[PATCH] Simplify _CPU_Counter_difference()
Sebastian Huber
Wed Dec 5 10:31:51 UTC 2018
In order to simplify the use of CPU counter values it is beneficial to
have monotonic increasing values within the range of the CPU counter
ticks data type, e.g. 32-bit unsigned integer. This eases the use of
CPU counter timestamps in external tools which do not know the details
of the CPU counter hardware. The CPU counter is the fastest way to get
a time on an RTEMS system.
Such a CPU counter may be also used as the timecounter. Use it on SPARC
for this purpose to simplify the clock drivers.
Update #3456.
bsps/or1k/generic_or1k/clock/clockdrv.c | 8 --
bsps/shared/dev/cpucounter/cpucounterdiff.c | 23 ----
bsps/sparc/erc32/clock/ckinit.c | 138 ++++++++++-----------
bsps/sparc/leon2/clock/ckinit.c | 93 ++++++++------
bsps/sparc/leon3/clock/ckinit.c | 126 +++++++------------
bsps/sparc/leon3/include/leon.h | 6 +
bsps/sparc/leon3/start/cpucounter.c | 32 ++---
c/src/lib/libbsp/sparc/leon2/Makefile.am | 1 -
cpukit/Makefile.am | 1 -
cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h | 7 +-
cpukit/score/cpu/or1k/include/rtems/score/cpu.h | 7 +-
cpukit/score/cpu/sparc/include/rtems/score/cpu.h | 23 ++--
.../cpu/sparc/include/rtems/score/sparcimpl.h | 61 ++++-----
cpukit/score/cpu/sparc/sparc-counter-asm.S | 80 +++++++++++-
cpukit/score/cpu/sparc/sparc-counter.c | 48 -------
15 files changed, 307 insertions(+), 347 deletions(-)
delete mode 100644 bsps/shared/dev/cpucounter/cpucounterdiff.c
delete mode 100644 cpukit/score/cpu/sparc/sparc-counter.c
diff --git a/bsps/or1k/generic_or1k/clock/clockdrv.c b/bsps/or1k/generic_or1k/clock/clockdrv.c
index 44365aa02c..7b8a07fd3d 100644
--- a/bsps/or1k/generic_or1k/clock/clockdrv.c
+++ b/bsps/or1k/generic_or1k/clock/clockdrv.c
@@ -109,14 +109,6 @@ static void generic_or1k_clock_initialize(void)
rtems_timecounter_install(&or1ksim_tc);
-CPU_Counter_ticks _CPU_Counter_difference(
- CPU_Counter_ticks second,
- CPU_Counter_ticks first
- return second - first;
#define Clock_driver_support_at_tick() generic_or1k_clock_at_tick()
#define Clock_driver_support_initialize_hardware() generic_or1k_clock_initialize()
diff --git a/bsps/shared/dev/cpucounter/cpucounterdiff.c b/bsps/shared/dev/cpucounter/cpucounterdiff.c
deleted file mode 100644
index d77945d5b8..0000000000
--- a/bsps/shared/dev/cpucounter/cpucounterdiff.c
+++ /dev/null
@@ -1,23 +0,0 @@
- * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <rtems/score/cpu.h>
diff --git a/bsps/sparc/erc32/clock/ckinit.c b/bsps/sparc/erc32/clock/ckinit.c
index e7c5b07f33..6d6a335fed 100644
--- a/bsps/sparc/erc32/clock/ckinit.c
+++ b/bsps/sparc/erc32/clock/ckinit.c
@@ -24,103 +24,97 @@
#include <bsp.h>
#include <bspopts.h>
-#include <rtems/counter.h>
+#include <rtems/sysinit.h>
#include <rtems/timecounter.h>
#include <rtems/score/sparcimpl.h>
-#define ERC32_REAL_TIME_CLOCK_FREQUENCY 1000000
- * The Real Time Clock Counter Timer uses this trap type.
