[PATCH] Fix wrong function signatures
kho237115 at gmail.com
Wed Dec 5 21:58:53 UTC 2018
linkers/rtems-score-object.ini | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/linkers/rtems-score-object.ini b/linkers/rtems-score-object.ini
index b4a977f..1e98a71 100644
--- a/linkers/rtems-score-object.ini
+++ b/linkers/rtems-score-object.ini
@@ -31,7 +31,7 @@ _Objects_Get_next = Objects_Control*, Objects_Id, const Objects_Information*, Ob
_Objects_Get_information = Objects_Information*, Objects_APIs, uint16_t
_Objects_Get_information_id = Objects_Information*, Objects_Id
_Objects_Get_name_as_string = char*, Objects_Id, size_t, char*
-_Objects_Set_name = bool, Objects_Information*, Objects_Control*, const char*
+_Objects_Set_name = bool, const Objects_Information*, Objects_Control*, const char*
_Objects_Namespace_remove = void, Objects_Information*, Objects_Control*
-_Objects_Close = void, Objects_Information*, Objects_Control*
+_Objects_Close = void, const Objects_Information*, Objects_Control*
_Objects_Active_count = Objects_Maximum, const Objects_Information*
2.17.1
