cpu/x86_64/cpu.c
index 308d231186..88c4a98a3e 100644
--- a/cpukit/score/cpu/x86_64/cpu.c
+++ b/cpukit/score/cpu/x86_64/cpu.c
@@ -38,6 +38,7 @@
 #endif
 #include <rtems/score/isr.h>
 #include <rtems/score/tls.h>
@@ -52,17 +53,17 @@ void _CPU_Initialize(void)
-uint32_t _CPU_ISR_Get_level(void)
-  return 0;
 void _CPU_ISR_install_raw_handler(
   uint32_t    vector,
   proc_ptr    new_handler,
   proc_ptr   *old_handler
+    vector,
+    (uintptr_t) new_handler,
+    (uintptr_t*) old_handler
 void _CPU_ISR_install_vector(
@@ -73,11 +74,7 @@ void _CPU_ISR_install_vector(
-void _CPU_Install_interrupt_stack(void)
 void *_CPU_Thread_Idle_body(uintptr_t ignored)
-  for( ; ; ) { }
+  for ( ; ; ) { }
diff --git a/cpukit/score/cpu/x86_64/headers.am b/cpukit/score/cpu/x86_64/headers.am
index d23c39d99b..02798adf54 100644
--- a/cpukit/score/cpu/x86_64/headers.am
+++ b/cpukit/score/cpu/x86_64/headers.am
@@ -14,4 +14,5 @@ include_rtems_score_HEADERS += include/rtems/score/cpu.h
 include_rtems_score_HEADERS += include/rtems/score/cpu_asm.h
 include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
+include_rtems_score_HEADERS += include/rtems/score/idt.h
 include_rtems_score_HEADERS += include/rtems/score/x86_64.h
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
index 557d11109d..8f4a3c8d2e 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
@@ -101,12 +101,57 @@ typedef struct {
   double      some_float_register;
 } Context_Control_fp;
+ * Caller-saved registers for interrupt frames
 typedef struct {
-    uint32_t   special_interrupt_register;
+   * @note: rdi is a caller-saved register too, but it's used in function calls
+   * and is hence saved separately on the stack;
+   * @see _ISR_Handler
+  uint64_t rax;
+  uint64_t rcx;
+  uint64_t rdx;
+  uint64_t rsi;
+  uint64_t r8;
+  uint64_t r9;
+  uint64_t r10;
+  uint64_t r11;
+   * This holds the rsp just before _ISR_Handler is called; it's needed because
+   * in the handler, we align the stack to make further calls, and we're not
+   * sure how alignment may move the stack-pointer around, leaving no way to get
+   * back to the stack, and therefore the interrupt frame.
+  uint64_t saved_rsp;
+  /* XXX:
+   * - FS segment selector for TLS
+   * - x87 status word?
+   * - MMX?
+   * - XMM?
 } CPU_Interrupt_frame;
 #endif /* !ASM */
+#define CPU_INTERRUPT_FRAME_SIZE 72
+ * When SMP is enabled, percpuasm.c has a similar assert, but since we use the
+ * interrupt frame regardless of SMP, we'll confirm it here.
+#ifndef ASM
+  RTEMS_STATIC_ASSERT(
+    sizeof(CPU_Interrupt_frame) == CPU_INTERRUPT_FRAME_SIZE,
+    CPU_INTERRUPT_FRAME_SIZE
+#endif
 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
@@ -126,31 +171,55 @@ typedef struct {
 #define _CPU_Initialize_vectors()
-// XXX: For RTEMS critical sections
-#define _CPU_ISR_Disable( _isr_cookie ) \
-    (_isr_cookie) = 0;   /* do something to prevent warnings */ \
+#define _CPU_ISR_Enable(_level)                             \
+  amd64_enable_interrupts();                                \
+  _level = 0;                                               \
+  (void) _level; /* Prevent -Wunused-but-set-variable */    \
-#define _CPU_ISR_Enable( _isr_cookie )  \
-    (void) (_isr_cookie);   /* prevent warnings from -Wunused-but-set-variable */ \
+#define _CPU_ISR_Disable(_level)                            \
+  _level = 1;                                               \
-#define _CPU_ISR_Flash( _isr_cookie ) \
+#define _CPU_ISR_Flash(_level)                              \
+  amd64_disable_interrupts();                               \
+  _level = 1;                                               \
-RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
+RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled(uint32_t level)
-  return false;
+  return (level & EFLAGS_INTR_ENABLE) != 0;
-#define _CPU_ISR_Set_level( new_level ) \
+RTEMS_INLINE_ROUTINE void _CPU_ISR_Set_level(uint32_t new_level)
+  if ( new_level ) {
+  else {
+RTEMS_INLINE_ROUTINE uint32_t _CPU_ISR_Get_level(void)
+  uint64_t rflags;
+  __asm__ volatile ( "pushf; \
+                      popq %0"
+                     : "=rm" (rflags)
-uint32_t   _CPU_ISR_Get_level( void );
+  uint32_t level = (rflags & EFLAGS_INTR_ENABLE) ? 0 : 1;
+  return level;
 /* end of ISR handler macros */
@@ -228,8 +297,6 @@ void _CPU_ISR_install_vector(
-void _CPU_Install_interrupt_stack( void );
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
 void _CPU_Context_switch(
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
index 5d4b608eb8..09807f1489 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
@@ -45,6 +45,14 @@ RTEMS_INLINE_ROUTINE void outport_byte(uint16_t port, uint8_t val)
   __asm__ volatile ( "outb %0, %1" : : "a" (val), "Nd" (port) );
+RTEMS_INLINE_ROUTINE uint16_t amd64_get_cs(void)
+  uint16_t segment = 0;
+  __asm__ volatile ( "movw %%cs, %0" : "=r" (segment) : "0" (segment) );
+  return segment;
 RTEMS_INLINE_ROUTINE void amd64_set_cr3(uint64_t segment)
@@ -58,6 +66,16 @@ RTEMS_INLINE_ROUTINE void cpuid(
                      : "=a" (*eax), "=b" (*ebx), "=c" (*ecx), "=d" (*edx)
                      : "a" (code) );
+RTEMS_INLINE_ROUTINE void amd64_enable_interrupts(void)
+  __asm__ volatile ( "sti" );
+RTEMS_INLINE_ROUTINE void amd64_disable_interrupts(void)
+  __asm__ volatile ( "cli" );
 #endif /* !ASM */
 #endif
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/idt.h b/cpukit/score/cpu/x86_64/include/rtems/score/idt.h
index 0000000000..e1f69b1409
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/idt.h
@@ -0,0 +1,131 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_IDT_H
+#define _RTEMS_SCORE_IDT_H
+#include <rtems/rtems/intr.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define IDT_INTERRUPT_GATE     (0b1110)
+#define IDT_PRESENT            (0b10000000)
+ * XXX: The IDT size should be smaller given that we likely won't map all 256
+ * vectors, but for simplicity, this works better.
