[PATCH 5/5] bsps/x86_64: Add APIC timer based clock driver
Amaan Cheval amaan.cheval at gmail.com
Mon Aug 13 11:27:24 UTC 2018
The APIC timer is calibrated by running the i8254 PIT for a fraction of a
second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the
APIC counter has ticked. The calibration can be run multiple times (determined
by APIC_TIMER_NUM_CALIBRATIONS) and averaged out.
Updates #2898.
 bsps/x86_64/amd64/clock/clock.c               | 299 ++++++++++++++++++
 bsps/x86_64/amd64/headers.am                  |   3 +
 bsps/x86_64/amd64/include/apic.h              |  62 ++++
 bsps/x86_64/amd64/include/clock.h             |  99 ++++++
 bsps/x86_64/amd64/include/pic.h               |  75 +++++
 bsps/x86_64/amd64/interrupts/pic.c            |  76 +++++
 c/src/lib/libbsp/x86_64/amd64/Makefile.am     |   4 +-
 .../cpu/x86_64/include/rtems/score/cpu_asm.h  |  23 ++
 8 files changed, 640 insertions(+), 1 deletion(-)
 create mode 100644 bsps/x86_64/amd64/clock/clock.c
 create mode 100644 bsps/x86_64/amd64/include/apic.h
 create mode 100644 bsps/x86_64/amd64/include/clock.h
 create mode 100644 bsps/x86_64/amd64/include/pic.h
 create mode 100644 bsps/x86_64/amd64/interrupts/pic.c
diff --git a/bsps/x86_64/amd64/clock/clock.c b/bsps/x86_64/amd64/clock/clock.c
new file mode 100644
index 0000000000..76e537755a
--- /dev/null
+++ b/bsps/x86_64/amd64/clock/clock.c
@@ -0,0 +1,299 @@
+ * Copyright (c) 2018.
+ * Amaan Cheval <amaan.cheval at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <stdio.h>
+#include <assert.h>
+#include <bsp.h>
+#include <rtems.h>
+#include <pic.h>
+#include <apic.h>
+#include <clock.h>
+#include <rtems/score/idt.h>
+#include <rtems/timecounter.h>
+#include <rtems/score/cpu.h>
+#include <rtems/score/cpuimpl.h>
+#include <rtems/score/x86_64.h>
+#include <bsp/irq-generic.h>
+/* Use the amd64_apic_base as an array of 32-bit APIC registers */
+volatile uint32_t *amd64_apic_base;
+static struct timecounter amd64_clock_tc;
+extern volatile uint32_t Clock_driver_ticks;
+extern void apic_spurious_handler(void);
+extern void Clock_isr(void *param);
+static uint32_t amd64_clock_get_timecount(struct timecounter *tc)
+  return Clock_driver_ticks;
+ * When the CPUID instruction is executed with a source operand of 1 in the EAX
+ * register, bit 9 of the CPUID feature flags returned in the EDX register
+ * indicates the presence (set) or absence (clear) of a local APIC.
+bool has_apic_support()
+  uint32_t eax, ebx, ecx, edx;
+  cpuid(1, &eax, &ebx, &ecx, &edx);
+  return (edx >> 9) & 1;
+ * Initializes the APIC by hardware and software enabling it, and sets up the
+ * amd64_apic_base pointer that can be used as a 32-bit addressable array to
+ * access APIC registers.
+void apic_initialize(void)
+  if ( !has_apic_support() ) {
+    printf("warning: cpuid claims no APIC support - trying anyway.\n");
+   * The APIC base address is a 36-bit physical address.
+   * We have identity-paging setup at the moment, which makes this simpler, but
+   * that's something to note since the variables below use virtual addresses.
+   * Bits 0-11 (inclusive) are 0, making the address page (4KiB) aligned.
+   * Bits 12-35 (inclusive) of the MSR point to the rest of the address.
