[PATCH] eng/coding-doxygen: Fix errors
Marçal Comajoan Cara
mcomajoancara at gmail.com
Wed Dec 5 14:44:52 UTC 2018
This work was part of GCI 2018.
eng/coding-doxygen.rst | 732 +++++++++++++++++++++--------------------
1 file changed, 370 insertions(+), 362 deletions(-)
diff --git a/eng/coding-doxygen.rst b/eng/coding-doxygen.rst
index 49c53bb..ee5f693 100644
--- a/eng/coding-doxygen.rst
+++ b/eng/coding-doxygen.rst
@@ -4,10 +4,10 @@
.. COMMENT: RTEMS Foundation, The RTEMS Documentation Project
General Doxygen Recommentations
-TBD - Convert the following to Rest and insert into this file
-TBD - https://devel.rtems.org/wiki/Developer/Coding/Doxygen
+.. COMMENT: TBD - Convert the following to Rest and insert into this file
+.. COMMENT: TBD - https://devel.rtems.org/wiki/Developer/Coding/Doxygen
.. sidebar:: *History*
@@ -23,451 +23,459 @@ TBD - https://devel.rtems.org/wiki/Developer/Coding/Doxygen
diagrams.
Doxygen Best Practices
-* Do not use @a. Instead use @param to document function parameters.
-* Do not use @return. Instead use @retval to document return status codes.
+* Do not use ``@a``. Instead use ``@param`` to document function parameters.
+* Do not use ``@return``. Instead use ``@retval`` to document return status
+ codes.
* Do not write documentation for trivial functions.
-* Do not repeat documentation, use @see for example.
-* Do not use @note.
-* Use groups and arrange them in a hierarchy. Put every file into at least one group.
+* Do not repeat documentation, use ``@see`` for example.
+* Do not use ``@note``.
+* Use groups and arrange them in a hierarchy. Put every file into at least
+ one group.
* Use dot comments for state diagrams.
-* Use one whitespace character after an asterisk.
+* Use one whitespace character after an asterisk.
-Special Notes for Google Code In Students
+Special Notes for Google Code-in Students
-* Follow the directions given by the `Google Code In
-<https://devel.rtems.org/wiki/GCI>`_ task and this should take care
-of itself if in doubt ask a mentor and/or tell a mentor the decision
-you made.
+Follow the directions given by the `Google Code-in
+<https://devel.rtems.org/wiki/GCI>`_ task and this should take
+care of itself if in doubt ask a mentor and/or tell a mentor the decision you
+made.
Header File Example
-The files *thread.h*
-(https://git.rtems.org/rtems/tree/cpukit/score/include/rtems/score/thread.h)
-and *threadimpl.h*
-(https://git.rtems.org/rtems/tree/cpukit/score/include/rtems/score/threadimpl.h)
-should be a good example of how a header file should be written. The
-following gives details in bits and pieces.
+`thread.h
+<https://git.rtems.org/rtems/tree/cpukit/include/rtems/score/thread.h>`_ and
+`threadimpl.h
+<https://git.rtems.org/rtems/tree/cpukit/include/rtems/score/threadimpl.h>`_
+should be a good example of how a header file shouldbe written. The following
+gives details in bits and pieces.
Header blocks
-Header files should contain the similar comment blocks as other source files, described at `Boilerplate File Header <https://devel.rtems.org/wiki/Developer/Coding/Boilerplate_File_Header>`_.
- .. code-block:: c
- * @file
- * @ingroup FlipFlop
- * @brief Flip-Flop API
- * Copyright (c) YYYY Author.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-Header Guard
+Header files should contain the similar comment blocks as other source files,
+described at :ref:`coding-file-hdr`.
+.. code-block:: c
+ * @file
+ * @ingroup FlipFlop
+ * @brief Flip-Flop API
+ * Copyright (c) YYYY Author.
+ * http://www.rtems.com/license/LICENSE.