-#define CLOCK_VECTOR ERC32_TRAP_TYPE( ERC32_INTERRUPT_REAL_TIME_CLOCK )
-#define Clock_driver_support_install_isr( _new ) \
- set_vector( _new, CLOCK_VECTOR, 1 )
-#define Clock_driver_support_set_interrupt_affinity( _online_processors ) \
- do { \
- (void) _online_processors; \
- } while (0)
extern int CLOCK_SPEED;
-static rtems_timecounter_simple erc32_tc;
+#define ERC32_REAL_TIME_CLOCK_FREQUENCY 1000000
-static uint32_t erc32_tc_get( rtems_timecounter_simple *tc )
- return ERC32_MEC.Real_Time_Clock_Counter;
+static struct timecounter erc32_tc;
-static bool erc32_tc_is_pending( rtems_timecounter_simple *tc )
+static void erc32_clock_init( void )
- return ERC32_Is_interrupt_pending( ERC32_INTERRUPT_REAL_TIME_CLOCK );
+ struct timecounter *tc;
+ tc = &erc32_tc;
+ tc->tc_get_timecount = _SPARC_Get_timecount_clock;
+ tc->tc_counter_mask = 0xffffffff;
+ tc->tc_frequency = ERC32_REAL_TIME_CLOCK_FREQUENCY;
+ tc->tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
+ rtems_timecounter_install(tc);
-static uint32_t erc32_tc_get_timecount( struct timecounter *tc )
+uint32_t _CPU_Counter_frequency(void)
- return rtems_timecounter_simple_downcounter_get(
- tc,
- erc32_tc_get,
- erc32_tc_is_pending
+ return ERC32_REAL_TIME_CLOCK_FREQUENCY;
-static void erc32_tc_at_tick( rtems_timecounter_simple *tc )
+static void erc32_clock_at_tick( void )
- /* Nothing to do */
+ SPARC_Counter *counter;
+ rtems_interrupt_level level;
-static void erc32_tc_tick( void )
- rtems_timecounter_simple_downcounter_tick(
- &erc32_tc,
- erc32_tc_get,
- erc32_tc_at_tick
+ counter = &_SPARC_Counter_mutable;
+ rtems_interrupt_local_disable(level);
+ ERC32_Clear_interrupt( ERC32_INTERRUPT_REAL_TIME_CLOCK );
+ counter->accumulated += counter->interval;
+ rtems_interrupt_local_enable(level);
-static void erc32_counter_initialize( void )
+static void erc32_clock_initialize_early( void )
- _SPARC_Counter_initialize(
- _SPARC_Counter_read_address,
- _SPARC_Counter_difference_clock_period,
- &ERC32_MEC.Real_Time_Clock_Counter
+ /* approximately 1 us per countdown */
+ ERC32_MEC.Real_Time_Clock_Scalar = CLOCK_SPEED - 1;
+ ERC32_MEC.Real_Time_Clock_Counter =
+ rtems_configuration_get_microseconds_per_tick();
+ ERC32_MEC_Set_Real_Time_Clock_Timer_Control(
+ ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING |
+ ERC32_MEC_TIMER_COUNTER_LOAD_SCALER |
+ ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER
+ ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO
-uint32_t _CPU_Counter_frequency(void)
- return ERC32_REAL_TIME_CLOCK_FREQUENCY;
+ counter->read_isr_disabled = _SPARC_Counter_read_clock_isr_disabled;
+ counter->read = _SPARC_Counter_read_clock;
+ counter->counter_register = &ERC32_MEC.Real_Time_Clock_Counter,
+ counter->pending_register = &ERC32_MEC.Interrupt_Pending;
+ counter->pending_mask = UINT32_C(1) << ERC32_INTERRUPT_REAL_TIME_CLOCK;
+ counter->accumulated = rtems_configuration_get_microseconds_per_tick();
+ counter->interval = rtems_configuration_get_microseconds_per_tick();
-#define Clock_driver_support_initialize_hardware() \
+RTEMS_SYSINIT_ITEM(
+ erc32_clock_initialize_early,
+ RTEMS_SYSINIT_CPU_COUNTER,
+ RTEMS_SYSINIT_ORDER_FIRST
+ * The Real Time Clock Counter Timer uses this trap type.