+  uint64_t apic_base_msr = rdmsr(APIC_BASE_MSR);
+  amd64_apic_base = (uint32_t*) apic_base_msr;
+  amd64_apic_base = (uint32_t*) ((uintptr_t) amd64_apic_base & 0x0ffffff000);
+  /* Hardware enable the APIC just to be sure */
+  wrmsr(
+    APIC_BASE_MSR,
+    apic_base_msr | APIC_BASE_MSR_ENABLE,
+    apic_base_msr >> 32
+  DBG_PRINTF("APIC is at 0x%" PRIxPTR "\n", (uintptr_t) amd64_apic_base);
+  DBG_PRINTF(
+    "APIC ID at *0x%" PRIxPTR "=0x%" PRIx32 "\n",
+    (uintptr_t) &amd64_apic_base[APIC_REGISTER_APICID],
+    amd64_apic_base[APIC_REGISTER_APICID]
+  DBG_PRINTF(
+    "APIC spurious vector register *0x%" PRIxPTR "=0x%" PRIx32 "\n",
+    (uintptr_t) &amd64_apic_base[APIC_REGISTER_SPURIOUS],
+    amd64_apic_base[APIC_REGISTER_SPURIOUS]
+   * Software enable the APIC by mapping spurious vector and setting enable bit.
+  uintptr_t old;
+  amd64_install_raw_interrupt(
+    BSP_VECTOR_SPURIOUS,
+    (uintptr_t) apic_spurious_handler,
+    &old
+  amd64_apic_base[APIC_REGISTER_SPURIOUS] =
+    APIC_SPURIOUS_ENABLE | BSP_VECTOR_SPURIOUS;
+  DBG_PRINTF(
+   * The PIC may send spurious IRQs even when disabled, and without remapping
+   * IRQ7 would look like an exception.
+  pic_remap(PIC1_REMAP_DEST, PIC2_REMAP_DEST);
+  pic_disable();
+static void apic_isr(void *param)
+  Clock_isr(param);
+  amd64_apic_base[APIC_REGISTER_EOI] = APIC_EOI_ACK;
+void apic_timer_install_handler(void)
+  rtems_status_code sc = rtems_interrupt_handler_install(
+    BSP_VECTOR_APIC_TIMER,
+    "APIC timer",
+    RTEMS_INTERRUPT_UNIQUE,
+    apic_isr,
+    NULL
+  assert(sc == RTEMS_SUCCESSFUL);
+uint32_t apic_timer_calibrate(void)
+  /* Configure APIC timer in one-shot mode to prepare for calibration */
+  amd64_apic_base[APIC_REGISTER_LVT_TIMER] = BSP_VECTOR_APIC_TIMER;
+  amd64_apic_base[APIC_REGISTER_TIMER_DIV] = APIC_TIMER_SELECT_DIVIDER;
+  /* Enable the channel 2 timer gate and disable the speaker output */
+  uint8_t chan2_value = (inport_byte(PIT_PORT_CHAN2_GATE) | PIT_CHAN2_TIMER_BIT)
+    & ~PIT_CHAN2_SPEAKER_BIT;
+  outport_byte(PIT_PORT_CHAN2_GATE, chan2_value);
+  /* Initialize PIT in one-shot mode on Channel 2 */
+  outport_byte(
+    PIT_PORT_MCR,
+    PIT_SELECT_CHAN2 | PIT_SELECT_ACCESS_LOHI |
+      PIT_SELECT_ONE_SHOT_MODE | PIT_SELECT_BINARY_MODE
+   * Disable interrupts while we calibrate for 2 reasons:
+   *   - Writing values to the PIT should be atomic (for now, this is okay
+   *     because we're the only ones ever touching the PIT ports, but an
+   *     interrupt resetting the PIT could mess calibration up).
+   *   - We need to make sure that no interrupts throw our synchronization of
+   *     the APIC timer off.
