Some problems with the libbsd update
Wed Aug 22 11:44:53 UTC 2018
On Wed, Aug 22, 2018, 4:51 AM Sebastian Huber <
> On 22/08/18 09:50, Sebastian Huber wrote:
> > To support everything in RTEMS is a lot of work, so I have to make
> > some trade-offs. The implementation of this API must be as efficient
> > as possible since it is used in the critical paths of the network
> > stack. I will try to use a single global epoch and thread-specific
> > records as suggested by Matthew Macy to avoid the need for
> > per-processor data structures and the thread pinning. One key issue is
> > that epoch records must not be destroyed:
> > https://www.mankier.com/3/ck_epoch_register
> > The consequence of this is that unlimited thread objects may lead to
> > undefined behaviour with this implementation approach. Also
> > thread-local storage cannot be used since it is reinitialized once a
> > thread restarted or reused. The epoch record must be included in the
> > Thread_Control and must not be touched by _Thread_Initialize(). This
> > means I have to move the API and its implementation along with the
> > Concurrency Kit to RTEMS.
> Ok, there is also an
> http://www.concurrencykit.org/doc/ck_epoch_unregister.html
> and
> http://www.concurrencykit.org/doc/ck_epoch_recycle.html
> This allows a localized implementation in libbsd.
> Due to performance reasons this requires the use of thread-local
> storage. Any objections to make thread-local storage a hard requirement
> for libbsd support?
Not particularly but there should be an effort to identify which targets do
not have TLS support yet. Other than sparc, arm, powerpc and i386, I don't
know the status. Sounds like a series of tickets.
Certainly seems like the mist straightforward approach to solving the
problem. But it requires some work on TLS which was needed anyway.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180822/b07cd30e/attachment-0002.html>
