covoar SIGKILL Investigation
Joel Sherrill
joel at rtems.org
Fri Aug 31 18:31:36 UTC 2018
On Fri, Aug 31, 2018, 12:44 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Hello,
> I have listed all the specific exes for which covoar fails.
> I have observed that covoar fails only for some specific exe for some
> symbol-sets,
> this was the reason for covoar not completing successfully. If we exclude
> these exe,
> covoar finishes successfully for the whole testsuites. So the prolem has
> become more
> specific now, we'll have to investigate for only these exe.
> Here's the list of all the symbol-sets that were failing, along with the
> exe files that made them
> trip.
> posix ----
> sptests/spmutex01.exe
> fstests/fsclose01.exe
> sapi ----
> sptests/spversion01.exe
> librfs ----
> fstests/mrfs_fserror.exe
> fstests/mrfs_fsrdwr.exe
> (all fstests/mrfs_*.exe fails)
> fstests/fsrofs01.exe
> libtests/flashdisk01.exe
> libdevnull ----
> sptests/sp21.exe
> psxtests/psxmmap01.exe
> tmtests/tm20.exe
> libblock ----
> fstests/fsbdpart01.exe
Thanks.
Have you had a chance to try get with catch throw?
> On Wed, 22 Aug 2018 at 21:11, Vijay Kumar Banerjee <
>> I will send the attachment offlist as it's too big for the list.
>> On Wed, 22 Aug 2018 at 21:07, Vijay Kumar Banerjee <
>>> The coverage for whole testsuite completed successfully,
>>> I have attached the zip file here and also included the js and css files
>>> in it.
>>> coverage didn't complete for the following symbol-set libraries and was
>>> returning,
>>> covoar error 10
>>> * libsapi.a
>>> * libposix.a
>>> * librfs.a
>>> * libcsupport.a
>>> * libdevnull.a
>>> * libblock.a
>>> On Wed, 22 Aug 2018 at 10:22, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 22/08/2018 14:41, Joel Sherrill wrote:
>>>> > On Tue, Aug 21, 2018, 10:26 PM Chris Johns <chrisj at rtems.org
>>>> > <mailto:chrisj at rtems.org>> wrote:
>>>> > On 22/08/2018 09:29, Joel Sherrill wrote:
>>>> > > On Tue, Aug 21, 2018, 4:05 PM Vijay Kumar Banerjee
>>>> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>
>>>> > > <mailto:vijaykumar9597 at gmail.com <mailto:
>>>> vijaykumar9597 at gmail.com>>> wrote:
>>>> > > On Wed, 22 Aug 2018 at 01:55, Joel Sherrill <joel at rtems.org
>>>> > <mailto:joel at rtems.org>
>>>> > > <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>>>> > > How long is covoar taking for the entire set?
>>>> > > It works great. this is what `time` says
>>>> > > real17m49.887s
>>>> > > user14m25.620s
>>>> > > sys0m37.847s
>>>> > > What speed and type of processor do you have?
>>>> > The program is single threaded so the preprocessing of each
>>>> executable is
>>>> > sequential. Memory usage is reasonable so there is no swapping.
>>>> > Running covoar from the command line on a box with:
>>>> > hw.machine: amd64
>>>> > hw.model: Intel(R) Core(TM) i7-6900K CPU @ 3.20GHz
>>>> > hw.ncpu: 16
>>>> > hw.machine_arch: amd64
>>>> > plus 32G of memory has a time of:
>>>> > 366.32 real 324.97 user 41.33 sys
>>>> > The approximate time break down is:
>>>> > ELF/DWARF loading : 110s (1m50s)
>>>> > Objdump : 176s (2m56s)
>>>> > Processing : 80s (1m20s)
>>>> > I don't mind this execution time for the near future. It is far from
>>>> obscene
>>>> > after building and running 600 tests.
>>>> Yeah, there are other things we need to do first.
>>>> > The DWARF loading is not optimised and I load all source line to
>>>> address maps
>>>> > and all functions rather that selectively scanning for specific
>>>> names at the
>>>> > DWARF level. It is not clear to me scanning would be better or
>>>> faster.
>>>> > I doubt it is worth the effort. There should be few symbols in an exe
>>>> we don't
>>>> > care about. Especially once we start to worry about libc and libm.
>>>> Yeah, this is what I thought at the start.
>>>> > My hope
>>>> > is moving to Capstone would help lower or remove the objdump
>>>> overhead. Then
>>>> > there is threading for the loading.
>>>> > > I don't recall it taking near this long in the past. I used to
>>>> run it as
>>>> > part of
>>>> > > development.
>>>> > The objdump processing is simpler than before so I suspect the
>>>> time would have
>>>> > been at least 4 minutes.
>>>> > > But we may have more tests and the code has changed.
>>>> > I think having more tests is the dominant factor.
>>>> > > Reading dwarf
>>>> > > with the file open/closes, etc just may be more expensive than
>>>> parsing the
>>>> > text
>>>> > > files.
>>>> > The reading DWARF is a cost and at the moment it is not optimised
>>>> but it is only
>>>> > a cost because we still parse the objdump data. I think opening
>>>> and closing
>>>> > files is not a factor.
>>>> > The parsing the objdump is the largest component of time. Maybe
>>>> using Capstone
>>>> > with the ELF files will help.
>>>> > > But it is more accurate and lays the groundwork.for more types
>>>> of analysis.
>>>> > Yes and think this is important.
>>>> > +1
>>>> > > Eventually we will have to profile this code. Whatever is
>>>> costly is done for
>>>> > > each exe so there is a multiplier.
>>>> > > I suspect this code would parallelize reading info from the
>>>> exes fairly well.
>>>> > Agreed.
>>>> > Might be a good case for C++11 threads if one of the thread container
>>>> classes is
>>>> > a nice pool.
>>>> Good idea. I think we need to look at some of the global object
>>>> pointers before
>>>> we head down this path.
>>>> > And we might have some locking to account for in core data
>>>> structures. Are STL
>>>> > container instances thread safe?
>>>> We need to manage all locking.
>>>> > But an addition after feature stable relative to old output plus
>>>> Capstone.
>>>> Agreed.
>>>> > > Merging the info and generating the reports not well due to
>>>> data contention.
>>>> > Yes.
>>>> > > But optimizing too early and the wrong way is not smart.
>>>> > Yes. We need Capstone to be added before this can happen.
>>>> > +1
>>>> > I would also like to see gcov support but that will not be a factor
>>>> in the
>>>> > performance we have. It will add reading a lot more files (gcno) and
>>>> writing a
>>>> > lot of gcda at the end. Again more important to be right than fast at
>>>> first. And
>>>> > completely an addition.
>>>> Agreed.
>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180831/cbcef9f9/attachment-0001.html>
