[PATCH] eng/vc-authors: Convert wiki page to Rest
Marçal Comajoan Cara mcomajoancara at gmail.com
Mon Dec 3 05:46:52 UTC 2018
Converted https://devel.rtems.org/wiki/Developer/Git/Committers
to Rest, and TBDs and wiki TODOs into comments. Also changed http
links to https (the ones that are possible), corrected some typos,
created a folder for eng images and added some formatting.
This work was part of GCI 2018.
 eng/vc-authors.rst              | 351 +++++++++++++++++++++++++++++++-
 images/eng/Git-personalrepo.png | Bin 0 -> 24895 bytes
 2 files changed, 349 insertions(+), 2 deletions(-)
 create mode 100644 images/eng/Git-personalrepo.png
diff --git a/eng/vc-authors.rst b/eng/vc-authors.rst
index 68f28e3..dacb205 100644
--- a/eng/vc-authors.rst
+++ b/eng/vc-authors.rst
@@ -7,5 +7,352 @@
 Software Development (Git Writers)
-TBD - Convert https://devel.rtems.org/wiki/Developer/Git/Committers
-TBD - and insert here.
+.. COMMENT: TBD - Convert https://devel.rtems.org/wiki/Developer/Git/Committers
+.. COMMENT: TBD - and insert here.
+.. COMMENT: TBD - Some guidelines for anyone who wishes to contribute to
+.. COMMENT: TBD - rtems... Patches? Pull Requests?...
+ The preferred workflow for making changes to RTEMS is to push patches to a
+ committer's personal repository in public view and then merge changes from
+ there. For working on enhancements or bug fixes committers are encouraged to
+ push to branches on their personal repositories and to merge into the main
+ RTEMS repository from their personal repository. Personal branches should
+ not be pushed to the RTEMS repository.
+SSH Access
+Currently all committer's should have an ssh account on the main git server,
+dispatch.rtems.org. If you have been granted commit access and do have an
+account on dispatch.rtems.org one should be requested on the devel@… list.
+SSH access for git uses key logins instead of passwords. The key should be at
+least 1024bits in length.
+The public repositories can by cloned with
+.. code-block:: shell
+  git clone ssh://user@dispatch.rtems.org/data/git/rtems.git
+Or replace `rtems.git` with another repo to clone another one.
+Personal Repository
+Personal repositories keep the clutter away from the master repository. A
+user with a personal repository can make commits, create and delete branches,
+plus more without interfering with the master repository. Commits to the
+master repository generate email to the vc@… list and development type commits
+by a developer would only add noise and lessen the effectiveness of the commit
+list
+A committer should maintain a personal clone of the RTEMS repository through
+which all changes merged into the RTEMS head are sent. The personal repository
+is also a good place for committers to push branches that contain works in
+progress. The following instructions show how to setup a personal repositor
+that by default causes commits to go to your private local repository and
+pushes to go to your publicly visible personal repository. The RTEMS head is
+configured as a remote repository named 'upstream' to which you can push
+changes that have been approved for merging into RTEMS.
+Branches aren't automatically pushed until you tell git to do the initial push
+after which the branch is pushed automatically. In order to keep code private
+just put it on a branch in your local clone and do not push the branch.
+Create a personal repository
+Set up the server side repository. In the following substitute user with your
+username.
+  # ssh git.rtems.org
+  [user at git ~]$ ln -s /data/git/user git
+  [user at git ~]$ ls -l
+  lrwxrwxrwx 1 user rtems 16 Feb  1 11:52 git -> /data/git/user
+  [user at git ~]$ cd git
+  [user at git git]$ git clone --mirror /data/git/rtems.git
+Provide a description for the repository, for example "Clone of master
+repository."
+  [user at git git]$ echo "Clone of master repository." > rtems.git/description
+  [user at git git]$ logout
+Clone the repository on your local machine
+  # git clone ssh://user@dispatch.rtems.org/home/user/git/rtems.git
+  # cd rtems
+Add the RTEMS repository as a remote repository and get the remote tags
+and branches
+  # git remote add upstream ssh://user@dispatch.rtems.org/data/git/rtems.git
+  # git fetch upstream
+After a little while you should be able to see your personal repo
+at https://git.rtems.org/@USER@/rtems.git/ and you can create other
+repositories in your git directory that will propagate
+to https://git.rtems.org/@USER@/ if you need. For example, `joel`'s personal
+repos appear at https://git.rtems.org/joel/.
+.. image:: ../images/eng/Git-personalrepo.png
+Check your setup
+  git remote show origin
+Should print something similar to
+ * remote origin
+   Fetch URL: ssh://user@dispatch.rtems.org/home/user/git/rtems.git
+   Push  URL: ssh://user@dispatch.rtems.org/home/user/git/rtems.git
+   HEAD branch: master
+   Remote branches:
+     4.10   tracked
+     4.8    tracked
+     4.9    tracked
+     master tracked
+   Local branch configured for 'git pull':
+     master merges with remote master
+   Local ref configured for 'git push':
+     master pushes to master (up to date)
+Push commits to personal repo master from local master
+  # git push
+Push a branch onto personal repo
+  # git push origin branchname
+Update from upstream master (RTEMS head)
+ When you have committed changes on a branch that is private (hasn't been
+ pushed to your personal repo) then you can use rebase to obtain a linear
+ history and avoid merge commit messages.
+  # git checkout new_features
+  # git pull --rebase upstream master
+If you cannot do a fast-forward merge then you could use the ``--no-commit``
+flag to prevent merge from issuing an automatic merge commit message.
+When you have committed changes on a branch that is public/shared with another
+developer you should not rebase that branch.
+GIT Push Configuration
+People with write access to the main repository should make sure that they
+push the right branch with the git push command. The above setup ensures
+that git push will not touch the main repository, which is identified as
+upstream, unless you specify the upstream (by ``git push upstream master``).
+Lets suppose we have a test branch intended for integration into the master
+branch of the main repository.
+  # git branch
+    master
+   *  test
+There are two options for pushing with the branch. First,
+  # git push origin test
+Will push the test branch to the personal repository. To delete the remote
+branch
+  # git push origin :test
+You'll still need to delete your local branch if you are done with it.
+If you are going to work exclusively with one branch for a while, you might
+want to configure git to automatically push that branch when you use git push.
+By default git push will use the local master branch, but you can use the
+`test` branch as the source of your changes:
+  # git config remote.origin.push test:master
+Now git push will merge into your master branch on your personal repository.
+You can also setup a remote branch:
+  # git config remote.origin.push test:test
+You can see what branch is configured for pushing with
+  # git remote show origin
+And reset to the default
+  # git config remote.origin.push master
+Pull a Developer's Repo
+The procedures for creating personal repositories ensure that every developer
+can post branches that anyone else can review. To pull a developer's personal
+repository into your local RTEMS git clone, just add a new remote repo:
+  # git remote add devname git://dispatch.rtems.org/devname/rtems.git
+  # git fetch devname
+  # git remote show devname
+  # git branch -a
+Replace devname with the developer's user name on git, which you can see by
+accessing https://git.rtems.org. Now you can switch to the branches
+for this developer.
+Use a tracking branch if the developer's branch is changing:
+  # git branch --track new_feature devname/new_feature
+Committing
+Ticket Updates
+Our trac instance supports updating a related ticket with the commit message.
+Any references to a ticket for example #1234 will insert the message into
+he ticket as an 'update'. No command is required.
+Closing a ticket can be done by prefixing the ticket number with any of the
+following commands:
+``close``, ``closed``, ``closes``, ``fix``, ``fixed``, or ``fixes``
+For example:
+``closes #1234``
+``This is a random update it closes #1234 and updates #5678``
+Commands
+When merging someone's work, whether your own or otherwise, we have some
+suggested procedures to follow.
+* Never work in the master branch. Checkout a new branch and apply
+  patches/commits to it.
+* Before pushing upstream:
+  - Update master by fetching from the server
+  - Rebase the working branch against the updated master
+  - Push the working branch to the server master
+The basic workflow looks like
+  # git checkout -b somebranch upstream/master
+  # patch .. git add/rm/etc
+  # git commit ...
+  # git push upstream somebranch:master
+If someone pushed since you updated the server rejects your push until you
+are up to date.
+For example a workflow where you will commit a series of patches from
+``../patches/am/`` directory:
+  # git checkout -b am
+  # git am ../patches/am*
+  # git push upstream am:master
+  # git checkout master
+  # git pull upstream master
+  # git log
+  # git branch -d am
+  # git push
+The git log stage will show your newly pushed patches if everything worked
+properly, and you can delete the am branch created. The git push at the end
+will push the changes up to your personal repository.
+Another way to do this which pushes directly to the upstream is shown here
+in an example which simply (and quickly) applies a patch to the branch:
+  git checkout -b rtems4.10 --track remotes/upstream/4.10
+  cat /tmp/sp.diff | patch
+  vi sparc.t
+  git add sparc.t
+  git commit -m "sparc.t: Correct for V8/V9"
+  git push upstream rtems4.10:4.10
+  git checkout master
+  git log
+  git branch -d rtems4.10
+Pushing Multiple Commits
+A push with more than one commit results in Trac missing them. Please use the
+following script to push a single commit at a time:
+  #! /bin/sh
+  commits=$(git log --format='%h' origin/master..HEAD | tail -r)
+  for c in $commits
+  do
+    cmd=$(echo $c | sed 's%\(.*\)%git push origin \1:master%')
+    echo $cmd
+  $cmd
+  done
+Ooops!
