[PATCH] Fix wrong function signatures
Thu Dec 6 01:54:33 UTC 2018
Pushed.
Thanks
On 06/12/2018 08:58, kho237115 at gmail.com wrote:
> From: kaidoho <kho237115 at gmail.com>
>  linkers/rtems-score-object.ini | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/linkers/rtems-score-object.ini b/linkers/rtems-score-object.ini
> index b4a977f..1e98a71 100644
> --- a/linkers/rtems-score-object.ini
> +++ b/linkers/rtems-score-object.ini
> @@ -31,7 +31,7 @@ _Objects_Get_next = Objects_Control*, Objects_Id, const Objects_Information*, Ob
>  _Objects_Get_information = Objects_Information*, Objects_APIs, uint16_t
>  _Objects_Get_information_id = Objects_Information*, Objects_Id
>  _Objects_Get_name_as_string = char*, Objects_Id, size_t, char*
> -_Objects_Set_name = bool, Objects_Information*, Objects_Control*, const char*
> +_Objects_Set_name = bool, const Objects_Information*, Objects_Control*, const char*
>  _Objects_Namespace_remove = void, Objects_Information*, Objects_Control*
> -_Objects_Close = void, Objects_Information*, Objects_Control*
> +_Objects_Close = void, const Objects_Information*, Objects_Control*
>  _Objects_Active_count = Objects_Maximum, const Objects_Information*
