[PATCH 5/7] score: Optimize object lookup
Thu Dec 6 14:57:08 UTC 2018
On 28/11/2018 08:20, Sebastian Huber wrote:
> On 26/11/2018 14:12, Sebastian Huber wrote:
>> The local table no longer needs a NULL pointer entry at array index
>> zero.  Adjust all the object iteration loops accordingly.
> I think this is the only problematic change. Previously the local
> table was organized like this:
> Objects_Control *local_table[] = {
>   NULL, // Always
>   NULL or pointer to object with ID index 1 (the first valid index,
> index zero is invalid),
>   NULL or pointer to object with ID index 2,
>   NULL or pointer to object with ID index maximum
> Now it is:
> This is just a minor space optimization. We could also keep the NULL
> entry, but it is technically not required.
I used the new test framework
https://devel.rtems.org/raw-attachment/ticket/3199/contributor.pdf
to profile the _Objects_Get() function and compare the old vs. new
implementation on a QorIQ T4240. The new implementation performs
slightly better under memory pressure conditions, for example:
diff -u qoriq_e6500_32_old.txt qoriq_e6500_32_new.txt
  M:B:ObjectsGetSuccess
  M:V:DirtyCache
  M:N:1024
  M:MI:0.000000039
-M:Q1:0.000000541
-M:Q2:0.000000573
-M:Q3:0.000000721
-M:MX:0.000001739
-M:MAD:0.000000119
-M:D:0.000620305
-M:E:ObjectsGetSuccess:D:0.264528922
+M:Q1:0.000000277
+M:Q2:0.000000540
+M:Q3:0.000000578
+M:MX:0.000001042
+M:MAD:0.000000158
+M:D:0.000492539
+M:E:ObjectsGetSuccess:D:0.262732549
I tested this with the following test code:
#include <t.h>
#include <rtems/rtems/timerimpl.h>
static void
object_get_success(void *arg)
     rtems_id id;
     ISR_lock_Context lock_context;
     id = *(rtems_id *)arg;
     _Objects_Get(id, &lock_context, &_Timer_Information);
     _ISR_lock_ISR_enable(&lock_context);
static void
object_get_invalid_id(void *arg)
     (void)arg;
     _Objects_Get(0, &lock_context, &_Timer_Information);
T_TEST_CASE(measure_object_get)
     static const T_measure_runtime_config config = {
         .sample_count = 1024
     T_measure_runtime_context *ctx;
     T_measure_runtime_request req;
     rtems_status_code sc;
     rtems_id id;
     sc = rtems_timer_create(rtems_build_name('T', 'E', 'S', 'T'), &id);
     T_rsc_success(sc);
     ctx = T_measure_runtime_create(&config);
     T_assert_not_null(ctx);
     memset(&req, 0, sizeof(req));
     req.name = "ObjectsGetSuccess";
     req.body = object_get_success;
     req.arg = &id;
     T_measure_runtime(ctx, &req);
     req.name = "ObjectsGetInvalidID";
     req.body = object_get_invalid_id;
     sc = rtems_timer_delete(id);
     T_rsc_success(sc);
Attached are the test reports.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
A:xyz
S:Platform:RTEMS
S:Compiler:7.3.0 20180125 (RTEMS 5, RSB 30da0c720b78eba16a3f5272206c07415368617b, Newlib 2ab57ad59bc35dafffa69cd4da5e228971de069f)
S:Version:5.0.0.b6db2a24d73d23a4d267772d6b10773272fec3f3
S:BSP:qoriq_e6500_32
S:RTEMS_DEBUG:0
S:RTEMS_MULTIPROCESSING:0
S:RTEMS_POSIX_API:1
S:RTEMS_PROFILING:0
S:RTEMS_SMP:1
B:zalloc_auto
P:0:23:UI1:test-malloc.c:42
P:1:23:UI1:test-malloc.c:43
Y:zalloc_auto:N:2:F:0:D:0.005077
B:wrong_step
P:0:23:UI1:test-plan.c:6
F:1:23:UI1:test-plan.c:7:planned step (2)
Y:wrong_step:N:2:F:1:D:0.006032
B:verbose
P:0:23:UI1:test.c:57
F:1:23:UI1:test.c:58:some test
Y:verbose:N:2:F:1:D:0.004728
B:timer
P:0:23:UI1:test-rtems.c:26
P:1:23:UI1:test-rtems.c:29
P:2:23:UI1:test-rtems.c:33
P:3:23:ISR:test-rtems.c:14
P:4:23:ISR:test-rtems.c:15
P:5:23:UI1:test-rtems.c:38
P:6:23:UI1:test-rtems.c:39
P:7:23:UI1:test-rtems.c:42
Y:timer:N:8:F:0:D:0.023645
B:time_to_string
P:0:23:UI1:test-time.c:11
P:1:23:UI1:test-time.c:12
P:2:23:UI1:test-time.c:13
P:3:23:UI1:test-time.c:14
P:4:23:UI1:test-time.c:17
P:5:23:UI1:test-time.c:18
Y:time_to_string:N:6:F:0:D:0.014116
B:time
P:0:23:UI1:test-time.c:51
P:1:23:UI1:test-time.c:52
P:2:23:UI1:test-time.c:53
P:3:23:UI1:test-time.c:54
P:4:23:UI1:test-time.c:57
P:5:23:UI1:test-time.c:59
P:6:23:UI1:test-time.c:60
P:7:23:UI1:test-time.c:63
P:8:23:UI1:test-time.c:65
P:9:23:UI1:test-time.c:66
P:10:23:UI1:test-time.c:69
P:11:23:UI1:test-time.c:71
P:12:23:UI1:test-time.c:72
P:13:23:UI1:test-time.c:75
P:14:23:UI1:test-time.c:77
P:15:23:UI1:test-time.c:78
P:16:23:UI1:test-time.c:81
P:17:23:UI1:test-time.c:83
P:18:23:UI1:test-time.c:84
P:19:23:UI1:test-time.c:87
P:20:23:UI1:test-time.c:89
P:21:23:UI1:test-time.c:90
P:22:23:UI1:test-time.c:93
P:23:23:UI1:test-time.c:95
P:24:23:UI1:test-time.c:96
P:25:23:UI1:test-time.c:99
P:26:23:UI1:test-time.c:101
P:27:23:UI1:test-time.c:102
P:28:23:UI1:test-time.c:105
P:29:23:UI1:test-time.c:107
P:30:23:UI1:test-time.c:108
P:31:23:UI1:test-time.c:111
P:32:23:UI1:test-time.c:113
P:33:23:UI1:test-time.c:114
P:34:23:UI1:test-time.c:117
P:35:23:UI1:test-time.c:119
P:36:23:UI1:test-time.c:120
P:37:23:UI1:test-time.c:123
P:38:23:UI1:test-time.c:125
P:39:23:UI1:test-time.c:126
Y:time:N:40:F:0:D:0.097747
B:ticks
P:0:23:UI1:test-time.c:147
F:1:23:UI1:test-time.c:148:0 != 0
L:tick frequency 1500000000Hz
L:tick resolution 0ns
L:tick digits 9
P:2:23:UI1:test-time.c:172
P:3:23:UI1:test-time.c:173
P:4:23:UI1:test-time.c:174
P:5:23:UI1:test-time.c:175
Y:ticks:N:6:F:1:D:0.021420
B:tick
L:0.000000000
Y:tick:N:0:F:0:D:0.001337
B:test_true
P:0:23:UI1:test.c:69
F:1:23:UI1:test.c:70:a
F:*:23:UI1:test.c:72:ab 0
P:2:23:UI1:test.c:73
F:3:23:UI1:test.c:74:abc 0
P:4:23:UI1:test.c:75
F:5:23:UI1:test.c:76:abcd 0 1 2
Y:test_true:N:6:F:4:D:0.015507
B:test_psx_success
P:0:23:UI1:test-psx.c:31
F:1:23:UI1:test-psx.c:32:-1 == 0, 0
F:*:23:UI1:test-psx.c:34:-1 == 0, 0
P:2:23:UI1:test-psx.c:35
F:3:23:UI1:test-psx.c:36:-1 == 0, 0
Y:test_psx_success:N:4:F:3:D:0.014204
B:test_psx_error
P:0:23:UI1:test-psx.c:19
F:1:23:UI1:test-psx.c:20:-1 == -1, ENOMEM == ERANGE
F:2:23:UI1:test-psx.c:21:0 == -1, ENOMEM == ENOMEM
F:*:23:UI1:test-psx.c:23:-1 == -1, ENOMEM == ERANGE
F:*:23:UI1:test-psx.c:24:0 == -1, ENOMEM == ENOMEM
P:3:23:UI1:test-psx.c:25
F:4:23:UI1:test-psx.c:26:0 == -1, ENOMEM == ENOMEM
Y:test_psx_error:N:5:F:5:D:0.027331
B:test_null
P:0:23:UI1:test.c:149
F:1:23:UI1:test.c:150:&a == NULL
F:*:23:UI1:test.c:152:&a == NULL
P:2:23:UI1:test.c:153
F:3:23:UI1:test.c:154:&a == NULL
P:4:23:UI1:test.c:155
F:5:23:UI1:test.c:156:&a == NULL
Y:test_null:N:6:F:4:D:0.017855
B:test_not_null
P:0:23:UI1:test.c:163
F:1:23:UI1:test.c:164:NULL != NULL
F:*:23:UI1:test.c:166:NULL != NULL
P:2:23:UI1:test.c:167
F:3:23:UI1:test.c:168:NULL != NULL
P:4:23:UI1:test.c:169
F:5:23:UI1:test.c:170:NULL != NULL
Y:test_not_null:N:6:F:4:D:0.018550
B:test_ne_ushort
P:0:23:UI1:test.c:529
F:1:23:UI1:test.c:530:1 != 1
F:*:23:UI1:test.c:532:4 != 4
P:2:23:UI1:test.c:533
F:3:23:UI1:test.c:534:7 != 7
P:4:23:UI1:test.c:535
F:5:23:UI1:test.c:536:10 != 10
Y:test_ne_ushort:N:6:F:4:D:0.016637
B:test_ne_uptr
P:0:23:UI1:test.c:1681
F:1:23:UI1:test.c:1682:1 != 1
F:*:23:UI1:test.c:1684:4 != 4
P:2:23:UI1:test.c:1685
F:3:23:UI1:test.c:1686:7 != 7
P:4:23:UI1:test.c:1687
F:5:23:UI1:test.c:1688:10 != 10
Y:test_ne_uptr:N:6:F:4:D:0.017246
B:test_ne_ulong
P:0:23:UI1:test.c:817
F:1:23:UI1:test.c:818:1 != 1
F:*:23:UI1:test.c:820:4 != 4
P:2:23:UI1:test.c:821
F:3:23:UI1:test.c:822:7 != 7
P:4:23:UI1:test.c:823
F:5:23:UI1:test.c:824:10 != 10
Y:test_ne_ulong:N:6:F:4:D:0.016638
B:test_ne_ull
P:0:23:UI1:test.c:961
F:1:23:UI1:test.c:962:1 != 1
F:*:23:UI1:test.c:964:4 != 4
P:2:23:UI1:test.c:965
F:3:23:UI1:test.c:966:7 != 7
P:4:23:UI1:test.c:967
F:5:23:UI1:test.c:968:10 != 10
Y:test_ne_ull:N:6:F:4:D:0.016637
B:test_ne_uint
P:0:23:UI1:test.c:673
F:1:23:UI1:test.c:674:1 != 1
F:*:23:UI1:test.c:676:4 != 4
P:2:23:UI1:test.c:677
F:3:23:UI1:test.c:678:7 != 7
P:4:23:UI1:test.c:679
F:5:23:UI1:test.c:680:10 != 10
Y:test_ne_uint:N:6:F:4:D:0.016638
B:test_ne_uchar
P:0:23:UI1:test.c:385
F:1:23:UI1:test.c:386:1 != 1
F:*:23:UI1:test.c:388:4 != 4
P:2:23:UI1:test.c:389
F:3:23:UI1:test.c:390:7 != 7
P:4:23:UI1:test.c:391
F:5:23:UI1:test.c:392:10 != 10
Y:test_ne_uchar:N:6:F:4:D:0.016638
B:test_ne_u8
P:0:23:UI1:test.c:1105
F:1:23:UI1:test.c:1106:1 != 1
F:*:23:UI1:test.c:1108:4 != 4
P:2:23:UI1:test.c:1109
