[PATCH] score: Avoid sbintime_t in API headers
Mon Dec 3 12:20:53 UTC 2018
The sbintime_t is a non-POSIX type and not visible if strict standard
options are selected.
Move implementation details from <rtems/score/timestamp.h> to
<rtems/score/timestampimpl.h>.
Update #3598.
 cpukit/headers.am                            |   2 +-
 cpukit/include/rtems/score/threadimpl.h      |   1 +
 cpukit/include/rtems/score/timecounter.h     |   2 +-
 cpukit/include/rtems/score/timestamp.h       | 264 +----------------------
 cpukit/include/rtems/score/timestampimpl.h   | 302 +++++++++++++++++++++++++++
 cpukit/include/rtems/score/watchdogimpl.h    |   4 +-
 cpukit/rtems/src/clockgetuptimenanoseconds.c |   1 +
 cpukit/rtems/src/clockgetuptimetimeval.c     |   1 +
 8 files changed, 309 insertions(+), 268 deletions(-)
 create mode 100644 cpukit/include/rtems/score/timestampimpl.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 1dbd154e0e..8172328c68 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -390,7 +390,7 @@ include_rtems_score_HEADERS += include/rtems/score/threadqimpl.h
 include_rtems_score_HEADERS += include/rtems/score/timecounter.h
 include_rtems_score_HEADERS += include/rtems/score/timecounterimpl.h
 include_rtems_score_HEADERS += include/rtems/score/timespec.h
-include_rtems_score_HEADERS += include/rtems/score/timestamp.h
+include_rtems_score_HEADERS += include/rtems/score/timestampimpl.h
 include_rtems_score_HEADERS += include/rtems/score/tls.h
 include_rtems_score_HEADERS += include/rtems/score/todimpl.h
 include_rtems_score_HEADERS += include/rtems/score/userext.h
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 39937f9283..0e93cb501d 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -31,6 +31,7 @@
 #include <rtems/score/status.h>
 #include <rtems/score/sysstate.h>
+#include <rtems/score/timestampimpl.h>
 #include <rtems/score/freechain.h>
diff --git a/cpukit/include/rtems/score/timecounter.h b/cpukit/include/rtems/score/timecounter.h
index 79444de482..9d688eebe8 100644
--- a/cpukit/include/rtems/score/timecounter.h
+++ b/cpukit/include/rtems/score/timecounter.h
@@ -74,7 +74,7 @@ void _Timecounter_Binuptime( struct bintime *bt );
  * @return Returns the uptime.
-sbintime_t _Timecounter_Sbinuptime( void );
+int64_t _Timecounter_Sbinuptime( void );
  * @brief Returns the uptime in the timespec format.
diff --git a/cpukit/include/rtems/score/timestamp.h b/cpukit/include/rtems/score/timestamp.h
index 6fc17ced9c..1e6a25ef28 100644
--- a/cpukit/include/rtems/score/timestamp.h
+++ b/cpukit/include/rtems/score/timestamp.h
@@ -40,9 +40,6 @@
-#include <sys/time.h>
-#include <rtems/score/basedefs.h>
 #include <rtems/score/timespec.h>
 #ifdef __cplusplus
@@ -52,266 +49,7 @@ extern "C" {
  *   Define the Timestamp control type.
-typedef sbintime_t Timestamp_Control;
- *  @brief Set timestamp to specified seconds and nanoseconds.
- *  This method sets the timestamp to the specified @a _seconds and @a _nanoseconds
- *  value.
- *  @param[in] _time points to the timestamp instance to validate.
- *  @param[in] _seconds is the seconds portion of the timestamp
- *  @param[in] _nanoseconds is the nanoseconds portion of the timestamp
-RTEMS_INLINE_ROUTINE void _Timestamp_Set(
-  Timestamp_Control *_time,
-  time_t             _seconds,
-  long               _nanoseconds
-  struct timespec _ts;
-  _ts.tv_sec = _seconds;
-  _ts.tv_nsec = _nanoseconds;
-  *_time = tstosbt(_ts);
- *  @brief Sets the timestamp to zero.
- *  This method sets the timestamp to zero.
- *  value.
- *  @param[in] _time points to the timestamp instance to zero.
-RTEMS_INLINE_ROUTINE void _Timestamp_Set_to_zero(
-  *_time = 0;
- *  @brief Less than operator for timestamps.
