[rtems-test] powerpc/psim: RTEMS_POSIX_API: Passed:567 Failed:5 Timeout:2 Invalid:0 Wrong:0
Tue Dec 4 03:56:20 UTC 2018
On 04/12/2018 14:49, Joel Sherrill wrote:
> On Mon, Dec 3, 2018, 9:34 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org> wrote:
>     On 03/12/2018 17:27, Sebastian Huber wrote:
>     > On 03/12/2018 05:53, Joel Sherrill wrote:
>     >> Timeouts:
>     >>   unlimited.exe
>     > It is strange that this times out. If I run it by hand, then it runs without a
>     > failure:
>     > time psim -i ./powerpc-rtems5/c/psim/testsuites/samples/unlimited.exe
>     >  TEST3 : signal task 0a0103e9 to delete, task 999 ending.
>     >  TEST3 : completed
>     > *** END OF TEST UNLIMITED TASK ***
>     > *** FATAL ***
>     > fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
>     > fatal code: 0 (0x00000000)
>     > RTEMS version: 5.0.0.dedb34f9ef5527a596046ff9cbf19c8a93dfdaee
>     > RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB
>     > 30da0c720b78eba16a3f5272206c07415368617b, Newlib
>     > 2ab57ad59bc35dafffa69cd4da5e228971de069f)
>     > executing thread ID: 0x08a010001
>     > executing thread name: UI1
>     > real    0m2.573s
>     > user    0m2.055s
>     > sys     0m0.294s
>     Is your rtems-tools fully updated?
> A lot updated when I just pulled. I will leave it building again when I head to bed.
>     Is the host at full load when this test fails?
> No. Idle otherwise
This would point to a locking issue in the rtems-test command.
