Aligned operations mismatch
Mikhail Svetkin
mikhail.svetkin at gmail.com
Thu Aug 23 18:32:02 UTC 2018
Yes, I use the legacy network stack (I did not know it is legacy, Do you
have any plans to remove it from source?).
I will create the ticket and I will send the patch.
Best regards,
Mikhail
On Thu, 23 Aug 2018 at 07:33, Sebastian Huber <
> On 23/08/18 07:29, Sebastian Huber wrote:
> > Hello,
> > On 22/08/18 16:49, Mikhail Svetkin wrote:
> >> Hi all,
> >> I have found a problem with assembler code generation in network
> >> stack on ARM processor (aligment fault).
> >> I am using:
> >> arm-rtems5-gcc (GCC) 7.2.0 20170814 (RTEMS 5, RSB
> >> a6d011e028a0776cedf0823940eb882e917a44e5, Newlib 2.5.0.20170922)
> >> The compiler generates invalid instruction 'ldmia' here
> https://git.rtems.org/rtems/tree/cpukit/libnetworking/netinet/udp_usrreq.c#n160
> >> The instruction does not support unaligned accesses.
> >> Also i have found the bug fix in FreeBSD repository
> https://github.com/freebsd/freebsd/commit/6cc0e8d2a0b583db5707f811d4ebfbe1ad05e628
> > this is a three year old commit. Which libbsd version do you use? This
> > fix is included in the libbsd 4.11 and master branch.
> Oh, I should have read the URL more carefully. You use the legacy
> network stack. Please open a ticket for this.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180823/32c54bf2/attachment.html>