- *  This method is the less than operator for timestamps.
- *  @param[in] _lhs points to the left hand side timestamp
- *  @param[in] _rhs points to the right hand side timestamp
- *  @retval This method returns true if @a _lhs is less than the @a _rhs and
- *          false otherwise.
-RTEMS_INLINE_ROUTINE bool _Timestamp_Less_than(
-  const Timestamp_Control *_lhs,
-  const Timestamp_Control *_rhs
-  return *_lhs < *_rhs;
- *  @brief Greater than operator for timestamps.
- *  This method is the greater than operator for timestamps.
- *  @retval This method returns true if @a _lhs is greater than the @a _rhs and
-RTEMS_INLINE_ROUTINE bool _Timestamp_Greater_than(
-  return *_lhs > *_rhs;
- *  @brief Equal to than operator for timestamps.
- *  This method is the is equal to than operator for timestamps.
- *  @retval This method returns true if @a _lhs is equal to  @a _rhs and
-RTEMS_INLINE_ROUTINE bool _Timestamp_Equal_to(
-  return *_lhs == *_rhs;
- *  @brief Adds two timestamps.
- *  This routine adds two timestamps.  The second argument is added
- *  to the first.
- *  @param[in] _time points to the base time to be added to
- *  @param[in] _add points to the timestamp to add to the first argument
-RTEMS_INLINE_ROUTINE void _Timestamp_Add_to(
-  const Timestamp_Control *_add
-  *_time += *_add;
- *  @brief Subtracts two timestamps.
- *  This routine subtracts two timestamps.  @a result is set to
- *  @a end - @a start.
- *  @param[in] _start points to the starting time
- *  @param[in] _end points to the ending time
- *  @param[in] _result points to the difference between
- *             starting and ending time.
- *  @retval This method fills in @a _result.
-RTEMS_INLINE_ROUTINE void _Timestamp_Subtract(
-  const Timestamp_Control *_start,
-  const Timestamp_Control *_end,
-  Timestamp_Control       *_result
-  *_result = *_end - *_start;
- *  @brief Divides a timestamp by another timestamp.
- *  This routine divides a timestamp by another timestamp.  The
- *  intended use is for calculating percentages to three decimal points.
- *  @param[in] _lhs points to the left hand number
- *  @param[in] _rhs points to the right hand number
- *  @param[in] _ival_percentage points to the integer portion of the average
- *  @param[in] _fval_percentage points to the thousandths of percentage
- *  @retval This method fills in @a result.
-RTEMS_INLINE_ROUTINE void _Timestamp_Divide(
-  const Timestamp_Control *_rhs,
-  uint32_t                *_ival_percentage,
-  uint32_t                *_fval_percentage
-  struct timespec _ts_left;
-  struct timespec _ts_right;
-  _ts_left = sbttots( *_lhs );
-  _ts_right = sbttots( *_rhs );
-  _Timespec_Divide(
-    &_ts_left,
-    &_ts_right,
-    _ival_percentage,
-    _fval_percentage
- *  @brief Get seconds portion of timestamp.
- *  This method returns the seconds portion of the specified timestamp
- *  @retval The seconds portion of @a _time.
-RTEMS_INLINE_ROUTINE time_t _Timestamp_Get_seconds(
-  const Timestamp_Control *_time
-  return (*_time >> 32);
- *  @brief Get nanoseconds portion of timestamp.
- *  This method returns the nanoseconds portion of the specified timestamp
- *  @retval The nanoseconds portion of @a _time.
-RTEMS_INLINE_ROUTINE uint32_t _Timestamp_Get_nanoseconds(
-  _ts = sbttots( *_time );
-  return (uint32_t) _ts.tv_nsec;
- *  @brief Get the timestamp as nanoseconds.
- *  This method returns the timestamp as nanoseconds.
- *  @retval The time in nanoseconds.
-RTEMS_INLINE_ROUTINE uint64_t _Timestamp_Get_as_nanoseconds(
-  return _Timespec_Get_as_nanoseconds( &_ts );
- *  @brief Convert timestamp to struct timespec.
- *  This method returns the seconds portion of the specified @a _timestamp.
- *  @param[in] _timestamp points to the timestamp
- *  @param[in] _timespec points to the timespec
-RTEMS_INLINE_ROUTINE void _Timestamp_To_timespec(
-  const Timestamp_Control *_timestamp,
-  struct timespec         *_timespec
-  *_timespec = sbttots( *_timestamp );
- *  @brief Convert timestamp to struct timeval.
