[PATCH 17/17] Remove bsps/sparc64/shared/helenos/boot/generic/string.c
Wed Aug 29 20:15:30 UTC 2018
 bsps/sparc64/shared/helenos/boot/generic/string.c | 211 ----------------------
 c/src/lib/libbsp/sparc64/niagara/Makefile.am      |   1 -
 c/src/lib/libbsp/sparc64/usiii/Makefile.am        |   1 -
 3 files changed, 213 deletions(-)
 delete mode 100644 bsps/sparc64/shared/helenos/boot/generic/string.c
diff --git a/bsps/sparc64/shared/helenos/boot/generic/string.c b/bsps/sparc64/shared/helenos/boot/generic/string.c
deleted file mode 100644
index ad6d1b7..0000000
--- a/bsps/sparc64/shared/helenos/boot/generic/string.c
+++ /dev/null
@@ -1,211 +0,0 @@
- * Copyright (c) 2001-2004 Jakub Jermar
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * - Redistributions of source code must retain the above copyright
- *   notice, this list of conditions and the following disclaimer.
- * - Redistributions in binary form must reproduce the above copyright
- *   notice, this list of conditions and the following disclaimer in the
- *   documentation and/or other materials provided with the distribution.
- * - The name of the author may not be used to endorse or promote products
- *   derived from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
- * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
- * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
- * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
- * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
- * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
- * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-/** @addtogroup generic
- * Modifications are made to compile for RTEMS. Remove strncpy() and atoi()
-#include <string.h>
- * @file
- * @brief	String manipulation functions.
-/** Return number of characters in a string.
- * @param str		NULL terminated string.
- * @return		Number of characters in str.
-size_t strlen(const char *str)
-	int i;
-	for (i = 0; str[i]; i++)
-	return i;
-/** Compare two NULL terminated strings.
- * Do a char-by-char comparison of two NULL terminated strings.
- * The strings are considered equal iff they consist of the same
- * characters on the minimum of their lengths.
- * @param src		First string to compare.
- * @param dst		Second string to compare.
- * @return		0 if the strings are equal, -1 if first is smaller,
- * 			1 if second smaller.
-int strcmp(const char *src, const char *dst)
-	for (; *src && *dst; src++, dst++) {
-		if (*src < *dst)
-			return -1;
-		if (*src > *dst)
-			return 1;
-	if (*src == *dst)
-		return 0;
-	if (!*src)
-		return -1;
-	return 1;
- * characters on the minimum of their lengths and specified maximal
- * length.
- * @param len		Maximal length for comparison.
-int strncmp(const char *src, const char *dst, size_t len)
-	int i;
-	for (i = 0; *src && *dst && i < len; src++, dst++, i++) {
-		if (*src < *dst)
-			return -1;
-		if (*src > *dst)
-			return 1;
-	if (i == len || *src == *dst)
-		return 0;
-	if (!*src)
-		return -1;
-	return 1;
-#if 0
-/** Copy NULL terminated string.
- * Copy at most 'len' characters from string 'src' to 'dest'.
- * If 'src' is shorter than 'len', '\0' is inserted behind the
- * last copied character.
- * @param src		Source string.
- * @param dest		Destination buffer.
- * @param len		Size of destination buffer.
-void strncpy(char *dest, const char *src, size_t len)
-	int i;
-	for (i = 0; i < len; i++) {
-		if (!(dest[i] = src[i]))
-			return;
-	dest[i-1] = '\0';
-/** Convert ascii representation to unative_t.
- * Supports 0x for hexa & 0 for octal notation.
- * Does not check for overflows, does not support negative numbers
- * @param text		Textual representation of number.
- * @return		Converted number or 0 if no valid number found.
-unative_t atoi(const char *text)
-	int base = 10;
-	unative_t result = 0;
-	if (text[0] == '0' && text[1] == 'x') {
-		base = 16;
-		text += 2;
-	} else if (text[0] == '0')
-		base = 8;
-	while (*text) {
-		if (base != 16 &&
-		    ((*text >= 'A' && *text <= 'F') ||
-		    (*text >='a' && *text <='f')))
-			break;
-		if (base == 8 && *text >='8')
-			break;
-		if (*text >= '0' && *text <= '9') {
-			result *= base;
-			result += *text - '0';
-		} else if (*text >= 'A' && *text <= 'F') {
-			result *= base;
-			result += *text - 'A' + 10;
-		} else if (*text >= 'a' && *text <= 'f') {
-			result *= base;
-			result += *text - 'a' + 10;
-		} else
-			break;
-		text++;
-	return result;
-#endif
-/** Move piece of memory to another, possibly overlapping, location.
- * @param dst		Destination address.
- * @param src		Source address.
- * @param len		Number of bytes to move.
- * @return		Destination address.
-void *memmove(void *dst, const void *src, size_t len)
-	char *d = dst;
-	const char *s = src;
-	if (s < d) {
-		while (len--)
-			*(d + len) = *(s + len);
-	} else {
-		while (len--)
-			*d++ = *s++;
-	return dst;
diff --git a/c/src/lib/libbsp/sparc64/niagara/Makefile.am b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
index 0744847..bdf737f 100644
--- a/c/src/lib/libbsp/sparc64/niagara/Makefile.am
+++ b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
@@ -28,7 +28,6 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/start/setvec.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/helenos/boot/genarch/balloc.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/helenos/boot/genarch/ofw.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/helenos/boot/genarch/ofw_tree.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/helenos/boot/generic/string.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/helenos/boot/sparc64/loader/ofwarch.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/helenos/boot/sparc64/loader/main.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/helenos/boot/sparc64/loader/ofwasm.S
diff --git a/c/src/lib/libbsp/sparc64/usiii/Makefile.am b/c/src/lib/libbsp/sparc64/usiii/Makefile.am
index 751ed93..234f335 100644
--- a/c/src/lib/libbsp/sparc64/usiii/Makefile.am
+++ b/c/src/lib/libbsp/sparc64/usiii/Makefile.am
@@ -35,7 +35,6 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc64/shared/start/setvec.c
1.8.3.1