+So you pushed something upstream and broke the repository. First things first:
+stop what you're doing and notify devel at ... so that (1) you can get help and
+(2) no one pulls from the broken repo. For an extended outage also notify
+users at .... Now, breathe easy and let's figure out what happened. One thing
+that might work is to just `undo the push
+<https://stackoverflow.com/questions/1270514/undoing-a-git-push>`_. To get an
+idea of what you did, run ``git reflog``, which might be useful for getting
+assistance in undoing whatever badness was done.
diff --git a/images/eng/Git-personalrepo.png b/images/eng/Git-personalrepo.png
new file mode 100644
index 0000000000000000000000000000000000000000..751499a4fac6b4ea05a5ce226aec084c0c653196
GIT binary patch
literal 24895
zcmZsCWmH>Dv^MS*q(Gra at ZwP1OK_K9#ibN?cM2sGm*Q56lu(@FlHyK*;#w at l-R*|=
zuDjOv<6|wtIbmkb%$_}4p8cF?O?3r)oR>IANJ#ifiXd$yBor;g^*$B`;#0Tr%oy<p
z&Eu_-E*9b^5X%~ZxW{%?H1t5UpMCyCe#@Hei};e#Q_jFs$K}1JkA=Gpl8=uMmz}eN
zhn0n^4VR0%ZT6w~OC%&ZBqflHu5ZqMu1}8c^i5Pg`CM1mW#n at 4)e4A6mxxG9QwHYj
z7%h-?AFJfZRv691Y|j(T8_jGP-6yY8Bd0|~HCe29RL!wyFf?;@)!$qvCML$e`2K3_
zFfVG{#&$a=;84uR`DW#+4K7g#HQ;!m;-LUCMZQIS(wm-lUbL!tqW~(BI1W3zGy<D!
zl}Lamx|~oEtz1FYpCPK`Nv6(=lRZ1Qc<7?nFCYW1a3SILzoWGgH~>RN;A^1IAIoJB
zoFan@=(N`@iHiitICEvyw3CV%@Edda{p}a$*+(+17b at 3hC_LmDhYj?j8TppMA2F8%
zd$h$sj4y<z{KPt6sGWCHqk4qJf2|$XwleLz$Iw|8L at W5Ri19qz3?32)20^P6q}VhA
z1%%?D>(#p0XMo~PG*v-RJ*6fKeSSbpFUt2_f<~w6KkVefAr2dnwQq=^MtF{%i}Aab
za;d%RC_p|eMPvf#E(X93JqI<`Rq~0{0JF%#5)H}!^MG%DiC(#VL;j^sXiDg>42pa;
z^#C*b&<RE$ADSY{W%({Mzz!J?xesYMbQBh%djT2uw+iJCwKhjRu7Nt2uistuc~*F$
zt%q@}5gjvC^CiYj|GJ?mMQRTN!{E at CVKypEtZGv*f8dN5B?R5uZ{H`}7!#>X{U=DO
z^OrMt+2~!s@>`HRaz&U^-or+zI*?fq-Mq}><5@*Y_>R#IT0N?Jn5wxzwJI3*;~bI7
zjoZSjIpje24}Bu at +&pPpIt{Qs1Y#cF$(yli_YwLyYMYC-W(+?F%&$Ee8$Qy#NQ5w2
zw2TFy^1`G-K_ks;e at OvKSN>*&P!*K9Mcg_<OpCECFPJ-cnYf?>X(Oj`Pgg((w1D(2
z=ZFG35S8OtQUk;|R1?6nO<{)K1`p`ConJwNw|aF&Tw9|Ag!V#P#O7MS^;8FQ;=~@N
zoTwd|)8e+Y0he%MFz1O8H?i=jU#m9QBX=AV>40sPv;96N#^!<w5BxL6WPcKdTaBct
z`t&#mdjW6v4|*&dw|z{jyRQ$zb$uiKKp1+CB-jrBb0f5E`EzFcHWS9C{@@L>l=6y4
zA;+APXFL|yq}~(@0uKkh#2>-_y}imS^kUpQWX<-0Onv^SUGh#wAo!zHOOW`qdx&3r
zvl&L2N80R_>ZQ)33Z2wIhX at V`{X at XZlD)oFe}~X8<e7lUvNI-m-=KrK!}Q>p%zvo|
zmpa>qN7`%hYZ)2=>6Q@|)mCdw`Q95jR?B7&#B1~gU-B=2ZM&mA;*Qsg{rRXTW1?1}
z55c>RNVjNn2|@S!VyjGRHCnwj(<D!`32)cls?I{;b;9{xV*X#^PHyj~Ups=$jb-x{
zW=L#mnp6~GeWQIIE4#!Wwyn5Aqr$RzP%N;w<&V at dF@O1m=SDS)gq^(SL?$qAW79`Y
z2?YcB41&aYO^Ymgv at qA0V#&*eTt)g8&nqG4n37#RTy61wEzX$6;Q;e0$bfRieZ2%#
z6NU$gAqt1jj2c=C3LM!9<%sJ^*t9MoOeZ(t1#&)8G0b;lRLg#WtK^-9V4uny;T(S3
zmQH^aW?>lva2C1KW2F+M14Yj=!rj&!rLWG&4k-m9j&a}R*NWjwyAin?4dDD3wgq%=
zf!@-b(JY`GSq7(T at b)KLwv~1GV%VVV4Ydv!5?Ii<cl7(3C!lCpp)D4xFOws=5W1qf
zWJ5f=b7W1zfNKJ=-&ucAf8!6k%Q+H>gQ<4qa0l=ZN=NaSLa`}aMm>P1blb)wD0#j6
z{m3wzjG(hm5InF#wD9FmuMR6Sx~NkRH=*sUKbTVwh8tQC;3WAqiibLFHzePMC$G|O
z><;d*z_r~diF8ll5gYVb<gjgCC&qj4)1ro~ca4gNG3ynm%ws(PNBb&K=Lin2zmY99
z<#lb&Kc#``m5$W~53Qcn+Ts5mExmWFI(72(D{kBM>@yxAyDrr*WYk<sm3Xx#hQ(9#
z;_ghDd(j!E+C{m2S9h3X3%q at T6TEp@L(*kct)9m^B&Q-hPG5psUOaAF>i_Vf^He7f
zjl*jw{nqYGi97o=v~2piQY`m2<v!IffKL)h8>QY2s^8uLc0A&&I<pSVKi#2_DTbj-
z+5jX4A8=`1XpU2L^l%*ev2a#b;qFy}B{!*R7q7F4*Ti~|+8x}CA7<^YkX(~B3`vh^
z^N;j7HB$Bc;&m=VobzR&_BzxC92PKc-HY;;H)}m<;_Gcex?r=Dif_zga6$M%0(79x
zz3vvxsC*Zb!UZ*>^b}L~!XaO at l~<$NTwHqPyc>%xwDT{fzz=LoeY!)R$KdbKkgKV~
z&M+VQiOOEW_*sv{v&&5B3tg{Vy;vVWEE3TgC-@=Pr at 2o3#W6!HCfpN{N!*j#uj^$&
z){uwh`O9;VlR*1|!nGLs9>byPHOLys^U=MgW2G at 3I@aA|B-1Q3P8$&V?x%a;TsH+W
z69wV;1=Pqwx6A|o80|yCmEkH$LcI={{ARHlN~1G9D&trlLDJ}1b9PA&HrbhakKC7%
zs-NQBP03!!@xn(W!q2^&y;Pg#{@yXs|Hz^R2Yu?xT0$JOg+n^C5$4A${VE}*J;r0|
zyn1%;LQS0~C>M~V3rm6gsS+-i&n(9H?uNbZvtqi3CaE8#p1~y<3J<S;l3?a}Wp0po
z`Dhg9<S)O)sXbjtcVRjUGg%U__;hw927Ul4w$J8tKIEF)hqM(!`-7x(r%^-uXShE?
zUX3@;O~XA9pJ31!uBDZl2)>6C8xVF>&U}0)MZZ*1K9|87(`(Z3-QEssVQ24N0$H{4
zyUFXMsA#W$uL=Tn61 at mTL+Zc+rJqHUGAN*`NMH#L;E|=g(lU-Q5Ljigt}CfOZS^ab
z;H^g0?5|JqLRl75aS`O9tLE~3uSk>7Vc8j4CSmSQ7bpG_AW#dM-Kqx>=Fp!I#fMnc
z3t2B6Dm1Y}hj6$U4S7=b$3H6Gj}1M(-VaWlP!C at GDI1C(1iE8gPXr~464<`)Kr<E*
zqj!ItJb%EAm%zO at OV(p@|H-}Vg2<9qoc!<u^vDf6)k|b9ZgA>?*pZ^f=So#2zjiM)
z1O;w|GU4KtMgly=K88y#<I4Qoz7U;z#GCGDprGkPBV7GViRao}m-=}iJtHZ3{8pUt
z{KEeMYntJ=+pZAjM<L)O*~Z}OE;MG$Z$p>RXt*);4#)IYhDUUr?_<3<@UL0A1XH{x
zdhI+Wb%bKWG5|kJUjv7{mT%c-jZlw@!JHU9kRivRHrtUp=gHD{zVDBtb~e-Cw=q-r
zywigz0%ZJuZaibJvr$w5NuA$!4+K644)1vZOIjysv48S3H<SD>-sx$)2Z0`?Z(KwG
zDFM50Y;VFKs*|V2T6r6~Vfg{=gz^PHrl&=G#7)0z=>CKX=V<1}&~T5jWFRw6f0eIM
z_$m!f7v@#n;2{*y;X&acBT4a&gcw7i(+>oi!CcIGT2;_f`Tt_ADHusx7SjEw2A#dZ
zSLhy389ogl>5Zy=1XWlV%n8V+0e;dS-EPZIYbCyBYkbE!>IC(TP}5Bm{laW@*-NQ<
z{N}ixANChz<ih|zuSt*;dhn6%6?JL25}F~~Khd71q~d$AoIhC5+fs}r=QuaZ9!d8!
zF_1L{vp|<xhQnZ|Tv1AA(+?!yF}YO=4m0R$mp5}T_ZX)86Rg5HIxlgdZ;C at 6OaeH%
z7okweNPu=;>Gf3jkM&`Kp{ogWnO$`D^3Nn=tLB|DR^2H&EE$?F4N@?`7Z7Mi#EGM?
