[PATCH] leon, apbuart: replace termios c_cflag & CBAUD with c_{i, o}speed
Daniel Hellstrom daniel at gaisler.com
Fri Aug 24 13:32:43 UTC 2018
ince some time RTEMS started to use the termios c_ispeed and
c_ospeed variables in the termios struct to hold the UART baudrate.
However the APBUART driver still uses the old c_cflag sometimes
causing other UART parameters to get overwritten, for example the
partiy setting no mapped to the same bits as the old CBAUD mask.
At the same time the RTEMS primitievs for setting/reading
c_{i,o}speed is now used.
 bsps/sparc/shared/uart/apbuart_cons.c | 64 ++---------------------------------
 1 file changed, 3 insertions(+), 61 deletions(-)
diff --git a/bsps/sparc/shared/uart/apbuart_cons.c b/bsps/sparc/shared/uart/apbuart_cons.c
index ac8a436..a54c2229 100644
--- a/bsps/sparc/shared/uart/apbuart_cons.c
+++ b/bsps/sparc/shared/uart/apbuart_cons.c
@@ -515,57 +515,6 @@ static int read_task(rtems_termios_device_context *base)
 	return EOF;
-struct apbuart_baud {
-	unsigned int num;
-	unsigned int baud;
-static struct apbuart_baud apbuart_baud_table[] = {
-	{B50, 50},
-	{B75, 75},
-	{B110, 110},
-	{B134, 134},
-	{B150, 150},
-	{B200, 200},
-	{B300, 300},
-	{B600, 600},
-	{B1200, 1200},
-	{B1800, 1800},
-	{B2400, 2400},
-	{B4800, 4800},
-	{B9600, 9600},
-	{B19200, 19200},
-	{B38400, 38400},
-	{B57600, 57600},
-	{B115200, 115200},
-	{B230400, 230400},
-	{B460800, 460800},
-#define BAUD_NUM (sizeof(apbuart_baud_table)/sizeof(struct apbuart_baud))
-static int apbuart_baud_num2baud(unsigned int num)
-	int i;
-	for(i=0; i<BAUD_NUM; i++)
-		if (apbuart_baud_table[i].num == num)
-			return apbuart_baud_table[i].baud;
-	return -1;
-static struct apbuart_baud *apbuart_baud_find_closest(unsigned int baud)
-	int i, diff;
-	for(i=0; i<BAUD_NUM-1; i++) {
-		diff = apbuart_baud_table[i+1].baud -
-			apbuart_baud_table[i].baud;
-		if (baud < (apbuart_baud_table[i].baud + diff/2))
-			return &apbuart_baud_table[i];
-	return &apbuart_baud_table[BAUD_NUM-1];
 int apbuart_get_baud(struct apbuart_priv *uart)
 	unsigned int core_clk_hz;
@@ -581,11 +530,6 @@ int apbuart_get_baud(struct apbuart_priv *uart)
 	return core_clk_hz / ((scaler + 1) * 8);
-static struct apbuart_baud *apbuart_get_baud_closest(struct apbuart_priv *uart)
-	return apbuart_baud_find_closest(apbuart_get_baud(uart));
 static bool set_attributes(
 	rtems_termios_device_context *base,
 	const struct termios *t
@@ -644,7 +588,7 @@ static bool set_attributes(
 	rtems_termios_device_lock_release(base, &lock_context);
 	/* Baud rate */
-  baud = apbuart_baud_num2baud(t->c_ospeed);
+	baud = rtems_termios_baud_to_number(t->c_ospeed);
 	if (baud > 0){
 		/* Get APBUART core frequency */
 		drvmgr_freq_get(uart->dev, DEV_APB_SLV, &core_clk_hz);
@@ -666,9 +610,8 @@ static void get_attributes(
 	struct apbuart_priv *uart = base_get_priv(base);
 	unsigned int ctrl;
-	struct apbuart_baud *baud;
-  t->c_cflag = t->c_cflag & ~(CSIZE|PARENB|PARODD|CLOCAL);
+	t->c_cflag = t->c_cflag & ~(CSIZE|PARENB|PARODD|CLOCAL);
 	/* Hardware support only CS8 */
 	t->c_cflag |= CS8;
@@ -685,8 +628,7 @@ static void get_attributes(
 	if ((ctrl & LEON_REG_UART_CTRL_FL) == 0)
 		t->c_cflag |= CLOCAL;
-	baud = apbuart_get_baud_closest(uart);
-	t->c_cflag |= baud->num;
+	rtems_termios_set_best_baud(t, apbuart_get_baud(uart));
 static void write_polled(
2.7.4