+#define CLOCK_VECTOR ERC32_TRAP_TYPE( ERC32_INTERRUPT_REAL_TIME_CLOCK )
+#define Clock_driver_support_install_isr( _new ) \
+ set_vector( _new, CLOCK_VECTOR, 1 )
+#define Clock_driver_support_set_interrupt_affinity( _online_processors ) \
do { \
- /* approximately 1 us per countdown */ \
- ERC32_MEC.Real_Time_Clock_Scalar = CLOCK_SPEED - 1; \
- ERC32_MEC.Real_Time_Clock_Counter = \
- rtems_configuration_get_microseconds_per_tick(); \
- ERC32_MEC_Set_Real_Time_Clock_Timer_Control( \
- ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING | \
- ERC32_MEC_TIMER_COUNTER_LOAD_SCALER | \
- ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER \
- ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO \
- rtems_timecounter_simple_install( \
- &erc32_tc, \
- ERC32_REAL_TIME_CLOCK_FREQUENCY, \
- rtems_configuration_get_microseconds_per_tick(), \
- erc32_tc_get_timecount \
- erc32_counter_initialize(); \
+ (void) _online_processors; \
} while (0)
-#define Clock_driver_timecounter_tick() erc32_tc_tick()
+#define Clock_driver_support_at_tick() erc32_clock_at_tick()
+#define Clock_driver_support_initialize_hardware() erc32_clock_init()
#include "../../../shared/dev/clock/clockimpl.h"
diff --git a/bsps/sparc/leon2/clock/ckinit.c b/bsps/sparc/leon2/clock/ckinit.c
index f622975832..2707c7daa2 100644
--- a/bsps/sparc/leon2/clock/ckinit.c
+++ b/bsps/sparc/leon2/clock/ckinit.c
@@ -24,42 +24,73 @@
#include <bsp.h>
-static rtems_timecounter_simple leon2_tc;
+extern int CLOCK_SPEED;
+#define LEON2_TIMER_1_FREQUENCY 1000000
+static struct timecounter leon2_tc;
-static uint32_t leon2_tc_get( rtems_timecounter_simple *tc )
+static void leon2_clock_init( void )
- return LEON_REG.Timer_Counter_1;
+ tc = &leon2_tc;
+ tc->tc_frequency = LEON2_TIMER_1_FREQUENCY;
-static bool leon2_tc_is_pending( rtems_timecounter_simple *tc )
+static void leon2_clock_at_tick( void )
- return LEON_Is_interrupt_pending( LEON_INTERRUPT_TIMER1 );
+ LEON_Clear_interrupt( LEON_INTERRUPT_TIMER1 );
-static uint32_t leon2_tc_get_timecount( struct timecounter *tc )
+static void leon2_clock_initialize_early( void )
- tc,
- leon2_tc_get,
- leon2_tc_is_pending
+ LEON_REG.Timer_Reload_1 =
+ rtems_configuration_get_microseconds_per_tick() - 1;
+ LEON_REG.Timer_Control_1 = (
+ LEON_REG_TIMER_COUNTER_ENABLE_COUNTING |
+ LEON_REG_TIMER_COUNTER_RELOAD_AT_ZERO |
+ LEON_REG_TIMER_COUNTER_LOAD_COUNTER
-static void leon2_tc_at_tick( rtems_timecounter_simple *tc )
+ counter->counter_register = &LEON_REG.Timer_Counter_1;
+ counter->pending_register = &LEON_REG.Interrupt_Pending;
+ counter->pending_mask = UINT32_C(1) << LEON_INTERRUPT_TIMER1;
-static void leon2_tc_tick( void )
+ leon2_clock_initialize_early,
- &leon2_tc,
- leon2_tc_get,
- leon2_tc_at_tick
+ return LEON2_TIMER_1_FREQUENCY;
@@ -71,27 +102,9 @@ static void leon2_tc_tick( void )
-extern int CLOCK_SPEED;
+#define Clock_driver_support_at_tick() leon2_clock_at_tick()
- do { \
- LEON_REG.Timer_Reload_1 = \
- rtems_configuration_get_microseconds_per_tick() - 1; \
- LEON_REG.Timer_Control_1 = ( \
- LEON_REG_TIMER_COUNTER_ENABLE_COUNTING | \
- LEON_REG_TIMER_COUNTER_RELOAD_AT_ZERO | \
- LEON_REG_TIMER_COUNTER_LOAD_COUNTER \
- &leon2_tc, \
- 1000000, \
- leon2_tc_get_timecount \
- } while (0)
-#define Clock_driver_timecounter_tick() leon2_tc_tick()
