Proposal for procedure for architecture/BSP removal
Sebastian Huber
Thu Aug 23 17:51:02 UTC 2018
Hello,
I would like to propose a procedure for architecture/BSP removal since I think the RTEMS master carries to much historic ballast around with no active user base.
Once the release branch is created, an announcement is placed on the devel and users mailing lists and the web site news. The announcement should encourage all active RTEMS users to test their favourite BSP with the release branch and report back the status. Problems should be then be fixed with an active involvement of all core developers.
This announcement is repeated on the mailing lists after two weeks five times. This gives a testing period of three months. This should be enough to cover holiday seasons and urgent project schedules. Users may request an extension of the period.
Afterwards, the status of the BSP/architecture is recorded in the User Manual. Architectures/BSPs with no response will be removed from the release branch and the master. The removal is recorded in the User Manual. A BSP/architecture may not be removed if some maintainer shows up. This maintainer should be recorded somewhere and its duty is to fix problems with this BSP/architecture which show up during the development on the master branch. This includes tool chain problems, warnings due to compiler improvements, driver interface changes, CPU port API changes, new CPU port features, etc.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