+  amd64_disable_interrupts();
+  /* Set PIT reload value */
+  uint32_t pit_ticks = PIT_CALIBRATE_TICKS;
+  uint8_t low_tick = pit_ticks & 0xff;
+  uint8_t high_tick = (pit_ticks >> 8) & 0xff;
+  outport_byte(PIT_PORT_CHAN2, low_tick);
+  stub_io_wait();
+  outport_byte(PIT_PORT_CHAN2, high_tick);
+  /* Start APIC timer's countdown */
+  const uint32_t apic_calibrate_init_count = 0xffffffff;
+  /* Restart PIT by disabling the gated input and then re-enabling it */
+  chan2_value &= ~PIT_CHAN2_TIMER_BIT;
+  chan2_value |= PIT_CHAN2_TIMER_BIT;
+  amd64_apic_base[APIC_REGISTER_TIMER_INITCNT] = apic_calibrate_init_count;
+  while ( pit_ticks <= PIT_CALIBRATE_TICKS ) {
+    /* Send latch command to read multi-byte value atomically */
+    outport_byte(PIT_PORT_MCR, PIT_SELECT_CHAN2);
+    pit_ticks = inport_byte(PIT_PORT_CHAN2);
+    pit_ticks |= inport_byte(PIT_PORT_CHAN2) << 8;
+  uint32_t apic_currcnt = amd64_apic_base[APIC_REGISTER_TIMER_CURRCNT];
+  DBG_PRINTF("PIT stopped at 0x%" PRIx32 "\n", pit_ticks);
+  /* Stop APIC timer to calculate ticks to time ratio */
+  amd64_apic_base[APIC_REGISTER_LVT_TIMER] = APIC_DISABLE;
+  /* Get counts passed since we started counting */
+  uint32_t apic_ticks_per_sec = apic_calibrate_init_count - apic_currcnt;
+  DBG_PRINTF(
+    "APIC ticks passed in 1/%d of a second: 0x%" PRIx32 "\n",
+    PIT_CALIBRATE_DIVIDER,
+    apic_ticks_per_sec
+  /* We ran the PIT for a fraction of a second */
+  apic_ticks_per_sec = apic_ticks_per_sec * PIT_CALIBRATE_DIVIDER;
+  /* Re-enable interrupts now that calibration is complete */
+  amd64_enable_interrupts();
+  /* Confirm that the APIC timer never hit 0 and IRQ'd during calibration */
+  assert(Clock_driver_ticks == 0);
+  assert(apic_ticks_per_sec != 0 &&
+         apic_ticks_per_sec != apic_calibrate_init_count);
+  DBG_PRINTF(
+    "CPU frequency: 0x%" PRIu64 "\nAPIC ticks/sec: 0x%" PRIu32 "\n",
+    /* Multiply to undo effects of divider */
+    (uint64_t) apic_ticks_per_sec * APIC_TIMER_DIVIDE_VALUE,
+  return apic_ticks_per_sec;
+void apic_timer_initialize(uint64_t desired_freq_hz)
+  uint32_t apic_ticks_per_sec = 0;
+  uint32_t apic_tick_collections[APIC_TIMER_NUM_CALIBRATIONS] = {0};
+  uint64_t apic_tick_total = 0;
+  for (uint32_t i = 0; i < APIC_TIMER_NUM_CALIBRATIONS; i++) {
+    apic_tick_collections[i] = apic_timer_calibrate();
+    apic_tick_total += apic_tick_collections[i];
+  apic_ticks_per_sec = apic_tick_total / APIC_TIMER_NUM_CALIBRATIONS;
+   * The APIC timer counter is decremented at the speed of the CPU bus
+   * frequency (and we use a frequency divider).
