covoar SIGKILL Investigation
Wed Aug 22 04:52:12 UTC 2018
On 22/08/2018 14:41, Joel Sherrill wrote:
> On Tue, Aug 21, 2018, 10:26 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 22/08/2018 09:29, Joel Sherrill wrote:
>     > On Tue, Aug 21, 2018, 4:05 PM Vijay Kumar Banerjee
>     <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>
>     > <mailto:vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>> wrote:
>     >     On Wed, 22 Aug 2018 at 01:55, Joel Sherrill <joel at rtems.org
>     <mailto:joel at rtems.org>
>     >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>     >         How long is covoar taking for the entire set?
>     >     It works great. this is what `time` says
>     >     real17m49.887s
>     >     user14m25.620s
>     >     sys0m37.847s
>     > What speed and type of processor do you have?
>     The program is single threaded so the preprocessing of each executable is
>     sequential. Memory usage is reasonable so there is no swapping.
>     Running covoar from the command line on a box with:
>      hw.machine: amd64
>      hw.model: Intel(R) Core(TM) i7-6900K CPU @ 3.20GHz
>      hw.ncpu: 16
>      hw.machine_arch: amd64
>     plus 32G of memory has a time of:
>           366.32 real       324.97 user        41.33 sys
>     The approximate time break down is:
>      ELF/DWARF loading  : 110s (1m50s)
>      Objdump            : 176s (2m56s)
>      Processing         :  80s (1m20s)
> I don't mind this execution time for the near future. It is far from obscene
> after building and running 600 tests.
Yeah, there are other things we need to do first.
>     The DWARF loading is not optimised and I load all source line to address maps
>     and all functions rather that selectively scanning for specific names at the
>     DWARF level. It is not clear to me scanning would be better or faster.
> I doubt it is worth the effort. There should be few symbols in an exe we don't
> care about. Especially once we start to worry about libc and libm.
Yeah, this is what I thought at the start.
>     My hope
>     is moving to Capstone would help lower or remove the objdump overhead. Then
>     there is threading for the loading.
>     > I don't recall it taking near this long in the past. I used to run it as
>     part of
>     > development.
>     The objdump processing is simpler than before so I suspect the time would have
>     been at least 4 minutes.
>     > But we may have more tests and the code has changed.
>     I think having more tests is the dominant factor.
>     > Reading dwarf
>     > with the file open/closes, etc just may be more expensive than parsing the
>     text
>     > files.
>     The reading DWARF is a cost and at the moment it is not optimised but it is only
>     a cost because we still parse the objdump data. I think opening and closing
>     files is not a factor.
>     The parsing the objdump is the largest component of time. Maybe using Capstone
>     with the ELF files will help.
>     > But it is more accurate and lays the groundwork.for more types of analysis.
>     Yes and think this is important.
> +1
>     > Eventually we will have to profile this code. Whatever is costly is done for
>     > each exe so there is a multiplier.
>     > I suspect this code would parallelize reading info from the exes fairly well.
>     Agreed.
> Might be a good case for C++11 threads if one of the thread container classes is
> a nice pool.
Good idea. I think we need to look at some of the global object pointers before
we head down this path.
> And we might have some locking to account for in core data structures. Are STL
> container instances thread safe?
We need to manage all locking.
> But an addition after feature stable relative to old output plus Capstone.
Agreed.
>     > Merging the info and generating the reports not well due to data contention.
>     Yes.
>     > But optimizing too early and the wrong way is not smart.
>     Yes. We need Capstone to be added before this can happen.
> +1
> I would also like to see gcov support but that will not be a factor in the
> performance we have. It will add reading a lot more files (gcno) and writing a
> lot of gcda at the end. Again more important to be right than fast at first. And
> completely an addition.
Agreed.