ze6!zE+Df5apxQzun|i|qe@>&oNeS9|#O$8=O^W!cTYbvU)`<dWx$XtcQ2V at +?tXX$
zjz+q5I3x#9WLmvs00!v63;&BqH+IH^MHF+nc{N~2b-8w2FR22M#!1P at TKqso?T}cX
zH18Fgv8j5NieICT;a}v6P?^0;8+_MoKE0U?+9Moy6OaJ~TFnwAS+9Lsc(d=z)gb1g
z(k?k(w8VZMdgMZBIo5sNz at a~_$!KvNpZO9{orc}S-KDyEZjRNkhp}SW_!b8Tuyf?a
zb!!i~Vmr#p**Y=?B&o3FD}NXC4URIO?Z)W-%=#=g<KOCJNt9!4I%KX9Jr@~NGeqV|
zDI!fMKw^3zdCY)<<PPTUD?la(a6DR(Nh8yvCJ2cijG;S*A_*X|I>lywSI3=TetKVz
z-a(p#3t}_`C4)8tRfEgLha^k{de5jps6Kj0R^>IvEoY6G$B9??6PfwW^vL2|z)2<0
zcFe#VGi2sZ4y=Sw)7`q;ii}kt`n4kHwco2;LFVXzJ>X=2V_Q~4J^MJN+dn0C*JeoU
zMS2!&2YTsgw!#JsapjB9mj*3F4~)xg4r<QnlYlm50L at Y`R0Z*^yzkUQv}5A;S*IQ~
zZ}qFQn#pKgSJaVKNRqUG#GJroxlQ#E4y>^CCFn=QiDdvzy-N5N(3E>H#pP`mk8A1y
z2Y+)88LFcSs3pyJP2&&RUBRIC*(I~!3iZf6s3<X3WTlhbOB>B4?@2RM&pnXYjlEis
zht9&u{eyy$7*b6=AN|MmFEyl`{B6xT7-8Nlnt991KJ(E4+`I?j?(y4Sd})n6o?zd`
zof~`_uRC98x7&5}?A1JSTihV0E+m at su14RlcGlmdO>+F#$gfMB_bs`ORkhrqAEXv@
zKkXczQIBWmI(0 at 4Mg-55$07gkTs8ybEZVYg at G327eH%RN1TJUC1LMPhaEgJ;x`)}e
z-7SlV`w-p}g;lXTgRn at +J-rMuZV2b9s8=42Hr%arY*sQ~>L}1Oe9-ubMt<qXH}UL1
zY at TI}>=nxXcXw>$BdLNNvmE1leyJ=Boan%ynX1=TH|A1K0b{*2_(25o&qr}YYZ at Qu
zj^oO`jWUVN&xCsIn*zSz2A)bXWB)}Pp*BKogQi-7hTrWPC%sI>&k%pR!NU-$%}Y}1
zKZhwEmRVle_kEWI=+5U#=!(NkIP-c0R1wnOqvm%x8~?JwWWC3C=_7W=A?SwMDegv8
zlq|*V9y7yywKBtM^POs_8(qRXf^B(m8WPZfSdJ8J-8ik at G>PP1Ar!Y~r1P3l-uSA}
zUGh6P12c31FG`AJLvFDW>flflOqbWgNZC$#);`4>Ue?uI^xnLm3CM at fVC`=aKd93N
z-LmR1gB5+d7y!mTeB*7-^}kIGiOx(~YtItgH`b?lk+hY8jKRQrqB0yh9@;6KkGel~
znv^~56jA|+?K6JPfqG}u-9BDbDs`JFaK2EHUGo$;?^A8m4jt5PGeKn;bYyKs^YA!~
zReF&T*R17SwuAoj)8ea`W(X>y-376LAa2f&qmMkMiQIpzzf>N!yy9IiXXv9^yWvDF
z&N?<(O>uNb+GcJd=YOSCQ5O|6z at GtlAEG^-Khuz_Ne^_(IGQEf2wTK-)Ja#E5DhzO
z=j}8>k*7P<&1cKswP?-5{w}3I%?q9;wEY38HQ*RU0c6HxUVCLjZzcWSWnslDuEv}Y
z$LUXNm<SH8N0M}(OE5D#H$YeZ)+%{*VWhp|NMjBoQC(RchbIB~a2W~;0&6W*ri$?2
z>n at Gz64*DsK?1txrtptkoyEh-DUiKlPm%8BV=fSW5780QhCI at PcI@0WLN$X*617el
zdCtc3E7F%Irg)wXh at Jtv8Rx|o#^tp at FV)Fg-Qfa1d=z`}DZY=I$gakKW5uy2R+ajI
zV}-g~HSLaty?`Ul-<FIyeMTgBr~yR?y4#QMp#5Mjfym>F2iG>UUw)#jnW9NKHAiLs
z-8`VS$dR at k0bw*xwl6_F$=EEX`lCwn$GRFgWQiCX(dEUnf9ZX`Ni#A>B>Vq;t-|^L
zG%x_z{MWQs8}~oqA at BmrGW2Jk{(M#Q2jw{q`ELmOu>a76=OKQ=5cc=~Gb{-aLYATo
zz>2U892GPtHaRwWTH()`Xx9|3i2Qu1ZpIQ at 0tmd$LnV at BtRdBrX1nptMa?*ajlt&z
zYCPbGXO833#l7%kiM9aoWhiQYkYnVGE<gv=d%idmO at 1-9_X0$$#9sJ8juZd_D3NM`
zh{I4KNwuYsBT3!D-{P>AKrEHn3M1Ysv$?0eRc0+gT;+^^W-UxaC9Tfl&_fkN<om;|
z!;>IDlAg3Ja7PY>1t1dwjQ$3W^q@<AQ4jSbsAmjkHS*6zO&WXRWRuDDC`d%X5s?8z
z+Q4PLdT^17RI%rwGLeedj&a4;hBN%=&%sn!S}}WpkW$+Fj}S)GWhHB#2|R{mf_mmK
zR$>Ta7^9_~0x%jxtZ{u^h8sprmrY`wsK#|enkb7rpF@}a*4r(IY_pbTt`geJ_0ADn
zCnqYBpuUJjDF=jx8eJ$+5zUf}Rv66^DXgu?nDn9tdA(tppr051%OXBehD%}4W9%b!
ze2OgK-N44X_&V&lGAN62LzCh2W>5AIC3*L_GrQ%eP)$OZ!xYz}S<<{2lR$5<rHdBR
zK4FcIGR1tePL!2Y$jMgWQkYjFz!mNz29J6y>Z)|p1DBO7aCl=`K3Nwk(tY+#hA>4k
z65Gk4{GN1DkqxyJ9jVhINExO-6_%%ojE9N#$rJD<5T`9xp8tM^l_ntw8P}V$9%RVl
zb=#>ZEF>utPAZnlr8LR>i3FN+_c~fh8B(ud1qk<%Q?EOje_OycPmu;$LM-1Xsg`mE
z*{QIICMpXhE71qGDLK30&Gou9)a8p`dPJB|Z!y%~NQ1AMoJ_6y5Q<m~pa&jA+n^xU
z`K|?^g4vQJPrg75Z}5tXa5Tph+22OG*=NeH*sT72qBma&lMjWQ(`B;NTcFf<0`uPZ
zC#tgmqrDef<fYjXksTR6qEa*Fw^Li?Ug%9zKW{6KJZK at Y>r1`O>lz!=65Tx;9QsJz
zbG at y)bn!=7!L$8;WyjJWZ6&zi0#8<hX8~%NXQOFJqGcPHrL7ITIIw=?ubbZDWF%~b
zkP7j8h at yjbQ#cw|i9`^kGP$;sdLxExm;`A}niI7p!~6(+R3y}Bzrk)48(^m(+L#E-
z^eiHjRbrTND$fG+!rsT%Bvn|~Wy#*lCG6-sXOlTUpWg^%Ah8-wI#K^tyz8!V3z>T5
zHyD?KrcG at gbskHUkM7SNr>QI;Fj at 7b5Xm^Bf^ad(Q3LqJ=P<R+x at afsy3exW#r+rW
z8b@(3pG|=ATM$rb8 at S$_?0s&7wfyfxq|RI+i~z^5Uyz_Kk0XyE;i{qlN(D?-d at TeR
z7x63*lHE}(T+}l}(MEG*%s-k}CSV`fWRoZ<UlJVVd>-*7g;LsJkB1l=VtODIs at aJF
zR`doPm}o;%uYawt!I@{|;(LJ?pdzw^rc5+0##~dpZzM|2?`+C=BVqpW)n6($kMUcZ
z&A?Z!PI|KcDVMZjZH@}@6>rYh^U?}3b+rg$bMz>~aU24-Dw>*Q>M+-yse^j>%RZh^
zPvBC+ATdxKDZef%H?WT at c*VFU^*PFwU>J0#8C)73#QU0$ALmq?io!m)F4n>H@$MYL
z<+E7iDg!c_$jkqoS5Db2J=w)f+rjjQ6lr*F)H|&@#_ap9WTP5X<9T(v*h<M~N`IZ@
zc~U#{#0997!@$-x at mtoX?4#2zOM-)(Lp?gL^?5(Z6d9fTab!j6Fc(_9jx|}D*6sao
zB9J7;Ol7g)Us#_e`ahSxS7EDO0O&+r|J>f4b<X~y2~lL%zQI0d{#=7s*iNP~n)Ws}
zV`0d4e;omi?lmZV?RgG`L5hVrask2Jik~JHKeNPqL~$6f<Xm+PHTwrJK{UFEE*d;2
zI%ViHII%t{B)U#Eas12g?G^>4 at m?&_e6|(Z3LwTTg8Mi?PQU9yvr__-DjRxQb$VRe
zKyYvwwAeYDRGIOu=wuRk#z2|p*Pn}*23 at HnumDGELc$&Tpg|{(-OtZLeU(T`sUViO
zZj3=<+rMZCmBHu at gw5{5qq3 at 2Tb<Nd6W=uF9xnX?`Olqrr`gve8K<4_wq9FU<<(6-
zALJJh$nWTRye)V6<n;!LH2F^_$_MXB>b$BX4;w^&%7GSsN6uyp__h#lJpZ at PZB0V3
zCTj7Gj+Fai&cc7okVPzGtgY`RNA`6R0>QWIab!-=@Qn*v`ZL#Zg;>E<oZpCb(-)02
z(VEnt9~<<`RT`~M%4#(Tk6DHcoQ$U#v1R_|)S{}QI8XqI4D51#|9zLYakPvenbGRs
zNN0w;3zeudHuh>#H+*EG-9Kuv<PX}jk+25>CX*!F#_=!~ng~@C2QgRH9U6G)mm*W^
z)9ubT?3gDfoZfM$#Y*Iu13bJEO#e2pO&6Q8h><1D18bE*G|=$_1CEP0NY6wHy78Pi
zx~__y(pygy><R38A~6N`0Xtmd9yU*_uaJle7X at M)Mv0p`GEFkSE6k(X-EHu_>l~r%
zinsP2quz4cXRuI}B`69&?;`c%ALxxv27T@(TccVT*F})PJ~AG9%Ppc<fdt6p0+Q^_
zV;ng#i!J7G0UO9ywK+kI$uu0+%-wc74FZQeCBqc8M`O%)hmI{hK5mOSB}#ZaxhJ06
z;6}BRD3FSN%P}$BoDhi?qn--(`_I>Umnq3jCxv>5`G;N2PbCD!PS%TwjkMmLz$`ao
zhTKgq#2g5mCACe_N6;S^LKmt3IeKs<A})TudEatE%uk_`y7<W;OB}m?&A3FF#jndr
zrwx$wp at k<M_n#F5GUtUl?K;IEH={`jV#mOL8W*qoVcene*{EHUZAq8zfE3{<gMhv2
zH$*!izR+Pty~kIA^P^&?XgZWL#u7DPUbit2&`3Vf?G3}GlP%3~(UaL7YBjr${=g#P
zyH817-ZZ31SKy1L#ci}gQ at K>=VcGa4XWA_YWJ%FgwIiFe*q|#1ZyLk1mxADDQq3jR
zeKXptkFir|jBxgZ97tOz(P#Ga&8M};b@$6kQOQ;nnVu`}%6XQ5kX*c>H0-Z?Jslkv
zYh!*F#wgEH`}o`6d+YFRng5!K?l7xA<7I)Bu|nZHxjN1Os>Rwyx58^s+<_w-CuNpk
zYJG#9qi}uLfyg5JbacXJTg6?X^}=<7^qTnGW-*7h+}9#sJR448A+cKN3Qvk{cow8n
zPJHt)$I%rd7pL?O*i`&NGw<#!Mj0_YGUj1%&e_Be`)F3c4r*+lXH*3y0_EaVpZ`Gj
zat;b at 4Vs}sD?-8qdwo1J6n7;~y(sU8AWA at Lh*NNDzrYL=h98K6M at f^c%|(CXe!v$;
ztw;UjS0QQyYP0(J8SG`3cqD~JfmV+;gFFnLKFVYOa)u&s2nX;*HKZO{9bLVD|Eemi
zv7I{+NPI9SF>v#N>^Kj)tzSdPjPfxoK7(sP)m*5$sq(EJNZoy(5^K|<<F4 at +a}sG%
zk~Ech6!efNX$GcSnu}&$2 at PHcn}z;`v1MF0Z^5*|5^HGl at ovycz3Kgy!2FjJ(JaE*
z^k3~O^|iSLS34*}0Z$aa8t*zU-W?^_J|*Sn-twm%y&D?{iT|N_nW80Sak)8fO+89?