+   * This means:
+   *   apic_ticks_per_sec = (cpu_bus_frequency / timer_divide_value)
+   * Therefore:
+   *   reload_value = apic_ticks_per_sec / desired_freq_hz
+  uint32_t apic_timer_reload_value = apic_ticks_per_sec / desired_freq_hz;
+  amd64_apic_base[APIC_REGISTER_LVT_TIMER] = BSP_VECTOR_APIC_TIMER | APIC_SELECT_TMR_PERIODIC;
+  amd64_apic_base[APIC_REGISTER_TIMER_INITCNT] = apic_timer_reload_value;
+void amd64_clock_driver_initialize(void)
+  uint64_t us_per_tick = rtems_configuration_get_microseconds_per_tick();
+  uint64_t irq_ticks_per_sec = 1000000 / us_per_tick;
+  DBG_PRINTF(
+    "us_per_tick = %d\nDesired frequency = %d irqs/sec\n",
+    us_per_tick,
+    irq_ticks_per_sec
+  /* Setup and enable the APIC itself */
+  apic_initialize();
+  /* Setup and initialize the APIC timer */
+  apic_timer_initialize(irq_ticks_per_sec);
+  amd64_clock_tc.tc_get_timecount = amd64_clock_get_timecount;
+  amd64_clock_tc.tc_counter_mask = 0xffffffff;
+  amd64_clock_tc.tc_frequency = irq_ticks_per_sec;
+  amd64_clock_tc.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
+  rtems_timecounter_install(&amd64_clock_tc);
+#define Clock_driver_support_install_isr(_new) \
+  apic_timer_install_handler()
+#define Clock_driver_support_initialize_hardware() \
+  amd64_clock_driver_initialize()
+#include "../../../shared/dev/clock/clockimpl.h"
diff --git a/bsps/x86_64/amd64/headers.am b/bsps/x86_64/amd64/headers.am
index f9f42e7fd3..68f5858406 100644
--- a/bsps/x86_64/amd64/headers.am
+++ b/bsps/x86_64/amd64/headers.am
@@ -1,7 +1,10 @@
 ## This file was generated by "./boostrap -H".
 include_HEADERS =
+include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/apic.h
 include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/bsp.h
 include_HEADERS += include/bspopts.h
+include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/clock.h
+include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/pic.h
 include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/start.h
 include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/tm27.h
diff --git a/bsps/x86_64/amd64/include/apic.h b/bsps/x86_64/amd64/include/apic.h
index 0000000000..f1e6495daa
--- /dev/null
+++ b/bsps/x86_64/amd64/include/apic.h
@@ -0,0 +1,62 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _AMD64_APIC_H
+#define _AMD64_APIC_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* The address of the MSR pointing to the APIC base physical address */
+#define APIC_BASE_MSR             0x1B
+/* Value to hardware-enable the APIC through the APIC_BASE_MSR */
+#define APIC_BASE_MSR_ENABLE      0x800
+ * Since amd64_apic_base is an array of 32-bit elements, these byte-offsets
+ * need to be divided by 4 to index the array.
+#define APIC_OFFSET(val) (val >> 2)
+#define APIC_REGISTER_APICID        APIC_OFFSET(0x20)
+#define APIC_REGISTER_EOI           APIC_OFFSET(0x0B0)
+#define APIC_REGISTER_SPURIOUS      APIC_OFFSET(0x0F0)
+#define APIC_REGISTER_LVT_TIMER     APIC_OFFSET(0x320)
+#define APIC_REGISTER_TIMER_INITCNT APIC_OFFSET(0x380)
+#define APIC_REGISTER_TIMER_CURRCNT APIC_OFFSET(0x390)
+#define APIC_REGISTER_TIMER_DIV     APIC_OFFSET(0x3E0)
+#define APIC_DISABLE                0x10000
+#define APIC_EOI_ACK                0
+#define APIC_SELECT_TMR_PERIODIC    0x20000
+#define APIC_SPURIOUS_ENABLE        0x100
+#ifdef __cplusplus
+#endif
+#endif /* _AMD64_APIC_H */
diff --git a/bsps/x86_64/amd64/include/clock.h b/bsps/x86_64/amd64/include/clock.h
index 0000000000..4219c92d48
--- /dev/null
+++ b/bsps/x86_64/amd64/include/clock.h
@@ -0,0 +1,99 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _AMD64_CLOCK_H
+#define _AMD64_CLOCK_H
+#include <rtems/score/basedefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifndef ASM
+  extern volatile uint32_t *amd64_apic_base;
+  bool has_apic_support(void);
+  void apic_initialize(void);
+  void apic_timer_install_handler(void);
+  uint32_t apic_timer_calibrate(void);
+  void apic_timer_initialize(uint64_t desired_freq_hz);
+  void amd64_clock_driver_initialize(void);
+#endif
+/* Number of times to calibrate the APIC timer to average it out */
+#define APIC_TIMER_NUM_CALIBRATIONS 5
+/* Default divide value used by APIC timer */
+#define APIC_TIMER_DIVIDE_VALUE     16
+/* Value to set in register to pick the divide value above */
+#define APIC_TIMER_SELECT_DIVIDER   3
+#define PIT_FREQUENCY               1193180
+ * The PIT_FREQUENCY determines how many times the PIT counter is decremented
+ * per second - therefore, we can calculate how many ticks we set based on what
+ * fraction of a second we're okay with spending on calibration
+#define PIT_CALIBRATE_DIVIDER       20
+#define PIT_CALIBRATE_TICKS       (PIT_FREQUENCY/PIT_CALIBRATE_DIVIDER)
+/* Since the PIT only has 2 one-byte registers, the maximum tick value is
+ * limited to 16-bits. We can set the PIT to use a frequency divider if
+ * needed. */
+RTEMS_STATIC_ASSERT(
+  PIT_CALIBRATE_TICKS <= 0xffff,
+/* I/O ports for the PIT */
+#define PIT_PORT_CHAN0              0x40
+#define PIT_PORT_CHAN1              0x41
+#define PIT_PORT_CHAN2              0x42
+ * The input to channel 2 can be gated through software, using bit 0 of port
+ * 0x61.
