[PATCH] dev/sc16is752: Add name space for field names.
list at c-mauderer.de list at c-mauderer.de
Wed Aug 15 10:26:13 UTC 2018
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
The field names for the registers generated a name collision (MSR_RI on
the power pc). This patch adds a SC16IS752_ prefix for all field names.
Closes #3501.
 cpukit/dev/serial/sc16is752-regs.h | 108 ++++++++++++++---------------
 cpukit/dev/serial/sc16is752.c      |  85 ++++++++++++-----------
 2 files changed, 98 insertions(+), 95 deletions(-)
diff --git a/cpukit/dev/serial/sc16is752-regs.h b/cpukit/dev/serial/sc16is752-regs.h
index 21d425a118..b07e489a3e 100644
--- a/cpukit/dev/serial/sc16is752-regs.h
+++ b/cpukit/dev/serial/sc16is752-regs.h
@@ -52,76 +52,76 @@ extern "C" {
 #define SC16IS752_XOFF2 0x7
 /* FCR */
-#define FCR_FIFO_EN        0x01
-#define FCR_RX_FIFO_RST    0x02
-#define FCR_TX_FIFO_RST    0x04
-#define FCR_TX_FIFO_TRG_8  0x00
-#define FCR_TX_FIFO_TRG_16 0x10
-#define FCR_TX_FIFO_TRG_32 0x20
-#define FCR_TX_FIFO_TRG_56 0x30
-#define FCR_RX_FIFO_TRG_8  0x00
-#define FCR_RX_FIFO_TRG_16 0x40
-#define FCR_RX_FIFO_TRG_56 0x80
-#define FCR_RX_FIFO_TRG_60 0xc0
+#define SC16IS752_FCR_FIFO_EN        0x01
+#define SC16IS752_FCR_RX_FIFO_RST    0x02
+#define SC16IS752_FCR_TX_FIFO_RST    0x04
+#define SC16IS752_FCR_TX_FIFO_TRG_8  0x00
+#define SC16IS752_FCR_TX_FIFO_TRG_16 0x10
+#define SC16IS752_FCR_TX_FIFO_TRG_32 0x20
+#define SC16IS752_FCR_TX_FIFO_TRG_56 0x30
+#define SC16IS752_FCR_RX_FIFO_TRG_8  0x00
+#define SC16IS752_FCR_RX_FIFO_TRG_16 0x40
+#define SC16IS752_FCR_RX_FIFO_TRG_56 0x80
+#define SC16IS752_FCR_RX_FIFO_TRG_60 0xc0
 /* EFCR */
-#define EFCR_RS485_ENABLE (1u << 0)
-#define EFCR_RX_DISABLE (1u << 1)
-#define EFCR_TX_DISABLE (1u << 2)
+#define SC16IS752_EFCR_RS485_ENABLE (1u << 0)
+#define SC16IS752_EFCR_RX_DISABLE (1u << 1)
+#define SC16IS752_EFCR_TX_DISABLE (1u << 2)
 /* IER */
-#define IER_RHR (1u << 0)
-#define IER_THR (1u << 1)
-#define IER_RECEIVE_LINE_STATUS (1u << 2)
-#define IER_MODEM_STATUS (1u << 3)
-#define IER_SLEEP_MODE (1u << 4)
-#define IER_XOFF (1u << 5)
-#define IER_RTS (1u << 6)
-#define IER_CTS (1u << 7)
+#define SC16IS752_IER_RHR (1u << 0)
+#define SC16IS752_IER_THR (1u << 1)
+#define SC16IS752_IER_RECEIVE_LINE_STATUS (1u << 2)
+#define SC16IS752_IER_MODEM_STATUS (1u << 3)
+#define SC16IS752_IER_SLEEP_MODE (1u << 4)
+#define SC16IS752_IER_XOFF (1u << 5)
+#define SC16IS752_IER_RTS (1u << 6)
+#define SC16IS752_IER_CTS (1u << 7)
 /* IIR */
-#define IIR_TX_INTERRUPT (1u << 1)
-#define IIR_RX_INTERRUPT (1u << 2)
+#define SC16IS752_IIR_TX_INTERRUPT (1u << 1)
+#define SC16IS752_IIR_RX_INTERRUPT (1u << 2)
 /* LCR */
-#define LCR_CHRL_5_BIT (0u << 1) | (0u << 0)
-#define LCR_CHRL_6_BIT (0u << 1) | (1u << 0)
-#define LCR_CHRL_7_BIT (1u << 1) | (0u << 0)
