Best Home for uncrustify configuration file
Thu Dec 6 02:04:18 UTC 2018
On 05/12/2018 17:10, Sebastian Huber wrote:
> On 05/12/2018 05:18, Chris Johns wrote:
>> On 05/12/2018 14:59, Joel Sherrill wrote:
>>> Current location:
>>> https://devel.rtems.org/attachment/wiki/Developer/Coding/Conventions/rtems.uncrustify
>>> Any thoughts on a better location? The page is being converted to Rest for the
>>> SW Eng Handbook.
>> How good is it? The page says the configuration can assist.
>> Should this stay in the wiki? Maybe moved up a level as this page is consumed?
> If it works maybe we could add such scripts to a rtems-tools.
Yes if it works.
> The last time I
> tried to use uncrustify to get the RTEMS style (some years ago) was not very
> successful. I asked a student this week to try out clang-format.
Should we have a command to run what ever tool does the work so the documented
command is always the same?