+#define Clock_driver_support_initialize_hardware() leon2_clock_init()
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index 0cd78ea716..fecbf32c1b 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -27,6 +27,7 @@
#include <rtems/rtems/intr.h>
#include <ambapp.h>
#include <rtems/score/profiling.h>
+#include <rtems/score/sparcimpl.h>
/* The LEON3 BSP Timer driver can rely on the Driver Manager if the
@@ -42,59 +43,7 @@ static int clkirq;
static void (*leon3_tc_tick)(void);
-static rtems_timecounter_simple leon3_tc;
-#ifndef RTEMS_SMP
-static uint32_t leon3_tc_get(rtems_timecounter_simple *tc)
- return LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].value;
-static bool leon3_tc_is_pending(rtems_timecounter_simple *tc)
- return LEON_Is_interrupt_pending(clkirq);
-static void leon3_tc_at_tick( rtems_timecounter_simple *tc )
-static uint32_t leon3_tc_get_timecount(struct timecounter *tc)
- tc,
- leon3_tc_get,
- leon3_tc_is_pending
-static void leon3_tc_tick_simple(void)
- &leon3_tc,
- leon3_tc_get,
- leon3_tc_at_tick
-#endif
-static uint32_t leon3_tc_get_timecount_up_counter(struct timecounter *tc)
- return leon3_up_counter_low();
-static uint32_t leon3_tc_get_timecount_irqmp(struct timecounter *tc)
- return LEON3_IrqCtrl_Regs->timestamp[0].counter;
-#ifdef RTEMS_SMP
-static uint32_t leon3_tc_get_timecount_second_timer(struct timecounter *tc)
- return 0xffffffff - LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX + 1].value;
-#endif
+static struct timecounter leon3_tc;
#ifdef RTEMS_PROFILING
#define IRQMP_TIMESTAMP_S1_S2 ((1U << 25) | (1U << 26))
@@ -146,12 +95,23 @@ static void leon3_tc_tick_irqmp_timestamp_init(void)
rtems_timecounter_tick();
-#ifdef RTEMS_SMP
-static void leon3_tc_tick_second_timer(void)
+static void leon3_tc_tick_default(void)
+#ifndef RTEMS_SMP
+ LEON3_IrqCtrl_Regs->iclear = counter->pending_mask;
+#endif
-#endif
static void leon3_tc_do_tick(void)
@@ -196,9 +156,11 @@ static void leon3_clock_initialize(void)
volatile struct irqmp_timestamp_regs *irqmp_ts;
volatile struct gptimer_regs *gpt;
irqmp_ts = &LEON3_IrqCtrl_Regs->timestamp[0];
gpt = LEON3_Timer_Regs;
+ tc = &leon3_tc;
gpt->timer[LEON3_CLOCK_INDEX].reload =
@@ -210,10 +172,8 @@ static void leon3_clock_initialize(void)
if (leon3_up_counter_is_available()) {
/* Use the LEON4 up-counter if available */
- leon3_tc.tc.tc_get_timecount = leon3_tc_get_timecount_up_counter;
- leon3_tc.tc.tc_counter_mask = 0xffffffff;
- leon3_tc.tc.tc_frequency = leon3_up_counter_frequency();
- leon3_tc.tc.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
+ tc->tc_get_timecount = _SPARC_Get_timecount_asr23;
+ tc->tc_frequency = leon3_up_counter_frequency();
if (!leon3_irqmp_has_timestamp(irqmp_ts)) {
@@ -222,13 +182,11 @@ static void leon3_clock_initialize(void)
#endif
leon3_tc_tick = leon3_tc_tick_irqmp_timestamp_init;
- rtems_timecounter_install(&leon3_tc.tc);
} else if (leon3_irqmp_has_timestamp(irqmp_ts)) {
/* Use the interrupt controller timestamp counter if available */
- leon3_tc.tc.tc_get_timecount = leon3_tc_get_timecount_irqmp;
- leon3_tc.tc.tc_frequency = ambapp_freq_get(&ambapp_plb, LEON3_Timer_Adev);
+ tc->tc_get_timecount = _SPARC_Get_timecount_up;
+ tc->tc_frequency = ambapp_freq_get(&ambapp_plb, LEON3_Timer_Adev);
@@ -236,8 +194,6 @@ static void leon3_clock_initialize(void)
* counter. Use an arbitrary interrupt source.