zkx;h8clzRx(t|K}Lo|JQKEE at 6Z`-WDkTd4KVU_bM6`@98h6<*s5u2j1mfkCa-V5AH
z+ulbqB<iOvH^c at adOU`ZMantLaA7AfBN34Rx+m`9QFso%*ijEi!T8})-N)yDZ7xdN
z`Qjp1xj6!)%K91evQ9~ZbZ&vBS35Z*BKP|r^G~Y2Je}T2FkfYja5A`9SYAc<fOPTP
zIHtAp-rZ39g!l^0v)t42l{=gEB2J!o%efZK^*M50_9eB>ojQ{sUxTArTl1q at u<%pV
zCiynWJYRA at vqT?$x6AkH_NvR^-jSy<>(wM8b?sG at i~+2850*7&zOhU3(Xyged)Zez
z`IGry?PMwc1QW?I$^95M=pRC5N2oUEn&`(xLS_->Ow=39xs2u{$P0k#p+M%}oo=OQ
zrN1e!@{eaeH6l?g+r62nD4fsw`DNL!^`U`$n(wn#t~_sTx8nM at 4a0^2O0)gP at TG8L
z;%_7f1t$$HZcWoRHZpE71;t>gAGwPnl at t5`!a?eh-u<4GvgI!-=2DxZA8ziV?J0W)
z;u$EXZ18viywCGeSd=`yTO+=#N5|j?FAQmp&Q3dLZzL1|l|e=*2`ExmI)b!K6ux90
z8?Bhv?HWH7LeIj|!`O4jKOyJ)PVelW(X4gCY^HB9w#9sBIyFI)Jmk3_szmdVxn&}6
zavnFP)M<#09>N%|A93zs<K8McT2X{h`)CbA2kz{W&x-Us<F<E5DhSXB5j00^mg~k(
z->QSSj#=hFMN-E=*IL>;aj!$Y>3)<in1<Zwz62TDrA?ZkL-ahn<J5a`9;E9E2nXsm
z(h4A5MEFhtw9eBxsw*WZjwY^j(~*PrMp5q_Alj1DmZ;AyXC>VJvE-%))WZYaV4Ykn
zsXP80d2c<T;d`6?xp|MckmULpO1Sgo4{j)8a|}9MMEubGJmZf>LcLLi*$x;*`@OhG
zw8{x9nVY at b=S8XbgftDb4Q95J!Wn`OsOH at mee#2ak~kTj6 at D~IXo{gm!LXU`-tIKN
zDd^7u*4ynG)fsAIS%hB8>O at U4)L at RQ1;k at 7GrLYNmB0QOG7%b+v0(eU|8soJ_F5KS
zl~(?y<hjPqI6~#t+E(Da|8`^$NgBo9t4lH${+c^b1Kbh5*KRf?RV?+&Qp^?69TN9>
zYbkwv>wtaby>^1qzC>+0_hq0=|J;L6TgCrz0pib9cKW}^e>1rKR(yV^(us3dJmyK4
zY|Zsc4#4DOjRxoInf^B~`kT2Bzpiv-yCtQvT(^WZA?T5!^Y&Vw3=|Xfd=55EQ!?xP
z2{b~^-c*^Mzg{M3N&nI>-<uZwU7y?kOXZ14GyGe?^#i=4QRZLX?_9t1Q7c9JUfbIB
zNz2N>J!Jw~sgWrCAS~%2D>kyWUrH4z*PAaruyc59QDS^JDu4GC(sC3!S-*2O at I__6
ztXlh6E=h+FdZg&x*_Fq|Qu)n?cMPgHlF4soJP2Kz7fY_cz1H~S08 at ou*upSjfLNg|
z;2Qq-lh7jxm}6-iKw9uPTqBoEz;UX3E8c{XV&YWdH;FLDJ^H`HRMdMah8%I-e;#B>
zc^TP0wj=jbRmcv!B!W5dCln7D8z#*>5H+1pT4b>>!mw_bZ|s#L$FUFK2K897 at 8h{f
z=^@=3aV+LPfxw7l2FVxZZBFwr#Jw$HAHy_x6Oug_DyZn=lwQkO5FEt}X>ja{@>6p)
zVW~0o-3H?tSHWD37iS;8- at v@O!y0=5?fc5R=CLbCA6AJOiju%jDMm&QrtY1Mp at wo9
zWmTLymhtV#X>Qkt at IAKIoG2scK7Y4xMJmqh#Qnxn+8!Pj$<|q&MQ at n>nJ(UH^*sbo
zt9Wyk{dPu}gs~%!;K;-1iShXN#<Ol59p1c1 at Qy&|pDlPtQ~|WD?mlk4+4{#@dECed
zS(sLoN12Xl$UmUTW&ZSik-!y{8lD_pd*LFr<(-#v&!|t(oa{#hKiU2y#9rUI3wvFe
z>%&=96_RTuN2bHBhOlP(T!E1UHLtF>C_6Xdw7UKT92;p#jflA6BR at Q6kVR}{6k1$w
zeVIDHBzmehw&O?OVsiVU)JHPc0d6v!Gwm at n)9ya-rA>H4u7$-Dp7nM1c%1C%hkNHA
zh~)W~8NRm(d#Aqzjn%Z9QXYF+Y7az-5kBISDt(H(m=-Cffn&WcHy^P4I;+k<r*|h;
z1AaJl^xm^{Le)3;Ev#~b>%?RzVhG`l41&xBoPdkEr&#EP2p`wc^2nZS#NyU=EnHO@
z at WtgaST<^oK=nZEOFDO;NI~OI=Ga}~&r+(ls0g#r_VX{N_x65~kGl&Ol_%wn(^O`_
zj&aNQq55{sh^R}sj2&_juPO)#7KqSb`$}H`aTjNxLB1$}t{j2yQz1DC04;%+b(_Ar
z2!E`=1AHwjU`?sajq(Cn9}2BHI+Xy3d~^p~yaQKIA8U@~^Pt${@_ at nZV#QCaK=Qv3
zRe*>-coqNm7$=2=XZ95`9WVsdxeu#YC#)FOyW$;#04d3Bn;@!M;G at UPIvy09HR9=^
zGXfD4$WOQKarYT93`A|mCE(``)tcej%QZ~k=?^Fu!SAt~jKj`MXv at 6D4JQRM7|*y8
z>f-xF0>Q)4ns1%wVf0`t`%5Li_}1unw8N$8{fYpY<hW>FZ)$pJ^;vu_BZ%dAk3V=6
zAJ>JIopyf0laOnvzB)M+h4nS3<zZhlecf3O`M8CL-i<~TYky1v2^Hn=H(LoD7>Swq
zFVuWVO}k~OkO$ja#;d;#I?fv>9yGQqeSWFFB0*257iK8VSM8ifZhNhbr>7(7%?GKA
zO-CVD=;y>g?I%7vY at 6sX7r=VHE?xXJG3LF-LAb@{f+O^$yUqZ1EY{HUnYJDQ*{Z)k
zXl&gEVJdIA3vWrrXYWa$R*wDUKtPJI-^UWT;U4fZpGkxY6&nr3;ks-#e;NPsWz<MK
zCW=LJq}}S!261wX1<qfa8XVklxMcixLTNqo_83!vR|lGn{@nj at Qm1I2+w;{bO89Ea
zgT4M_aXfgqZYpo<(_bMpyRZJnQuqEV3&$^J$6C`EBDYrlb_PG_r<pXyHY7PUpZyVQ
zMl5IA?;ZY_()oK_eH1VKY<lL56z?=d5w~jAMp$SDF6*qdJb+nw%1~e*0a5M43MC#H
zZP(V#_vpU5FX+UbTvA{2mcm&`39Uz$uQopFKP2Y`62x8&Q6-r9#z-M=&H4TzY1K0U
z6_NLOU>w&shPp3s^r7AOSyn)IU$>3rhq|wK9(u2I>@pOHFZ$zMmtbs1p#cEI|Fpc+
zeEb44pG@=G!rN+{+i3A_WFmzbG^#HW|ImZ#zpwuI>QWg}7an at L-Gxk^JR=yV&AIhU
zgBEYDFTdlS1j%Hhb&~VzySRp at v8$tk4~A=gbb2%fJB`^J1{1s;^9}@^#GDqF>2(j4
zPbZfNadFsRCjU<7>PZtz$gaBnq);|%(Kq3|SBzEPBrknH2^E^@)RK|*d*1&q*jcN&
zH?0Nm?%bnQLw4k8mS)0qLcVrQgwd+krix^WTsj@&oW8V2-#9+$Htt-z#X%f~?4Z at -
z+uK=W5~*ocrEg4bIq(L`$7A-w9N0gd+{O?>KG98=3rp~UpBz}0xBkPYGoLtnO`+Sp
zu~ixM`wS^ly=jzH!rV}ogb%k%`T8UCM-DlS9r_<MNFBHVnWQ~^S$r>s at +6)%tHK$u
zBz#hnfW+U2kEy^9qSA(Ds?}0xQt?Z|eUpj=Ph7F%J|Q&Kj`N2$NcGOsS%^HvCcm?D
zD+q>`Ue#*z>MEf%zhf|HuUAq-^^27F;!<8+F2b(<OP?G+BA$K?{ZT$ilCm|N!DZDH
zvh*M>c3`;DdMfe4tTm%|mh1iF*4c at 13rYoU^`-e52TGnf!Yj85o9>6C{w!5*XQGb-
zehq$E84kioF=mUe)8Y{i5_Z#iuUVl0x!WKdeniTcsAx|KxU2A>dqP6&@05!nIA`YO
zjgca*a(zTd;2mM7*D3CqpWUd+Py5yEW~yzB*oSw`AxxSH{U2n1w^)w2HxYdotKv@`
zRi|}y++tScP-(&oS|%;@7O&x90c~#6U5Njh1W+VxxO`XO$tJM03=WS=kob3huy%G6
zsH(4zavTQv at e6IZGl8;KZ_#2RuXXgVIm0p1Q4+C4&`JQ-<#Ky|<;Pc6_)-mxWXm7m
z+8lZU2*-#c`qELu^rm1WPe}q1i_s$LS0n+dn+P}Z8=)R`edCrh*M|Fpi`@tx;Op^_
z-PU>WkT^%d;SANN73uY7zO?SHpn^`DUiExdPeO>_&uu#<cAtk2_HwJJ0XyfN&|L6&
z&xcndQU*4;-_tHq;{@`A0d}R(s9jrBWXSsuzAFvTzISh`M4Fh*+ov&yxZg>T1k^ri
zZpr*zrG4x$Dige);GZzwzT7 at w>f|}5+r!VC7Q+lbdH8#Tn)XWEK7RGQA<j3^#vz at C
z8A_K3+1<Wac=A<~25UeRnYU=r8?iq);Gc+R<tsNURK6BnHv^&X8J(l~qN&L5mg)R*
z_zuOCv&MLjW<scXwL&!VVF(p?N^q=6=4SSI49SKjulkm%|BDO(knLX``_9CJCmvox
zSL<&XCli{E^Rhd>7eTZ+ at eK}NJ#8T9e_GGZeZ0aqei*}~&o5}~n?s<!Xs_2g!m7D;
zA5;0d3<ntB_7!iEZQeMvEL>v*1f&o-RYoD=w6p2FD(Lje;nJz>S2YmTO3OLtGt80K
zCUNi4D|O at 9UusP=%-BfR=vY4;FXsIxzsZg at 8PaWR_EHZdm$+a6kKWI;=CVRS0wPA9
zZ_Fi*qT-}ihNRhWp&v_Q8li%12?q<rj%fBuWzBK*juVQgOGv=(Iv={<ab2w{90j)?