F:3:23:UI1:test.c:1110:7 != 7
P:4:23:UI1:test.c:1111
F:5:23:UI1:test.c:1112:10 != 10
Y:test_ne_u8:N:6:F:4:D:0.017246
B:test_ne_u64
P:0:23:UI1:test.c:1537
F:1:23:UI1:test.c:1538:1 != 1
F:*:23:UI1:test.c:1540:4 != 4
P:2:23:UI1:test.c:1541
F:3:23:UI1:test.c:1542:7 != 7
P:4:23:UI1:test.c:1543
F:5:23:UI1:test.c:1544:10 != 10
Y:test_ne_u64:N:6:F:4:D:0.017246
B:test_ne_u32
P:0:23:UI1:test.c:1393
F:1:23:UI1:test.c:1394:1 != 1
F:*:23:UI1:test.c:1396:4 != 4
P:2:23:UI1:test.c:1397
F:3:23:UI1:test.c:1398:7 != 7
P:4:23:UI1:test.c:1399
F:5:23:UI1:test.c:1400:10 != 10
Y:test_ne_u32:N:6:F:4:D:0.017246
B:test_ne_u16
P:0:23:UI1:test.c:1249
F:1:23:UI1:test.c:1250:1 != 1
F:*:23:UI1:test.c:1252:4 != 4
P:2:23:UI1:test.c:1253
F:3:23:UI1:test.c:1254:7 != 7
P:4:23:UI1:test.c:1255
F:5:23:UI1:test.c:1256:10 != 10
Y:test_ne_u16:N:6:F:4:D:0.017246
B:test_ne_sz
P:0:23:UI1:test.c:1825
F:1:23:UI1:test.c:1826:1 != 1
F:*:23:UI1:test.c:1828:4 != 4
P:2:23:UI1:test.c:1829
F:3:23:UI1:test.c:1830:7 != 7
P:4:23:UI1:test.c:1831
F:5:23:UI1:test.c:1832:10 != 10
Y:test_ne_sz:N:6:F:4:D:0.017246
B:test_ne_str
P:0:23:UI1:test.c:227
F:1:23:UI1:test.c:228:"a" != "a"
F:*:23:UI1:test.c:230:"a" != "a"
P:2:23:UI1:test.c:231
F:3:23:UI1:test.c:232:"a" != "a"
P:4:23:UI1:test.c:233
F:5:23:UI1:test.c:234:"a" != "a"
Y:test_ne_str:N:6:F:4:D:0.017855
B:test_ne_ssz
P:0:23:UI1:test.c:1753
F:1:23:UI1:test.c:1754:1 != 1
F:*:23:UI1:test.c:1756:4 != 4
P:2:23:UI1:test.c:1757
F:3:23:UI1:test.c:1758:7 != 7
P:4:23:UI1:test.c:1759
F:5:23:UI1:test.c:1760:10 != 10
Y:test_ne_ssz:N:6:F:4:D:0.017246
B:test_ne_short
P:0:23:UI1:test.c:457
F:1:23:UI1:test.c:458:1 != 1
F:*:23:UI1:test.c:460:4 != 4
P:2:23:UI1:test.c:461
F:3:23:UI1:test.c:462:7 != 7
P:4:23:UI1:test.c:463
F:5:23:UI1:test.c:464:10 != 10
Y:test_ne_short:N:6:F:4:D:0.016638
B:test_ne_schar
P:0:23:UI1:test.c:313
F:1:23:UI1:test.c:314:1 != 1
F:*:23:UI1:test.c:316:4 != 4
P:2:23:UI1:test.c:317
F:3:23:UI1:test.c:318:7 != 7
P:4:23:UI1:test.c:319
F:5:23:UI1:test.c:320:10 != 10
Y:test_ne_schar:N:6:F:4:D:0.016637
B:test_ne_ptr
P:0:23:UI1:test.c:135
F:1:23:UI1:test.c:136:&a != &a
F:*:23:UI1:test.c:138:&a != &a
F:3:23:UI1:test.c:140:&a != &a
P:4:23:UI1:test.c:141
F:5:23:UI1:test.c:142:&a != &a
Y:test_ne_ptr:N:6:F:4:D:0.017160
B:test_ne_nstr
P:0:23:UI1:test.c:261
F:1:23:UI1:test.c:262:"aaa" != "aaa"
F:2:23:UI1:test.c:263:"aaa" != "aaa"
F:*:23:UI1:test.c:265:"aaa" != "aaa"
F:*:23:UI1:test.c:266:"aaa" != "aaa"
P:3:23:UI1:test.c:267
F:4:23:UI1:test.c:268:"aaa" != "aaa"
F:5:23:UI1:test.c:269:"aaa" != "aaa"
P:6:23:UI1:test.c:270
F:7:23:UI1:test.c:271:"aaa" != "aaa"
Y:test_ne_nstr:N:8:F:7:D:0.029156
B:test_ne_mem
P:0:23:UI1:test.c:197
F:1:23:UI1:test.c:198:memcmp(&a, &a, sizeof(a)) != 0
F:*:23:UI1:test.c:200:memcmp(&a, &a, sizeof(a)) != 0
P:2:23:UI1:test.c:201
F:3:23:UI1:test.c:202:memcmp(&a, &a, sizeof(a)) != 0
P:4:23:UI1:test.c:203
F:5:23:UI1:test.c:204:memcmp(&a, &a, sizeof(a)) != 0
Y:test_ne_mem:N:6:F:4:D:0.024809
B:test_ne_long
P:0:23:UI1:test.c:745
F:1:23:UI1:test.c:746:1 != 1
F:*:23:UI1:test.c:748:4 != 4
P:2:23:UI1:test.c:749
F:3:23:UI1:test.c:750:7 != 7
P:4:23:UI1:test.c:751
F:5:23:UI1:test.c:752:10 != 10
Y:test_ne_long:N:6:F:4:D:0.016638
B:test_ne_ll
P:0:23:UI1:test.c:889
F:1:23:UI1:test.c:890:1 != 1
F:*:23:UI1:test.c:892:4 != 4
P:2:23:UI1:test.c:893
F:3:23:UI1:test.c:894:7 != 7
P:4:23:UI1:test.c:895
F:5:23:UI1:test.c:896:10 != 10
Y:test_ne_ll:N:6:F:4:D:0.016638
B:test_ne_iptr
P:0:23:UI1:test.c:1609
F:1:23:UI1:test.c:1610:1 != 1
F:*:23:UI1:test.c:1612:4 != 4
P:2:23:UI1:test.c:1613
F:3:23:UI1:test.c:1614:7 != 7
P:4:23:UI1:test.c:1615
F:5:23:UI1:test.c:1616:10 != 10
Y:test_ne_iptr:N:6:F:4:D:0.017245
B:test_ne_int
P:0:23:UI1:test.c:601
F:1:23:UI1:test.c:602:1 != 1
F:*:23:UI1:test.c:604:4 != 4
P:2:23:UI1:test.c:605
F:3:23:UI1:test.c:606:7 != 7
P:4:23:UI1:test.c:607
F:5:23:UI1:test.c:608:10 != 10
Y:test_ne_int:N:6:F:4:D:0.016638
B:test_ne_i8
P:0:23:UI1:test.c:1033
F:1:23:UI1:test.c:1034:1 != 1
F:*:23:UI1:test.c:1036:4 != 4
P:2:23:UI1:test.c:1037
F:3:23:UI1:test.c:1038:7 != 7
P:4:23:UI1:test.c:1039
F:5:23:UI1:test.c:1040:10 != 10
Y:test_ne_i8:N:6:F:4:D:0.017246
B:test_ne_i64
P:0:23:UI1:test.c:1465
F:1:23:UI1:test.c:1466:1 != 1
F:*:23:UI1:test.c:1468:4 != 4
P:2:23:UI1:test.c:1469
F:3:23:UI1:test.c:1470:7 != 7
P:4:23:UI1:test.c:1471
F:5:23:UI1:test.c:1472:10 != 10
Y:test_ne_i64:N:6:F:4:D:0.017247
B:test_ne_i32
P:0:23:UI1:test.c:1321
F:1:23:UI1:test.c:1322:1 != 1
F:*:23:UI1:test.c:1324:4 != 4
P:2:23:UI1:test.c:1325
F:3:23:UI1:test.c:1326:7 != 7
P:4:23:UI1:test.c:1327
F:5:23:UI1:test.c:1328:10 != 10
Y:test_ne_i32:N:6:F:4:D:0.017246
B:test_ne_i16
P:0:23:UI1:test.c:1177
F:1:23:UI1:test.c:1178:1 != 1
F:*:23:UI1:test.c:1180:4 != 4
P:2:23:UI1:test.c:1181
F:3:23:UI1:test.c:1182:7 != 7
P:4:23:UI1:test.c:1183
F:5:23:UI1:test.c:1184:10 != 10
Y:test_ne_i16:N:6:F:4:D:0.017247
B:test_ne_char
P:0:23:UI1:test.c:289
F:1:23:UI1:test.c:290:'1' != '1'
F:*:23:UI1:test.c:292:'4' != '4'
P:2:23:UI1:test.c:293
F:3:23:UI1:test.c:294:'7' != '7'
P:4:23:UI1:test.c:295
F:5:23:UI1:test.c:296:'A' != 'A'
Y:test_ne_char:N:6:F:4:D:0.017855
B:test_ne
P:0:23:UI1:test.c:105
F:1:23:UI1:test.c:106:2 != 2
F:*:23:UI1:test.c:108:5 != 5
P:2:23:UI1:test.c:109
F:3:23:UI1:test.c:110:5 != 5
F:5:23:UI1:test.c:112:11 != 11
Y:test_ne:N:6:F:4:D:0.016638
B:test_lt_ushort
P:0:23:UI1:test.c:577
F:1:23:UI1:test.c:578:3 < 3
F:*:23:UI1:test.c:580:6 < 6
P:2:23:UI1:test.c:581
F:3:23:UI1:test.c:582:9 < 9
P:4:23:UI1:test.c:583
F:5:23:UI1:test.c:584:12 < 12
Y:test_lt_ushort:N:6:F:4:D:0.016292
B:test_lt_uptr
P:0:23:UI1:test.c:1729
F:1:23:UI1:test.c:1730:3 < 3
F:*:23:UI1:test.c:1732:6 < 6
P:2:23:UI1:test.c:1733
F:3:23:UI1:test.c:1734:9 < 9
P:4:23:UI1:test.c:1735
F:5:23:UI1:test.c:1736:12 < 12
Y:test_lt_uptr:N:6:F:4:D:0.016899
B:test_lt_ulong
P:0:23:UI1:test.c:865
F:1:23:UI1:test.c:866:3 < 3
F:*:23:UI1:test.c:868:6 < 6
P:2:23:UI1:test.c:869
F:3:23:UI1:test.c:870:9 < 9
P:4:23:UI1:test.c:871
F:5:23:UI1:test.c:872:12 < 12
Y:test_lt_ulong:N:6:F:4:D:0.016291
B:test_lt_ull
P:0:23:UI1:test.c:1009
F:1:23:UI1:test.c:1010:3 < 3
F:*:23:UI1:test.c:1012:6 < 6
P:2:23:UI1:test.c:1013
F:3:23:UI1:test.c:1014:9 < 9
P:4:23:UI1:test.c:1015
F:5:23:UI1:test.c:1016:12 < 12
Y:test_lt_ull:N:6:F:4:D:0.016898
B:test_lt_uint
P:0:23:UI1:test.c:721
F:1:23:UI1:test.c:722:3 < 3
F:*:23:UI1:test.c:724:6 < 6
P:2:23:UI1:test.c:725
F:3:23:UI1:test.c:726:9 < 9
P:4:23:UI1:test.c:727
F:5:23:UI1:test.c:728:12 < 12
Y:test_lt_uint:N:6:F:4:D:0.016290
B:test_lt_uchar
P:0:23:UI1:test.c:433
F:1:23:UI1:test.c:434:3 < 3
F:*:23:UI1:test.c:436:6 < 6
P:2:23:UI1:test.c:437
F:3:23:UI1:test.c:438:9 < 9
P:4:23:UI1:test.c:439
F:5:23:UI1:test.c:440:12 < 12
Y:test_lt_uchar:N:6:F:4:D:0.016292
B:test_lt_u8
P:0:23:UI1:test.c:1153
F:1:23:UI1:test.c:1154:3 < 3
F:*:23:UI1:test.c:1156:6 < 6
P:2:23:UI1:test.c:1157
F:3:23:UI1:test.c:1158:9 < 9
P:4:23:UI1:test.c:1159
F:5:23:UI1:test.c:1160:12 < 12
Y:test_lt_u8:N:6:F:4:D:0.016900
B:test_lt_u64
P:0:23:UI1:test.c:1585
F:1:23:UI1:test.c:1586:3 < 3
F:*:23:UI1:test.c:1588:6 < 6
P:2:23:UI1:test.c:1589
F:3:23:UI1:test.c:1590:9 < 9
P:4:23:UI1:test.c:1591
F:5:23:UI1:test.c:1592:12 < 12
Y:test_lt_u64:N:6:F:4:D:0.016897
B:test_lt_u32
P:0:23:UI1:test.c:1441
F:1:23:UI1:test.c:1442:3 < 3
F:*:23:UI1:test.c:1444:6 < 6
P:2:23:UI1:test.c:1445
F:3:23:UI1:test.c:1446:9 < 9
P:4:23:UI1:test.c:1447
F:5:23:UI1:test.c:1448:12 < 12
Y:test_lt_u32:N:6:F:4:D:0.016899
B:test_lt_u16
P:0:23:UI1:test.c:1297
F:1:23:UI1:test.c:1298:3 < 3
F:*:23:UI1:test.c:1300:6 < 6
P:2:23:UI1:test.c:1301
F:3:23:UI1:test.c:1302:9 < 9
P:4:23:UI1:test.c:1303
F:5:23:UI1:test.c:1304:12 < 12
Y:test_lt_u16:N:6:F:4:D:0.016900
B:test_lt_sz
P:0:23:UI1:test.c:1873
F:1:23:UI1:test.c:1874:3 < 3
F:*:23:UI1:test.c:1876:6 < 6
P:2:23:UI1:test.c:1877
F:3:23:UI1:test.c:1878:9 < 9
P:4:23:UI1:test.c:1879
F:5:23:UI1:test.c:1880:12 < 12
Y:test_lt_sz:N:6:F:4:D:0.016899
B:test_lt_ssz
P:0:23:UI1:test.c:1801
F:1:23:UI1:test.c:1802:3 < 3
F:*:23:UI1:test.c:1804:6 < 6
P:2:23:UI1:test.c:1805
F:3:23:UI1:test.c:1806:9 < 9
P:4:23:UI1:test.c:1807
F:5:23:UI1:test.c:1808:12 < 12