irqmp_ts->control = 0x1;
} else {
#ifdef RTEMS_SMP
@@ -245,24 +201,32 @@ static void leon3_clock_initialize(void)
* controller. At least on SMP configurations we must use a second timer
* in free running mode for the timecounter.
- gpt->timer[LEON3_CLOCK_INDEX + 1].ctrl =
+ gpt->timer[LEON3_COUNTER_GPTIMER_INDEX].ctrl =
GPTIMER_TIMER_CTRL_EN | GPTIMER_TIMER_CTRL_IE;
- leon3_tc.tc.tc_get_timecount = leon3_tc_get_timecount_second_timer;
- leon3_tc.tc.tc_frequency = LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER;
- leon3_tc_tick = leon3_tc_tick_second_timer;
+ tc->tc_get_timecount = _SPARC_Get_timecount_down;
#else
- leon3_tc_tick = leon3_tc_tick_simple;
- &leon3_tc,
- LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER,
- leon3_tc_get_timecount
+ counter->counter_register = &gpt->timer[LEON3_CLOCK_INDEX].value;
+ counter->pending_register = &LEON3_IrqCtrl_Regs->ipend;
+ counter->pending_mask = UINT32_C(1) << clkirq;
#endif
+ tc->tc_frequency = LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER,
+ leon3_tc_tick = leon3_tc_tick_default;
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 758b760b0b..afe0d91ca4 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -333,6 +333,12 @@ extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
#define LEON3_CLOCK_INDEX 0
#endif
+#if defined(RTEMS_SMP)
+#define LEON3_COUNTER_GPTIMER_INDEX (LEON3_CLOCK_INDEX + 1)
+#else
+#define LEON3_COUNTER_GPTIMER_INDEX LEON3_CLOCK_INDEX
+#endif
* We assume that a boot loader (usually GRMON) initialized the GPTIMER 0 to
* run with 1MHz. This is used to determine all clock frequencies of the PnP
diff --git a/bsps/sparc/leon3/start/cpucounter.c b/bsps/sparc/leon3/start/cpucounter.c
index f583d9b0fb..007bb6d8ec 100644
--- a/bsps/sparc/leon3/start/cpucounter.c
+++ b/bsps/sparc/leon3/start/cpucounter.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2014, 2016 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2014, 2018 embedded brains GmbH. All rights reserved.