zr*{!Lz^<VUU56<6;W^+~U0 at bF$F(R=bGlbO>!Vu+MWqLCI5U0|L6b3vi-7q2kWk}O
z7xYkkWh<<95aUilysPXd1az}^>Z$mnEB?1f#4GCJ)YRVu`<KQ8bl1Hj3_Rfg5`e6-
zsxmA|@YTi;JnAAH*LJXyiDUj}#Jkn at FER(1ZaXlQX2;()2q2>u5i|Rp=CCw7%WPTv
z{c35oEkCv&%uK1kpK-EE39ee}9(m-a{Oyc{@QwV3H*Ue5R`%I{`nU^_P6tZAqLWJV
zilj<g;c;B`Jj(sVdAtiq$K0*FNPjG7 at pb11d#STDIA0GNfBOc3+0V(LM6({TYYVLn
zBVA0E{r%S_-{n7&vI+p>FMXxK5I#|&6&-$x9&lBSub|@ftI8u!QWv0jxr+ at t(vxdf
z51uK*&f`-3#b|m#8 at 6wIy6X=|TO44_u4L3VX}(1y;hL8VV(NqGyM3(q_EO)q$0!I<
z7x0lr at C%@2z!{q#RwjL-!4HE~H at BavDCaF0r|#6M=nC5udLw~!%LrtpdRck_RFA#O
zdEBqG!-9N#(BXp0tV*3D+T<+%33s0Qt2jpOUsh{Qzoruk9oq)$OciZMYYs$`fWn-$
zPdZyRDf-pgA+31?EWlb=@{u`<iKWZqR=87R0qP%n>YR!j{)6_%kJsXPQJ*{~{KioM
zj;*UAAsS>!19TT%1Ynb|P#@$FS4n%!>x7K+1i12~JP3vPq)4100K58|y!=Z+S;GRE
zpjTEuZMZY9$LS0)<H>2^zj-$_pOe5&uiMgdTSPQDZGSYA)Oh>Q7FoZBh*wa}PvUz8
z{FC!qe-#NK60u@%%&F~<cE7E^ZXMXD4&8_}yYPEGM32+xB-^dC?Bq6Ye!t!6d<$NR
zK88R2ot3fwOPN`%ftsL2dU~m-FK(fmNk94zANg7SA=3af4c2+jxroSy=nvgJha{*o
z*)y|d>Q*Y~@j^hr)|yh6dkqBdg446s at 2QYr@v>*h)3r7h69iHxNje!LW%T-Wmn5Dc
zo$+z!voh)-p*DBUNxbflL at g5#hUlF~TmFS4%$gK4g|&_tm>e<ahJLK)L|jm|E2Emn
z87h`r<{#KNMc&j>;xtPJ=45VsJEA{u?FhF;TJj&NAS<y){ztSJ7GiQ-RnP^?rhKq<
zolg9m*@pi2%Jv~|MM++0+(^9q?Tv=QQ|cqz0|LrG1m at Wa8TnpYk6*}oW)ItzZN6=e
z9r_6-aqe9@*6bWJ)0o(wf*$tk^W8QEh4d7A*VK-RR_;B|HP{2UPpsqqA&%WEd0iuT
z<<!x7P9FTvU|+R#Sogk<&0_Hni#lB1XnOOTjx8ISp;q;)07`~h8*9Ut5!_dSJ3e_m
zEvFL=2}9fMts(ah!Q<JP54P^^{?&^~k<@fj<_Q_)Xst$1=uIU2_=BZDcPeK2f2=%{
zYzh6=JXLW*gLlkN{D7Nu+h7T)k#1kzG>h8E*|d)t204tXg#)87eW=l<i4s^pdSD|%
zT;4})2RFDJN_I<)Ai%qF{#FO?0a+blA>y&oa<`2~_rAbnX+IjM>g$B$03?>-7D)YR
zUV}Wi4z#JI8hXnFtd#?Y>`Z%Ot~rgkm|`uxi>l(qO}T&b>RK7({L7jrp=-0(|K(f)
zm5G0pUxIO8gumzHkKVeB2^Wk5%Y~Zt60)}XZKg|_`C$Zl(S(SFsoBK4-chYszJJP;
zSsX-!?a3x8z7~DBBl}V*8a~0wsvx|S0JZmy=`~3ASFKNa${$^)Albg_IV{)qNBSJA
zjX4#D at 7P$`%ys*<Vt4pHA<`(;X>A(QQ`g9g&nhvQb at l|agq?X*8XZaOQO1L(LBk at Z
zfjQqI6`GHKnk(Hsoc*>X<V7HL@;)y|SI3{kq-aj8B$sd4vI$*E5Scy#AGdJbHShDJ
z?7rMT5Wm?<vDxcr+qOAG<fqRIx?boNZ(TQ>p)pqJZ;H>E-r(r-rW|g~UbP8qJo&Oc
z?V#(pAv}LgOJz3xeHXC9wWsC(Y4m!}UfV!>pi1(Q?5X)!D)#VAR*2cLi?gw>)%-{4
zKwWVc<5T(h#3ysggT1$9Y3@(!cQ;3JPc{f41iDURE}czC{E)29`qNORdL)$ljC+hN
z<$A`sJlom7?;1RK_O)Ll%Yag$G#<(7W8F(Vrst#<>jt$vhIMc&=kH-r>(?$%DgeXq
zL6vilHTW2{2Tofh^b5-{lmQ9_o+_+am>1TO#wcPZmO at v~S|vhvFtVcoI*pJ44AogM
z-}`*e?)~oH#lDr2CSmNMhQL~U606kcO#5P~ZK2o5!3Hsvp{1exVRd15piQH-cO$8s
z-Mqk3iYETwj3d)BU?I`WRWn#DPGJ6LHvSpZbjy;Mu$MGeUh8xkXPmQc??0sAS0WI=
zX^*Py%(HxYCgw;n`E-`ORYa7DJ+85Ksnw`IukL2YOWx_tTV-}Cim>Ch{+&ByL$r7I
zyoV2FHbHlYm}MvTPqx-81zzaJcjc{TeC8_3hd*TMUfJgA;Ybn at EmqR_3n0Ko8x#6w
z^q*(7<f)`Q+h$fxR_Cw8h5yQYD#o`mSg2OMaL09LS1SqpH%HGEu)(*jnlD at 0q<+8p
z{i$5 at 5dk&aOx)Af9NFU2DwAr@)Mkp?^YJj&Tc2q(cnC_oG~3 at R-!t7>T7kQ7C9*er
z&;86<g$H)bU*RJjjELQmGawYCTS-g_Xrs+~`lfe>0?)w0-)KVq%01zZrbAp(&a<|T
zx|>&z9rs5ZO at YWnfw~TLHr%Ua_6FW?^aCMRaXuESZ62z)%zh_{W0CiV&2brA+}}-%
zN8ZFX?ggqA)Utrz1`+&tka+L=7)L?BjvZg+nxr|sk%1j&ixkpR1Q6~u6sP_byAseq
zbAaE|nh_+3!w($y2|VO8PlE;<OnpKWP8bS8KJSd}OZSR{sd(0Z_*+eVbaBXo#CB0*
zmYN5rY-QNF=3UMo#<w_EVR+l92pK8?mSuz9bhKUCq#YU!8A^;<BB~<@5Z-)njOqEv
zh9{#uUXHH%-rY5ptMY2<8ui5L+y3q}2~j@^6#ckBXzA2vgy?BB6S+2AuV0cxlna~V
zvf4>mii&r8^^6rG%(LU*LRXg>F8hcXd=!!0HaY+DdQPf5WA_yO7d;X6Al-kLVp at UW
z*dEMCzfuhRStp2Tp4Qz=4IWUsr=s`^mXZ8fu9&On659O&<`IZD!r1Kk45cMBhNyOS
zp0iVxk&~14uP_Ao`JA=>5Us`uW#d-+Y7>(deASPr43r{lgZDPt*!D>exyJEsi~gVl
z;QICfktb#%z(Ro#y|QrQR8>hm{N&-nj=`;0X?007x;Q&nKBQaFX8n`LnJd5h{eHXE
z5(yoDH8%FuFRd}zs~yeB(p7}PPd7(~2$XjgzcW7Rl{_)+tMS_9VS`!^?2yOX at q6>?
z%xRX55Arar at X@rm&E($IWkCia?Q{||kiVwnkbO0 at 5;q!b0U<#ZMB-28AeqB;^aywh
zvb{}}%$SHc$<PuP1OJ4IYfL+t at z6BVX9Vgw?21;X<2Qx?nE3;df49)1I?6GAnYzxY
zGs*V;Ml3~nLGoTBPpxkPPy2~NIIO4``}n1U!8n`DWXKz=Nz)SEJP|y+aqFn*VjW|a
z=jvc}QKA6mY${U$9wv?G8U3 at VG&^|sJTb24Vy;wIfaRMR*<#Wyc-m2kjeg|$xJ at L!
