Unstable RTEMS 6 tool chain?
Tue Dec 4 03:37:16 UTC 2018
On 03/12/2018 17:45, Sebastian Huber wrote:
> what about adding an unstable RTEMS 6 tool chain to the RSB which is
> automatically updated weekly? I would like to test the Newlib, Binutils, GCC and
> GDB head regularly. I could set up a cron job to check out the Git master each
> Sunday (RTEMS, Newlib, Binutils, GCC and GDB), update the RSB, build the tools,
> run the tests on erc32. If everything goes well push the change to RSB,
> otherwise report the problem.
This sounds fantastic. If you want to place the scripts in
https://git.rtems.org/chrisj/rtems-admin.git/ please let me know and I can make
sure the perms are ok.