* Dornierstr. 4
@@ -29,46 +29,38 @@ static void leon3_counter_initialize(void)
leon3_up_counter_enable();
- _SPARC_Counter_read_asr23,
- _SPARC_Counter_difference_normal,
- NULL
+ counter->read_isr_disabled = _SPARC_Counter_read_asr23;
+ counter->read = _SPARC_Counter_read_asr23;
leon3_counter_frequency = leon3_up_counter_frequency();
+ counter->read_isr_disabled = _SPARC_Counter_read_up;
+ counter->read = _SPARC_Counter_read_up;
+ counter->counter_register = &LEON3_IrqCtrl_Regs->timestamp[0].counter;
/* Enable interrupt timestamping for an arbitrary interrupt line */
- (volatile const uint32_t *) &irqmp_ts->counter
leon3_counter_frequency = ambapp_freq_get(&ambapp_plb, LEON3_IrqCtrl_Adev);
} else if (gpt != NULL) {
/* Fall back to the first GPTIMER if available */
+ counter->read_isr_disabled = _SPARC_Counter_read_down;
+ counter->read = _SPARC_Counter_read_down;
+ counter->counter_register = &gpt->timer[LEON3_COUNTER_GPTIMER_INDEX].value;
/* Enable timer just in case no clock driver is configured */
- gpt->timer[LEON3_CLOCK_INDEX].ctrl |= GPTIMER_TIMER_CTRL_EN;
- (volatile const uint32_t *) &gpt->timer[LEON3_CLOCK_INDEX].value
+ gpt->timer[LEON3_COUNTER_GPTIMER_INDEX].ctrl |= GPTIMER_TIMER_CTRL_EN;
leon3_counter_frequency = ambapp_freq_get(&ambapp_plb, LEON3_Timer_Adev) /
(gpt->scaler_reload + 1);
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 7471007ef9..72946c03db 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -26,7 +26,6 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/leon2/start/bspstart.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/start/bspgetworkarea.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/leon2/start/setvec.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 5eee92d2d6..87b9236638 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1756,7 +1756,6 @@ librtemscpu_a_SOURCES += score/cpu/sparc/sparc-access.S
librtemscpu_a_SOURCES += score/cpu/sparc/sparc-context-validate.S
librtemscpu_a_SOURCES += score/cpu/sparc/sparc-context-volatile-clobber.S
librtemscpu_a_SOURCES += score/cpu/sparc/sparc-counter-asm.S
-librtemscpu_a_SOURCES += score/cpu/sparc/sparc-counter.c
librtemscpu_a_SOURCES += score/cpu/sparc/syscall.S
librtemscpu_a_SOURCES += score/cpu/sparc/window.S
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index 7ab09d990e..6b6094ae10 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -1219,10 +1219,13 @@ CPU_Counter_ticks _CPU_Counter_read( void );
* @return Returns second minus first modulo counter period.
+static inline CPU_Counter_ticks _CPU_Counter_difference(
+ return second - first;
#ifdef RTEMS_SMP
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index 0d1566a0c9..663a1755ba 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -712,10 +712,13 @@ uint32_t _CPU_Counter_frequency( void );
/** Type that can store a 32-bit integer or a pointer. */
typedef uintptr_t CPU_Uint32ptr;
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
index 252aa4026e..abc813cfa5 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
@@ -1103,29 +1103,28 @@ uint32_t _CPU_Counter_frequency( void );
typedef CPU_Counter_ticks ( *SPARC_Counter_read )( void );
-typedef CPU_Counter_ticks ( *SPARC_Counter_difference )(
* The SPARC processors supported by RTEMS have no built-in CPU counter
* support. We have to use some hardware counter module for this purpose, for
* example the GPTIMER instance used by the clock driver. The BSP must provide
- * an implementation of the CPU counter read and difference functions. This
- * allows the use of dynamic hardware enumeration.
+ * an implementation of the CPU counter read function. This allows the use of
+ * dynamic hardware enumeration.
typedef struct {
- SPARC_Counter_read counter_read;
- SPARC_Counter_difference counter_difference;
- volatile const CPU_Counter_ticks *counter_address;
+ SPARC_Counter_read read_isr_disabled;
+ SPARC_Counter_read read;
+ volatile const CPU_Counter_ticks *counter_register;
+ volatile const uint32_t *pending_register;
+ uint32_t pending_mask;
+ CPU_Counter_ticks accumulated;
+ CPU_Counter_ticks interval;
} SPARC_Counter;
extern const SPARC_Counter _SPARC_Counter;
static inline CPU_Counter_ticks _CPU_Counter_read( void )
- return ( *_SPARC_Counter.counter_read )();
+ return ( *_SPARC_Counter.read )();
@@ -1133,7 +1132,7 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
- return ( *_SPARC_Counter.counter_difference )( second, first );
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h b/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h
index 81b4441b25..edc03bd074 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h
@@ -1,5 +1,5 @@
- * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2016, 2018 embedded brains GmbH. All rights reserved.