Y:test_lt_ssz:N:6:F:4:D:0.016900
B:test_lt_short
P:0:23:UI1:test.c:505
F:1:23:UI1:test.c:506:3 < 3
F:*:23:UI1:test.c:508:6 < 6
P:2:23:UI1:test.c:509
F:3:23:UI1:test.c:510:9 < 9
P:4:23:UI1:test.c:511
F:5:23:UI1:test.c:512:12 < 12
Y:test_lt_short:N:6:F:4:D:0.016290
B:test_lt_schar
P:0:23:UI1:test.c:361
F:1:23:UI1:test.c:362:3 < 3
F:*:23:UI1:test.c:364:6 < 6
P:2:23:UI1:test.c:365
F:3:23:UI1:test.c:366:9 < 9
P:4:23:UI1:test.c:367
F:5:23:UI1:test.c:368:12 < 12
Y:test_lt_schar:N:6:F:4:D:0.016291
B:test_lt_long
P:0:23:UI1:test.c:793
F:1:23:UI1:test.c:794:3 < 3
F:*:23:UI1:test.c:796:6 < 6
P:2:23:UI1:test.c:797
F:3:23:UI1:test.c:798:9 < 9
P:4:23:UI1:test.c:799
F:5:23:UI1:test.c:800:12 < 12
Y:test_lt_long:N:6:F:4:D:0.016291
B:test_lt_ll
P:0:23:UI1:test.c:937
F:1:23:UI1:test.c:938:3 < 3
F:*:23:UI1:test.c:940:6 < 6
P:2:23:UI1:test.c:941
F:3:23:UI1:test.c:942:9 < 9
P:4:23:UI1:test.c:943
F:5:23:UI1:test.c:944:12 < 12
Y:test_lt_ll:N:6:F:4:D:0.016291
B:test_lt_iptr
P:0:23:UI1:test.c:1657
F:1:23:UI1:test.c:1658:3 < 3
F:*:23:UI1:test.c:1660:6 < 6
P:2:23:UI1:test.c:1661
F:3:23:UI1:test.c:1662:9 < 9
P:4:23:UI1:test.c:1663
F:5:23:UI1:test.c:1664:12 < 12
Y:test_lt_iptr:N:6:F:4:D:0.016901
B:test_lt_int
P:0:23:UI1:test.c:649
F:1:23:UI1:test.c:650:3 < 3
F:*:23:UI1:test.c:652:6 < 6
P:2:23:UI1:test.c:653
F:3:23:UI1:test.c:654:9 < 9
P:4:23:UI1:test.c:655
F:5:23:UI1:test.c:656:12 < 12
Y:test_lt_int:N:6:F:4:D:0.016291
B:test_lt_i8
P:0:23:UI1:test.c:1081
F:1:23:UI1:test.c:1082:3 < 3
F:*:23:UI1:test.c:1084:6 < 6
P:2:23:UI1:test.c:1085
F:3:23:UI1:test.c:1086:9 < 9
P:4:23:UI1:test.c:1087
F:5:23:UI1:test.c:1088:12 < 12
Y:test_lt_i8:N:6:F:4:D:0.016900
B:test_lt_i64
P:0:23:UI1:test.c:1513
F:1:23:UI1:test.c:1514:3 < 3
F:*:23:UI1:test.c:1516:6 < 6
P:2:23:UI1:test.c:1517
F:3:23:UI1:test.c:1518:9 < 9
P:4:23:UI1:test.c:1519
F:5:23:UI1:test.c:1520:12 < 12
Y:test_lt_i64:N:6:F:4:D:0.016899
B:test_lt_i32
P:0:23:UI1:test.c:1369
F:1:23:UI1:test.c:1370:3 < 3
F:*:23:UI1:test.c:1372:6 < 6
P:2:23:UI1:test.c:1373
F:3:23:UI1:test.c:1374:9 < 9
P:4:23:UI1:test.c:1375
F:5:23:UI1:test.c:1376:12 < 12
Y:test_lt_i32:N:6:F:4:D:0.016900
B:test_lt_i16
P:0:23:UI1:test.c:1225
F:1:23:UI1:test.c:1226:3 < 3
F:*:23:UI1:test.c:1228:6 < 6
P:2:23:UI1:test.c:1229
F:3:23:UI1:test.c:1230:9 < 9
P:4:23:UI1:test.c:1231
F:5:23:UI1:test.c:1232:12 < 12
Y:test_lt_i16:N:6:F:4:D:0.016901
B:test_le_ushort
P:0:23:UI1:test.c:565
F:1:23:UI1:test.c:566:3 <= 2
F:*:23:UI1:test.c:568:6 <= 5
P:2:23:UI1:test.c:569
F:3:23:UI1:test.c:570:9 <= 8
P:4:23:UI1:test.c:571
F:5:23:UI1:test.c:572:12 <= 11
Y:test_le_ushort:N:6:F:4:D:0.016638
B:test_le_uptr
P:0:23:UI1:test.c:1717
F:1:23:UI1:test.c:1718:3 <= 2
F:*:23:UI1:test.c:1720:6 <= 5
P:2:23:UI1:test.c:1721
F:3:23:UI1:test.c:1722:9 <= 8
P:4:23:UI1:test.c:1723
F:5:23:UI1:test.c:1724:12 <= 11
Y:test_le_uptr:N:6:F:4:D:0.017247
B:test_le_ulong
P:0:23:UI1:test.c:853
F:1:23:UI1:test.c:854:3 <= 2
F:*:23:UI1:test.c:856:6 <= 5
P:2:23:UI1:test.c:857
F:3:23:UI1:test.c:858:9 <= 8
P:4:23:UI1:test.c:859
F:5:23:UI1:test.c:860:12 <= 11
Y:test_le_ulong:N:6:F:4:D:0.016638
B:test_le_ull
P:0:23:UI1:test.c:997
F:1:23:UI1:test.c:998:3 <= 2
F:*:23:UI1:test.c:1000:6 <= 5
P:2:23:UI1:test.c:1001
F:3:23:UI1:test.c:1002:9 <= 8
P:4:23:UI1:test.c:1003
F:5:23:UI1:test.c:1004:12 <= 11
Y:test_le_ull:N:6:F:4:D:0.017073
B:test_le_uint
P:0:23:UI1:test.c:709
F:1:23:UI1:test.c:710:3 <= 2
F:*:23:UI1:test.c:712:6 <= 5
P:2:23:UI1:test.c:713
F:3:23:UI1:test.c:714:9 <= 8
P:4:23:UI1:test.c:715
F:5:23:UI1:test.c:716:12 <= 11
Y:test_le_uint:N:6:F:4:D:0.016638
B:test_le_uchar
P:0:23:UI1:test.c:421
F:1:23:UI1:test.c:422:3 <= 2
F:*:23:UI1:test.c:424:6 <= 5
P:2:23:UI1:test.c:425
F:3:23:UI1:test.c:426:9 <= 8
P:4:23:UI1:test.c:427
F:5:23:UI1:test.c:428:12 <= 11
Y:test_le_uchar:N:6:F:4:D:0.016638
B:test_le_u8
P:0:23:UI1:test.c:1141
F:1:23:UI1:test.c:1142:3 <= 2
F:*:23:UI1:test.c:1144:6 <= 5
P:2:23:UI1:test.c:1145
F:3:23:UI1:test.c:1146:9 <= 8
P:4:23:UI1:test.c:1147
F:5:23:UI1:test.c:1148:12 <= 11
Y:test_le_u8:N:6:F:4:D:0.017248
B:test_le_u64
P:0:23:UI1:test.c:1573
F:1:23:UI1:test.c:1574:3 <= 2
F:*:23:UI1:test.c:1576:6 <= 5
P:2:23:UI1:test.c:1577
F:3:23:UI1:test.c:1578:9 <= 8
P:4:23:UI1:test.c:1579
F:5:23:UI1:test.c:1580:12 <= 11
Y:test_le_u64:N:6:F:4:D:0.017247
B:test_le_u32
P:0:23:UI1:test.c:1429
F:1:23:UI1:test.c:1430:3 <= 2
F:*:23:UI1:test.c:1432:6 <= 5
P:2:23:UI1:test.c:1433
F:3:23:UI1:test.c:1434:9 <= 8
P:4:23:UI1:test.c:1435
F:5:23:UI1:test.c:1436:12 <= 11
Y:test_le_u32:N:6:F:4:D:0.017248
B:test_le_u16
P:0:23:UI1:test.c:1285
F:1:23:UI1:test.c:1286:3 <= 2
F:*:23:UI1:test.c:1288:6 <= 5
P:2:23:UI1:test.c:1289
F:3:23:UI1:test.c:1290:9 <= 8
P:4:23:UI1:test.c:1291
F:5:23:UI1:test.c:1292:12 <= 11
Y:test_le_u16:N:6:F:4:D:0.017247
B:test_le_sz
P:0:23:UI1:test.c:1861
F:1:23:UI1:test.c:1862:3 <= 2
F:*:23:UI1:test.c:1864:6 <= 5
P:2:23:UI1:test.c:1865
F:3:23:UI1:test.c:1866:9 <= 8
P:4:23:UI1:test.c:1867
F:5:23:UI1:test.c:1868:12 <= 11
Y:test_le_sz:N:6:F:4:D:0.017246
B:test_le_ssz
P:0:23:UI1:test.c:1789
F:1:23:UI1:test.c:1790:3 <= 2
F:*:23:UI1:test.c:1792:6 <= 5
P:2:23:UI1:test.c:1793
F:3:23:UI1:test.c:1794:9 <= 8
P:4:23:UI1:test.c:1795
F:5:23:UI1:test.c:1796:12 <= 11
Y:test_le_ssz:N:6:F:4:D:0.017247
B:test_le_short
P:0:23:UI1:test.c:493
F:1:23:UI1:test.c:494:3 <= 2
F:*:23:UI1:test.c:496:6 <= 5
P:2:23:UI1:test.c:497
F:3:23:UI1:test.c:498:9 <= 8
P:4:23:UI1:test.c:499
F:5:23:UI1:test.c:500:12 <= 11
Y:test_le_short:N:6:F:4:D:0.016637
B:test_le_schar
P:0:23:UI1:test.c:349
F:1:23:UI1:test.c:350:3 <= 2
F:*:23:UI1:test.c:352:6 <= 5
P:2:23:UI1:test.c:353
F:3:23:UI1:test.c:354:9 <= 8
P:4:23:UI1:test.c:355
F:5:23:UI1:test.c:356:12 <= 11
Y:test_le_schar:N:6:F:4:D:0.016639
B:test_le_long
P:0:23:UI1:test.c:781
F:1:23:UI1:test.c:782:3 <= 2
F:*:23:UI1:test.c:784:6 <= 5
P:2:23:UI1:test.c:785
F:3:23:UI1:test.c:786:9 <= 8
P:4:23:UI1:test.c:787
F:5:23:UI1:test.c:788:12 <= 11
Y:test_le_long:N:6:F:4:D:0.016638
B:test_le_ll
P:0:23:UI1:test.c:925
F:1:23:UI1:test.c:926:3 <= 2
F:*:23:UI1:test.c:928:6 <= 5
P:2:23:UI1:test.c:929
F:3:23:UI1:test.c:930:9 <= 8
P:4:23:UI1:test.c:931
F:5:23:UI1:test.c:932:12 <= 11
Y:test_le_ll:N:6:F:4:D:0.016638
B:test_le_iptr
P:0:23:UI1:test.c:1645
F:1:23:UI1:test.c:1646:3 <= 2
F:*:23:UI1:test.c:1648:6 <= 5
P:2:23:UI1:test.c:1649
F:3:23:UI1:test.c:1650:9 <= 8
P:4:23:UI1:test.c:1651
F:5:23:UI1:test.c:1652:12 <= 11
Y:test_le_iptr:N:6:F:4:D:0.017247
B:test_le_int
P:0:23:UI1:test.c:637
F:1:23:UI1:test.c:638:3 <= 2
F:*:23:UI1:test.c:640:6 <= 5
P:2:23:UI1:test.c:641
F:3:23:UI1:test.c:642:9 <= 8
P:4:23:UI1:test.c:643
F:5:23:UI1:test.c:644:12 <= 11
Y:test_le_int:N:6:F:4:D:0.016638
B:test_le_i8
P:0:23:UI1:test.c:1069
F:1:23:UI1:test.c:1070:3 <= 2
F:*:23:UI1:test.c:1072:6 <= 5
P:2:23:UI1:test.c:1073
F:3:23:UI1:test.c:1074:9 <= 8
P:4:23:UI1:test.c:1075
F:5:23:UI1:test.c:1076:12 <= 11
Y:test_le_i8:N:6:F:4:D:0.017246
B:test_le_i64
P:0:23:UI1:test.c:1501
F:1:23:UI1:test.c:1502:3 <= 2
F:*:23:UI1:test.c:1504:6 <= 5
P:2:23:UI1:test.c:1505
F:3:23:UI1:test.c:1506:9 <= 8
P:4:23:UI1:test.c:1507
F:5:23:UI1:test.c:1508:12 <= 11
Y:test_le_i64:N:6:F:4:D:0.017246
B:test_le_i32
P:0:23:UI1:test.c:1357
F:1:23:UI1:test.c:1358:3 <= 2
F:*:23:UI1:test.c:1360:6 <= 5
P:2:23:UI1:test.c:1361
F:3:23:UI1:test.c:1362:9 <= 8
P:4:23:UI1:test.c:1363
F:5:23:UI1:test.c:1364:12 <= 11
Y:test_le_i32:N:6:F:4:D:0.017248
B:test_le_i16
P:0:23:UI1:test.c:1213
F:1:23:UI1:test.c:1214:3 <= 2
F:*:23:UI1:test.c:1216:6 <= 5
P:2:23:UI1:test.c:1217
F:3:23:UI1:test.c:1218:9 <= 8
P:4:23:UI1:test.c:1219
F:5:23:UI1:test.c:1220:12 <= 11
Y:test_le_i16:N:6:F:4:D:0.017247
B:test_gt_ushort
P:0:23:UI1:test.c:553
F:1:23:UI1:test.c:554:3 > 3
F:*:23:UI1:test.c:556:6 > 6
P:2:23:UI1:test.c:557
F:3:23:UI1:test.c:558:9 > 9
F:4:23:UI1:test.c:559:10 > 11
Y:test_gt_ushort:N:5:F:4:D:0.014291
B:test_gt_uptr
P:0:23:UI1:test.c:1705
F:1:23:UI1:test.c:1706:3 > 3
F:*:23:UI1:test.c:1708:6 > 6
P:2:23:UI1:test.c:1709
F:3:23:UI1:test.c:1710:9 > 9
F:4:23:UI1:test.c:1711:10 > 11
Y:test_gt_uptr:N:5:F:4:D:0.014814
B:test_gt_ulong
P:0:23:UI1:test.c:841
F:1:23:UI1:test.c:842:3 > 3
F:*:23:UI1:test.c:844:6 > 6