+#define PIT_PORT_CHAN2_GATE         0x61
+#define PIT_CHAN2_TIMER_BIT         1
+#define PIT_CHAN2_SPEAKER_BIT       2
+/* The PIT mode/command register */
+#define PIT_PORT_MCR                0x43
+/* PIT values to select channels, access, and operating modes */
+#define PIT_SELECT_CHAN0            0b00000000
+#define PIT_SELECT_CHAN1            0b01000000
+#define PIT_SELECT_CHAN2            0b10000000
+ * In the lo/hi mode, the low-byte is sent to the data port, followed by the
+ * high-byte; this makes it important that this be an atomic operation.
+#define PIT_SELECT_ACCESS_LOHI      0b00110000
+#define PIT_SELECT_ONE_SHOT_MODE    0b00000010
+#define PIT_SELECT_BINARY_MODE      0
+#ifdef __cplusplus
+#endif
+#endif /* _AMD64_CLOCK_H */
diff --git a/bsps/x86_64/amd64/include/pic.h b/bsps/x86_64/amd64/include/pic.h
index 0000000000..f2b0aa83e2
--- /dev/null
+++ b/bsps/x86_64/amd64/include/pic.h
@@ -0,0 +1,75 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _AMD64_PIC_H
+#define _AMD64_PIC_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define PIC1          0x20  /* IO base address for master PIC */
+#define PIC2          0xA0  /* IO base address for slave PIC */
+#define PIC1_COMMAND  PIC1
+#define PIC1_DATA    (PIC1+1)
+#define PIC2_COMMAND  PIC2
+#define PIC2_DATA    (PIC2+1)
+/* reinitialize the PIC controllers, giving them specified vector offsets
+   rather than 8h and 70h, as configured by default */
+#define PIC_ICW1_ICW4       0x01  /* ICW4 (not) needed */
+#define PIC_ICW1_SINGLE     0x02  /* Single (cascade) mode */
+#define PIC_ICW1_INTERVAL4  0x04  /* Call address interval 4 (8) */
+#define PIC_ICW1_LEVEL      0x08  /* Level triggered (edge) mode */
+#define PIC_ICW1_INIT       0x10  /* Initialization - required! */
+#define PIC_ICW4_8086       0x01  /* 8086/88 (MCS-80/85) mode */
+#define PIC_ICW4_AUTO       0x02  /* Auto (normal) EOI */
+#define PIC_ICW4_BUF_SLAVE  0x08  /* Buffered mode/slave */
+#define PIC_ICW4_BUF_MASTER 0x0C  /* Buffered mode/master */
+#define PIC_ICW4_SFNM       0x10  /* Special fully nested (not) */
+/* This remaps IRQ0 to vector number 0x20 and so on (i.e. IDT[32]) */
+#define PIC1_REMAP_DEST           0x20
+#define PIC2_REMAP_DEST           0x28
+/* Remap PIC1's interrupts to offset1 and PIC2's to offset2 */
+void pic_remap(uint8_t offset1, uint8_t offset2);
+ * Mask all interrupt requests on PIC.
