Future of or1k RTEMS support?
Martin Erik Werner martinerikwerner.aac at gmail.com
Fri Aug 24 12:04:28 UTC 2018
Hi,
Regarding or1k, we (ÅAC Microtec/Clyde Space) are currently using it,
together with RTEMS, in some of our products[0], and are thus quite
interested in its continued life as a part of RTEMS, at least in the
foreseeable future (i.e. RTEMS 5).
With regards to the upstreaming of GCC, there are still ongoing work on
this for or1k at https://github.com/stffrdhrn/gcc .
[0]
http://aacmicrotec.com/products/spacecraft-subsystems/avionics/siriusobc/
http://aacmicrotec.com/products/spacecraft-subsystems/avionics/siriustcm/
Martin Erik Werner <martinerikwerner.aac at gmail.com>
ÅAC Microtec AB | Clyde Space Ltd.
On Thu, 2018-07-26 at 10:01 +0100, Hesham Almatary wrote:
> Hi Sebastian,
> Yes, I agree with you. Furthermore, most of the or1k hardware and software folks are moving to riscv now.
> Should we make it obsolete?
> Cheers,
> Hesham
> On Thu, 26 Jul 2018 at 7:10 am, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> > Hello,
> > the or1k ecosystem has a major problem with their non-FSF GCC from my
> > point of view which is maintained here:
> > https://github.com/openrisc/or1k-gcc
> > The last commit was in 2016.  It looks like a dead project to me.
> > Given the momentum RISC-V has currently why would someone still want to
> > use or1k? All RISC-V tools are upstream and well maintained. It is the
> > target with the most helpful and responsive maintainers that I worked
> > with so far.
> > devel mailing list
> > devel at rtems.org
