[PATCH 2/7] Add inline functions to convert between sbintime_t
Tue Dec 4 06:44:39 UTC 2018
and decimal time units. Use them in some existing code that is
vulnerable to roundoff errors.
The existing constant SBT_1NS is a honeypot, luring unsuspecting folks into
writing code such as long_timeout_ns*SBT_1NS to generate the argument for a
sleep call.  The actual value of 1ns in sbt units is ~4.3, leading to a
large roundoff error giving a shorter sleep than expected when multiplying
by the trucated value of 4 in SBT_1NS.  (The evil honeypot aspect becomes
clear after you waste a whole day figuring out why your sleeps return early.)
 newlib/libc/include/sys/time.h | 59 +++++++++++++++++++++++++++++++++++++-----
 1 file changed, 52 insertions(+), 7 deletions(-)
diff --git a/newlib/libc/include/sys/time.h b/newlib/libc/include/sys/time.h
index 2cf543d0b..f263a5352 100644
--- a/newlib/libc/include/sys/time.h
+++ b/newlib/libc/include/sys/time.h
@@ -138,7 +138,7 @@ bintime_shift(struct bintime *_bt, int _exp)
 #define	SBT_1M	(SBT_1S * 60)
 #define	SBT_1MS	(SBT_1S / 1000)
 #define	SBT_1US	(SBT_1S / 1000000)
-#define	SBT_1NS	(SBT_1S / 1000000000)
+#define	SBT_1NS	(SBT_1S / 1000000000) /* beware rounding, see nstosbt() */
 #define	SBT_MAX	0x7fffffffffffffffLL
 static __inline int
@@ -165,6 +165,53 @@ sbttobt(sbintime_t _sbt)
 	return (_bt);
+ * Decimal<->sbt conversions.  Multiplying or dividing by SBT_1NS results in
+ * large roundoff errors which sbttons() and nstosbt() avoid.  Millisecond and
+ * microsecond functions are also provided for completeness.
+static __inline int64_t
+sbttons(sbintime_t _sbt)
+	return ((1000000000 * _sbt) >> 32);
+static __inline sbintime_t
+nstosbt(int64_t _ns)
+	return ((_ns * (((uint64_t)1 << 63) / 500000000) >> 32));
+sbttous(sbintime_t _sbt)
+	return ((1000000 * _sbt) >> 32);
+ustosbt(int64_t _us)
+	return ((_us * (((uint64_t)1 << 63) / 500000) >> 32));
+sbttoms(sbintime_t _sbt)
+	return ((1000 * _sbt) >> 32);
+mstosbt(int64_t _ms)
+	return ((_ms * (((uint64_t)1 << 63) / 500) >> 32));
  * Background information:
@@ -220,7 +267,7 @@ sbttots(sbintime_t _sbt)
 	struct timespec _ts;
 	_ts.tv_sec = _sbt >> 32;
-	_ts.tv_nsec = ((uint64_t)1000000000 * (uint32_t)_sbt) >> 32;
+	_ts.tv_nsec = sbttons((uint32_t)_sbt);
 	return (_ts);
@@ -228,8 +275,7 @@ static __inline sbintime_t
 tstosbt(struct timespec _ts)
-	return (((sbintime_t)_ts.tv_sec << 32) +
-	    (_ts.tv_nsec * (((uint64_t)1 << 63) / 500000000) >> 32));
+	return (((sbintime_t)_ts.tv_sec << 32) + nstosbt(_ts.tv_nsec));
 static __inline struct timeval
@@ -238,7 +284,7 @@ sbttotv(sbintime_t _sbt)
 	struct timeval _tv;
 	_tv.tv_sec = _sbt >> 32;
-	_tv.tv_usec = ((uint64_t)1000000 * (uint32_t)_sbt) >> 32;
+	_tv.tv_usec = sbttous((uint32_t)_sbt);
 	return (_tv);
@@ -246,8 +292,7 @@ static __inline sbintime_t
 tvtosbt(struct timeval _tv)
-	return (((sbintime_t)_tv.tv_sec << 32) +
-	    (_tv.tv_usec * (((uint64_t)1 << 63) / 500000) >> 32));
+	return (((sbintime_t)_tv.tv_sec << 32) + ustosbt(_tv.tv_usec));
 #endif /* __BSD_VISIBLE */
2.16.4