P:2:23:UI1:test.c:845
F:3:23:UI1:test.c:846:9 > 9
F:4:23:UI1:test.c:847:10 > 11
Y:test_gt_ulong:N:5:F:4:D:0.014290
B:test_gt_ull
P:0:23:UI1:test.c:985
F:1:23:UI1:test.c:986:3 > 3
F:*:23:UI1:test.c:988:6 > 6
P:2:23:UI1:test.c:989
F:3:23:UI1:test.c:990:9 > 9
F:4:23:UI1:test.c:991:10 > 11
Y:test_gt_ull:N:5:F:4:D:0.014290
B:test_gt_uint
P:0:23:UI1:test.c:697
F:1:23:UI1:test.c:698:3 > 3
F:*:23:UI1:test.c:700:6 > 6
P:2:23:UI1:test.c:701
F:3:23:UI1:test.c:702:9 > 9
F:4:23:UI1:test.c:703:10 > 11
Y:test_gt_uint:N:5:F:4:D:0.014290
B:test_gt_uchar
P:0:23:UI1:test.c:409
F:1:23:UI1:test.c:410:3 > 3
F:*:23:UI1:test.c:412:6 > 6
P:2:23:UI1:test.c:413
F:3:23:UI1:test.c:414:9 > 9
F:4:23:UI1:test.c:415:10 > 11
Y:test_gt_uchar:N:5:F:4:D:0.014291
B:test_gt_u8
P:0:23:UI1:test.c:1129
F:1:23:UI1:test.c:1130:3 > 3
F:*:23:UI1:test.c:1132:6 > 6
P:2:23:UI1:test.c:1133
F:3:23:UI1:test.c:1134:9 > 9
F:4:23:UI1:test.c:1135:10 > 11
Y:test_gt_u8:N:5:F:4:D:0.014812
B:test_gt_u64
P:0:23:UI1:test.c:1561
F:1:23:UI1:test.c:1562:3 > 3
F:*:23:UI1:test.c:1564:6 > 6
P:2:23:UI1:test.c:1565
F:3:23:UI1:test.c:1566:9 > 9
F:4:23:UI1:test.c:1567:10 > 11
Y:test_gt_u64:N:5:F:4:D:0.014813
B:test_gt_u32
P:0:23:UI1:test.c:1417
F:1:23:UI1:test.c:1418:3 > 3
F:*:23:UI1:test.c:1420:6 > 6
P:2:23:UI1:test.c:1421
F:3:23:UI1:test.c:1422:9 > 9
F:4:23:UI1:test.c:1423:10 > 11
Y:test_gt_u32:N:5:F:4:D:0.014813
B:test_gt_u16
P:0:23:UI1:test.c:1273
F:1:23:UI1:test.c:1274:3 > 3
F:*:23:UI1:test.c:1276:6 > 6
P:2:23:UI1:test.c:1277
F:3:23:UI1:test.c:1278:9 > 9
F:4:23:UI1:test.c:1279:10 > 11
Y:test_gt_u16:N:5:F:4:D:0.014813
B:test_gt_sz
P:0:23:UI1:test.c:1849
F:1:23:UI1:test.c:1850:3 > 3
F:*:23:UI1:test.c:1852:6 > 6
P:2:23:UI1:test.c:1853
F:3:23:UI1:test.c:1854:9 > 9
F:4:23:UI1:test.c:1855:10 > 11
Y:test_gt_sz:N:5:F:4:D:0.014813
B:test_gt_ssz
P:0:23:UI1:test.c:1777
F:1:23:UI1:test.c:1778:3 > 3
F:*:23:UI1:test.c:1780:6 > 6
P:2:23:UI1:test.c:1781
F:3:23:UI1:test.c:1782:9 > 9
F:4:23:UI1:test.c:1783:10 > 11
Y:test_gt_ssz:N:5:F:4:D:0.014812
B:test_gt_short
P:0:23:UI1:test.c:481
F:1:23:UI1:test.c:482:3 > 3
F:*:23:UI1:test.c:484:6 > 6
P:2:23:UI1:test.c:485
F:3:23:UI1:test.c:486:9 > 9
F:4:23:UI1:test.c:487:10 > 11
Y:test_gt_short:N:5:F:4:D:0.014290
B:test_gt_schar
P:0:23:UI1:test.c:337
F:1:23:UI1:test.c:338:3 > 3
F:*:23:UI1:test.c:340:6 > 6
P:2:23:UI1:test.c:341
F:3:23:UI1:test.c:342:9 > 9
F:4:23:UI1:test.c:343:10 > 11
Y:test_gt_schar:N:5:F:4:D:0.014291
B:test_gt_long
P:0:23:UI1:test.c:769
F:1:23:UI1:test.c:770:3 > 3
F:*:23:UI1:test.c:772:6 > 6
P:2:23:UI1:test.c:773
F:3:23:UI1:test.c:774:9 > 9
F:4:23:UI1:test.c:775:10 > 11
Y:test_gt_long:N:5:F:4:D:0.014289
B:test_gt_ll
P:0:23:UI1:test.c:913
F:1:23:UI1:test.c:914:3 > 3
F:*:23:UI1:test.c:916:6 > 6
P:2:23:UI1:test.c:917
F:3:23:UI1:test.c:918:9 > 9
F:4:23:UI1:test.c:919:10 > 11
Y:test_gt_ll:N:5:F:4:D:0.014290
B:test_gt_iptr
P:0:23:UI1:test.c:1633
F:1:23:UI1:test.c:1634:3 > 3
F:*:23:UI1:test.c:1636:6 > 6
P:2:23:UI1:test.c:1637
F:3:23:UI1:test.c:1638:9 > 9
F:4:23:UI1:test.c:1639:10 > 11
Y:test_gt_iptr:N:5:F:4:D:0.014814
B:test_gt_int
P:0:23:UI1:test.c:625
F:1:23:UI1:test.c:626:3 > 3
F:*:23:UI1:test.c:628:6 > 6
P:2:23:UI1:test.c:629
F:3:23:UI1:test.c:630:9 > 9
F:4:23:UI1:test.c:631:10 > 11
Y:test_gt_int:N:5:F:4:D:0.014290
B:test_gt_i8
P:0:23:UI1:test.c:1057
F:1:23:UI1:test.c:1058:3 > 3
F:*:23:UI1:test.c:1060:6 > 6
P:2:23:UI1:test.c:1061
F:3:23:UI1:test.c:1062:9 > 9
F:4:23:UI1:test.c:1063:10 > 11
Y:test_gt_i8:N:5:F:4:D:0.014813
B:test_gt_i64
P:0:23:UI1:test.c:1489
F:1:23:UI1:test.c:1490:3 > 3
F:*:23:UI1:test.c:1492:6 > 6
P:2:23:UI1:test.c:1493
F:3:23:UI1:test.c:1494:9 > 9
F:4:23:UI1:test.c:1495:10 > 11
Y:test_gt_i64:N:5:F:4:D:0.014813
B:test_gt_i32
P:0:23:UI1:test.c:1345
F:1:23:UI1:test.c:1346:3 > 3
F:*:23:UI1:test.c:1348:6 > 6
P:2:23:UI1:test.c:1349
F:3:23:UI1:test.c:1350:9 > 9
F:4:23:UI1:test.c:1351:10 > 11
Y:test_gt_i32:N:5:F:4:D:0.014813
B:test_gt_i16
P:0:23:UI1:test.c:1201
F:1:23:UI1:test.c:1202:3 > 3
F:*:23:UI1:test.c:1204:6 > 6
P:2:23:UI1:test.c:1205
F:3:23:UI1:test.c:1206:9 > 9
F:4:23:UI1:test.c:1207:10 > 11
Y:test_gt_i16:N:5:F:4:D:0.014814
B:test_ge_ushort
P:0:23:UI1:test.c:541
F:1:23:UI1:test.c:542:2 >= 3
F:*:23:UI1:test.c:544:5 >= 6
P:2:23:UI1:test.c:545
F:3:23:UI1:test.c:546:8 >= 9
P:4:23:UI1:test.c:547
F:5:23:UI1:test.c:548:11 >= 12
Y:test_ge_ushort:N:6:F:4:D:0.016638
B:test_ge_uptr
P:0:23:UI1:test.c:1693
F:1:23:UI1:test.c:1694:2 >= 3
F:*:23:UI1:test.c:1696:5 >= 6
P:2:23:UI1:test.c:1697
F:3:23:UI1:test.c:1698:8 >= 9
P:4:23:UI1:test.c:1699
F:5:23:UI1:test.c:1700:11 >= 12
Y:test_ge_uptr:N:6:F:4:D:0.017248
B:test_ge_ulong
P:0:23:UI1:test.c:829
F:1:23:UI1:test.c:830:2 >= 3
F:*:23:UI1:test.c:832:5 >= 6
P:2:23:UI1:test.c:833
F:3:23:UI1:test.c:834:8 >= 9
P:4:23:UI1:test.c:835
F:5:23:UI1:test.c:836:11 >= 12
Y:test_ge_ulong:N:6:F:4:D:0.016638
B:test_ge_ull
P:0:23:UI1:test.c:973
F:1:23:UI1:test.c:974:2 >= 3
F:*:23:UI1:test.c:976:5 >= 6
P:2:23:UI1:test.c:977
F:3:23:UI1:test.c:978:8 >= 9
P:4:23:UI1:test.c:979
F:5:23:UI1:test.c:980:11 >= 12
Y:test_ge_ull:N:6:F:4:D:0.016638
B:test_ge_uint
P:0:23:UI1:test.c:685
F:1:23:UI1:test.c:686:2 >= 3
F:*:23:UI1:test.c:688:5 >= 6
P:2:23:UI1:test.c:689
F:3:23:UI1:test.c:690:8 >= 9
P:4:23:UI1:test.c:691
F:5:23:UI1:test.c:692:11 >= 12
Y:test_ge_uint:N:6:F:4:D:0.016639
B:test_ge_uchar
P:0:23:UI1:test.c:397
F:1:23:UI1:test.c:398:2 >= 3
F:*:23:UI1:test.c:400:5 >= 6
P:2:23:UI1:test.c:401
F:3:23:UI1:test.c:402:8 >= 9
P:4:23:UI1:test.c:403
F:5:23:UI1:test.c:404:11 >= 12
Y:test_ge_uchar:N:6:F:4:D:0.016640
B:test_ge_u8
P:0:23:UI1:test.c:1117
F:1:23:UI1:test.c:1118:2 >= 3
F:*:23:UI1:test.c:1120:5 >= 6
P:2:23:UI1:test.c:1121
F:3:23:UI1:test.c:1122:8 >= 9
P:4:23:UI1:test.c:1123
F:5:23:UI1:test.c:1124:11 >= 12
Y:test_ge_u8:N:6:F:4:D:0.017247
B:test_ge_u64
P:0:23:UI1:test.c:1549
F:1:23:UI1:test.c:1550:2 >= 3
F:*:23:UI1:test.c:1552:5 >= 6
P:2:23:UI1:test.c:1553
F:3:23:UI1:test.c:1554:8 >= 9
P:4:23:UI1:test.c:1555
F:5:23:UI1:test.c:1556:11 >= 12
Y:test_ge_u64:N:6:F:4:D:0.017245
B:test_ge_u32
P:0:23:UI1:test.c:1405
F:1:23:UI1:test.c:1406:2 >= 3
F:*:23:UI1:test.c:1408:5 >= 6
P:2:23:UI1:test.c:1409
F:3:23:UI1:test.c:1410:8 >= 9
P:4:23:UI1:test.c:1411
F:5:23:UI1:test.c:1412:11 >= 12
Y:test_ge_u32:N:6:F:4:D:0.017247
B:test_ge_u16
P:0:23:UI1:test.c:1261
F:1:23:UI1:test.c:1262:2 >= 3
F:*:23:UI1:test.c:1264:5 >= 6
P:2:23:UI1:test.c:1265
F:3:23:UI1:test.c:1266:8 >= 9
P:4:23:UI1:test.c:1267
F:5:23:UI1:test.c:1268:11 >= 12
Y:test_ge_u16:N:6:F:4:D:0.017247
B:test_ge_sz
P:0:23:UI1:test.c:1837
F:1:23:UI1:test.c:1838:2 >= 3
F:*:23:UI1:test.c:1840:5 >= 6
P:2:23:UI1:test.c:1841
F:3:23:UI1:test.c:1842:8 >= 9
P:4:23:UI1:test.c:1843
F:5:23:UI1:test.c:1844:11 >= 12
Y:test_ge_sz:N:6:F:4:D:0.017246
B:test_ge_ssz
P:0:23:UI1:test.c:1765
F:1:23:UI1:test.c:1766:2 >= 3
F:*:23:UI1:test.c:1768:5 >= 6
P:2:23:UI1:test.c:1769
F:3:23:UI1:test.c:1770:8 >= 9
P:4:23:UI1:test.c:1771
F:5:23:UI1:test.c:1772:11 >= 12
Y:test_ge_ssz:N:6:F:4:D:0.017246
B:test_ge_short
P:0:23:UI1:test.c:469
F:1:23:UI1:test.c:470:2 >= 3
F:*:23:UI1:test.c:472:5 >= 6
P:2:23:UI1:test.c:473
F:3:23:UI1:test.c:474:8 >= 9
P:4:23:UI1:test.c:475
F:5:23:UI1:test.c:476:11 >= 12
Y:test_ge_short:N:6:F:4:D:0.016639
B:test_ge_schar
P:0:23:UI1:test.c:325
F:1:23:UI1:test.c:326:2 >= 3
F:*:23:UI1:test.c:328:5 >= 6
P:2:23:UI1:test.c:329
F:3:23:UI1:test.c:330:8 >= 9
P:4:23:UI1:test.c:331
F:5:23:UI1:test.c:332:11 >= 12
Y:test_ge_schar:N:6:F:4:D:0.016637
B:test_ge_long
P:0:23:UI1:test.c:757
F:1:23:UI1:test.c:758:2 >= 3
F:*:23:UI1:test.c:760:5 >= 6
P:2:23:UI1:test.c:761
F:3:23:UI1:test.c:762:8 >= 9
P:4:23:UI1:test.c:763
F:5:23:UI1:test.c:764:11 >= 12
Y:test_ge_long:N:6:F:4:D:0.016638
B:test_ge_ll
P:0:23:UI1:test.c:901
F:1:23:UI1:test.c:902:2 >= 3
F:*:23:UI1:test.c:904:5 >= 6
P:2:23:UI1:test.c:905
F:3:23:UI1:test.c:906:8 >= 9
P:4:23:UI1:test.c:907
F:5:23:UI1:test.c:908:11 >= 12
Y:test_ge_ll:N:6:F:4:D:0.016638
B:test_ge_iptr
P:0:23:UI1:test.c:1621
F:1:23:UI1:test.c:1622:2 >= 3
F:*:23:UI1:test.c:1624:5 >= 6
P:2:23:UI1:test.c:1625
F:3:23:UI1:test.c:1626:8 >= 9
P:4:23:UI1:test.c:1627
F:5:23:UI1:test.c:1628:11 >= 12
