Unstable RTEMS 6 tool chain?
Sebastian Huber
Mon Dec 3 06:45:07 UTC 2018
Hello,
what about adding an unstable RTEMS 6 tool chain to the RSB which is
automatically updated weekly? I would like to test the Newlib, Binutils,
GCC and GDB head regularly. I could set up a cron job to check out the
Git master each Sunday (RTEMS, Newlib, Binutils, GCC and GDB), update
the RSB, build the tools, run the tests on erc32. If everything goes
well push the change to RSB, otherwise report the problem.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