- *  @param[in] _timeval points to the timeval
-RTEMS_INLINE_ROUTINE void _Timestamp_To_timeval(
-  struct timeval          *_timeval
-  *_timeval = sbttotv( *_timestamp );
+typedef int64_t Timestamp_Control;
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/timestampimpl.h b/cpukit/include/rtems/score/timestampimpl.h
new file mode 100644
index 0000000000..555d9354f2
--- /dev/null
+++ b/cpukit/include/rtems/score/timestampimpl.h
@@ -0,0 +1,302 @@
+ *  @file  rtems/score/timestamp.h
+ *  @brief Helpers for Manipulating Timestamps
+ *  This include file contains helpers for manipulating timestamps.
+ *  COPYRIGHT (c) 1989-2009.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef _RTEMS_SCORE_TIMESTAMPIMPL_H
+#define _RTEMS_SCORE_TIMESTAMPIMPL_H
+ * @addtogroup SuperCoreTimeStamp
+#include <rtems/score/timestamp.h>
+#include <rtems/score/basedefs.h>
+#include <sys/time.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  @brief Set timestamp to specified seconds and nanoseconds.
+ *  This method sets the timestamp to the specified @a _seconds and @a _nanoseconds
+ *  value.
+ *  @param[in] _time points to the timestamp instance to validate.
+ *  @param[in] _seconds is the seconds portion of the timestamp
+ *  @param[in] _nanoseconds is the nanoseconds portion of the timestamp
+RTEMS_INLINE_ROUTINE void _Timestamp_Set(
+  Timestamp_Control *_time,
+  time_t             _seconds,
+  long               _nanoseconds
+  struct timespec _ts;
+  _ts.tv_sec = _seconds;
+  _ts.tv_nsec = _nanoseconds;
+  *_time = tstosbt(_ts);
+ *  @brief Sets the timestamp to zero.
+ *  This method sets the timestamp to zero.
+ *  value.
+ *  @param[in] _time points to the timestamp instance to zero.
+RTEMS_INLINE_ROUTINE void _Timestamp_Set_to_zero(
+  *_time = 0;
+ *  @brief Less than operator for timestamps.
+ *  This method is the less than operator for timestamps.
+ *  @param[in] _lhs points to the left hand side timestamp
+ *  @param[in] _rhs points to the right hand side timestamp
+ *  @retval This method returns true if @a _lhs is less than the @a _rhs and
+ *          false otherwise.
+RTEMS_INLINE_ROUTINE bool _Timestamp_Less_than(
+  const Timestamp_Control *_lhs,
+  const Timestamp_Control *_rhs
+  return *_lhs < *_rhs;
+ *  @brief Greater than operator for timestamps.
+ *  This method is the greater than operator for timestamps.
+ *  @retval This method returns true if @a _lhs is greater than the @a _rhs and
+RTEMS_INLINE_ROUTINE bool _Timestamp_Greater_than(
+  return *_lhs > *_rhs;
+ *  @brief Equal to than operator for timestamps.
+ *  This method is the is equal to than operator for timestamps.
+ *  @retval This method returns true if @a _lhs is equal to  @a _rhs and
+RTEMS_INLINE_ROUTINE bool _Timestamp_Equal_to(
+  return *_lhs == *_rhs;
+ *  @brief Adds two timestamps.
+ *  This routine adds two timestamps.  The second argument is added
+ *  to the first.
+ *  @param[in] _time points to the base time to be added to
+ *  @param[in] _add points to the timestamp to add to the first argument
+RTEMS_INLINE_ROUTINE void _Timestamp_Add_to(
+  const Timestamp_Control *_add
+  *_time += *_add;
+ *  @brief Subtracts two timestamps.
+ *  This routine subtracts two timestamps.  @a result is set to
+ *  @a end - @a start.
+ *  @param[in] _start points to the starting time
+ *  @param[in] _end points to the ending time
+ *  @param[in] _result points to the difference between
+ *             starting and ending time.
+ *  @retval This method fills in @a _result.
+RTEMS_INLINE_ROUTINE void _Timestamp_Subtract(
+  const Timestamp_Control *_start,
+  const Timestamp_Control *_end,
+  Timestamp_Control       *_result
+  *_result = *_end - *_start;
+ *  @brief Divides a timestamp by another timestamp.