Y:test_ge_iptr:N:6:F:4:D:0.017245
B:test_ge_int
P:0:23:UI1:test.c:613
F:1:23:UI1:test.c:614:2 >= 3
F:*:23:UI1:test.c:616:5 >= 6
P:2:23:UI1:test.c:617
F:3:23:UI1:test.c:618:8 >= 9
P:4:23:UI1:test.c:619
F:5:23:UI1:test.c:620:11 >= 12
Y:test_ge_int:N:6:F:4:D:0.016638
B:test_ge_i8
P:0:23:UI1:test.c:1045
F:1:23:UI1:test.c:1046:2 >= 3
F:*:23:UI1:test.c:1048:5 >= 6
P:2:23:UI1:test.c:1049
F:3:23:UI1:test.c:1050:8 >= 9
P:4:23:UI1:test.c:1051
F:5:23:UI1:test.c:1052:11 >= 12
Y:test_ge_i8:N:6:F:4:D:0.017246
B:test_ge_i64
P:0:23:UI1:test.c:1477
F:1:23:UI1:test.c:1478:2 >= 3
F:*:23:UI1:test.c:1480:5 >= 6
P:2:23:UI1:test.c:1481
F:3:23:UI1:test.c:1482:8 >= 9
P:4:23:UI1:test.c:1483
F:5:23:UI1:test.c:1484:11 >= 12
Y:test_ge_i64:N:6:F:4:D:0.017246
B:test_ge_i32
P:0:23:UI1:test.c:1333
F:1:23:UI1:test.c:1334:2 >= 3
F:*:23:UI1:test.c:1336:5 >= 6
P:2:23:UI1:test.c:1337
F:3:23:UI1:test.c:1338:8 >= 9
P:4:23:UI1:test.c:1339
F:5:23:UI1:test.c:1340:11 >= 12
Y:test_ge_i32:N:6:F:4:D:0.017247
B:test_ge_i16
P:0:23:UI1:test.c:1189
F:1:23:UI1:test.c:1190:2 >= 3
F:*:23:UI1:test.c:1192:5 >= 6
P:2:23:UI1:test.c:1193
F:3:23:UI1:test.c:1194:8 >= 9
P:4:23:UI1:test.c:1195
F:5:23:UI1:test.c:1196:11 >= 12
Y:test_ge_i16:N:6:F:4:D:0.017247
B:test_false
F:1:23:UI1:test.c:82:a
F:*:23:UI1:test.c:84:ab 0
F:3:23:UI1:test.c:86:abc 0
F:5:23:UI1:test.c:88:abcd 0 1 2
Y:test_false:N:6:F:4:D:0.015508
B:test_eq_ushort
P:0:23:UI1:test.c:517
F:1:23:UI1:test.c:518:2 == 3
F:*:23:UI1:test.c:520:5 == 6
P:2:23:UI1:test.c:521
F:3:23:UI1:test.c:522:8 == 9
P:4:23:UI1:test.c:523
F:5:23:UI1:test.c:524:11 == 12
Y:test_eq_ushort:N:6:F:4:D:0.016639
B:test_eq_uptr
P:0:23:UI1:test.c:1669
F:1:23:UI1:test.c:1670:2 == 3
F:*:23:UI1:test.c:1672:5 == 6
P:2:23:UI1:test.c:1673
F:3:23:UI1:test.c:1674:8 == 9
P:4:23:UI1:test.c:1675
F:5:23:UI1:test.c:1676:11 == 12
Y:test_eq_uptr:N:6:F:4:D:0.017248
B:test_eq_ulong
P:0:23:UI1:test.c:805
F:1:23:UI1:test.c:806:2 == 3
F:*:23:UI1:test.c:808:5 == 6
P:2:23:UI1:test.c:809
F:3:23:UI1:test.c:810:8 == 9
P:4:23:UI1:test.c:811
F:5:23:UI1:test.c:812:11 == 12
Y:test_eq_ulong:N:6:F:4:D:0.016638
B:test_eq_ull
P:0:23:UI1:test.c:949
F:1:23:UI1:test.c:950:2 == 3
F:*:23:UI1:test.c:952:5 == 6
P:2:23:UI1:test.c:953
F:3:23:UI1:test.c:954:8 == 9
P:4:23:UI1:test.c:955
F:5:23:UI1:test.c:956:11 == 12
Y:test_eq_ull:N:6:F:4:D:0.016637
B:test_eq_uint
P:0:23:UI1:test.c:661
F:1:23:UI1:test.c:662:2 == 3
F:*:23:UI1:test.c:664:5 == 6
P:2:23:UI1:test.c:665
F:3:23:UI1:test.c:666:8 == 9
P:4:23:UI1:test.c:667
F:5:23:UI1:test.c:668:11 == 12
Y:test_eq_uint:N:6:F:4:D:0.016637
B:test_eq_uchar
P:0:23:UI1:test.c:373
F:1:23:UI1:test.c:374:2 == 3
F:*:23:UI1:test.c:376:5 == 6
P:2:23:UI1:test.c:377
F:3:23:UI1:test.c:378:8 == 9
P:4:23:UI1:test.c:379
F:5:23:UI1:test.c:380:11 == 12
Y:test_eq_uchar:N:6:F:4:D:0.016639
B:test_eq_u8
P:0:23:UI1:test.c:1093
F:1:23:UI1:test.c:1094:2 == 3
F:*:23:UI1:test.c:1096:5 == 6
P:2:23:UI1:test.c:1097
F:3:23:UI1:test.c:1098:8 == 9
P:4:23:UI1:test.c:1099
F:5:23:UI1:test.c:1100:11 == 12
Y:test_eq_u8:N:6:F:4:D:0.017246
B:test_eq_u64
P:0:23:UI1:test.c:1525
F:1:23:UI1:test.c:1526:2 == 3
F:*:23:UI1:test.c:1528:5 == 6
P:2:23:UI1:test.c:1529
F:3:23:UI1:test.c:1530:8 == 9
P:4:23:UI1:test.c:1531
F:5:23:UI1:test.c:1532:11 == 12
Y:test_eq_u64:N:6:F:4:D:0.017245
B:test_eq_u32
P:0:23:UI1:test.c:1381
F:1:23:UI1:test.c:1382:2 == 3
F:*:23:UI1:test.c:1384:5 == 6
P:2:23:UI1:test.c:1385
F:3:23:UI1:test.c:1386:8 == 9
P:4:23:UI1:test.c:1387
F:5:23:UI1:test.c:1388:11 == 12
Y:test_eq_u32:N:6:F:4:D:0.017248
B:test_eq_u16
P:0:23:UI1:test.c:1237
F:1:23:UI1:test.c:1238:2 == 3
F:*:23:UI1:test.c:1240:5 == 6
P:2:23:UI1:test.c:1241
F:3:23:UI1:test.c:1242:8 == 9
P:4:23:UI1:test.c:1243
F:5:23:UI1:test.c:1244:11 == 12
Y:test_eq_u16:N:6:F:4:D:0.017247
B:test_eq_sz
P:0:23:UI1:test.c:1813
F:1:23:UI1:test.c:1814:2 == 3
F:*:23:UI1:test.c:1816:5 == 6
P:2:23:UI1:test.c:1817
F:3:23:UI1:test.c:1818:8 == 9
P:4:23:UI1:test.c:1819
F:5:23:UI1:test.c:1820:11 == 12
Y:test_eq_sz:N:6:F:4:D:0.017247
B:test_eq_str
P:0:23:UI1:test.c:212
F:1:23:UI1:test.c:213:"a" == "b"
F:*:23:UI1:test.c:215:"a" == "b"
P:2:23:UI1:test.c:216
F:3:23:UI1:test.c:217:"a" == "b"
P:4:23:UI1:test.c:218
F:5:23:UI1:test.c:219:"a" == "b"
Y:test_eq_str:N:6:F:4:D:0.017856
B:test_eq_ssz
P:0:23:UI1:test.c:1741
F:1:23:UI1:test.c:1742:2 == 3
F:*:23:UI1:test.c:1744:5 == 6
P:2:23:UI1:test.c:1745
F:3:23:UI1:test.c:1746:8 == 9
P:4:23:UI1:test.c:1747
F:5:23:UI1:test.c:1748:11 == 12
Y:test_eq_ssz:N:6:F:4:D:0.017248
B:test_eq_short
P:0:23:UI1:test.c:445
F:1:23:UI1:test.c:446:2 == 3
F:*:23:UI1:test.c:448:5 == 6
P:2:23:UI1:test.c:449
F:3:23:UI1:test.c:450:8 == 9
P:4:23:UI1:test.c:451
F:5:23:UI1:test.c:452:11 == 12
Y:test_eq_short:N:6:F:4:D:0.016639
B:test_eq_schar
P:0:23:UI1:test.c:301
F:1:23:UI1:test.c:302:2 == 3
F:*:23:UI1:test.c:304:5 == 6
P:2:23:UI1:test.c:305
F:3:23:UI1:test.c:306:8 == 9
P:4:23:UI1:test.c:307
F:5:23:UI1:test.c:308:11 == 12
Y:test_eq_schar:N:6:F:4:D:0.016638
B:test_eq_ptr
F:1:23:UI1:test.c:121:&a == &b
F:*:23:UI1:test.c:123:&a == &b
F:3:23:UI1:test.c:125:&a == &b
F:5:23:UI1:test.c:127:&a == &b
Y:test_eq_ptr:N:6:F:4:D:0.017159
B:test_eq_nstr
P:0:23:UI1:test.c:242
P:1:23:UI1:test.c:243
F:2:23:UI1:test.c:244:"aaa" == "aaab"
F:*:23:UI1:test.c:247:"aaa" == "aaab"
P:3:23:UI1:test.c:248
P:4:23:UI1:test.c:249
F:5:23:UI1:test.c:250:"aaa" == "aaab"
P:6:23:UI1:test.c:251
P:7:23:UI1:test.c:252
F:8:23:UI1:test.c:253:"aaa" == "aaab"
Y:test_eq_nstr:N:9:F:4:D:0.025593
B:test_eq_mem
F:1:23:UI1:test.c:181:memcmp(&a, &b, sizeof(a)) == 0
F:*:23:UI1:test.c:183:memcmp(&a, &b, sizeof(a)) == 0
F:3:23:UI1:test.c:185:memcmp(&a, &b, sizeof(a)) == 0
F:5:23:UI1:test.c:187:memcmp(&a, &b, sizeof(a)) == 0
Y:test_eq_mem:N:6:F:4:D:0.024810
B:test_eq_long
P:0:23:UI1:test.c:733
F:1:23:UI1:test.c:734:2 == 3
F:*:23:UI1:test.c:736:5 == 6
P:2:23:UI1:test.c:737
F:3:23:UI1:test.c:738:8 == 9
P:4:23:UI1:test.c:739
F:5:23:UI1:test.c:740:11 == 12
Y:test_eq_long:N:6:F:4:D:0.016638
B:test_eq_ll
P:0:23:UI1:test.c:877
F:1:23:UI1:test.c:878:2 == 3
F:*:23:UI1:test.c:880:5 == 6
P:2:23:UI1:test.c:881
F:3:23:UI1:test.c:882:8 == 9
P:4:23:UI1:test.c:883
F:5:23:UI1:test.c:884:11 == 12
Y:test_eq_ll:N:6:F:4:D:0.016639
B:test_eq_iptr
P:0:23:UI1:test.c:1597
F:1:23:UI1:test.c:1598:2 == 3
F:*:23:UI1:test.c:1600:5 == 6
P:2:23:UI1:test.c:1601
F:3:23:UI1:test.c:1602:8 == 9
P:4:23:UI1:test.c:1603
F:5:23:UI1:test.c:1604:11 == 12
Y:test_eq_iptr:N:6:F:4:D:0.017247
B:test_eq_int
P:0:23:UI1:test.c:589
F:1:23:UI1:test.c:590:2 == 3
F:*:23:UI1:test.c:592:5 == 6
P:2:23:UI1:test.c:593
F:3:23:UI1:test.c:594:8 == 9
P:4:23:UI1:test.c:595
F:5:23:UI1:test.c:596:11 == 12
Y:test_eq_int:N:6:F:4:D:0.016637
B:test_eq_i8
P:0:23:UI1:test.c:1021
F:1:23:UI1:test.c:1022:2 == 3
F:*:23:UI1:test.c:1024:5 == 6
P:2:23:UI1:test.c:1025
F:3:23:UI1:test.c:1026:8 == 9
P:4:23:UI1:test.c:1027
F:5:23:UI1:test.c:1028:11 == 12
Y:test_eq_i8:N:6:F:4:D:0.017247
B:test_eq_i64
P:0:23:UI1:test.c:1453
F:1:23:UI1:test.c:1454:2 == 3
F:*:23:UI1:test.c:1456:5 == 6
P:2:23:UI1:test.c:1457
F:3:23:UI1:test.c:1458:8 == 9
P:4:23:UI1:test.c:1459
F:5:23:UI1:test.c:1460:11 == 12
Y:test_eq_i64:N:6:F:4:D:0.017247
B:test_eq_i32
P:0:23:UI1:test.c:1309
F:1:23:UI1:test.c:1310:2 == 3
F:*:23:UI1:test.c:1312:5 == 6
P:2:23:UI1:test.c:1313
F:3:23:UI1:test.c:1314:8 == 9
P:4:23:UI1:test.c:1315
F:5:23:UI1:test.c:1316:11 == 12
Y:test_eq_i32:N:6:F:4:D:0.017246
B:test_eq_i16
P:0:23:UI1:test.c:1165
F:1:23:UI1:test.c:1166:2 == 3
F:*:23:UI1:test.c:1168:5 == 6
P:2:23:UI1:test.c:1169
F:3:23:UI1:test.c:1170:8 == 9
P:4:23:UI1:test.c:1171
F:5:23:UI1:test.c:1172:11 == 12
Y:test_eq_i16:N:6:F:4:D:0.017247
B:test_eq_char
P:0:23:UI1:test.c:277
F:1:23:UI1:test.c:278:'2' == '3'
F:*:23:UI1:test.c:280:'5' == '6'
P:2:23:UI1:test.c:281
F:3:23:UI1:test.c:282:'8' == '9'
P:4:23:UI1:test.c:283
F:5:23:UI1:test.c:284:'B' == 'C'
Y:test_eq_char:N:6:F:4:D:0.017855
B:test_eq
F:1:23:UI1:test.c:94:1 == 2
F:*:23:UI1:test.c:96:4 == 5
F:3:23:UI1:test.c:98:7 == 8
P:4:23:UI1:test.c:99
F:5:23:UI1:test.c:100:10 == 11
Y:test_eq:N:6:F:4:D:0.016116
B:test_eno_success
P:0:23:UI1:test-eno.c:43