+ * @note Even with all interrupts masked, the PIC may still send spurious
+ * interrupts (IRQ7), so we should handle them still.
+void pic_disable(void);
+#ifdef __cplusplus
+#endif
+#endif /* _AMD64_PIC_H */
diff --git a/bsps/x86_64/amd64/interrupts/pic.c b/bsps/x86_64/amd64/interrupts/pic.c
index 0000000000..c5a890b885
--- /dev/null
+++ b/bsps/x86_64/amd64/interrupts/pic.c
@@ -0,0 +1,76 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <stdint.h>
+#include <rtems.h>
+#include <pic.h>
+  uint8_t a1, a2;
+  /* save masks */
+  a1 = inport_byte(PIC1_DATA);
+  a2 = inport_byte(PIC2_DATA);
+  /* start the initialization sequence in cascade mode */
+  outport_byte(PIC1_COMMAND, PIC_ICW1_INIT | PIC_ICW1_ICW4);
+  stub_io_wait();
+  outport_byte(PIC2_COMMAND, PIC_ICW1_INIT | PIC_ICW1_ICW4);
+  stub_io_wait();
+  /* ICW2: Master PIC vector offset */
+  outport_byte(PIC1_DATA, offset1);
+  stub_io_wait();
+  /* ICW2: Slave PIC vector offset */
+  outport_byte(PIC2_DATA, offset2);
+  stub_io_wait();
+  /* ICW3: tell Master PIC that there is a slave PIC at IRQ2 (0000 0100) */
+  outport_byte(PIC1_DATA, 4);
+  stub_io_wait();
+  /* ICW3: tell Slave PIC its cascade identity (0000 0010) */
+  outport_byte(PIC2_DATA, 2);
+  stub_io_wait();
+  outport_byte(PIC1_DATA, PIC_ICW4_8086);
+  stub_io_wait();
+  outport_byte(PIC2_DATA, PIC_ICW4_8086);
+  stub_io_wait();
+  /* restore saved masks. */
+  outport_byte(PIC1_DATA, a1);
+  outport_byte(PIC2_DATA, a2);
+  /* Mask all lines on both master and slave PIC to disable */
+  outport_byte(PIC1_DATA, 0xff);
+  outport_byte(PIC2_DATA, 0xff);
diff --git a/c/src/lib/libbsp/x86_64/amd64/Makefile.am b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
index d4102cdfb4..101c98b96c 100644
--- a/c/src/lib/libbsp/x86_64/amd64/Makefile.am
+++ b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
@@ -27,11 +27,13 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/start/page.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
+# interrupts
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/interrupts/pic.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/interrupts/idt.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/interrupts/isr_handler.S
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
 # clock
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/clock/clock-simidle.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/clock/clock.c
 # console
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios-init.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
index 09807f1489..4ad50b9f42 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h
@@ -67,6 +67,21 @@ RTEMS_INLINE_ROUTINE void cpuid(
                      : "a" (code) );
+RTEMS_INLINE_ROUTINE uint64_t rdmsr(uint32_t msr)
+  uint32_t low, high;
+  __asm__ volatile ( "rdmsr" :
+                     "=a" (low), "=d" (high) :
+                     "c" (msr) );
+   return low | (uint64_t) high << 32;
+RTEMS_INLINE_ROUTINE void wrmsr(uint32_t msr, uint32_t low, uint32_t high)
+  __asm__ volatile ( "wrmsr" : :
+                     "a" (low), "d" (high), "c" (msr) );
 RTEMS_INLINE_ROUTINE void amd64_enable_interrupts(void)
   __asm__ volatile ( "sti" );
@@ -76,6 +91,14 @@ RTEMS_INLINE_ROUTINE void amd64_disable_interrupts(void)
   __asm__ volatile ( "cli" );
+RTEMS_INLINE_ROUTINE void stub_io_wait(void)
+  /* XXX: This likely won't be required on any modern boards, but this function
+   * exists so it's easier to find all the places it may be used.
 #endif /* !ASM */
 #endif
2.18.0
