[PATCH 09/17] monlib.[ch]: Fix warnings for external vs internal use of .h
Wed Aug 29 20:15:22 UTC 2018
 bsps/arm/csb337/umon/monlib.c |  1 +
 bsps/include/umon/monlib.h    | 12 ++++++------
 2 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/bsps/arm/csb337/umon/monlib.c b/bsps/arm/csb337/umon/monlib.c
index 36f9158..44c9ec0 100644
--- a/bsps/arm/csb337/umon/monlib.c
+++ b/bsps/arm/csb337/umon/monlib.c
@@ -43,6 +43,7 @@
  *  standards and to eliminate C++ style comments.
+#define _INSIDE_MONLIB
 #include <umon/monlib.h>
 static int		(*_tfsseek)(int,int,int);
diff --git a/bsps/include/umon/monlib.h b/bsps/include/umon/monlib.h
index efbfc93..c26350f 100644
--- a/bsps/include/umon/monlib.h
+++ b/bsps/include/umon/monlib.h
@@ -148,16 +148,16 @@ extern unsigned long mon_assignhandler(long hnum,
 extern struct tfshdr *mon_tfsnext(struct tfshdr *tfp);
 extern struct tfshdr *mon_tfsstat(char *filename);
-#if SHOWVARARGS
+ * The external caller should see these as variable argument methods but
+ * they are not implemented that way, so let monlib.c prototype them internally
+ * when building that file.
+#ifndef _INSIDE_MONLIB
 extern void mon_memtrace(char *fmt, ...);
 extern int mon_printf(char *fmt, ...);
 extern int mon_cprintf(char *fmt, ...);
 extern int mon_sprintf(char *,char *fmt, ...);
-#else
-extern void mon_memtrace();
-extern int mon_printf();
-extern int mon_cprintf();
-extern int mon_sprintf();
 #endif
 #ifdef __cplusplus
1.8.3.1