F:1:23:UI1:test-eno.c:44:ENOMEM == 0
F:*:23:UI1:test-eno.c:46:ENOMEM == 0
P:2:23:UI1:test-eno.c:47
F:3:23:UI1:test-eno.c:48:ENOMEM == 0
Y:test_eno_success:N:4:F:3:D:0.014466
B:test_eno
P:0:23:UI1:test-eno.c:33
F:1:23:UI1:test-eno.c:34:ENOMEM == ERANGE
F:*:23:UI1:test-eno.c:36:ENOMEM == ERANGE
P:2:23:UI1:test-eno.c:37
F:3:23:UI1:test-eno.c:38:ENOMEM == ERANGE
Y:test_eno:N:4:F:3:D:0.015770
B:steps
P:0:23:UI1:test-plan.c:31
P:1:23:UI1:test-plan.c:33
P:2:23:UI1:test-plan.c:34
Y:steps:N:3:F:0:D:0.007074
B:step
P:0:23:UI1:test-step.c:5
F:1:23:UI1:test-step.c:6:planned step (2)
Y:step:N:2:F:1:D:0.006031
B:stat
P:0:23:UI1:test-psx.c:13
Y:stat:N:1:F:0:D:0.002295
B:rsc_success
P:0:23:UI1:test-rtems.c:59
F:1:23:UI1:test-rtems.c:60:RTEMS_INVALID_NUMBER == RTEMS_SUCCESSFUL
F:*:23:UI1:test-rtems.c:62:RTEMS_INVALID_NUMBER == RTEMS_SUCCESSFUL
P:2:23:UI1:test-rtems.c:63
F:3:23:UI1:test-rtems.c:64:RTEMS_INVALID_NUMBER == RTEMS_SUCCESSFUL
Y:rsc_success:N:4:F:3:D:0.022899
B:rsc
P:0:23:UI1:test-rtems.c:48
F:1:23:UI1:test-rtems.c:49:RTEMS_INVALID_NUMBER == RTEMS_INVALID_ID
F:*:23:UI1:test-rtems.c:51:RTEMS_INVALID_NUMBER == RTEMS_INVALID_ID
P:2:23:UI1:test-rtems.c:52
F:3:23:UI1:test-rtems.c:53:RTEMS_INVALID_NUMBER == RTEMS_INVALID_ID
Y:rsc:N:4:F:3:D:0.022897
B:quiet
Y:quiet:N:2:F:1:D:0.000033
B:plan_ok
P:0:23:UI1:test-plan.c:13
Y:plan_ok:N:1:F:0:D:0.002379
B:plan_failed
P:0:23:UI1:test-plan.c:19
F:*:23:UI1:*:*:actual steps (1), planned steps (2)
Y:plan_failed:N:1:F:1:D:0.006868
B:now
L:0.000000640
Y:now:N:0:F:0:D:0.001335
B:normal
F:1:23:UI1:test.c:48:some test
Y:normal:N:2:F:1:D:0.002814
B:missing_timer_delete
P:0:23:UI1:test-leak.c:119
F:*:23:UI1:*:*:RTEMS timer leak (1)
Y:missing_timer_delete:N:1:F:1:D:0.005660
B:missing_task_delete
P:0:23:UI1:test-leak.c:110
F:*:23:UI1:*:*:RTEMS task leak (1)
F:*:23:UI1:*:*:memory leak in workspace or heap
Y:missing_task_delete:N:1:F:2:D:0.009824
B:missing_sema_delete
P:0:23:UI1:test-leak.c:14
F:*:23:UI1:*:*:RTEMS semaphore leak (1)
Y:missing_sema_delete:N:1:F:1:D:0.005930
B:missing_region_delete
P:0:23:UI1:test-leak.c:99
F:*:23:UI1:*:*:RTEMS region leak (1)
Y:missing_region_delete:N:1:F:1:D:0.005671
B:missing_period_delete
P:0:23:UI1:test-leak.c:88
F:*:23:UI1:*:*:RTEMS period leak (1)
Y:missing_period_delete:N:1:F:1:D:0.005671
B:missing_part_delete
P:0:23:UI1:test-leak.c:78
F:*:23:UI1:*:*:RTEMS partition leak (1)
Y:missing_part_delete:N:1:F:1:D:0.005933
B:missing_mq_delete
P:0:23:UI1:test-leak.c:67
F:*:23:UI1:*:*:RTEMS message queue leak (1)
Y:missing_mq_delete:N:1:F:2:D:0.010519
B:missing_key_delete
P:0:23:UI1:test-leak.c:128
P:1:23:UI1:test-leak.c:131
F:*:23:UI1:*:*:POSIX key leak (1)
F:*:23:UI1:*:*:POSIX key value pair leak (1)
Y:missing_key_delete:N:2:F:2:D:0.011916
B:missing_free
P:0:23:UI1:test-leak.c:22
Y:missing_free:N:1:F:1:D:0.006608
B:missing_extension_delete
P:0:23:UI1:test-leak.c:57
F:*:23:UI1:*:*:RTEMS extension leak (1)
Y:missing_extension_delete:N:1:F:1:D:0.005940
B:missing_close
P:0:23:UI1:test-leak.c:35
F:*:23:UI1:*:*:file descriptor leak (1)
Y:missing_close:N:1:F:1:D:0.005946
B:missing_barrier_delete
P:0:23:UI1:test-leak.c:45
F:*:23:UI1:*:*:RTEMS barrier leak (1)
Y:missing_barrier_delete:N:1:F:1:D:0.005766
B:measure_runtime
P:0:23:UI1:test-rtems-measure.c:43
P:1:0:UI1:test-rtems-measure.c:46
M:B:Empty
M:V:ValidCache
M:N:1024
M:MI:0.000000000
M:Q1:0.000000000
M:Q2:0.000000000
M:Q3:0.000000001
M:MX:0.000000297
M:MAD:0.000000000
M:D:0.000001249
M:E:Empty:D:0.938240855
M:B:Empty
M:V:HotCache
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000007
M:MAD:0.000000000
M:D:0.000002508
M:E:Empty:D:0.000013984
M:B:Empty
M:V:DirtyCache
M:N:1024
M:MI:0.000000007
M:Q1:0.000000007
M:Q2:0.000000007
M:Q3:0.000000008
M:MX:0.000000647
M:MAD:0.000000000
M:D:0.000015453
M:E:Empty:D:0.260872014
M:B:Empty
M:V:Load
M:L:1
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000221
M:MAD:0.000000000
M:D:0.000003577
M:E:Empty:D:0.000008501
M:B:Empty
M:V:Load
M:L:2
M:N:1024
M:MI:0.000000003
M:Q1:0.000000004
M:Q2:0.000000004
M:Q3:0.000000004
M:MX:0.000000005
M:MAD:0.000000000
M:D:0.000004053
M:E:Empty:D:0.000009739
M:B:Empty
M:V:Load
M:L:3
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000004
M:MX:0.000000247
M:MAD:0.000000000
M:D:0.000003928
M:E:Empty:D:0.000009234
M:B:Empty
M:V:Load
M:L:4
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000394
M:MAD:0.000000000
M:D:0.000003945
M:E:Empty:D:0.000009085
M:B:Empty
M:V:Load
M:L:5
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000614
M:MAD:0.000000000
M:D:0.000004094
M:E:Empty:D:0.000009339
M:B:Empty
M:V:Load
M:L:6
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000667
M:MAD:0.000000000
M:D:0.000004249
M:E:Empty:D:0.000010018
M:B:Empty
M:V:Load
M:L:7
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000999
M:MAD:0.000000000
M:D:0.000004609
M:E:Empty:D:0.000009540
M:B:Empty
M:V:Load
M:L:8
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000966
M:MAD:0.000000000
M:D:0.000004853
M:E:Empty:D:0.000010387
M:B:Empty
M:V:Load
M:L:9
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000608
M:MAD:0.000000000
M:D:0.000004286
M:E:Empty:D:0.000009198
M:B:Empty
M:V:Load
M:L:10
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000924
M:MAD:0.000000000
M:D:0.000004874
M:E:Empty:D:0.000009780
M:B:Empty
M:V:Load
M:L:11
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000838
M:MAD:0.000000000
M:D:0.000005322
M:E:Empty:D:0.000010225
M:B:Empty
M:V:Load
M:L:12
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001019
M:MAD:0.000000000
M:D:0.000006165
M:E:Empty:D:0.000011081
M:B:Empty
M:V:Load
M:L:13
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001262
M:MAD:0.000000000
M:D:0.000005426
M:E:Empty:D:0.000010333
M:B:Empty
M:V:Load
M:L:14
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001356
M:MAD:0.000000000
M:D:0.000005766
M:E:Empty:D:0.000011822
M:B:Empty
M:V:Load
M:L:15
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001488
M:MAD:0.000000000
M:D:0.000005586
M:E:Empty:D:0.000010485
M:B:Empty
M:V:Load
M:L:16
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000362
M:MAD:0.000000000
M:D:0.000005459
M:E:Empty:D:0.000012096
M:B:Empty
M:V:Load
M:L:17
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001666
M:MAD:0.000000000
M:D:0.000008672
M:E:Empty:D:0.000015278
M:B:Empty
M:V:Load
M:L:18
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001170
M:MAD:0.000000000
M:D:0.000005387
M:E:Empty:D:0.000011471
M:B:Empty
M:V:Load
M:L:19
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000534
M:MAD:0.000000000
M:D:0.000006462
M:E:Empty:D:0.000012462
M:B:Empty
M:V:Load
M:L:20
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000622
M:MAD:0.000000000
M:D:0.000008147
M:E:Empty:D:0.000014879
M:B:Empty
M:V:Load
M:L:21
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000684
M:MAD:0.000000000
M:D:0.000007044
M:E:Empty:D:0.000013946
M:B:Empty
M:V:Load
M:L:22
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000776
M:MAD:0.000000000
M:D:0.000008494
M:E:Empty:D:0.000017412
M:B:Empty
M:V:Load
M:L:23
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001628
M:MAD:0.000000000
M:D:0.000008171
M:E:Empty:D:0.000014333
M:B:Empty
M:V:Load
M:L:24
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000002610
M:MAD:0.000000000
M:D:0.000013190
M:E:Empty:D:0.000019781
M:V:ValidCache
M:N:1024
M:MI:0.000000289
M:Q1:0.000000546
M:Q2:0.000000605
M:Q3:0.000000706
M:MX:0.000000989
M:MAD:0.000000093
M:D:0.000610639
M:E:ObjectsGetSuccess:D:0.943333185
M:V:HotCache
M:N:1024
M:MI:0.000000028
M:Q1:0.000000029
M:Q2:0.000000029
M:Q3:0.000000029
M:MX:0.000000031
M:MAD:0.000000000
M:D:0.000029806
M:E:ObjectsGetSuccess:D:0.000067945
M:V:DirtyCache
M:N:1024
M:MI:0.000000039
M:Q1:0.000000541
M:Q2:0.000000573
M:Q3:0.000000721
M:MX:0.000001739
M:MAD:0.000000119
M:D:0.000620305
M:V:Load
M:L:1
M:N:1024
M:MI:0.000000027
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000000613
M:MAD:0.000000000
M:D:0.000029202
M:E:ObjectsGetSuccess:D:0.000035770
M:V:Load
M:L:2
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000000661
M:MAD:0.000000000
M:D:0.000029245
