powerpc build failures with gcc master
Joel Sherrill
joel at rtems.org
Tue Aug 28 21:19:12 UTC 2018
Hi
The GCC master no longer supports the -mno-spe flag. This results
in configure time failures that GCC does not work:
configure:3499: powerpc-rtems5-gcc -mcpu=8540 -meabi -msdata=sysv
-fno-common -msoft-float -mno-spe -Og -g -ffunction-sections
-fdata-sections conftest.c >&5
powerpc-rtems5-gcc: error: unrecognized command line option '-mno-spe'; did
you mean '-fno-see'?
This impacts the t32mppc and all mpc55xx variants.
Looks like deleting the option is the correct solution. Any other thoughts
on how to correct this?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180828/7d29622b/attachment.html>
