psxhdrs :Add POSIX API support to <utime.h>
Shashvat Jain
shashvatjain2002 at gmail.com
Sun Dec 2 17:46:20 UTC 2018
here is the updated patch attached
On Sun, Dec 2, 2018 at 8:28 PM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Hello ,
> I just added the test for utime.h header files
> the patch for the change has been attached here,
> Thank you
> Regards
> From 48d40d771c684af848a26efb1fff8a8d6e110c95 Mon Sep 17 00:00:00 2001
> From: Shashvat Jain <shashvatjain2002 at gmail.com>
> Date: Sat, 1 Dec 2018 12:57:44 -0500
> Subject: [PATCH] psxhdrs : Add POSIX API Signature Compliance Tests for
> utime.h (GCI 2018)
> testsuites/psxtests/Makefile.am | 1 +
> 1 file changed, 1 insertion(+)
> diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> index 553b259..8c527a8 100644
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -1069,6 +1069,7 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
> psxhdrs/unistd/setsid.c psxhdrs/unistd/setuid.c \
> psxhdrs/unistd/sleep.c psxhdrs/unistd/sync.c psxhdrs/unistd/ualarm.c \
> psxhdrs/unistd/usleep.c psxhdrs/sys/mman/mlockall.c \
> + psxhdrs/utime/utime.c \
> psxhdrs/sys/mman/mlock.c psxhdrs/sys/mman/mmap.c \
> psxhdrs/sys/mman/mprotect.c psxhdrs/sys/mman/msync.c \
> psxhdrs/sys/mman/munlockall.c psxhdrs/sys/mman/munlock.c \
> 1.8.3.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181202/71aa0cbd/attachment.html>
Name: 0001-psxhdrs-Add-POSIX-API-Signature-Compliance-Tests-for (1).patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181202/71aa0cbd/attachment.obj>
