bsp-builder Mystery Failures
Fri Aug 31 00:05:21 UTC 2018
On 22/8/18 12:24 am, Joel Sherrill wrote:
> Ignoring the epiphany failures (it shouldn't even attempt to
> build networking but I can't seem to find the .ini syntax to address
> that),
What happens if you add 'networking' to the 'exclude' line in this file ..
https://git.rtems.org/rtems-tools/tree/tester/rtems/rtems-bsps-epiphany.ini#n25
> the following results
> https://lists.rtems.org/pipermail/build/2018-August/000903.html
> have some failures I don't seem to be able to reproduce by
> hand. For example, number 9 is one of the set for SPARC BSPs.
>  9 smp-debug sparc/gr712rc build:
>       configure: /home/joel/rtems-work/rtems/configure --target=sparc-\
>       rtems5 --enable-rtemsbsp=gr712rc --prefix=/home/joel/rtems-work/bsps\
>       --enable-rtems-debug --enable-smp
>      error: bsps/sparc/shared/start/start.S:313 Error: Unknown opcode:
>             `mv'
> I can't reproduce that by hand. I also tried an m32c failure but couldn't
> reproduce it either.
> Help is appreciated.
I suggest you check the build output for the different build to see what is
different. Maybe a diff of the top level config.status may show something.