+Header guard
-After the comment blocks, use a header guard that assembles at
-least the include path of the file. For example, if flipflop.h is in
-<rtems/lib/flipflop.h> then
+After the comment blocks, use a header guard that assembles at least the
+include path of the file. For example, if ``flipflop.h`` is in
+``<rtems/lib/flipflop.h>`` then
- .. code-block:: c
+.. code-block:: c
- #ifndef RTEMS_LIB_FLIP_FLOP_H
- #define RTEMS_LIB_FLIP_FLOP_H
+ #ifndef RTEMS_LIB_FLIP_FLOP_H
+ #define RTEMS_LIB_FLIP_FLOP_H
Includes
Then add your include files before protecting C declarations from C++.
+.. code-block:: c
- .. code-block:: c
- #include <rtems.h>
+ #include <rtems.h>
- #ifdef __cplusplus
- extern "C" {
- #endif /* __cplusplus */
+ #ifdef __cplusplus
+ extern "C" {
+ #endif /* __cplusplus */
Using @defgroup for group definitions
-Add any group definitions surrounding the function declarations
-that belong in that group. Rarely, a header may define more than one
-group. Here we use a dot diagram.
- .. code-block:: c
- * @defgroup FlipFlop Flip-Flop
- * @brief Simple Flip-Flop state machine.
- * @dot
- * digraph {
- * start [label="START"];
- * flip [label="FLIP"];
- * flop [label="FLOP"];
- * flip -> flop [label="flop()", URL="\ref flop"];
- * flop -> flip [label="flip()", URL="\ref flip"];
- * start -> flip
- * [label="flip_flop_initialize(FLIP)", URL="\ref flip_flop_initialize"];
- * start -> flop
- * [label="flip_flop_initialize(FLOP)", URL="\ref flip_flop_initialize"];
- * flip -> start
- * [label="flip_flop_restart()", URL="\ref flip_flop_restart"];
- * @enddot
+Add any group definitions surrounding the function declarations that belong
+in that group. Rarely, a header may define more than one group. Here we use
+a dot diagram.
+.. code-block:: c
+ * @defgroup FlipFlop Flip-Flop
+ * @brief Simple Flip-Flop state machine.
+ * @dot
+ * digraph {
+ * start [label="START"];
+ * flip [label="FLIP"];
+ * flop [label="FLOP"];
+ * flip -> flop [label="flop()", URL="\ref flop"];
+ * flop -> flip [label="flip()", URL="\ref flip"];
+ * start -> flip
+ * [label="flip_flop_initialize(FLIP)", URL="\ref flip_flop_initialize"];
+ * start -> flop
+ * [label="flip_flop_initialize(FLOP)", URL="\ref flip_flop_initialize"];
+ * flip -> start
+ * [label="flip_flop_restart()", URL="\ref flip_flop_restart"];
+ * @enddot
enum and struct
-Provide documentation for declarations of enumerated types and
-structs. Use typedefs for structs, and do not use _t as a typename suffix.
- .. code-block:: c
- * @brief The set of possible flip-flop states.
- * Enumerated type to define the set of states for a flip-flop.
- typedef enum {
- START = 0,
- FLIP,
- FLOP
- } flip_flop_state;
- * @brief Object containing multiple flip-flops.
- * Encapsulates multiple flip-flops.
- typedef struct {
- * @brief Primary flip-flop.
- flip_flop_state primary;
- * @brief Secondary flip-flop.
- flip_flop_state secondary;
- } flip_flop_multiple;
+Provide documentation for declarations of enumerated types and structs.
+Use typedefs for structs, and do not use ``_t`` as a typename suffix.
+.. code-block:: c
+ * @brief The set of possible flip-flop states.
+ * Enumerated type to define the set of states for a flip-flop.
+ typedef enum {
+ START = 0,
+ FLIP,
+ FLOP
+ } flip_flop_state;
+ * @brief Object containing multiple flip-flops.
+ * Encapsulates multiple flip-flops.
+ typedef struct {
+ * @brief Primary flip-flop.
+ flip_flop_state primary;
+ * @brief Secondary flip-flop.