+#define IDT_SIZE               256
+/* Target vector number for spurious IRQs */
+#define BSP_VECTOR_SPURIOUS    0xFF
+/* Target vector number for the APIC timer */
+#define BSP_VECTOR_APIC_TIMER  32
+typedef struct _interrupt_descriptor {
+  uint16_t offset_0;              // bits 0-15
+  uint16_t segment_selector;      // a segment selector in the GDT or LDT
+  /* bits 0-2 are the offset into the IST, stored in the TSS */
+  uint8_t  interrupt_stack_table;
+  uint8_t  type_and_attributes;
+  uint16_t offset_1;              // bits 16-31
+  uint32_t offset_2;              // bits 32-63
+  uint32_t reserved_zero;
+} interrupt_descriptor;
+extern interrupt_descriptor amd64_idt[IDT_SIZE];
+struct idt_record {
+  uint16_t  limit;      /* Size of IDT array - 1 */
+  uintptr_t base;       /* Pointer to IDT array  */
+} RTEMS_PACKED;
+RTEMS_STATIC_ASSERT(
+  sizeof(struct idt_record) == 10,
+  "IDT pointer must be exactly 10 bytes"
+void lidt(struct idt_record *idtr);
+uintptr_t amd64_get_handler_from_idt(uint32_t vector);
+ * Called by _ISR_Handler to dispatch "RTEMS interrupts", i.e. call the
+ * registered RTEMS ISR.
+void amd64_dispatch_isr(rtems_vector_number vector);
+/* Defined in isr_handler.S */
+extern void rtems_irq_prologue_0(void);
+extern void rtems_irq_prologue_1(void);
+extern void rtems_irq_prologue_2(void);
+extern void rtems_irq_prologue_3(void);
+extern void rtems_irq_prologue_4(void);
+extern void rtems_irq_prologue_5(void);
+extern void rtems_irq_prologue_6(void);
+extern void rtems_irq_prologue_7(void);
+extern void rtems_irq_prologue_8(void);
+extern void rtems_irq_prologue_9(void);
+extern void rtems_irq_prologue_10(void);
+extern void rtems_irq_prologue_11(void);
+extern void rtems_irq_prologue_12(void);
+extern void rtems_irq_prologue_13(void);
+extern void rtems_irq_prologue_14(void);
+extern void rtems_irq_prologue_15(void);
+extern void rtems_irq_prologue_16(void);
+extern void rtems_irq_prologue_17(void);
+extern void rtems_irq_prologue_18(void);
+extern void rtems_irq_prologue_19(void);
+extern void rtems_irq_prologue_20(void);
+extern void rtems_irq_prologue_21(void);
+extern void rtems_irq_prologue_22(void);
+extern void rtems_irq_prologue_23(void);
+extern void rtems_irq_prologue_24(void);
+extern void rtems_irq_prologue_25(void);
+extern void rtems_irq_prologue_26(void);
+extern void rtems_irq_prologue_27(void);
+extern void rtems_irq_prologue_28(void);
+extern void rtems_irq_prologue_29(void);
+extern void rtems_irq_prologue_30(void);
+extern void rtems_irq_prologue_31(void);
+extern void rtems_irq_prologue_32(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/cpu/x86_64/x86_64-context-initialize.c b/cpukit/score/cpu/x86_64/x86_64-context-initialize.c
index 2324d16990..35e7d7cb60 100644
--- a/cpukit/score/cpu/x86_64/x86_64-context-initialize.c
+++ b/cpukit/score/cpu/x86_64/x86_64-context-initialize.c
@@ -76,11 +76,14 @@ void _CPU_Context_Initialize(
   (void) is_fp;
   // XXX: Should be used in the future
-  (void) new_level;
   (void) tls_area;
-  // XXX: Leaving interrupts off regardless of `new_level` for now
-  the_context->rflags = CPU_EFLAGS_INTERRUPTS_OFF;
+    the_context->rflags = CPU_EFLAGS_INTERRUPTS_OFF;
+  else {
+    the_context->rflags = CPU_EFLAGS_INTERRUPTS_ON;
   _stack  = ((uintptr_t) stack_area_begin) + stack_area_size;
   _stack &= ~(CPU_STACK_ALIGNMENT - 1);
2.18.0
