POSIX Signature Test for Header File glob.h (GCI2018)
Joel Sherrill
joel at rtems.org
Tue Dec 4 15:37:19 UTC 2018
This looks good. Did you claim this GCI task? If yes and someone approved
it, please reply with the URL.
Once you claim the GCI task, I will push this patch and approve the GCI
task.
Thanks.
--joel
On Tue, Dec 4, 2018 at 3:26 AM Abhimanyu Raghuvanshi <
abhimanyuraghuvanshi29 at gmail.com> wrote:
> From 3e8f31fdcdcd8b186891f4511584dbcec667950c Mon Sep 17 00:00:00 2001
> From: ABR290B <abhimayuraghuvanshi29 at gmail.com>
> Date: Tue, 4 Dec 2018 14:54:02 +0530
> Subject: [PATCH] POSIX Signature Test for glob.h (GCI2018)
> testsuites/psxtests/Makefile.am | 4 ++-
> testsuites/psxtests/psxhdrs/glob/glob.c | 40 +++++++++++++++++++++
> testsuites/psxtests/psxhdrs/glob/globfree.c | 34 ++++++++++++++++++
> 3 files changed, 77 insertions(+), 1 deletion(-)
> create mode 100644 testsuites/psxtests/psxhdrs/glob/glob.c
> create mode 100644 testsuites/psxtests/psxhdrs/glob/globfree.c
> diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> index 633b2efab1..fe18e92d78 100644
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -1137,7 +1137,9 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
> psxhdrs/penv/fesetexceptflag.c \
> psxhdrs/penv/fesetround.c \
> psxhdrs/penv/fesetexcept.c \
> - psxhdrs/penv/feupdateenv.c
> + psxhdrs/penv/feupdateenv.c \
> + psxhdrs/glob/glob.c \
> + psxhdrs/glob/globfree.c
> endif
> rtems_tests_PROGRAMS = $(psx_tests)
> diff --git a/testsuites/psxtests/psxhdrs/glob/glob.c
> b/testsuites/psxtests/psxhdrs/glob/glob.c
> new file mode 100644
> index 0000000000..81304af27a
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/glob/glob.c
> @@ -0,0 +1,40 @@
> + * @file
> + * @brief glob() API Conformance Test
> + * COPYRIGHT (c) 2018.
> + * Abhimanyu Raghuvanshi
> + * Permission to use, copy, modify, and/or distribute this software
> + * for any purpose with or without fee is hereby granted.
> + * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
> + * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
> + * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE
> AUTHOR
> + * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
> + * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
> + * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
> + * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
> SOFTWARE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <glob.h>
> +int test(void);
> +int test(void)
> + const char *a;
> + int b;
> + const char c;
> + int d;
> + int *(c, d);
> + glob_t *e;
> + return glob(a, b, NULL, e);
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxhdrs/glob/globfree.c
> b/testsuites/psxtests/psxhdrs/glob/globfree.c
> index 0000000000..0ba1f23d82
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/glob/globfree.c
> @@ -0,0 +1,34 @@
> + * @file
> + * @brief globfree() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> + glob_t *a;
> + return globfree(a);
> 2.19.1.windows.1
> 送られた ABR2908
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181204/5e3b84e9/attachment.html>