-#define LCR_CHRL_8_BIT (1u << 1) | (1u << 0)
-#define LCR_2_STOP_BIT (1u << 2)
-#define LCR_SET_PARITY (1u << 3)
-#define LCR_EVEN_PARITY (1u << 4)
-#define LCR_ENABLE_DIVISOR (1u << 7)
+#define SC16IS752_LCR_CHRL_5_BIT (0u << 1) | (0u << 0)
+#define SC16IS752_LCR_CHRL_6_BIT (0u << 1) | (1u << 0)
+#define SC16IS752_LCR_CHRL_7_BIT (1u << 1) | (0u << 0)
+#define SC16IS752_LCR_CHRL_8_BIT (1u << 1) | (1u << 0)
+#define SC16IS752_LCR_2_STOP_BIT (1u << 2)
+#define SC16IS752_LCR_SET_PARITY (1u << 3)
+#define SC16IS752_LCR_EVEN_PARITY (1u << 4)
+#define SC16IS752_LCR_ENABLE_DIVISOR (1u << 7)
 /* LSR */
-#define LSR_TXEMPTY (1u << 5)
-#define LSR_RXRDY (1u << 0)
-#define LSR_ERROR_BITS (7u << 2)
+#define SC16IS752_LSR_TXEMPTY (1u << 5)
+#define SC16IS752_LSR_RXRDY (1u << 0)
+#define SC16IS752_LSR_ERROR_BITS (7u << 2)
 /* MCR */
-#define MCR_DTR             (1u << 0)
-#define MCR_RTS             (1u << 1)
-#define MCR_TCR_TLR         (1u << 2)
-#define MCR_LOOPBACK        (1u << 4)
-#define MCR_XON_ANY         (1u << 5)
-#define MCR_IRDA_ENABLE     (1u << 6)
-#define MCR_PRESCALE_NEEDED (1u << 7)
+#define SC16IS752_MCR_DTR             (1u << 0)
+#define SC16IS752_MCR_RTS             (1u << 1)
+#define SC16IS752_MCR_TCR_TLR         (1u << 2)
+#define SC16IS752_MCR_LOOPBACK        (1u << 4)
+#define SC16IS752_MCR_XON_ANY         (1u << 5)
+#define SC16IS752_MCR_IRDA_ENABLE     (1u << 6)
+#define SC16IS752_MCR_PRESCALE_NEEDED (1u << 7)
 /* MSR */
-#define MSR_dCTS (1u << 0)
-#define MSR_dDSR (1u << 1)
-#define MSR_dRI  (1u << 2)
-#define MSR_dCD  (1u << 3)
-#define MSR_CTS  (1u << 4)
-#define MSR_DSR  (1u << 5)
-#define MSR_RI   (1u << 6)
-#define MSR_CD   (1u << 7)
+#define SC16IS752_MSR_dCTS (1u << 0)
+#define SC16IS752_MSR_dDSR (1u << 1)
+#define SC16IS752_MSR_dRI  (1u << 2)
+#define SC16IS752_MSR_dCD  (1u << 3)
+#define SC16IS752_MSR_CTS  (1u << 4)
+#define SC16IS752_MSR_DSR  (1u << 5)
+#define SC16IS752_MSR_RI   (1u << 6)
+#define SC16IS752_MSR_CD   (1u << 7)
 /* EFR */
-#define EFR_ENHANCED_FUNC_ENABLE (1u << 4)
-#define EFR_SPECIAL_CHAR_DETECT (1u << 5)
-#define EFR_RTS_FLOW_CTRL_EN (1u << 6)
-#define EFR_CTS_FLOW_CTRL_EN (1u << 7)
+#define SC16IS752_EFR_ENHANCED_FUNC_ENABLE (1u << 4)
+#define SC16IS752_EFR_SPECIAL_CHAR_DETECT (1u << 5)
+#define SC16IS752_EFR_RTS_FLOW_CTRL_EN (1u << 6)
+#define SC16IS752_EFR_CTS_FLOW_CTRL_EN (1u << 7)
 /* IOCONTROL: User accessible. Therefore see sc16is752.h for the defines. */
diff --git a/cpukit/dev/serial/sc16is752.c b/cpukit/dev/serial/sc16is752.c
index ac88c8389f..0dcf21765a 100644
--- a/cpukit/dev/serial/sc16is752.c
+++ b/cpukit/dev/serial/sc16is752.c
@@ -57,15 +57,15 @@ static void read_2_reg(
 static bool is_sleep_mode_enabled(sc16is752_context *ctx)
-  return (ctx->ier & IER_SLEEP_MODE) != 0;