+ *  This routine divides a timestamp by another timestamp.  The
+ *  intended use is for calculating percentages to three decimal points.
+ *  @param[in] _lhs points to the left hand number
+ *  @param[in] _rhs points to the right hand number
+ *  @param[in] _ival_percentage points to the integer portion of the average
+ *  @param[in] _fval_percentage points to the thousandths of percentage
+ *  @retval This method fills in @a result.
+RTEMS_INLINE_ROUTINE void _Timestamp_Divide(
+  const Timestamp_Control *_rhs,
+  uint32_t                *_ival_percentage,
+  uint32_t                *_fval_percentage
+  struct timespec _ts_left;
+  struct timespec _ts_right;
+  _ts_left = sbttots( *_lhs );
+  _ts_right = sbttots( *_rhs );
+  _Timespec_Divide(
+    &_ts_left,
+    &_ts_right,
+    _ival_percentage,
+    _fval_percentage
+ *  @brief Get seconds portion of timestamp.
+ *  This method returns the seconds portion of the specified timestamp
+ *  @retval The seconds portion of @a _time.
+RTEMS_INLINE_ROUTINE time_t _Timestamp_Get_seconds(
+  const Timestamp_Control *_time
+  return (*_time >> 32);
+ *  @brief Get nanoseconds portion of timestamp.
+ *  This method returns the nanoseconds portion of the specified timestamp
+ *  @retval The nanoseconds portion of @a _time.
+RTEMS_INLINE_ROUTINE uint32_t _Timestamp_Get_nanoseconds(
+  _ts = sbttots( *_time );
+  return (uint32_t) _ts.tv_nsec;
+ *  @brief Get the timestamp as nanoseconds.
+ *  This method returns the timestamp as nanoseconds.
+ *  @retval The time in nanoseconds.
+RTEMS_INLINE_ROUTINE uint64_t _Timestamp_Get_as_nanoseconds(
+  return _Timespec_Get_as_nanoseconds( &_ts );
+ *  @brief Convert timestamp to struct timespec.
+ *  This method returns the seconds portion of the specified @a _timestamp.
+ *  @param[in] _timestamp points to the timestamp
+ *  @param[in] _timespec points to the timespec
+RTEMS_INLINE_ROUTINE void _Timestamp_To_timespec(
+  const Timestamp_Control *_timestamp,
+  struct timespec         *_timespec
+  *_timespec = sbttots( *_timestamp );
+ *  @brief Convert timestamp to struct timeval.
+ *  @param[in] _timeval points to the timeval
+RTEMS_INLINE_ROUTINE void _Timestamp_To_timeval(
+  struct timeval          *_timeval
+  *_timeval = sbttotv( *_timestamp );
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/include/rtems/score/watchdogimpl.h b/cpukit/include/rtems/score/watchdogimpl.h
index 17ef130d3a..5a024069ca 100644
--- a/cpukit/include/rtems/score/watchdogimpl.h
+++ b/cpukit/include/rtems/score/watchdogimpl.h
@@ -398,9 +398,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec(
   return ticks;
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_sbintime(
-  sbintime_t sbt
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_sbintime( int64_t sbt )
   uint64_t ticks = ( sbt >> 32 ) << WATCHDOG_BITS_FOR_1E9_NANOSECONDS;
diff --git a/cpukit/rtems/src/clockgetuptimenanoseconds.c b/cpukit/rtems/src/clockgetuptimenanoseconds.c
index 03ff73bba3..71f5588db2 100644
--- a/cpukit/rtems/src/clockgetuptimenanoseconds.c
+++ b/cpukit/rtems/src/clockgetuptimenanoseconds.c
@@ -18,6 +18,7 @@
 #endif
 #include <rtems/rtems/clock.h>
 uint64_t rtems_clock_get_uptime_nanoseconds( void )
diff --git a/cpukit/rtems/src/clockgetuptimetimeval.c b/cpukit/rtems/src/clockgetuptimetimeval.c
index 2e09ae2cd2..0e095e6cb5 100644
--- a/cpukit/rtems/src/clockgetuptimetimeval.c
+++ b/cpukit/rtems/src/clockgetuptimetimeval.c
@@ -24,6 +24,7 @@
 #endif
 void rtems_clock_get_uptime_timeval( struct timeval *uptime )
2.16.4
