Aligned operations mismatch
Thu Aug 23 05:29:42 UTC 2018
Hello,
On 22/08/18 16:49, Mikhail Svetkin wrote:
> Hi all,
> I have found a problem with assembler code generation in network stack
> on ARM processor (aligment fault).
> I am using:
> arm-rtems5-gcc (GCC) 7.2.0 20170814 (RTEMS 5, RSB
> a6d011e028a0776cedf0823940eb882e917a44e5, Newlib 2.5.0.20170922)
> The compiler generates invalid instruction 'ldmia' here
> (https://git.rtems.org/rtems/tree/cpukit/libnetworking/netinet/udp_usrreq.c#n160).
> The instruction does not support unaligned accesses.
> Also i have found the bug fix in FreeBSD repository
> (https://github.com/freebsd/freebsd/commit/6cc0e8d2a0b583db5707f811d4ebfbe1ad05e628)
this is a three year old commit. Which libbsd version do you use? This
fix is included in the libbsd 4.11 and master branch.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