z=l!kUjVbsqhs8%|9!wRVM3~cMc|qU2weAgTeCQd7wCck at fHKryQ*=N|1op9L;=8<^
z(Mu6TtyU)Zpdl3HH=YTd$(D}4o6N at EA9h=fl{}n5f$qqr at 4}U|!4l@$-Ue;g5f%Gu
z{*9wp^1rRafqY6JjN6;GNXU}<4OWFh?jd(fu{>meNxiz|2=2sFV^}IeI~_<J$T~M}
z71*Os3O1Rx#KyjX>ECPcdxb5Qq}Iex`Er|c38|3X|0|;XGP(s<Luj38^D)^%quqG)
zI*EAgIe`2Ju8y}`Y_9k>C?%pe7Yh~Ff?E&^SN3eGFGOYPA6XB<)9(m8>go*ayANQ)
zz*F>NiTAL#+^TqawuPm$;0p$!SPu+_5p&6Wo|Io-M=hLdt~IgRdilKFiWf_Kzd at rI
z<(xNlOs$P0L9J=_$A3~weeH*I0z39R8s57U7c_--umy><pY7PJ?>6Q?2y#f+R3<9%
z(w>?ve+%(kOoe_|205Xh at -TD+db}aCAQqLRAmFl9`DP=*Y}038d%}!)9SLm#G?{&Z
z(xe$=4z_Zv-zy{E;}6aJs2Ev&laDBAf%O~Sa4CoR{di9W7g;{Hh<v|msq`fvdIMV>
zC;LX53cZ~0$1}*8vwXI%Y_sUm;4#&eeeL=#t{+K2Exv%m9MD?U=~wzz at k`j2dVJBZ
zjL_XTs;(y(<|$+vX_{+j{e<0U{f*t5pNtZ)m$<PToMnN7?k^wwB9%Pd7GJ24d?Pi0
zF$=mk(9Eu#oj1jLCI$$9Y~5LHLLH^by8iBqu;L6APA?I~_WgnRU$?S*^C^v(#eYdA
zqnH%JW^ZC&sk#UJ*7GWx`X?S!+)S^;_nB+N;&srTI7hc7GC$?Cv0m**+=~doYoz!E
zx*d0R*`|c4 at 1)}&YW{r2!!aC)+TUL9BeimRrdh~7vnX=?M$FOTgee=C at CFJaZUTqY
zOUmsB;0`}D80E$a#X>fW{pSs2RC4E3X=3~$+wbST_yPAqpZOJ>L`j04Tlma;d0e1Y
zr-WiaZM1P3PlALox%%>qfQ)4kd9Ghv86HDJjT(WKTduY_+ub}YrA6au4Z)xI^-QrK
zP{eGGIb7<>^!&LTkY?|Oavd7CzZEP|Pz5%W8bQ?CMNi+b at PGMR)Pxv5$u)!cMNKkZ
z<&<$nx_A`+GXqfNRnmtYc~KAHY at L7R?b>N{ff_U_HxVYr<xn+yNO92s<HDIRoUchw
zXYySZCJu)c?VfM$!@V&$rrek%_L*pbjSK`9xzn07h1Z<3jCng5v<ZWFRSf!r-#dJg
zJZccRh=la~&Xk&pQOZ%a&4#aPhmBJIb<nHH&))$&^f`IF{cjprfFz2^8?sl;p@>md
zK9{{$!|3I(d4=g0_ECJ=z$)MVGo)xLvj5*N${gkNK5>&+CbYnDKpKMWbT3oq`E_wS
zg7}%Z;a{Mt>SZo!wWAPDrZbAekT)Z`zB4{5Cw`;NT+-r!QEJFLy+7B3=$NG%TxEFM
zu(<sP^O+ub0fE#r=bELA;q^_XgV;;5-fXSg5n$e^c#vsyKomuD+j~;us2vv^H?dZ0
zKXr>2MqRu at 5J~={4808H<NdM?DPu%*BgJG}_n2`H6|p|nXV1H50Pc9Yx7_^5u=jVQ
z%XcwU)0-mKp!ttQMWmqmkbJ3Hh#B-xBOJfOsb~|`LAb}cA+eX8dee?Q4;r<R>7Q|#
zGlJwlkvk)3VavdTYtYSgSre`LSQK?((x_&y_`d`%V6oKBk~)y#pB(KiKqCUd-3oWd
zGmvF&oqJ25GT*NQZCP}xd&v$2BG`k2#u_*uDWqLm05<60j1<{s*P(3_f>Z8injnYJ
zGm{h>mC*<zWypz<Kgaa^E4Q1VpKXRKwZX83cXcLpnn;&jDT3Z504hRv%aP-oO&O8K
zm`rg7&Bq_{&=VSr(p=Uhb+?Vn<T=?lkJ<nCnnniw1YfGIGecy`KUrFT5*3xk3j6mt
zNF59 at 2ae3y-1EbZ(|x=mt~$~nBcgHZ<ZA$1e8H}A1eq at W2*4aaU~ZVX_8NkEFAJ_)
z5 at gT$Z;Dn$KV#{>&`zcOVoZ|PnA}lhUpyeUR7VP6HK)28_>1HhI2 at ceX}SDNy?X_)
zQv$-1U_TLLoXeugl*@Vr$3`>AAgZ?;0!5+AU*0^$zVnj@^Dhf>8b2$v9V0|hoHv#!
ztgOD6rN*;>-_DaE39Yfh!I~PQ!3`3G=p(U-SS3e6VwLVQ!^98;vCWJ;(FSA8X<R)M
zVTTA!r7&uBGGQo06P9LsH?P5rDcog>V3^`<qdFYWMekZXQz{h!0OZ at GF28!4H*TK5
zXixuSby0v|$<SA#IThr^ITeDt0V^Se>r{>v{pnZE*|ud=Kw=s8PbppKJ$w)Y(IjQj
zWu at X*maRyy;!(r~tyt~`t+ at U6854X&x-9qXpc2n&t%e1N_Gkmc0UCsbN(@=P+6dYw
zi1>pH^_ylY6}CiNYn`{uhSb|w=$r20?VBeOna_)=NH6nS^DQ3(#z*%|d{JDONCpu@
zim7TCk(`zqYH3)zVsnN|LS?N}MggA(fCzS_g#aZ7%s=z(f21)I1rRWF3^bAL`-wzG
zs!)kB3xr^teiB{)DDa&y($#w{T1v4p4+unQ^9|Cch+m>GQPU?M<j|!6XHrISKF{Oq
z{}jTB5dxkPt~o6b%e+I3LWp3 at W+7;dbZG_)DbmDFilNo2Xhz|1i?2;x-EZkds9Ca6
z2sB~#wFan;`qOynoX)2a#Sr2oMLG;k at Mwh%l~b6WblA~UDFkGto<t0m(AE#&OzVsF
zko08u)X~G2gXKSom?h*JQ&K&GI1EbVOsWTd)&l|lav(^_a%gWEiT-jVQJm;R>}a#U
z4lq%sM<441+Om}-5+ex8sc+#f047pRX`24Q!VI;|+Hev_3~%IKm<o&#{1X-zWNSwa
zQG9)z3N?LMq%QtD*B1lOtpxfVJ;O+(^e!JkRZgov6(I!Xp3&7#iV%eXq{zmRSqtYx
zFmc#(Fnd#Vg)x=ciZV!Y==%K(3>03lvsqA8Yk*bu{H_eci7J7+7;CgJ064DPhAJk^
z4aN_>waTwuMeanKDcfBW&2p%D!wxDE*rqRytIL?Jcy*-5PHd+&<My3ZBsEc%S0sln
zW at FQQQjf+f%?dWLfJG0WL{`<CUX9$nGt8m^o?=yNg3}|vOMJbjW|bn35Ui(<W=;N}
zB+jWQ4ME3YWlAS at X9dPsS?hpkO#3_GKcO!oyW~~6&1E$ZuNK6)insRjS}iR#*fc|o
zxquR2ukvTMAt4|d6$AQtejnxkxB$EDU+s0`u6{8Da*SqdXW1~&3S-RyuwSTbz#Cyz
z%Yt3R4NG|98x4T85~Vs)E$HocXi3>FTB8$!!0y$Z>A%hZXdXb2^8Q9bK*+XG!73#;
zPJ9JKO9XG;?kkiVnOqoEnd1eaJ}P&UQ$+EOHXE}ts1J1`Ocr{p4^ToaLADC*fEk&y
z9fx;nAsD#0_alCH+~DOcmu?^*GRbxBSEvRizczxSjvG1^Mh}x;Qz?B|K>L=5or6rR
zJKc$1HjA2pjE9C{UOTam+JUrEosww8VbR+S3mUVu+lDCOu34 at bBc}Vt<Q_du11T8Q
zktoS0v{zcc>QpCmFEj?U=`O{FvL1SuJ4<Wv33#`mx~32Fk(LH90oh<rJnMstpUT6^
zLDq=446i;o(dmiU08^J(Yi#f;1a`#3z#Z63L=yG4YQ(apDHQ5Vlw=8@`~h`XZs=bZ
zB}X{}|D1D@<xopEU-na?K%U09=9TY>Ma}aZ8b^Kcr_?P2kLn54-?Hr;3u-A!9gm2m
zI=UnvNi%`(9`hJYo-qh at 2`d&w9w{Ap+)ADW at uI}>y4ISrEmljh-<j;1nKPAz-2xg3
zZCS>ILur{_#^60aU_SPQCXPJGL-*przn1&uKh#+8^p<IU2pf<+>_$2yR{u34OAI6y
zJ$SP%=w(wki%WkaEF`zb at kI<%tmd at U|CDsy at oc@{pQt@!Z=c4jwy3oBXce{9o;BN;
zty$3$;#1TrAEQWX)ZWA_Vx$yB%%U+;QM)4cUcdPM{=Mhk^E%IS&U4=HbDn#j3)<!N
zy}Rv`F;v?e8IwgB`l{rlc0%5QGF^R{v?ZwWF7^Z9=UvNO%ntA=S?ON at TKKnyNB3eT
zq9+IdrP2$voHh7Ma(tLyHKVJhNIxkqs{L+nTYde2ybmj9H5oZO8`ZtPvU8rrulKIp
z>s@!i at VubW_M2?qR?7E^K3AS4DM)MHyUZ>w%6Eqt#N#hG#Sfx-OlxkinNXs0{#jPe
z>by5h({T#2=KQniP!kgAWQV)wXHE85V>GA7#gE)=i4c~2<+IhXSXnx(o)|9J%KoU9
zJ|D~R;hu|@=%IB1P~RoKH`>G`^*o{XI{+A7tCfI at w64`E$UpH&$i&VLaw_YXJkng(
z8c^$0AGSXt66R2YO<?HJSy=nZgQH;>5fdOyAcEb7vs`EUhP7<xY|M{v93Ga-aiwJr