+ flip_flop_state secondary;
+ } flip_flop_multiple;
Using @name for organization
-Complicated groups can be given additional organization by using @name,
-or by declaring additional groups within the hierarchy of the header
-file's top-level group.
+Complicated groups can be given additional organization by using ``@name``, or
+by declaring additional groups within the hierarchy of the header file's
+top-level group.
- .. code-block:: c
+.. code-block:: c
- * @name Flip-Flop Maintenance
+ * @name Flip-Flop Maintenance
Declaring functions
-Function declarations should have an @brief that states what the function
-does in a single topic sentence starting with a descriptive verb in the
-present tense.
- .. code-block:: c
- * @brief Initializes the flip-flop state.
- * @param[in] state The initial state to set the flip-flop.
- * @retval RTEMS_SUCCESSFUL Successfully initialized.
- * @retval RTEMS_INCORRECT_STATE Flip-flop state is not valid.
- rtems_status_code flip_flop_initialize(flip_flop_state state);
- * @brief Restarts the flip-flop.
- * @retval RTEMS_SUCCESSFUL Successfully restarted.
- * @retval RTEMS_INCORRECT_STATE Flip-flop not in flip state.
- rtems_status_code flip_flop_restart(void);
+Function declarations should have an @brief that states what the function does
+in a single topic sentence starting with a descriptive verb in the present
+tense.
+.. code-block:: c
+ * @brief Initializes the flip-flop state.
+ * @param[in] state The initial state to set the flip-flop.
+ * @retval RTEMS_SUCCESSFUL Successfully initialized.
+ * @retval RTEMS_INCORRECT_STATE Flip-flop state is not valid.
+ rtems_status_code flip_flop_initialize(flip_flop_state state);
+ * @brief Restarts the flip-flop.
+ * @retval RTEMS_SUCCESSFUL Successfully restarted.
+ * @retval RTEMS_INCORRECT_STATE Flip-flop not in flip state.
+ rtems_status_code flip_flop_restart(void);
Do not document trivial functions, such as getter/setter methods.
- .. code-block:: c
+.. code-block:: c
- flip_flop_state flip_flop_current_state(void);
+ flip_flop_state flip_flop_current_state(void);
-Close the documentation name definition and open a new name definition.
+Close the documentation name definition and open a new name definition.
- .. code-block:: c
+.. code-block:: c
- * @name Flip-Flop Usage
+ * @name Flip-Flop Usage
- * @brief Flip operation.
- * @retval RTEMS_SUCCESSFUL Flipped successfully.
- * @retval RTEMS_INCORRECT_STATE Incorrect state for flip operation.
- rtems_status_code flip( void );
+ * @brief Flip operation.
+ * @retval RTEMS_SUCCESSFUL Flipped successfully.
+ * @retval RTEMS_INCORRECT_STATE Incorrect state for flip operation.
+ rtems_status_code flip( void );
- * @brief Flop operation.
- * @retval RTEMS_SUCCESSFUL Flopped successfully.
- * @retval RTEMS_INCORRECT_STATE Incorrect state for flop operation.
- rtems_status_code flop( void );
+ * @brief Flop operation.
+ * @retval RTEMS_SUCCESSFUL Flopped successfully.
+ * @retval RTEMS_INCORRECT_STATE Incorrect state for flop operation.
+ rtems_status_code flop( void );
Ending the file
Close the documentation group definition, then the extern C declarations,
then the header guard.
- .. code-block:: c
+.. code-block:: c
- #endif /* RTEMS_LIB_FLIP_FLOP_H */
+ #endif /* RTEMS_LIB_FLIP_FLOP_H */
-No newline at the end of the file.
+ No newline at the end of the file.
Source File Example
- .. code-block:: c
- * @file
- * @brief Flip-Flop implementation.