* Dornierstr. 4
@@ -21,6 +21,8 @@
extern "C" {
#endif /* __cplusplus */
+struct timecounter;
* Provides a mutable alias to _SPARC_Counter for use in
* _SPARC_Counter_initialize(). The _SPARC_Counter and _SPARC_Counter_mutable
@@ -28,40 +30,27 @@ extern "C" {
extern SPARC_Counter _SPARC_Counter_mutable;
-CPU_Counter_ticks _SPARC_Counter_read_address( void );
+void _SPARC_Counter_at_tick_clock( void );
+CPU_Counter_ticks _SPARC_Counter_read_default( void );
+CPU_Counter_ticks _SPARC_Counter_read_up( void );
+CPU_Counter_ticks _SPARC_Counter_read_down( void );
+CPU_Counter_ticks _SPARC_Counter_read_clock_isr_disabled( void );
+CPU_Counter_ticks _SPARC_Counter_read_clock( void );
CPU_Counter_ticks _SPARC_Counter_read_asr23( void );
-CPU_Counter_ticks _SPARC_Counter_difference_normal(
+uint32_t _SPARC_Get_timecount_up( struct timecounter * );
-CPU_Counter_ticks _SPARC_Counter_difference_clock_period(
+uint32_t _SPARC_Get_timecount_down( struct timecounter * );
- * Returns always a value of one regardless of the parameters. This prevents
- * an infinite loop in rtems_counter_delay_ticks(). Its only a reasonably safe
- * default.
-CPU_Counter_ticks _SPARC_Counter_difference_one(
-static inline void _SPARC_Counter_initialize(
- SPARC_Counter_read counter_read,
- SPARC_Counter_difference counter_difference,
- _SPARC_Counter_mutable.counter_read = counter_read;
- _SPARC_Counter_mutable.counter_difference = counter_difference;
- _SPARC_Counter_mutable.counter_address = counter_address;
+uint32_t _SPARC_Get_timecount_clock( struct timecounter * );
+uint32_t _SPARC_Get_timecount_asr23( struct timecounter * );
* Defines the _SPARC_Counter and _SPARC_Counter_mutable global variables.
@@ -75,12 +64,16 @@ static inline void _SPARC_Counter_initialize(
"\t.section\t.data._SPARC_Counter,\"aw\", at progbits\n" \
"\t.align\t4\n" \
"\t.type\t_SPARC_Counter, #object\n" \
- "\t.size\t_SPARC_Counter, 12\n" \
+ "\t.size\t_SPARC_Counter, 28\n" \
"_SPARC_Counter:\n" \
"_SPARC_Counter_mutable:\n" \
- "\t.long\t_SPARC_Counter_read_address\n" \
- "\t.long\t_SPARC_Counter_difference_one\n" \
- "\t.long\t_SPARC_Counter\n" \
+ "\t.long\t_SPARC_Counter_read_default\n" \
+ "\t.long\t0\n" \
+ "\t.long\t0\n" \
+ "\t.long\t0\n" \
+ "\t.long\t0\n" \
+ "\t.long\t0\n" \
"\t.previous\n" \
diff --git a/cpukit/score/cpu/sparc/sparc-counter-asm.S b/cpukit/score/cpu/sparc/sparc-counter-asm.S
index 8ed079f48b..c0d557ff7d 100644
--- a/cpukit/score/cpu/sparc/sparc-counter-asm.S
+++ b/cpukit/score/cpu/sparc/sparc-counter-asm.S
@@ -1,5 +1,5 @@
* Dornierstr. 4
@@ -18,17 +18,91 @@
#include <rtems/asm.h>
+ * All functions except _SPARC_Counter_read_clock() in this module are
+ * sometimes called with traps disabled.