M:E:ObjectsGetSuccess:D:0.000035485
M:V:Load
M:L:3
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000001009
M:MAD:0.000000000
M:D:0.000031530
M:E:ObjectsGetSuccess:D:0.000038010
M:V:Load
M:L:4
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000002120
M:MAD:0.000000000
M:D:0.000053551
M:E:ObjectsGetSuccess:D:0.000061889
M:V:Load
M:L:5
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000030
M:MX:0.000002176
M:MAD:0.000000000
M:D:0.000066729
M:E:ObjectsGetSuccess:D:0.000075563
M:V:Load
M:L:6
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000240
M:MX:0.000001081
M:MAD:0.000000002
M:D:0.000138078
M:E:ObjectsGetSuccess:D:0.000152988
M:V:Load
M:L:7
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000225
M:MX:0.000002311
M:MAD:0.000000002
M:D:0.000134440
M:E:ObjectsGetSuccess:D:0.000147271
M:V:Load
M:L:8
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000151
M:Q3:0.000000347
M:MX:0.000002764
M:MAD:0.000000123
M:D:0.000207705
M:E:ObjectsGetSuccess:D:0.000219136
M:V:Load
M:L:9
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000189
M:Q3:0.000000322
M:MX:0.000002141
M:MAD:0.000000159
M:D:0.000206569
M:E:ObjectsGetSuccess:D:0.000218385
M:V:Load
M:L:10
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000139
M:Q3:0.000000396
M:MX:0.000003734
M:MAD:0.000000111
M:D:0.000238764
M:E:ObjectsGetSuccess:D:0.000250726
M:V:Load
M:L:11
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000253
M:Q3:0.000000463
M:MX:0.000002201
M:MAD:0.000000225
M:D:0.000291677
M:E:ObjectsGetSuccess:D:0.000308266
M:V:Load
M:L:12
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000229
M:Q3:0.000000511
M:MX:0.000028479
M:MAD:0.000000201
M:D:0.000341003
M:E:ObjectsGetSuccess:D:0.000364981
M:V:Load
M:L:13
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000262
M:Q3:0.000000458
M:MX:0.000002878
M:MAD:0.000000234
M:D:0.000294913
M:E:ObjectsGetSuccess:D:0.000313004
M:V:Load
M:L:14
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000213
M:Q3:0.000000479
M:MX:0.000004193
M:MAD:0.000000185
M:D:0.000290013
M:E:ObjectsGetSuccess:D:0.000313082
M:V:Load
M:L:15
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000241
M:Q3:0.000000505
M:MX:0.000003559
M:MAD:0.000000213
M:D:0.000306382
M:E:ObjectsGetSuccess:D:0.000323667
M:V:Load
M:L:16
M:N:1024
M:MI:0.000000028
M:Q1:0.000000030
M:Q2:0.000000340
M:Q3:0.000000619
M:MX:0.000003104
M:MAD:0.000000310
M:D:0.000392781
M:E:ObjectsGetSuccess:D:0.000427152
M:V:Load
M:L:17
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000101
M:Q3:0.000000503
M:MX:0.000004999
M:MAD:0.000000073
M:D:0.000291133
M:E:ObjectsGetSuccess:D:0.000306508
M:V:Load
M:L:18
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000437
M:MX:0.000002410
M:MAD:0.000000002
M:D:0.000251434
M:E:ObjectsGetSuccess:D:0.000273442
M:V:Load
M:L:19
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000467
M:MX:0.000002993
M:MAD:0.000000002
M:D:0.000279418
M:E:ObjectsGetSuccess:D:0.000311690
M:V:Load
M:L:20
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000525
M:MX:0.000003261
M:MAD:0.000000002
M:D:0.000303414
M:E:ObjectsGetSuccess:D:0.000344890
M:V:Load
M:L:21
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000635
M:MX:0.000004254
M:MAD:0.000000002
M:D:0.000355135
M:E:ObjectsGetSuccess:D:0.000392742
M:V:Load
M:L:22
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000691
M:MX:0.000002871
M:MAD:0.000000002
M:D:0.000383975
M:E:ObjectsGetSuccess:D:0.000436278
M:V:Load
M:L:23
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000030
M:Q3:0.000000557
M:MX:0.000005087
M:MAD:0.000000002
M:D:0.000321801
M:E:ObjectsGetSuccess:D:0.000354490
M:V:Load
M:L:24
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000629
M:MX:0.000003827
M:MAD:0.000000000
M:D:0.000352910
M:E:ObjectsGetSuccess:D:0.000399304
M:B:ObjectsGetInvalidID
M:V:ValidCache
M:N:1024
M:MI:0.000000018
M:Q1:0.000000153
M:Q2:0.000000292
M:Q3:0.000000308
M:MX:0.000000630
M:MAD:0.000000098
M:D:0.000267920
M:E:ObjectsGetInvalidID:D:0.941127817
M:V:HotCache
M:N:1024
M:MI:0.000000010
M:Q1:0.000000011
M:Q2:0.000000011
M:Q3:0.000000011
M:MX:0.000000013
M:MAD:0.000000000
M:D:0.000011411
M:E:ObjectsGetInvalidID:D:0.000034890
M:V:DirtyCache
M:N:1024
M:MI:0.000000019
M:Q1:0.000000238
M:Q2:0.000000267
M:Q3:0.000000435
M:MX:0.000006600
M:MAD:0.000000116
M:D:0.000348726
M:E:ObjectsGetInvalidID:D:0.263757136
M:V:Load
M:L:1
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000018
M:MAD:0.000000000
M:D:0.000010103
M:E:ObjectsGetInvalidID:D:0.000017849
M:V:Load
M:L:2
M:N:1024
M:MI:0.000000010
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000308
M:MAD:0.000000000
M:D:0.000011021
M:E:ObjectsGetInvalidID:D:0.000018079
M:V:Load
M:L:3
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000361
M:MAD:0.000000000
M:D:0.000010693
M:E:ObjectsGetInvalidID:D:0.000022334
M:V:Load
M:L:4
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000318
M:MAD:0.000000000
M:D:0.000010497
M:E:ObjectsGetInvalidID:D:0.000077874
M:V:Load
M:L:5
M:N:1024
M:MI:0.000000010
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000497
M:MAD:0.000000000
M:D:0.000010649
M:E:ObjectsGetInvalidID:D:0.000080187
M:V:Load
M:L:6
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000649
M:MAD:0.000000000
M:D:0.000010753
M:E:ObjectsGetInvalidID:D:0.000158512
M:V:Load
M:L:7
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001221
M:MAD:0.000000000
M:D:0.000011323
M:E:ObjectsGetInvalidID:D:0.000158776
M:V:Load
M:L:8
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001772
M:MAD:0.000000000
M:D:0.000011860
M:E:ObjectsGetInvalidID:D:0.000226076
M:V:Load
M:L:9
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001304
M:MAD:0.000000000
M:D:0.000011981
M:E:ObjectsGetInvalidID:D:0.000215151
M:V:Load
M:L:10
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001275
M:MAD:0.000000000
M:D:0.000013289
M:E:ObjectsGetInvalidID:D:0.000278091
M:V:Load
M:L:11
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002496
M:MAD:0.000000000
M:D:0.000012570
M:E:ObjectsGetInvalidID:D:0.000319214
M:V:Load
M:L:12
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002438
M:MAD:0.000000000
M:D:0.000013956
M:E:ObjectsGetInvalidID:D:0.000310133
M:V:Load
M:L:13
M:N:1024
M:MI:0.000000010
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000989
M:MAD:0.000000000
M:D:0.000011094
M:E:ObjectsGetInvalidID:D:0.000333221
M:V:Load
M:L:14
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001017
M:MAD:0.000000000
M:D:0.000011096
M:E:ObjectsGetInvalidID:D:0.000319309
M:V:Load
M:L:15
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000945
M:MAD:0.000000000
M:D:0.000011029
M:E:ObjectsGetInvalidID:D:0.000332545
M:V:Load
M:L:16
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001050
M:MAD:0.000000000
M:D:0.000011119
M:E:ObjectsGetInvalidID:D:0.000384078
M:V:Load
M:L:17
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000003593
M:MAD:0.000000000
M:D:0.000013681
M:E:ObjectsGetInvalidID:D:0.000373530
M:V:Load
M:L:18
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001207
M:MAD:0.000000000
M:D:0.000012329
M:E:ObjectsGetInvalidID:D:0.000432247
M:V:Load
M:L:19
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002829
M:MAD:0.000000000
M:D:0.000012919
M:E:ObjectsGetInvalidID:D:0.000407121
M:V:Load
M:L:20
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001918
M:MAD:0.000000000
M:D:0.000013097
M:E:ObjectsGetInvalidID:D:0.000521344
M:V:Load
M:L:21
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002445
M:MAD:0.000000000
M:D:0.000013821
M:E:ObjectsGetInvalidID:D:0.000458643
M:V:Load
M:L:22
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001780
M:MAD:0.000000000
M:D:0.000011893
M:E:ObjectsGetInvalidID:D:0.000525953
M:V:Load
M:L:23
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001790
M:MAD:0.000000000
M:D:0.000013381
M:E:ObjectsGetInvalidID:D:0.000488220
M:V:Load
M:L:24
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000935
M:MAD:0.000000000
M:D:0.000011065
M:E:ObjectsGetInvalidID:D:0.000637084
P:2:0:UI1:test-rtems-measure.c:65
Y:measure_runtime:N:3:F:0:D:5.464232
B:malloc_huge
