psxhdrs: add POSIX API Signature Compliance Tests for stdio.h File (GCI 2018)
Joel Sherrill
joel at rtems.org
Wed Dec 5 22:13:45 UTC 2018
On Wed, Dec 5, 2018 at 3:27 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On Thu, 6 Dec 2018 at 02:03, Joel Sherrill <joel at rtems.org> wrote:
>> Vijay
>> Do you still see it with the committed version of the patch? a couple of
>> methods are listed in the section where file names are comments out with
>> tickets beside them.
>> I still see the warning in the committed version if I compile getline.c
> with -Wall
If you compile by hand you will but it is disabled in the Makefile.am with
this comment:
## Specific issues that tickets are tracking
## lib_a_SOURCES += psxhdrs/dirent/dirfd.c See ticket #3371
## lib_a_SOURCES += psxhdrs/dirent/fdopendir.c See ticket #3371
## lib_a_SOURCES += psxhdrs/stdio/getdelim.c See ticket #3633
## lib_a_SOURCES += psxhdrs/stdio/getline.c See ticket #3633
I think this is OK until we address the issue in newlib.
And this is precisely the type of issue these tests are intended to find. :)
> --joel
>> On Wed, Dec 5, 2018 at 2:26 PM Vijay Kumar Banerjee <
>>> On Thu, 6 Dec 2018 at 01:39, Himanshu Sekhar Nayak <
>>> himanshuwindows8.1 at gmail.com> wrote:
>>>> Hi guys,
>>>> Here is the updated patch.
>>>> There's warning in getline.c even after defining _POSIX_C_SOURCE
>>>> Thanks
>>>> Himanshu
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181205/b61f84f6/attachment-0001.html>
