[PATCH 16/21] libchip/ata: Use rtems_blkdev_create()
    Sebastian Huber
    Mon Aug  6 07:14:48 UTC 2018
Update #3358.
 bsps/include/libchip/ata_internal.h |  2 --
 bsps/shared/dev/ide/ata.c           | 59 ++++++++-----------------------------
 2 files changed, 13 insertions(+), 48 deletions(-)
diff --git a/bsps/include/libchip/ata_internal.h b/bsps/include/libchip/ata_internal.h
index 985b6f597c..e977c91805 100644
--- a/bsps/include/libchip/ata_internal.h
+++ b/bsps/include/libchip/ata_internal.h
@@ -165,8 +165,6 @@ extern "C" {
 #define ATA_REGISTERS_POSITION       0xfc
-#define ATA_MINOR_NUM_RESERVED_PER_ATA_DEVICE     64
 #define ATA_MAX_RTEMS_INT_VEC_NUMBER              255
 #define ATA_MAX_NAME_LENGTH                       10
diff --git a/bsps/shared/dev/ide/ata.c b/bsps/shared/dev/ide/ata.c
index 7bb3f6ec73..fe2865fc90 100644
--- a/bsps/shared/dev/ide/ata.c
+++ b/bsps/shared/dev/ide/ata.c
@@ -18,7 +18,6 @@
 #include <assert.h>
 #include <string.h> /* for "memset" declaration */
-#include <rtems/diskdevs.h>
 #include <rtems/blkdev.h>
 #include <libchip/ide_ctrl_io.h>
 #include <libchip/ide_ctrl_cfg.h>
@@ -119,23 +118,17 @@ ata_add_to_controller_queue(rtems_device_minor_number  ctrl_minor,
  *     error occured
 static rtems_status_code
-ata_io_data_request(dev_t device, rtems_blkdev_request *req)
+ata_io_data_request(ata_ide_dev_t *ata_dev, rtems_blkdev_request *req)
     ata_req_t                 *areq; /* ATA request */
-    rtems_device_minor_number  rel_minor; /* relative minor which indexes
-                                           * ata_devs array
     rtems_device_minor_number  ctrl_minor;
     uint8_t                    dev;
-    rel_minor = (rtems_filesystem_dev_minor_t(device)) /
-                ATA_MINOR_NUM_RESERVED_PER_ATA_DEVICE;
     /* get controller which serves the ATA device */
-    ctrl_minor = ata_devs[rel_minor].ctrl_minor;
+    ctrl_minor = ata_dev->ctrl_minor;
     /* get ATA device identifier (0 or 1) */
-    dev = ata_devs[rel_minor].device;
+    dev = ata_dev->device;
     areq = malloc(sizeof(ata_req_t));
     if (areq == NULL)
@@ -251,25 +244,19 @@ ata_io_data_request(dev_t device, rtems_blkdev_request *req)
  *     error occured
-ata_non_data_request(dev_t device, uint32_t cmd, void *argp)
+ata_non_data_request(ata_ide_dev_t *ata_dev, uint32_t cmd, void *argp)
     rtems_status_code          rc;
-                                           * ata_devs array
     uint8_t                    dev;
     ata_queue_msg_t            msg;
     /* form the request */
@@ -943,18 +930,14 @@ ata_queue_task(rtems_task_argument arg)
 static int
 ata_ioctl(rtems_disk_device *dd, uint32_t cmd, void *argp)
-    dev_t                     device = rtems_disk_get_device_identifier(dd);
-    rtems_status_code         status;
+    ata_ide_dev_t     *ata_dev = rtems_disk_get_driver_data(dd);
+    rtems_status_code  status;
      * in most cases this means that device 'device' is not an registred ATA
      * device
-    if (ata_devs[rel_minor].device == ATA_UNDEFINED_VALUE)
+    if (ata_dev->device == ATA_UNDEFINED_VALUE)
         errno = ENODEV;
         return -1;
@@ -963,11 +946,11 @@ ata_ioctl(rtems_disk_device *dd, uint32_t cmd, void *argp)
     switch (cmd)
         case RTEMS_BLKIO_REQUEST:
-            status = ata_io_data_request(device, (rtems_blkdev_request *)argp);
+            status = ata_io_data_request(ata_dev, (rtems_blkdev_request *)argp);
             break;
         case ATAIO_SET_MULTIPLE_MODE:
-            status = ata_non_data_request(device, cmd, argp);
+            status = ata_non_data_request(ata_dev, cmd, argp);
             break;
         case RTEMS_BLKIO_CAPABILITIES:
@@ -1102,7 +1085,6 @@ rtems_ata_initialize(rtems_device_major_number major,
     uint16_t          *buffer;
     int                i, dev = 0;
     char               name[ATA_MAX_NAME_LENGTH];
-    dev_t              device;
     ata_int_st_t      *int_st;
 #if CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE
@@ -1114,11 +1096,6 @@ rtems_ata_initialize(rtems_device_major_number major,
     if (ata_initialized)
         return RTEMS_SUCCESSFUL;
-    /* initialization of disk devices library */
-    status = rtems_disk_io_initialize();
-    if (status != RTEMS_SUCCESSFUL)
-        return status;
     status = rtems_semaphore_create (rtems_build_name ('A', 'T', 'A', 'L'),
                                      1, RTEMS_ATA_LOCK_ATTRIBS, 0,
                                      &ata_lock);
@@ -1134,7 +1111,6 @@ rtems_ata_initialize(rtems_device_major_number major,
                  &ata_queue_id);
-        rtems_disk_io_done();
         return status;
@@ -1155,7 +1131,6 @@ rtems_ata_initialize(rtems_device_major_number major,
         rtems_message_queue_delete(ata_queue_id);
         return status;
@@ -1168,7 +1143,6 @@ rtems_ata_initialize(rtems_device_major_number major,
         rtems_task_delete(ata_task_id);
         return status;
@@ -1177,7 +1151,6 @@ rtems_ata_initialize(rtems_device_major_number major,
         return RTEMS_NO_MEMORY;
@@ -1221,7 +1194,6 @@ rtems_ata_initialize(rtems_device_major_number major,
                 free(buffer);
@@ -1275,7 +1247,6 @@ rtems_ata_initialize(rtems_device_major_number major,
                 free(buffer);
                 return status;
@@ -1328,17 +1299,13 @@ rtems_ata_initialize(rtems_device_major_number major,
             strcpy(name, "/dev/hd ");
             name[7] = 'a' + 2 * ctrl_minor + dev;
-            device = rtems_filesystem_make_dev_t(
-                         major,
-                         (ata_devs_number *
-                          ATA_MINOR_NUM_RESERVED_PER_ATA_DEVICE));
-            status = rtems_disk_create_phys(device, ATA_SECTOR_SIZE,
+            status = rtems_blkdev_create(name, ATA_SECTOR_SIZE,
                 ATA_DEV_INFO(ctrl_minor, dev).lba_avaible ?
                 ATA_DEV_INFO(ctrl_minor, dev).lba_sectors :
                 (ATA_DEV_INFO(ctrl_minor, dev).heads *
                  ATA_DEV_INFO(ctrl_minor, dev).cylinders *
                  ATA_DEV_INFO(ctrl_minor, dev).sectors),
-                ata_ioctl, NULL, name);
+                ata_ioctl, &ata_devs[ata_devs_number]);
                 ata_devs[ata_devs_number].device = ATA_UNDEFINED_VALUE;
2.13.7