- #include <rtems/lib/flipflop.h>
- static flip_flop_state current_state;
- if (current_state == START) {
- current_state = state;
- return RTEMS_SUCCESSFUL;
- } else {
- return RTEMS_INCORRECT_STATE;
- if (current_state == FLIP) {
- current_state = START;
- } else {
- return current_state;
- rtems_status_code flip(void)
- if (current_state == FLOP) {
- current_state = FLIP;
- } else {
- rtems_status_code flop(void)
- current_state = FLOP;
- } else {
+.. code-block:: c
+ * @file
+ * @brief Flip-Flop implementation.
+ #include <rtems/lib/flipflop.h>
+ static flip_flop_state current_state;
+ if (current_state == START) {
+ current_state = state;
+ return RTEMS_SUCCESSFUL;
+ } else {
+ return RTEMS_INCORRECT_STATE;
+ if (current_state == FLIP) {
+ current_state = START;
+ } else {
+ return current_state;
+ rtems_status_code flip(void)
+ if (current_state == FLOP) {
+ current_state = FLIP;
+ } else {
+ rtems_status_code flop(void)
+ current_state = FLOP;
+ } else {
-Document files with the @file directive omitting the optional filename argument. Doxygen will infer the filename from the actual name of the file. Within one Doxygen run all files are unique and specified by the current Doxyfile. We can define how the generated output of path and filenames looks like in the Doxyfile via the FULL_PATH_NAMES, STRIP_FROM_PATH and STRIP_FROM_INC_PATH options.
+Document files with the ``@file`` directive omitting the optional filename
+argument. Doxygen will infer the filename from the actual name of the file.
+Within one Doxygen run all files are unique and specified by the current
+Doxyfile. We can define how the generated output of path and filenames looks
+like in the Doxyfile via the ``FULL_PATH_NAMES``, ``STRIP_FROM_PATH`` and
+``STRIP_FROM_INC_PATH`` options.
-For documentation of function arguments there are basically to ways: The first one uses @param:
- .. code-block::
- * @brief Copies from a source to a destination memory area.
- * The source and destination areas may not overlap.
- * @param[out] dest The destination memory area to copy to.
- * @param[in] src The source memory area to copy from.
- * @param[in] n The number of bytes to copy.
- The second is to use @a param in descriptive text, for example:
- * Copies @a n bytes from a source memory area @a src to a destination memory
- * area @a dest, where both areas may not overlap.
-The @a indicates that the next word is a function argument and deserves some kind of highlighting. However, we feel that @a buries the usage of function arguments within description text. In RTEMS sources, we prefer to use @param instead of @a.
+For documentation of function arguments there are basically to ways:
+The first one uses ``@param``:
+.. code-block:: c
+ * @brief Copies from a source to a destination memory area.
+ * The source and destination areas may not overlap.
+ * @param[out] dest The destination memory area to copy to.
+ * @param[in] src The source memory area to copy from.
+ * @param[in] n The number of bytes to copy.
+The second is to use ``@a`` param in descriptive text, for example:
+.. code-block:: c
+ * Copies @a n bytes from a source memory area @a src to a destination memory
+ * area @a dest, where both areas may not overlap.
+The ``@a`` indicates that the next word is a function argument and deserves
+some kind of highlighting. However, we feel that ``@a`` buries the usage of
+function arguments within description text. In RTEMS sources, we prefer to
+use ``@param`` instead of ``@a``.
Doxyfile Hints
Header Files
-TBD - This is out of date since the include file reorganizaiton
-It is an RTEMS build feature that header files need to be installed
-in order to be useful. One workaround to generate documentation which
-allows automatic link generation is to use the installed header files as
-documentation input. Assume that we have the RTEMS sources in the rtems
-directory and the build of our BSP in build/powerpc-rtems5/mybsp relative
-to a common top-level directory. Then you can configure Doxygen like:
+It is an RTEMS build feature that header files need to be installed in order to
+be useful. One workaround to generate documentation which allows automatic
+link generation is to use the installed header files as documentation input.
+Assume that we have the RTEMS sources in the rtems directory and the build of
+our BSP in build/powerpc-rtems5/mybsp relative to a common top-level directory.
