[PATCH] rtems: Add rtems_scheduler_get_maximum_priority()
Sebastian Huber
Thu Dec 6 08:57:48 UTC 2018
Update #3636.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/rtems/tasks.h | 15 ++++++++++
cpukit/rtems/src/schedulergetmaxprio.c | 53 +++++++++++++++++++++++++++++++++
testsuites/sptests/spscheduler01/init.c | 26 +++++++++++++++-
4 files changed, 94 insertions(+), 1 deletion(-)
create mode 100644 cpukit/rtems/src/schedulergetmaxprio.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 87b9236638..c65048634b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -758,6 +758,7 @@ librtemscpu_a_SOURCES += rtems/src/rtemsobjectidgetnode.c
librtemscpu_a_SOURCES += rtems/src/rtemsobjectsetname.c
librtemscpu_a_SOURCES += rtems/src/rtemstimer.c
librtemscpu_a_SOURCES += rtems/src/scheduleraddprocessor.c
+librtemscpu_a_SOURCES += rtems/src/schedulergetmaxprio.c
librtemscpu_a_SOURCES += rtems/src/schedulergetprocessorset.c
librtemscpu_a_SOURCES += rtems/src/scheduleridentbyprocessor.c
librtemscpu_a_SOURCES += rtems/src/scheduleridentbyprocessorset.c
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 55863a9dd9..2dde93c73b 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -654,6 +654,21 @@ rtems_status_code rtems_scheduler_remove_processor(
uint32_t cpu_index
+ * @brief Gets the maximum task priority of the specified scheduler instance.
+ * @param[in] scheduler_id Identifier of the scheduler instance.
+ * @param[out] priority Pointer to a task priority value.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The @a priority parameter is @c NULL.
+ * @retval RTEMS_INVALID_ID Invalid scheduler instance identifier.
+rtems_status_code rtems_scheduler_get_maximum_priority(
+ rtems_id scheduler_id,
+ rtems_task_priority *priority
#ifdef __cplusplus
diff --git a/cpukit/rtems/src/schedulergetmaxprio.c b/cpukit/rtems/src/schedulergetmaxprio.c
new file mode 100644
index 0000000000..a1eef31761
--- /dev/null
+++ b/cpukit/rtems/src/schedulergetmaxprio.c
@@ -0,0 +1,53 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasks.h>
+#include <rtems/score/schedulerimpl.h>
+ uint32_t index;
+ if ( priority == NULL ) {
+ return RTEMS_INVALID_ADDRESS;
+ index = _Scheduler_Get_index_by_id( scheduler_id );
+ if ( index >= _Scheduler_Count ) {
+ return RTEMS_INVALID_ID;
+ *priority = _Scheduler_Table[ index ].maximum_priority;
+ return RTEMS_SUCCESSFUL;
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index fc03d0348d..04d65fcdd0 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2014, 2017 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2014, 2018 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
* Dornierstr. 4
@@ -474,6 +474,29 @@ static void test_scheduler_ident(void)
rtems_test_assert(scheduler_id == expected_id);
+static void test_scheduler_get_max_prio(void)
+ rtems_status_code sc;
+ rtems_task_priority priority;
+ rtems_id scheduler_id;
+ priority = 0;
+ sc = rtems_scheduler_get_maximum_priority(invalid_id, &priority);
+ rtems_test_assert(sc == RTEMS_INVALID_ID);
+ rtems_test_assert(priority == 0);
+ sc = rtems_task_get_scheduler(RTEMS_SELF, &scheduler_id);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_scheduler_get_maximum_priority(scheduler_id, NULL);
+ rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+ priority = 0;
+ sc = rtems_scheduler_get_maximum_priority(scheduler_id, &priority);
+ rtems_test_assert(priority == 255);
static void test_scheduler_get_processors(void)
@@ -601,6 +624,7 @@ static void Init(rtems_task_argument arg)
test_task_get_set_affinity();
test_task_get_set_scheduler();
test_scheduler_ident();
+ test_scheduler_get_max_prio();
test_scheduler_get_processors();
test_scheduler_add_remove_processors();
test_task_get_priority();
2.16.4
