Disable libnetwork on Epiphany?
Hesham Almatary heshamelmatary at gmail.com
Tue Aug 14 09:26:43 UTC 2018
On Tue, Aug 14, 2018 at 10:17 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Aug 14, 2018, 2:51 AM Hesham Almatary <heshamelmatary at gmail.com>
> wrote:
>> AFAIR, I've never tried epiphany with networking. The cores are
>> supposed to be accelerators, so the ARM core can offload some
>> processing to it.
>> P.S. aren't we gonna make Epiphany obsolete?  The discussion was
>> raised by Sebastian before to remove Epiphany support.
> I recalled or1k and not epiphany.
Yes you're right
>> On Tue, Aug 14, 2018 at 12:20 AM, Joel Sherrill <joel at rtems.org> wrote:
>> > Hi
>> > When you build with --enable-network on epiphany, it fails. Is it
>> > even reasonable to think it should build or be deployable?
>> > If not, I would like to force it disabled.
>> > Thoughts?
>> > --joel
>> Hesham
Hesham