+Then you can configure Doxygen like:
+.. code-block::
- .. code-block::
+ INPUT = rtems/bsps/powerpc/mybsp \
+ rtems/c/src/lib/libcpu/powerpc/mycpu \
+ rtems/make/custom/mybsp.cfg \
+ build/powerpc-rtems5/mybsp/lib/include/myincludes
- INPUT = rtems/bsps/powerpc/mybsp \
- rtems/c/src/lib/libcpu/powerpc/mycpu \
- rtems/make/custom/mybsp.cfg \
- build/powerpc-rtems5/mybsp/lib/include/myincludes
+ RECURSIVE = YES
- RECURSIVE = YES
+ EXCLUDE = rtems/bsps/powerpc/mybsp/include \
+ rtems/c/src/lib/libcpu/powerpc/mycpu/include
- EXCLUDE = rtems/bsps/powerpc/mybsp/include \
- rtems/c/src/lib/libcpu/powerpc/mycpu/include
+ FULL_PATH_NAMES = YES
- FULL_PATH_NAMES = YES
- STRIP_FROM_PATH = build/powerpc-rtems5/mybsp/lib/include \
- rtems
+ STRIP_FROM_PATH = build/powerpc-rtems5/mybsp/lib/include \
+ rtems
Script and Assembly Files
Doxygen cannot cope with script (= files with #-like comments) or assembly
-files. But you can add filter programs for them (TODO: Add source code
-for filter programs somewhere):
+files. But you can add filter programs for them
+.. COMMENT: TBD - Add source code for filter programs somewhere
- .. code-block::
+.. code-block::
- FILTER_PATTERNS = *.S=c-comments-only \
- *.s=c-comments-only \
- *.cfg=script-comments-only \
- *.am=script-comments-only \
- *.ac=script-comments-only
+ FILTER_PATTERNS = *.S=c-comments-only \
+ *.s=c-comments-only \
+ *.cfg=script-comments-only \
+ *.am=script-comments-only \
+ *.ac=script-comments-only
Assembly Example
- .. code-block::
+.. code-block:: c
- * @fn void mpc55xx_fmpll_reset_config()
- * @brief Configure FMPLL after reset.
- * Sets the system clock from 12 MHz in two steps up to 128 MHz.
- GLOBAL_FUNCTION mpc55xx_fmpll_reset_config
- /* Save link register */
- mflr r3
+ * @fn void mpc55xx_fmpll_reset_config()
+ * @brief Configure FMPLL after reset.
+ * Sets the system clock from 12 MHz in two steps up to 128 MHz.
+ GLOBAL_FUNCTION mpc55xx_fmpll_reset_config
+ /* Save link register */
+ mflr r3
- LA r4, FMPLL_SYNCR
+ LA r4, FMPLL_SYNCR
You have to put a declaration of this function somewhere in a header file.
Script Example
- .. code-block:: shell
- # @file
- # @ingroup mpc55xx_config
- # @brief Configure script of LibBSP for the MPC55xx evaluation boards.
- AC_PREREQ(2.60)
- AC_INIT([rtems-c-src-lib-libbsp-powerpc-mpc55xxevb],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+.. code-block:: shell
+ # @file
+ # @ingroup mpc55xx_config
+ # @brief Configure script of LibBSP for the MPC55xx evaluation boards.
+ AC_PREREQ([2.69])
+ AC_INIT([rtems-c-src-lib-libbsp-powerpc-mpc55xxevb],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
GCC Attributes
-The Doxygen C/C++ parser cannot cope with the GCC attribute((something))
-stuff. But you can discard such features with pre-defined preprocessor
-macros:
+The Doxygen C/C++ parser cannot cope with the GCC ``attribute((something))``
+stuff. But you can discard such features with pre-defined preprocessor macros
- ENABLE_PREPROCESSING = YES
- MACRO_EXPANSION = YES
- EXPAND_ONLY_PREDEF = YES
- PREDEFINED = __attribute__(x)=
+ ENABLE_PREPROCESSING = YES
+ MACRO_EXPANSION = YES
+ EXPAND_ONLY_PREDEF = YES
+ PREDEFINED = __attribute__(x)=
2.17.1
