covoar SIGKILL Investigation
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Aug 21 18:59:23 UTC 2018
On Tue, Aug 21, 2018, 7:34 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Aug 21, 2018 at 2:14 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 21/08/2018 16:55, Vijay Kumar Banerjee wrote:
>> > I tried running coverage with this latest
>> > master, covoar is taking up all the memory (7 GB) including the swap
>> (7.6 GB)
>> > and after a while, still gets killed. :(
>> I ran rtems-test and created the .cov files and then ran covoar from the
>> command
>> line (see below). Looking at top while it is running I see covoar topping
>> out
>> with a size around 1430M. The size is pretty static once the "Loading
>> symbol
>> sets:" is printed.
>> I have run covoar under valgrind with a smaller number of executables and
>> made
>> sure all the allocations are ok.
>> I get a number of size mismatch messages related the inline functions but
>> that
>> is a known issue.
>> > can there be something wrong with my environment?
>> I have no idea.
>> > I tried running it on a different system,
>> > coverage did run for the whole testsuite for score and rtems only.
>> > (I mentioned the symbols as argument to --coverage)
>> > but it  doesn't run for all the symbol-sets, strange.
>> I am not running coverage via the rtems-test command. I have been testing
>> at the
>> covoar command line.
>> Can you please try a variant of:
>>  /opt/work/chris/rtems/rt/rtems-tools.git/build/tester/covoar/covoar \
>>  -v \
>>  -S
>> /opt/work/chris/rtems/rt/rtems-tools.git/tester/rtems/testing/coverage/leon3-qemu-symbols.ini
>>  -O /opt/work/chris/rtems/kernel/bsps/leon3/leon3-qemu-coverage/score \
>>  -E
>> /opt/work/chris/rtems/rt/rtems-tools.git/tester/rtems/testing/coverage/Explanations.txt
>>  -p RTEMS-5 `find . -name \*.exe`
>> I have top running at the same time. The foot print grows while the DWARF
>> info
>> and .cov files are loaded which is
> Vijay .. I would add to make sure the gcov processing is turned off for
> now.
it's turned off. :)
After a lot of different attempts I realized that I just needed to waf
build after pulling the new changes. Sorry about that.
It did run successfully !
I'm now running coverage with rtems-test for the whole testsuite, I will be
reporting about it soon :)
>> Thanks
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180822/49e8cb22/attachment-0002.html>
