[PATCH] cpu-supplement: Remove empty index
Mon Aug 20 06:12:17 UTC 2018
On 13/08/18 02:01, Chris Johns wrote:
>> On 10 Aug 2018, at 5:39 pm, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> Due to the hierarchical structure an index is not absolutely necessary
>> and an empty index is not helpful.
> Are there index entries in the doc source that are not being processed?  If so the bug is in the generation and removing this entry may not be a solution.
> I did want to support indexes when the doc source was ported. HTML may not need them but does PDF benefit?
grep -r -l 'index::' c-user/ cpu-supplement/
c-user/dual_ports_memory_manager.rst
c-user/scheduling_concepts.rst
c-user/object_services.rst
c-user/constant_bandwidth_server.rst
c-user/timespec_helpers.rst
c-user/key_concepts.rst
c-user/barrier_manager.rst
c-user/symmetric_multiprocessing_services.rst
c-user/multiprocessing.rst
c-user/stack_bounds_checker.rst
c-user/red_black_trees.rst
c-user/configuring_a_system.rst
c-user/ada_support.rst
c-user/timer_manager.rst
c-user/message_manager.rst
c-user/board_support_packages.rst
c-user/directive_status_codes.rst
c-user/rtems_data_types.rst
c-user/fatal_error.rst
c-user/task_manager.rst
c-user/chains.rst
c-user/overview.rst
c-user/region_manager.rst
c-user/linker_sets.rst
c-user/clock_manager.rst
c-user/rate_monotonic_manager.rst
c-user/pci_library.rst
c-user/semaphore_manager.rst
c-user/interrupt_manager.rst
c-user/signal_manager.rst
c-user/partition_manager.rst
c-user/initialization.rst
c-user/user_extensions.rst
c-user/io_manager.rst
c-user/event_manager.rst
c-user/cpu_usage_statistics.rst
It seems the CPU Supplement doesn't contain index directives.
The RTEMS Classic API Guide contains index directives, however, the
index chapter is empty in the PDF
https://docs.rtems.org/branches/master/c-user.pdf
and non-empty in the HTML
https://docs.rtems.org/branches/master/c-user/genindex.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