+  return (ctx->ier & SC16IS752_IER_SLEEP_MODE) != 0;
 static void set_sleep_mode(sc16is752_context *ctx, bool enable)
   if (enable) {
-    ctx->ier |= IER_SLEEP_MODE;
+    ctx->ier |= SC16IS752_IER_SLEEP_MODE;
   } else {
-    ctx->ier &= ~IER_SLEEP_MODE;
+    ctx->ier &= ~SC16IS752_IER_SLEEP_MODE;
   write_reg(ctx, SC16IS752_IER, &ctx->ier, 1);
@@ -85,14 +85,14 @@ static void set_mcr_dll_dlh(
     set_sleep_mode(ctx, false);
-  ctx->lcr |= LCR_ENABLE_DIVISOR;
+  ctx->lcr |= SC16IS752_LCR_ENABLE_DIVISOR;
   write_reg(ctx, SC16IS752_LCR, &ctx->lcr, 1);
   write_reg(ctx, SC16IS752_MCR, &mcr, 1);
   write_reg(ctx, SC16IS752_DLH, &dlh, 1);
   write_reg(ctx, SC16IS752_DLL, &dll, 1);
-  ctx->lcr &= ~LCR_ENABLE_DIVISOR;
+  ctx->lcr &= ~SC16IS752_LCR_ENABLE_DIVISOR;
   if (sleep_mode) {
@@ -127,10 +127,10 @@ static bool set_baud(sc16is752_context *ctx, rtems_termios_baud_t baud)
     if (divisor > 0xFFFF){
       return false;
     } else {
-      mcr |= MCR_PRESCALE_NEEDED;
+      mcr |= SC16IS752_MCR_PRESCALE_NEEDED;
   } else {
-    mcr &= ~MCR_PRESCALE_NEEDED;
+    mcr &= ~SC16IS752_MCR_PRESCALE_NEEDED;
   set_mcr_dll_dlh(ctx, mcr, divisor);
@@ -155,42 +155,42 @@ static bool sc16is752_set_attributes(
   if ((term->c_cflag & CREAD) == 0){
-    ctx->efcr |= EFCR_RX_DISABLE;
+    ctx->efcr |= SC16IS752_EFCR_RX_DISABLE;
   } else {
-    ctx->efcr &= ~EFCR_RX_DISABLE;
+    ctx->efcr &= ~SC16IS752_EFCR_RX_DISABLE;
   write_reg(ctx, SC16IS752_EFCR, &ctx->efcr, 1);
   switch (term->c_cflag & CSIZE) {
     case CS5:
-      ctx->lcr |= LCR_CHRL_5_BIT;
+      ctx->lcr |= SC16IS752_LCR_CHRL_5_BIT;
       break;
     case CS6:
-      ctx->lcr |= LCR_CHRL_6_BIT;
+      ctx->lcr |= SC16IS752_LCR_CHRL_6_BIT;
       break;
     case CS7:
-      ctx->lcr |= LCR_CHRL_7_BIT;
+      ctx->lcr |= SC16IS752_LCR_CHRL_7_BIT;
       break;
     case CS8:
-      ctx->lcr |= LCR_CHRL_8_BIT;
+      ctx->lcr |= SC16IS752_LCR_CHRL_8_BIT;
       break;
   if ((term->c_cflag & PARENB) != 0){
     if ((term->c_cflag & PARODD) != 0) {
-      ctx->lcr &= ~LCR_EVEN_PARITY;
+      ctx->lcr &= ~SC16IS752_LCR_EVEN_PARITY;
     } else {
-      ctx->lcr |= LCR_EVEN_PARITY;
+      ctx->lcr |= SC16IS752_LCR_EVEN_PARITY;
   } else {
-    ctx->lcr &= ~LCR_SET_PARITY;
+    ctx->lcr &= ~SC16IS752_LCR_SET_PARITY;
   if ((term->c_cflag & CSTOPB) != 0) {
-    ctx->lcr |= LCR_2_STOP_BIT;
+    ctx->lcr |= SC16IS752_LCR_2_STOP_BIT;
   } else {
-    ctx->lcr &= ~LCR_2_STOP_BIT;
+    ctx->lcr &= ~SC16IS752_LCR_2_STOP_BIT;
@@ -218,20 +218,23 @@ static bool sc16is752_first_open(
   if (ctx->mode == SC16IS752_MODE_RS485) {
-    ctx->efcr = EFCR_RS485_ENABLE;
+    ctx->efcr = SC16IS752_EFCR_RS485_ENABLE;
   } else {
     ctx->efcr = 0;
   write_reg(ctx, SC16IS752_FCR, &ctx->efcr, 1);
-  fcr = FCR_FIFO_EN | FCR_RX_FIFO_RST | FCR_TX_FIFO_RST
