[PATCH 08/17] qoriq/include/tm27.h: Fix warnings
Wed Aug 29 20:15:21 UTC 2018
 bsps/powerpc/qoriq/include/tm27.h | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/bsps/powerpc/qoriq/include/tm27.h b/bsps/powerpc/qoriq/include/tm27.h
index 79ef3b4..e1084a1 100644
--- a/bsps/powerpc/qoriq/include/tm27.h
+++ b/bsps/powerpc/qoriq/include/tm27.h
@@ -40,7 +40,7 @@
 #define IPI_INDEX_HIGH 2
-static void Install_tm27_vector(void (*handler)(rtems_vector_number))
+RTEMS_INLINE_ROUTINE void Install_tm27_vector(void (*handler)(rtems_vector_number))
   rtems_status_code sc;
   rtems_vector_number low = QORIQ_IRQ_IPI_0 + IPI_INDEX_LOW;
@@ -71,24 +71,24 @@ static void Install_tm27_vector(void (*handler)(rtems_vector_number))
   assert(sc == RTEMS_SUCCESSFUL);
-static void qoriq_tm27_cause(uint32_t ipi_index)
+RTEMS_INLINE_ROUTINE void qoriq_tm27_cause(uint32_t ipi_index)
   uint32_t self = ppc_processor_id();
   qoriq.pic.per_cpu[self].ipidr[ipi_index].reg = UINT32_C(1) << self;
-static void Cause_tm27_intr(void)
+RTEMS_INLINE_ROUTINE void Cause_tm27_intr(void)
   qoriq_tm27_cause(IPI_INDEX_LOW);
-static void Clear_tm27_intr(void)
+RTEMS_INLINE_ROUTINE void Clear_tm27_intr(void)
   /* Nothing to do */
-static void Lower_tm27_intr(void)
+RTEMS_INLINE_ROUTINE inline void Lower_tm27_intr(void)
   qoriq_tm27_cause(IPI_INDEX_HIGH);
1.8.3.1