zVJ__+T1jVeCTbq~a~FfMHC*!_zZ$Xe`?Tlx6%i%blLvf7eWMYLN!c+C4B%Os%vEA8
zNy$vKzn1xy(r>%alS=zMGd&owbR#oC*+Q>Id*we%d+zF)8)t0EIw_Y4^5p7C+3^jT
z0W=r3TDF=kpz<dI7YU~#8=~m6{LQ_%Ba at YjjdbHpyNiLgsggB6GXu3#;8S;)T_^3K
zI0)Esrr;zDw!0l9HQtsIzDOiqIuq;*H%lvAPa<A8C`;Ic6NrO!e5t6Z6%pgJiML$y
zOpq2s)qqN4ruwq!xQT!IH<4^9CF&l8OHC23iT<{i+|j2Ry7UzlF-qbHbZzt!@qO3R
z(*oJwR_+{<7BS}x*e?z|T_g3q&t>ahN4Tbz{F)jI_j+TWQb~=N1{yXP17k%HWB9w^
zSun{a6-*@;(s{~P0W?%*4}8Fky>Xm at cnNTVWMc?qqz<>WUTT>j<cqa4Z^pABLV4GV
zN8k-t2$y)xuaaf=TcZNOzcEcsU)m9ydYPRy^m&sNw`wBh(+PZdBQR<LbIPIpP_F(X
zhM)ruDW^@k1sd9*!Z%l at YItx&n?g=yl2=TtV?JqQw)y?zEZEKyIS659QwlUDX9_y%
z;n@;kY|By+qzZir*-JUHC$ndoGfg_ at 1e~!DFGCnJ5lb>m)_ljj3g2;VQ?8B&DGlxd
zROj!uFS7Kxhn*7<Lq>^jxR9=90%n?@tYmFYEzFG*rK%zkugR%e&QfawlAB5h%PP<-
zWnZ%Ge~<~IyWrSSTkt5(QF^DN2rU)qXd9IWU<l?_7{ZN+ChY7pIKOIbDC_sS@;h3M
zP>l$Iw?wv_7XyySXIn$cIP>IFV9#I6-hq10!OBrrWD27FC;A%k*f_LR<klj#@+eM6
zO*G at JrCfb6x0%uIVu^d4Q0({dXR#OpNJAWRGzY7n at M`CkrK?0#(cHQ7AZoy$=v7qg
z{l+$N at sNtsT}mu@;NyOF%Q!Bn25jvw%|qdR2kA3DBQc);_pi0X<HzsEpht>^CJ#l=
zJa+(+ibN~PFPf5eyUGMdNRSRG;&l0`RK5W8Tx_aIZx|Mix10%}nTIOvNRqKcu|R2H
ztcF%vOoLViV713cgLfEnNZ#v_9~`TDeN~ZoDTu^isJ;(t at e<g(Mma!Z&tKnhq_C#2
zULtNi=_e^fAZ)CzPty?Nue7p-BVID|uMs^B(@H%#OhBNQQ3wH=N&>OKbrp2r27yv^
zr;M#><&Q0^06psGE}XmAjhDsjGWhS+8%ESvJk%8|B at vn?B5Ricohi?7u}8@%tA`9p
z(RgvonFyX9JS!C>WtxLHAXjQRi^R6Xz~dx<K=|zla0(D9+Bpn5w~JlUpa$FVttHP~
zenf at awB1B3`F$|Y5_j_}bP1slF#GIQ^5k5uJ`qg^r?BXMYctg>1ev<^=3>?wXCe$T
z{D#ZOoE}0ybuuS}7RrI`c&z(y^9kAUI*+KG+?-M;4&5Tci<_z_v(jdoA_*Ng`Y60g
znsD?gxid|SjpDo6RQ8#*BNY+VJ$x7f9W-3IaZ?8W-kj@&1=@=kW++)LzHqqG at Doh;
z0}K~1^Gj+uds)`Z2wzwiXgve2zk~$QBAq?=9B~&r=5tJFL|L;3QSFXv?pIbZchX0)
zrx}R|0XqIqaUtEfC&hnS0l$E at cdFbk=%H6C9B1IJtD-;HlDUg1^EstRHHq{%RWa2E
z{~@xez0(Hvq at dv-j<1Z{_2zR{#IP_=K1k3#XVALKSID{g49D>!$yfiP=F{Rf$j-%J
z{CFy8Zh9P!@A#D at aVQ~t&mtoCIUyhoC9U5hNLHykbhT9j3C-z1AC<l7szc+1^n|`+
z4oeREhX#q4Hj>rqGG8RB=`z=e(hx$xmU$vm+aKbdsUIKdnRTL?8pkh6tZZYaBz`kt
zt5n??u=A%`8VA#s9I}G54G|vT<3)nXP{u|*&JZv1O|!n-kAC^s2Z}*E&<2r<mUuO@
z8F?j}^C=H>V{IzSt>T+ZB41Oc`u0UvMR~$Sluc2=mHtPHJZJVFxBF_an7|D;)8{2y
zSlcucZXTqc_9<y3^~^{;$yd>+ at K13YdJ-(-4tiIQ9 at JOC9m<+%*VWG<O}xn0l0-ge
zxDt#7JR3hjOP`0=<uc(TpD$=-d6f~G(`V|p33n}hmY|L&Iu^M=$>ofDI#!9s#eXaT
ziTay00=}<%kHWZ-VUk21Xt)^1S8`{vzHeyt6s*tO#h-+&HGZdqiJh&$qhF?eD8T!|
zj)GX?Whc*B+s#E~-W=kUD at 2{@(5R;aPb at I?t4P6>2i2iQhL2S!%>2TkM<_Etic;9P
z%skHc$FYjl)3fKNrwLmyX3yLkhJi-`@h+`^BQkJ=Q5iNKcY&KwOS-|N*VF!oXjS;<
zEh`n_juf&2UO&FqAT~dCWLlfldIl?NHl+PP-$QvQPYiRB6v7ZpowCgdYx^Tbh|L>W
z|HYln;iNIxRgQ-l=7fWFKcOK4H9DtkWG at jlpA)yil$E<9 at GLvW_!lNj^Z4X$B5WF$
ztJhOS$^UVnb^upHGW<PT*i?C(OYV?@i9Iv+!NFk*@$zA>8gt&^Re>K*=e&Ggknm3~
z;$_#@dy at H@n&pV;r}%gK(qXZE7$fT9=Z#sGtxF;W&Atxlq*%z=e$uHhtl!{%D3T??
z**ENe)Kk_>jI37a>2u8V6D?L9mFM`y#Jxq-H>>p`S2e2z%U0V5ie`mQDbV^KWyq?H
z!1Gn;YZt*re=UXCeS6OA*N7veNM-g6&y{XH+fQ&UaeI(y8w$F9CA&~(_sOOl{&-(V
z(Bn<N=-v}J?6rs4t~PWvHiq5rNK!)x6X3E6BI75YD*)*2>X5RgP8_O}Zr|wCMn^<9
zw_At;+B>Wz5>Luh$===l9ebv>!(nK)b!Dj5?sewXiC!8mC>bK)u`LbG;sE(RBaK4#
z>)a{Y{J%_nM>R6~e*IF at rTiQ$j9{;+7i+7Dn5KgqYS$6?!Cb&(R&79MVzwq<ppvg)
zwh0LMIwth|5DiV~TQ?~zxMl)XG_FA^tnz%o*dE+GxLy)GJBPdCQ_gMrhbPy~_N|O%
za@*K)+xQ_s at CK1YmSQyJS&wtEx(zo!xm!zW5I~-4NRPUN_|I`MI&x4)vN<2fdW%|7
zEW$<|Ua3g0wJYWcT>f^}pFjK#lwwD`ltBi_`sCghYShr}DV-FTM2Nhm=!%S$7MY!*
z4gz8H_oSTb2ATCYCooOo25^PnxDt_oeSR8m?X|P}y|`TCm8DyO65)fmPNU!R88XhL
z6jxI6rd5b4GVcr(n7Ar9Wc;g#+ZSeM)@~1UAL)!2PlNMM-=S1NWO90Pjo|ukWk?cg
zz3mNQ#DZ+(s5!~DSi};uZU2H}bb6X2WrEVQ!9G-wCOTy6X^w8ukH6Mxk-nTVlb9*e
zd0^^#B&I}z|Cg0=7#5kooB@#&Z03+q3;E2T!dywl4ypJp#Qj;t0p)(?^rg3Q{?>bn
zaPo8 at q+4p~D{z}-!PGfD3K9hL)$(NRnT$_lTu{~<3A~b>jIvt at -XJT8*mC3d>Oe3C
z9N7(oG6DM)p}Ef?KZm^Spy7%^YE`4_=u)h1%!E}7YES9uvxllW63<)7)yb&HSJ~pS
zbJM5$jL=1qoCxZOD}Wc7V}||!&hdUdGflmUkp2m%eDuje|AfI<J1ymerUr1Ic3U*B
zc{bPA3a_Ivh&|ET`b>YGEEBLte8|xlUMkL^t{d$Z94QlW;Efl=tA0^NQX_Bs)+4G`
ziL1h(j|4ruG$g1JB^{q_;FX-v(^!PMB0(?c;Kh2h2>5n~;4{iBQgVuSknh3 at s2j_@
z%uo{s*WZeCp~PF at pF(R)f<^prv|9A&OQKrST4Mk$C051hL#3Koe^Dzfocu}inW|RJ
zfhfDlm4O)h-7rUGryIUfNEWOF%wq&&1bB6W6BV+$UmO2N3E(5v_m-3U5Amnzy;adZ
zJAn5BQ7CODH)hGvKQ<hWa^zFam;#;5?nR)~IhDDRPs>UCnxco2J#rY2meJS&`1&D^
ztjPNy98V8?Lv}BT=$oQ0iKIqGJ-oAIH|r14xRAbdsZmm6<0o~beq5uJmDKy6G?Wtt
z`0YUQkNjIlk$?)}?OAPpeNBHfu8;h4<}`0 at fCpnr>X at qeL*1gXikJbFLA_5%`kKx3
zK$el+22|(lf8XaW!1(^9b-(prshqX0DJ8CRurYsPCtdKZH?5Bz`x~&YOrAdZ>+fRg
z+*Ve_>vsp(pQI0`cM%`cJHOEk4q^ojR#XEA=cV>+^A!H-GzVr(&P-qjEej&rBep(I
zE0y^@4x&2c>X}TjZ&Lnm)MZj=O at D}qNXaJ$>idv-KnDrZQ~h)L8SxRd_*8Ru1lK83
zfAwkl74fnLdtzR`6d6q8`;?SR(ydxRp4F(4J9}^agz_(+bD5a&rdc$;rx9ojVYSVU
z=4!WGdwSV{>P!nOAhFYPYHXeRo_$w#1bymi1u(9h%1|+t-}PW=ojJ8g>KRS;Z?_2!
