covoar SIGKILL Investigation
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Aug 31 17:44:25 UTC 2018
Hello,
I have listed all the specific exes for which covoar fails.
I have observed that covoar fails only for some specific exe for some
symbol-sets,
this was the reason for covoar not completing successfully. If we exclude
these exe,
covoar finishes successfully for the whole testsuites. So the prolem has
become more
specific now, we'll have to investigate for only these exe.
Here's the list of all the symbol-sets that were failing, along with the
exe files that made them
trip.
posix ----
sptests/spmutex01.exe
fstests/fsclose01.exe
sapi ----
sptests/spversion01.exe
librfs ----
fstests/mrfs_fserror.exe
fstests/mrfs_fsrdwr.exe
(all fstests/mrfs_*.exe fails)
fstests/fsrofs01.exe
libtests/flashdisk01.exe
libdevnull ----
sptests/sp21.exe
psxtests/psxmmap01.exe
tmtests/tm20.exe
libblock ----
fstests/fsbdpart01.exe
On Wed, 22 Aug 2018 at 21:11, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> I will send the attachment offlist as it's too big for the list.
> On Wed, 22 Aug 2018 at 21:07, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> The coverage for whole testsuite completed successfully,
>> I have attached the zip file here and also included the js and css files
>> in it.
>> coverage didn't complete for the following symbol-set libraries and was
>> returning,
>> covoar error 10
>> * libsapi.a
>> * libposix.a
>> * librfs.a
>> * libcsupport.a
>> * libdevnull.a
>> * libblock.a
>> On Wed, 22 Aug 2018 at 10:22, Chris Johns <chrisj at rtems.org> wrote:
>>> On 22/08/2018 14:41, Joel Sherrill wrote:
>>> > On Tue, Aug 21, 2018, 10:26 PM Chris Johns <chrisj at rtems.org
>>> > <mailto:chrisj at rtems.org>> wrote:
>>> >     On 22/08/2018 09:29, Joel Sherrill wrote:
>>> >     > On Tue, Aug 21, 2018, 4:05 PM Vijay Kumar Banerjee
>>> >     <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>
>>> >     > <mailto:vijaykumar9597 at gmail.com <mailto:
>>> vijaykumar9597 at gmail.com>>> wrote:
>>> >     >     On Wed, 22 Aug 2018 at 01:55, Joel Sherrill <joel at rtems.org
>>> >     <mailto:joel at rtems.org>
>>> >     >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>>> >     >         How long is covoar taking for the entire set?
>>> >     >     It works great. this is what `time` says
>>> >     >     real17m49.887s
>>> >     >     user14m25.620s
>>> >     >     sys0m37.847s
>>> >     > What speed and type of processor do you have?
>>> >     The program is single threaded so the preprocessing of each
>>> executable is
>>> >     sequential. Memory usage is reasonable so there is no swapping.
>>> >     Running covoar from the command line on a box with:
>>> >      hw.machine: amd64
>>> >      hw.model: Intel(R) Core(TM) i7-6900K CPU @ 3.20GHz
>>> >      hw.ncpu: 16
>>> >      hw.machine_arch: amd64
>>> >     plus 32G of memory has a time of:
>>> >           366.32 real       324.97 user        41.33 sys
>>> >     The approximate time break down is:
>>> >      ELF/DWARF loading  : 110s (1m50s)
>>> >      Objdump            : 176s (2m56s)
>>> >      Processing         :  80s (1m20s)
>>> > I don't mind this execution time for the near future. It is far from
>>> obscene
>>> > after building and running 600 tests.
>>> Yeah, there are other things we need to do first.
>>> >     The DWARF loading is not optimised and I load all source line to
>>> address maps
>>> >     and all functions rather that selectively scanning for specific
>>> names at the
>>> >     DWARF level. It is not clear to me scanning would be better or
>>> faster.
>>> > I doubt it is worth the effort. There should be few symbols in an exe
>>> we don't
>>> > care about. Especially once we start to worry about libc and libm.
>>> Yeah, this is what I thought at the start.
>>> >     My hope
>>> >     is moving to Capstone would help lower or remove the objdump
>>> overhead. Then
>>> >     there is threading for the loading.
>>> >     > I don't recall it taking near this long in the past. I used to
>>> run it as
>>> >     part of
>>> >     > development.
>>> >     The objdump processing is simpler than before so I suspect the
>>> time would have
>>> >     been at least 4 minutes.
>>> >     > But we may have more tests and the code has changed.
>>> >     I think having more tests is the dominant factor.
>>> >     > Reading dwarf
>>> >     > with the file open/closes, etc just may be more expensive than
>>> parsing the
>>> >     text
>>> >     > files.
>>> >     The reading DWARF is a cost and at the moment it is not optimised
>>> but it is only
>>> >     a cost because we still parse the objdump data. I think opening
>>> and closing
>>> >     files is not a factor.
>>> >     The parsing the objdump is the largest component of time. Maybe
>>> using Capstone
>>> >     with the ELF files will help.
>>> >     > But it is more accurate and lays the groundwork.for more types
>>> of analysis.
>>> >     Yes and think this is important.
>>> > +1
>>> >     > Eventually we will have to profile this code. Whatever is costly
>>> is done for
>>> >     > each exe so there is a multiplier.
>>> >     > I suspect this code would parallelize reading info from the exes
>>> fairly well.
>>> >     Agreed.
>>> > Might be a good case for C++11 threads if one of the thread container
>>> classes is
>>> > a nice pool.
>>> Good idea. I think we need to look at some of the global object pointers
>>> before
>>> we head down this path.
>>> > And we might have some locking to account for in core data structures.
>>> Are STL
>>> > container instances thread safe?
>>> We need to manage all locking.
>>> > But an addition after feature stable relative to old output plus
>>> Capstone.
>>> Agreed.
>>> >     > Merging the info and generating the reports not well due to data
>>> contention.
>>> >     Yes.
>>> >     > But optimizing too early and the wrong way is not smart.
>>> >     Yes. We need Capstone to be added before this can happen.
>>> > +1
>>> > I would also like to see gcov support but that will not be a factor in
>>> the
>>> > performance we have. It will add reading a lot more files (gcno) and
>>> writing a
>>> > lot of gcda at the end. Again more important to be right than fast at
>>> first. And
>>> > completely an addition.
>>> Agreed.
>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180831/f5278833/attachment-0002.html>