-    | FCR_RX_FIFO_TRG_16 | FCR_TX_FIFO_TRG_32;
+  fcr = SC16IS752_FCR_FIFO_EN
+    | SC16IS752_FCR_RX_FIFO_RST
+    | SC16IS752_FCR_TX_FIFO_RST
+    | SC16IS752_FCR_RX_FIFO_TRG_16
+    | SC16IS752_FCR_TX_FIFO_TRG_32;
   write_reg(ctx, SC16IS752_FCR, &fcr, 1);
-  ctx->ier = IER_RHR;
+  ctx->ier = SC16IS752_IER_RHR;
-  set_efr(ctx, EFR_ENHANCED_FUNC_ENABLE);
+  set_efr(ctx, SC16IS752_EFR_ENHANCED_FUNC_ENABLE);
   rtems_termios_set_initial_baud(tty, 115200);
   ok = sc16is752_set_attributes(base, term);
@@ -265,14 +268,14 @@ static void sc16is752_write(
   sc16is752_context *ctx = (sc16is752_context *)base;
   if (len > 0) {
-    ctx->ier |= IER_THR;
+    ctx->ier |= SC16IS752_IER_THR;
     len = MIN(len, 32);
     ctx->tx_in_progress = (uint8_t)len;
     write_reg(ctx, SC16IS752_THR, (const uint8_t *)&buf[0], len);
   } else {
     ctx->tx_in_progress = 0;
-    ctx->ier &= ~IER_THR;
+    ctx->ier &= ~SC16IS752_IER_THR;
@@ -286,22 +289,22 @@ static void sc16is752_get_modem_bits(sc16is752_context *ctx, int *bits)
   read_reg(ctx, SC16IS752_MSR, &msr, 1);
   read_reg(ctx, SC16IS752_MCR, &mcr, 1);
-  if (msr & MSR_CTS) {
+  if (msr & SC16IS752_MSR_CTS) {
     *bits |= TIOCM_CTS;
-  if (msr & MSR_DSR) {
+  if (msr & SC16IS752_MSR_DSR) {
     *bits |= TIOCM_DSR;
-  if (msr & MSR_RI) {
+  if (msr & SC16IS752_MSR_RI) {
     *bits |= TIOCM_RI;
-  if (msr & MSR_CD) {
+  if (msr & SC16IS752_MSR_CD) {
     *bits |= TIOCM_CD;
-  if ((mcr & MCR_DTR) == 0) {
+  if ((mcr & SC16IS752_MCR_DTR) == 0) {
     *bits |= TIOCM_DTR;
-  if ((mcr & MCR_RTS) == 0) {
+  if ((mcr & SC16IS752_MCR_RTS) == 0) {
     *bits |= TIOCM_RTS;
@@ -316,29 +319,29 @@ static void sc16is752_set_modem_bits(
   if (bits != NULL) {
     if ((*bits & TIOCM_DTR) == 0) {
-      mcr |= MCR_DTR;
+      mcr |= SC16IS752_MCR_DTR;
     } else {
-      mcr &= ~MCR_DTR;
+      mcr &= ~SC16IS752_MCR_DTR;
     if ((*bits & TIOCM_RTS) == 0) {
-      mcr |= MCR_RTS;
+      mcr |= SC16IS752_MCR_RTS;
     } else {
-      mcr &= ~MCR_RTS;
+      mcr &= ~SC16IS752_MCR_RTS;
   if ((set & TIOCM_DTR) != 0) {
-    mcr &= ~MCR_DTR;
   if ((set & TIOCM_RTS) != 0) {
-    mcr &= ~MCR_RTS;
   if ((clear & TIOCM_DTR) != 0) {
-    mcr |= MCR_DTR;
   if ((clear & TIOCM_RTS) != 0) {
-    mcr |= MCR_RTS;
@@ -416,11 +419,11 @@ void sc16is752_interrupt_handler(void *arg)
   read_2_reg(ctx, SC16IS752_IIR, SC16IS752_RXLVL, data);
   iir = data[0];
-  if ((iir & IIR_TX_INTERRUPT) != 0 && ctx->tx_in_progress > 0) {
+  if ((iir & SC16IS752_IIR_TX_INTERRUPT) != 0 && ctx->tx_in_progress > 0) {
     rtems_termios_dequeue_characters(ctx->tty, ctx->tx_in_progress);
-  if ((iir & IIR_RX_INTERRUPT) != 0) {
+  if ((iir & SC16IS752_IIR_RX_INTERRUPT) != 0) {
     uint8_t buf[SC16IS752_FIFO_DEPTH];
     uint8_t rxlvl = data[1];
2.18.0