z2~Z1^V%rKFGKJ&nGb+{)pixP0)weAKrQOa~njCX6otti*C~DBYc-njh0`pO18AyDJ
zrpUCh>O#<`xkrH*Dv+Xiof8OjL6l!99flx=|K3|@y?<<^A%1!~ip~dB!BJL-X`zUE
zTIkupuCky4h%{Y{Ce<;24Y(7(O#G7!ixV`K0RCjxW{WFj#CVHC!xKk=ZPd=*rL#YM
zbmA&C9E;3wFoRf_e6ch;QBA&utyWrQ8dviQbE#Rl+k93532H`EZ4lX9SIu-W-d6Y*
zP)BPwqz=>MWNm1lY|Z9>m8&ghT!v}JcZrvvNmxaq{!~$Kv?LZF5f~IM<<;4*vpRn(
zU`=DgmKwZaDpoxz at BK^m9%#Jv!#@enr3T$3wo6D0{l57#t%+$HzM)F$r)!!pt5itZ
z%fLD{3`VZ_t at -vCV$9ih<ljd9?^(2!_A8lDMubiHR(kC11dWaYgn)&Zk*4h}Xf9;}
z82mc1S{!`Flt&qEN%ARgxjk?>vI{Q;K0B<-MN~1UQ0)Ua*@n at d?3^*B91$qmH@|rK
z%745!hYDW7O!r}f7$Zt4gF~AEYOR`FPl%m3^lTDOJmOmRYez8NzU+ugoSw%>J*Wo{
z@|$T&rlID^`LhDW|7&HWsE*5y)Nv*GwU~SrsN at h1fiQoXW{dPNrvlO?I2J|=xO0}>
zE1;{=5bcZhKk_LR>|8!WM~YmXVY~sp0t*2Xe~m2~lFHBm{XYvLe!;aMO+PS~sdVZe
zWw at N6UD8n=kV79ZpDSb}b6T^juy55ACZ8MApq2p)8!lo1+a<~L!&+(&H2rG`3MRy`
zGQ?f-Fs-54qY~EQcW>GhQ}uZaxxwYfZxpS7+Tg3ZNV>@rX<>u^LU~^wIV<o4Qz)d2
zz6pKM)oh&|_l{J%As9jS^H(ofzXo_Z{)~7Z5wf9B9Ahp44IjbC)DQ70jr#KW$xZ%@
zk2SCK4_GyPebgA&<a5KDsco6KXm@{5TSsd7B~_(<=BH&wXzp)JpZx>H72ZhB_7OO(
zjoE07&PIy;FzPohsS4c8C|f at Xzdd)cMk-<MTeioOikLDXurkZqI#CqG&|m?P0|bxa
zHk7M#bY4xqhUUb?+#y9VH?{}!wr8+Q34TDfVGi{k)Tw6ht_0}W#<#8vvjLN%d5qSe
zC-JA9Jq*@tYZ-Ui;nfenK7V$u&~D_jVcjtQA`-#M$zH`Z5io1t#qPisVVr03vp$Pq
z4jXe6zZ7>(P#}0>D#p7N!5DaC)n(~r%#ErR%FBhk#btal^L+5}F!H7g?|ozU<QGo4
zz!kmh%-S4==>VEfHsVfP(9X7G#h4{+OW*@01^Ucib!DW at Ce9`%B<}nqP)IpF{#z?c
zT%nrzVZT?1Q}%P+`3MHQlUbRKHH at rnB9G$soo54vchgFA;!7uM?KL&i- at m4y0?d-n
zif=q9C{8o3hi61&z`43-I^#a4=q!@zL|~ab*vZV3(}1Ehr@}0Kq%YL&=?-XH>^P<Q
zR_sLX^>9)uDP%Hbz8xP%a+c)W1A8uWlGm`&m9N6DC~}45MU%(PHDhBYoCG3p5szuX
z0{e-djXyV$1!u_&ez*2LnEYsOLh4Jh_L|O6a0B>nRI<wp^&?}RKE*Ms0Mz9D)j%Y!
zT3A&#jCLUDr=WF})qQbHb*!%O=s at O}@Z&^>uZTn-XIQ+b3Do>d{0|rV3{#FdDU4aA
zPH^-cGX84g(bwg!99oG?oobjuE-@?Ney%k9Hhg0;T+jAj(f~YqD%pJR_)3kc`^%2|
zcL1uXwAW2@?~7ko#B?@XcsFznjaiw_?0r6NO8cq^)gr}fg_hr2$xB$oE}jYd%ccnJ
z!8amqqdQ}=6B-1s?d3pn&;*3#P*$=k^7Pk4p at +~k+v~Nd$pa-MV<odT8RqD`xs}<<
zxE(3F(LN+TXx<c5%f<rq;ND=8qYI|ucv=@~N%e{%guwu|Quu9xRTRYWqlubGHT5AY
z#=N5iJ at U;bp7fMpqh_p5RBZv=uN0nAJVtSR8!MFZ&06cP;awAu=}ioLo~<{O)q{!j
z#p6_4sHx+%Z2)U(Cx-0;EJCN^NDj$&oPdqhxhz{Z)$|``Xr|<NIxgEpCP*(Y6_a*t
z>@JZxvdm7?cHkkN9GO_lmK<tEa+e~+4Y2xsSYxKJ9sb!x{N_n9=~n*%IWq0u;rtf<
za24-H4*Nh8f<a-zBKj~XJ8~(5G}HYRpChDdQ{AP6U^jd^Xw8bh4{QGQ6|hdi>guSK
zktUVDE*J35)$Jx=pE8<6(RZ)gBTHk`wQTNs#O;G$$Y8&pn*qPudbeC(scJv|1a><)
zva{e&+Zrz#y!xG`1gvx;h=_!f;!S55D~E<-ZSH^nAm4 at m<~y#taI%=xO+-Cj9Ueu=
z6PktR{GP<TIoo6b2YClOw5c3BZNj9V(PccNLTyr2RMV-xMN3vh9^Z4-Tiq{FkIKw@
z+`Z?wi2os+=i_MYr?oaoAI(@{lh%GB#=rx>wLTijSqOd{jm~gPR~w!v^F5q)?u;6l
zEn}-}^FL<NwhY>8;(!agir-XRBHA{%kEIkuc@>n5qL(u|zmt<rQ9Z94>~cj9m49Ux
za%gX#ko7blx(M4QSMzlmx~OXPJP0FKKXnfs%b!tX<l}Uhf2Djr_GD)`yL&HDz)LV-
z^q<fjmr#Oro7XR773}O&-`X$cT($PYdtycmC+u53Ll1U7T9$|Xu6}kNo~tcY^WEs7
z{w3#i==>%KDo6D4stbl)cyTMR<h-SW4E=kuw=m<iz|{#yfSun9Xb?=EM6LGd=ZVrg
zeFI=!nS+-<jt&G|T`b7X?XNp`3O~{4OY}Y4^zGp&3OHR8R#;-e`gD%cHTm8&_)Jxj
z!|M=!Xv2LEv;=k{Yuh*d@#fIGnb_)^pqq*xxb3wSvNk%ZH(4*Paw-wJLm7Jcrnykw
zM^I&-g+K7=PgrNNH${^R$*FEGR({tLXWH&Wyc3h7O_8CY&yH8#WVa2{>tW($|6`<(
zcdiz`_nGAvO8#=%ZTj9Xdp4KW*WKzD4J%$z=@RJo4E<qOoOb4Y-gUY`ze}=M9kwPb
zRu0Q0+uTOBXJUXmSB#(D at USS8-#xLtUT<&el=7~0dr-%JM&JJA-dpWn&UoL)<v`<A
z^-(}R&^`F&<@sn|c^Xi-?yHc$&cPzR)Q{maWOvuwsXLh__bcYci}D&7G=xemUu9!y
zbvmwdhKh}95Wq0+F*Wu at M(@^YH?#9t{&w&-e%x<!wmaP}x=$!POW-F;-n-fP&<l2I
zuKxS&1|hQpRv~2k$^4?(wNJ)f0$r5RwY{+554qiFOSmE8s6=w6X5o(sEbaZM4%p+H
zlh#6E))&D?xYV*t{Y+KmN_`HKjVi0tcGbA(lsi)CdOd~jwVQYKuwFHz)PMh_ at 2Z=$
zTrldoIDD54eHB_^Z)6ak4PT14&DRup5~_s!Cy4Vy<G7w-eeRzzOy`MMgWgA5B`A{s
zO5bC?Bdo8|$G-N_I}Nvk#YFn<n`CV}+7i`4^8#|S3^`$MPmVr6PIVRk=OjO!wDvz6
z!-rhOlc}Sogu$5#_Y&6AtTt+x!%y_N-S;M~x~;8Tdn4P_FS!qK^4{}pbyqJeG<6w0
zV_B2i-hhGtck_HbhT8)%kk1x<ZKs}ls}t-qjqhH5WxOa*JGpUr_!S8o%a`HypbQag
zqwS5&n9{sX9Ybqa+J?xk7d1(0k^=SLsGPt1l+FQ`NFUxR=Ws!FY94;=HF~)F<oecx
zPRcex<@l8*VypAT=?2o<Cdi;Kaq^wr?{M|GK(iBA$DR at Qzh6X$vTRhN4AV)`dvVmg
zNY{}j&)h5?#G0c1myHxN`_y<MR`-4h1rrVB`1uKPr+2}q>GGocMThDkd<!Q1T_EJn
z+-okCof}!9vMSqT`~e2R#wA8FZ~VDU at xMbBPF5FiP`jqBiHS1j;HZ~hql6RThH|tQ
z1rQ9J%K?tsV#?TU4W!-MvM5!L7`e`?N!NMxrVvHYeWVY;;L{)}+4b@`>wVl=^h&I{
z?`i%TNV&b;?feCkEd2Q1fo80OE3P%lrAU<HG^qXD-?}bviz)mP9D0Phn_<Pq%WTiC
zOxu4AeJNHYfGf(@KBK~p!#TFrpu4Jd!81ZvG~LlrMvJ*&bO9 at oMoY7=?7-Clt1^I7
z;FCzy at 82QP4GI<(-)6iXcZMO4emhqdbC at o+Z`B)fpMD8`IMhH+froa|C+UCinQRYv
zZLnY}f-e3X4e*^)2qw1po)Gs&x{pS`N_*EEX6Dw6eyspx-{_DbO|J3E at +(FlFm at pE
ziNIUY9230TcM>}23k+(B^qr5OeMpe;a(o`{T$}n|sF{9Rj5!&KN<lS<a~z^VL14Tz
zBxs7vU!wx048<$*#H8%lhPTpyGx$hicFa<))GA5fORY|ROgcD4na`u~6*W}_Jmu8%
zS`qhbhD`KCTrD`+vVcy3>ztW{fCKs0ApYM=x;aX34ibn5|Aa4o6S at X*!Dqv4$#hFw
z<g<WIigZmQZOLCR(GbZmg?ax&@ZlyA16zB<qO(3jE|6+0^iB}Sbo&1#^PmR3Y$^j1
zJ6W2&gLiQXAmK3kwWuoQ^^HXGFvdzD5|c>cL0h03 at c}O4!d36DsY_I)s;`KzAkt&$
zxk!!&dKt}#-*Y7iucLy*YXr81 at u7I-<kaMJFy*l$o^xA^L_((YNdezL4ndQnec%x!
z;R=|XoA#U|)Q|AI at ZcKWUnXoakjNCEl1GupqfHSljE14Dw~LbZlI5<~RfEYC6P8vX
z&9~oYv-#wQe<r00!yL0pUhKc3oYzgY1^;;_G>gWgN%>c5Db8ZsEP1}CB~risxA6ch
z`^JDx9MyO&F)IB^?d6PBWY at YH-Vx86?clFP(ye3D#E86&RLyHPy=}2~LKjRM3=C#E
z{(7pQn?s at qKpUwh&b&-Xc8gguTz;`RBAv{Km9DtZcQ<LVSfnoWnroVA2Yn;`NFek2
z9|8B{8mXJUK%5(Co$l2S<n>QTWClNTRnRTE9_IK`rMR<N=TO9J+KY0!jgR?7ljkcG
zsqk2>4Q6--x}-;6zwpg93HC5)0zHT?-+w!)6Fb?*@5!lC);JQAmZ8Ib-AMKCX=RNo
z3wtR2<#yhP#jlCQeI>71I<!0*pmEz|r?q2tg|*lOL8Df|qu#93a}xgX9tFc<n)C$8
PMlxM3Bh6|Jr+ at zslM*X3
literal 0
HcmV?d00001
2.17.1