.section ".text"
.align 4
- PUBLIC(_SPARC_Counter_read_address)
-SYM(_SPARC_Counter_read_address):
+ PUBLIC(_SPARC_Counter_read_default)
+SYM(_SPARC_Counter_read_default):
+ sethi %hi(_SPARC_Counter + 12), %o1
+ ld [%o1 + %lo(_SPARC_Counter + 12)], %o0
+ add %o0, 1, %o0
+ jmp %o7 + 8
+ st %o0, [%o1 + %lo(_SPARC_Counter + 12)]
+ PUBLIC(_SPARC_Counter_read_up)
+ PUBLIC(_SPARC_Get_timecount_up)
+SYM(_SPARC_Counter_read_up):
+SYM(_SPARC_Get_timecount_up):
sethi %hi(_SPARC_Counter + 8), %o0
ld [%o0 + %lo(_SPARC_Counter + 8)], %o0
jmp %o7 + 8
ld [%o0], %o0
+ PUBLIC(_SPARC_Counter_read_down)
+ PUBLIC(_SPARC_Get_timecount_down)
+SYM(_SPARC_Counter_read_down):
+SYM(_SPARC_Get_timecount_down):
+ sethi %hi(_SPARC_Counter + 8), %o0
+ ld [%o0 + %lo(_SPARC_Counter + 8)], %o0
+ ld [%o0], %o0
+ jmp %o7 + 8
+ xnor %g0, %o0, %o0
+ PUBLIC(_SPARC_Counter_read_clock_isr_disabled)
+SYM(_SPARC_Counter_read_clock_isr_disabled):
+ sethi %hi(_SPARC_Counter), %o5
+ or %o5, %lo(_SPARC_Counter), %o5
+ ld [%o5 + 8], %o3
+ ld [%o5 + 12], %o4
+ ld [%o5 + 16], %o2
+ ld [%o3], %o0
+ ld [%o4], %o1
+ btst %o1, %o2
+ bne .Lpending_isr_disabled
+ ld [%o5 + 20], %o4
+ jmp %o7 + 8
+ sub %o4, %o0, %o0
+.Lpending_isr_disabled:
+ ld [%o5 + 24], %o5
+ ld [%o3], %o0
+ add %o4, %o5, %o4
+ jmp %o7 + 8
+ sub %o4, %o0, %o0
+ PUBLIC(_SPARC_Counter_read_clock)
+ PUBLIC(_SPARC_Get_timecount_clock)
+SYM(_SPARC_Counter_read_clock):
+SYM(_SPARC_Get_timecount_clock):
+ ta SPARC_SWTRAP_IRQDIS
+ ld [%o5 + 8], %o3
+ ld [%o3], %o0
+ ld [%o4], %o1
+ btst %o1, %o2
+ bne .Lpending
+ ta SPARC_SWTRAP_IRQEN
+ jmp %o7 + 8
+ sub %o4, %o0, %o0
+.Lpending:
+ ld [%o3], %o0
+ add %o4, %o5, %o4
+ jmp %o7 + 8
+ sub %o4, %o0, %o0
PUBLIC(_SPARC_Counter_read_asr23)
+ PUBLIC(_SPARC_Get_timecount_asr23)
SYM(_SPARC_Counter_read_asr23):
+SYM(_SPARC_Get_timecount_asr23):
jmp %o7 + 8
mov %asr23, %o0
diff --git a/cpukit/score/cpu/sparc/sparc-counter.c b/cpukit/score/cpu/sparc/sparc-counter.c
index 9bc4061e9e..0000000000
--- a/cpukit/score/cpu/sparc/sparc-counter.c
+++ /dev/null
@@ -1,48 +0,0 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
-#if HAVE_CONFIG_H
- #include "config.h"
-#endif
-#include <rtems/score/sparcimpl.h>
-#include <rtems/config.h>
- CPU_Counter_ticks period;
- period = rtems_configuration_get_microseconds_per_tick();
- return ( first + period - second ) % period;
- return 1;
2.16.4
