Disable libnetwork on Epiphany?
Joel Sherrill
joel at rtems.org
Wed Aug 15 15:31:39 UTC 2018
On Tue, Aug 14, 2018 at 4:26 AM, Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> On Tue, Aug 14, 2018 at 10:17 AM, Joel Sherrill <joel at rtems.org> wrote:
> > On Tue, Aug 14, 2018, 2:51 AM Hesham Almatary <heshamelmatary at gmail.com>
> > wrote:
> >> AFAIR, I've never tried epiphany with networking. The cores are
> >> supposed to be accelerators, so the ARM core can offload some
> >> processing to it.
> >> P.S. aren't we gonna make Epiphany obsolete? The discussion was
> >> raised by Sebastian before to remove Epiphany support.
> > I recalled or1k and not epiphany.
> Yes you're right
And FWIW the epiphany bsp builder configuration is building networking
and I don't think it should. I couldn't find the magic syntax to tell it
not to
try since it already is noted as excluding smp.
Any ideas on that? I am hoping it doesn't take Chris to step in. :)
> >> On Tue, Aug 14, 2018 at 12:20 AM, Joel Sherrill <joel at rtems.org> wrote:
> >> > Hi
> >> > When you build with --enable-network on epiphany, it fails. Is it
> >> > even reasonable to think it should build or be deployable?
> >> > If not, I would like to force it disabled.
> >> > Thoughts?
> >> > --joel
> >> Hesham
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180815/c9c62afc/attachment.html>
