[rtems-test] powerpc/psim: RTEMS_POSIX_API: Passed:567 Failed:5 Timeout:2 Invalid:0 Wrong:0
Sebastian Huber
Mon Dec 3 06:27:23 UTC 2018
On 03/12/2018 05:53, Joel Sherrill wrote:
> Timeouts:
> unlimited.exe
It is strange that this times out. If I run it by hand, then it runs
without a failure:
time psim -i ./powerpc-rtems5/c/psim/testsuites/samples/unlimited.exe
TEST3 : signal task 0a0103e9 to delete, task 999 ending.
TEST3 : completed
*** END OF TEST UNLIMITED TASK ***
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 5.0.0.dedb34f9ef5527a596046ff9cbf19c8a93dfdaee
RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB
30da0c720b78eba16a3f5272206c07415368617b, Newlib
2ab57ad59bc35dafffa69cd4da5e228971de069f)
executing thread ID: 0x08a010001
executing thread name: UI1
real 0m2.573s
user 0m2.055s
sys 0m0.294s
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