P:0:0:UI1:test-malloc.c:25
Y:malloc_huge:N:1:F:0:D:0.002475
B:malloc_free
P:0:0:UI1:test-malloc.c:8
Y:malloc_free:N:1:F:0:D:0.002385
B:malloc_auto
P:0:0:UI1:test-malloc.c:17
Y:malloc_auto:N:1:F:0:D:0.002468
B:log
L:a custom message 1, 2, 3
Y:log:N:0:F:0:D:0.002468
B:is_main
P:0:0:UI1:test.c:64
Y:is_main:N:1:F:0:D:0.001858
B:fixture
L:setup begin
P:0:0:UI1:test-fixture.c:13
P:1:0:UI1:test-fixture.c:14
P:2:0:UI1:test-fixture.c:18
L:setup end
P:3:0:UI1:test-fixture.c:55
F:4:0:UI1:test-fixture.c:56:test fails and we stop the test case
L:stop begin
P:5:0:UI1:test-fixture.c:28
L:stop end
L:teardown begin
P:6:0:UI1:test-fixture.c:40
P:7:0:UI1:test-fixture.c:42
L:teardown end
Y:fixture:N:8:F:1:D:0.031071
B:example
P:0:0:UI1:test-example.c:5
F:1:0:UI1:test-example.c:6:test fails
F:*:0:UI1:test-example.c:8:quiet test fails
P:2:0:UI1:test-example.c:9
F:3:0:UI1:test-example.c:10:step test fails
F:4:0:UI1:test-example.c:11:this is a format string
Y:example:N:5:F:4:D:0.020725
B:double_plan
F:*:0:UI1:*:*:planned steps (99) already set
Y:double_plan:N:0:F:1:D:0.004033
B:d
P:0:0:UI1:test-verbosity.c:22
P:1:0:UI1:test-verbosity.c:23
P:2:0:UI1:test-verbosity.c:24
P:3:0:UI1:test-verbosity.c:25
P:4:0:UI1:test-verbosity.c:26
P:5:0:UI1:test-verbosity.c:27
Y:d:N:6:F:0:D:0.016205
B:calloc_auto
P:0:0:UI1:test-malloc.c:33
P:1:0:UI1:test-malloc.c:34
Y:calloc_auto:N:2:F:0:D:0.004905
B:c
F:0:0:UI1:test-verbosity.c:17:this is a format string
Y:c:N:1:F:1:D:0.004815
B:begin
L:time from test case begin 0.000000827
Y:begin:N:0:F:0:D:0.003597
B:b
F:*:0:UI1:test-verbosity.c:12:quiet test fails
Y:b:N:0:F:1:D:0.004208
B:assert2
L:setup
P:0:0:UI1:test-assert.c:45
P:1:0:UI1:test-assert.c:81
F:2:0:UI1:test-assert.c:82:test fails and we stop the test case
L:stop
P:3:0:UI1:test-assert.c:56
L:teardown
P:4:0:UI1:test-assert.c:67
P:5:0:UI1:test-assert.c:69
Y:assert2:N:6:F:1:D:0.020377
B:assert
P:0:0:UI1:test-assert.c:32
F:1:0:UI1:test-assert.c:33:test fails and we stop the test case
Y:assert:N:2:F:1:D:0.008119
B:a_test_case
P:0:0:UI1:test-simple.c:5
F:1:0:UI1:test-simple.c:6:not good
Y:a_test_case:N:2:F:1:D:0.005511
B:a
P:0:0:UI1:test-verbosity.c:5
F:1:0:UI1:test-verbosity.c:6:test fails
Y:a:N:2:F:1:D:0.006207
Z:xyz:C:200:N:1028:F:649:D:9.350026
A:xyz
S:Platform:RTEMS
S:Version:5.0.0.e974ae9447a9e19047ee977edf0d4be45a5ca88c-modified
S:RTEMS_DEBUG:0
S:RTEMS_POSIX_API:1
S:RTEMS_PROFILING:0
S:RTEMS_SMP:1
B:zalloc_auto
Y:zalloc_auto:N:2:F:0:D:0.005078
B:wrong_step
Y:wrong_step:N:2:F:1:D:0.006030
B:verbose
Y:verbose:N:2:F:1:D:0.004726
B:timer
Y:timer:N:8:F:0:D:0.022883
B:time_to_string
Y:time_to_string:N:6:F:0:D:0.014117
B:time
Y:time:N:40:F:0:D:0.097748
B:ticks
L:tick digits 9
B:tick
L:0.000000000
Y:tick:N:0:F:0:D:0.001335
B:test_true
Y:test_true:N:6:F:4:D:0.015508
B:test_psx_success
Y:test_psx_success:N:4:F:3:D:0.014203
B:test_psx_error
Y:test_psx_error:N:5:F:5:D:0.027332
B:test_null
Y:test_null:N:6:F:4:D:0.017854
B:test_not_null
Y:test_not_null:N:6:F:4:D:0.018551
B:test_ne_ushort
Y:test_ne_ushort:N:6:F:4:D:0.016638
B:test_ne_uptr
Y:test_ne_uptr:N:6:F:4:D:0.017245
B:test_ne_ulong
Y:test_ne_ulong:N:6:F:4:D:0.016637
B:test_ne_ull
Y:test_ne_ull:N:6:F:4:D:0.016638
B:test_ne_uint
B:test_ne_uchar
B:test_ne_u8
Y:test_ne_u8:N:6:F:4:D:0.017245
B:test_ne_u64
B:test_ne_u32
Y:test_ne_u32:N:6:F:4:D:0.017245
B:test_ne_u16
B:test_ne_sz
Y:test_ne_sz:N:6:F:4:D:0.017245
B:test_ne_str
B:test_ne_ssz
B:test_ne_short
B:test_ne_schar
Y:test_ne_schar:N:6:F:4:D:0.016636
B:test_ne_ptr
Y:test_ne_ptr:N:6:F:4:D:0.017158
B:test_ne_nstr
B:test_ne_mem
Y:test_ne_mem:N:6:F:4:D:0.024810
B:test_ne_long
Y:test_ne_long:N:6:F:4:D:0.016637
B:test_ne_ll
Y:test_ne_ll:N:6:F:4:D:0.016637
B:test_ne_iptr
Y:test_ne_iptr:N:6:F:4:D:0.017246
B:test_ne_int
Y:test_ne_int:N:6:F:4:D:0.016636
B:test_ne_i8
B:test_ne_i64
Y:test_ne_i64:N:6:F:4:D:0.017245
B:test_ne_i32
B:test_ne_i16
Y:test_ne_i16:N:6:F:4:D:0.017246
B:test_ne_char
Y:test_ne_char:N:6:F:4:D:0.017854
B:test_ne
B:test_lt_ushort
Y:test_lt_ushort:N:6:F:4:D:0.016290
B:test_lt_uptr
B:test_lt_ulong
Y:test_lt_ulong:N:6:F:4:D:0.016290
B:test_lt_ull
Y:test_lt_ull:N:6:F:4:D:0.016897
B:test_lt_uint
B:test_lt_uchar
Y:test_lt_uchar:N:6:F:4:D:0.016288
B:test_lt_u8
Y:test_lt_u8:N:6:F:4:D:0.016897
B:test_lt_u64
Y:test_lt_u64:N:6:F:4:D:0.016898
B:test_lt_u32
Y:test_lt_u32:N:6:F:4:D:0.016898
B:test_lt_u16
Y:test_lt_u16:N:6:F:4:D:0.016898
B:test_lt_sz
Y:test_lt_sz:N:6:F:4:D:0.016898
B:test_lt_ssz
Y:test_lt_ssz:N:6:F:4:D:0.016898
B:test_lt_short
Y:test_lt_short:N:6:F:4:D:0.016289
B:test_lt_schar
Y:test_lt_schar:N:6:F:4:D:0.016289
B:test_lt_long
Y:test_lt_long:N:6:F:4:D:0.016288
B:test_lt_ll
Y:test_lt_ll:N:6:F:4:D:0.016290
B:test_lt_iptr
Y:test_lt_iptr:N:6:F:4:D:0.016898
B:test_lt_int
Y:test_lt_int:N:6:F:4:D:0.016289
B:test_lt_i8
Y:test_lt_i8:N:6:F:4:D:0.016898
B:test_lt_i64
Y:test_lt_i64:N:6:F:4:D:0.016898
B:test_lt_i32
B:test_lt_i16
Y:test_lt_i16:N:6:F:4:D:0.016899
B:test_le_ushort
Y:test_le_ushort:N:6:F:4:D:0.016637
B:test_le_uptr
Y:test_le_uptr:N:6:F:4:D:0.017246
B:test_le_ulong
Y:test_le_ulong:N:6:F:4:D:0.016637
B:test_le_ull
Y:test_le_ull:N:6:F:4:D:0.017071
B:test_le_uint
Y:test_le_uint:N:6:F:4:D:0.016637
B:test_le_uchar
Y:test_le_uchar:N:6:F:4:D:0.016637
B:test_le_u8
Y:test_le_u8:N:6:F:4:D:0.017246
B:test_le_u64
Y:test_le_u64:N:6:F:4:D:0.017245
B:test_le_u32
Y:test_le_u32:N:6:F:4:D:0.017246
B:test_le_u16
Y:test_le_u16:N:6:F:4:D:0.017246
B:test_le_sz
Y:test_le_sz:N:6:F:4:D:0.017247
B:test_le_ssz
Y:test_le_ssz:N:6:F:4:D:0.017245
B:test_le_short
B:test_le_schar
Y:test_le_schar:N:6:F:4:D:0.016638
B:test_le_long
B:test_le_ll
Y:test_le_ll:N:6:F:4:D:0.016637
B:test_le_iptr
B:test_le_int
Y:test_le_int:N:6:F:4:D:0.016636
B:test_le_i8
B:test_le_i64
Y:test_le_i64:N:6:F:4:D:0.017244
B:test_le_i32
Y:test_le_i32:N:6:F:4:D:0.017247
B:test_le_i16
Y:test_le_i16:N:6:F:4:D:0.017246
B:test_gt_ushort
B:test_gt_uptr
Y:test_gt_uptr:N:5:F:4:D:0.014811
B:test_gt_ulong
Y:test_gt_ulong:N:5:F:4:D:0.014291
B:test_gt_ull
B:test_gt_uint
B:test_gt_uchar
B:test_gt_u8
B:test_gt_u64
Y:test_gt_u64:N:5:F:4:D:0.014812
B:test_gt_u32
Y:test_gt_u32:N:5:F:4:D:0.014812
B:test_gt_u16
Y:test_gt_u16:N:5:F:4:D:0.014812
B:test_gt_sz
Y:test_gt_sz:N:5:F:4:D:0.014812
B:test_gt_ssz
B:test_gt_short
Y:test_gt_short:N:5:F:4:D:0.014291
B:test_gt_schar
Y:test_gt_schar:N:5:F:4:D:0.014289
B:test_gt_long
Y:test_gt_long:N:5:F:4:D:0.014291
B:test_gt_ll
B:test_gt_iptr
Y:test_gt_iptr:N:5:F:4:D:0.014813
B:test_gt_int
B:test_gt_i8
Y:test_gt_i8:N:5:F:4:D:0.014812
B:test_gt_i64
Y:test_gt_i64:N:5:F:4:D:0.014811
B:test_gt_i32
B:test_gt_i16
Y:test_gt_i16:N:5:F:4:D:0.014811
B:test_ge_ushort
Y:test_ge_ushort:N:6:F:4:D:0.016637
B:test_ge_uptr
Y:test_ge_uptr:N:6:F:4:D:0.017246
B:test_ge_ulong
B:test_ge_ull
Y:test_ge_ull:N:6:F:4:D:0.016637
B:test_ge_uint
Y:test_ge_uint:N:6:F:4:D:0.016636
B:test_ge_uchar
Y:test_ge_uchar:N:6:F:4:D:0.016637
B:test_ge_u8
Y:test_ge_u8:N:6:F:4:D:0.017246
B:test_ge_u64
Y:test_ge_u64:N:6:F:4:D:0.017246
B:test_ge_u32
B:test_ge_u16
Y:test_ge_u16:N:6:F:4:D:0.017246
B:test_ge_sz
B:test_ge_ssz
B:test_ge_short
Y:test_ge_short:N:6:F:4:D:0.016638
B:test_ge_schar
Y:test_ge_schar:N:6:F:4:D:0.016638
B:test_ge_long
Y:test_ge_long:N:6:F:4:D:0.016637
B:test_ge_ll
Y:test_ge_ll:N:6:F:4:D:0.016637
B:test_ge_iptr
B:test_ge_int
B:test_ge_i8
Y:test_ge_i8:N:6:F:4:D:0.017247
B:test_ge_i64
Y:test_ge_i64:N:6:F:4:D:0.017245
B:test_ge_i32
Y:test_ge_i32:N:6:F:4:D:0.017245
B:test_ge_i16
B:test_false
Y:test_false:N:6:F:4:D:0.015506
B:test_eq_ushort
B:test_eq_uptr
Y:test_eq_uptr:N:6:F:4:D:0.017245
B:test_eq_ulong
Y:test_eq_ulong:N:6:F:4:D:0.016637
B:test_eq_ull
Y:test_eq_ull:N:6:F:4:D:0.016639
B:test_eq_uint
Y:test_eq_uint:N:6:F:4:D:0.016638
B:test_eq_uchar
B:test_eq_u8
Y:test_eq_u8:N:6:F:4:D:0.017247
B:test_eq_u64
Y:test_eq_u64:N:6:F:4:D:0.017246
B:test_eq_u32
Y:test_eq_u32:N:6:F:4:D:0.017246
B:test_eq_u16
Y:test_eq_u16:N:6:F:4:D:0.017245
B:test_eq_sz
Y:test_eq_sz:N:6:F:4:D:0.017245
B:test_eq_str
B:test_eq_ssz
Y:test_eq_ssz:N:6:F:4:D:0.017247
B:test_eq_short
Y:test_eq_short:N:6:F:4:D:0.016638
B:test_eq_schar
Y:test_eq_schar:N:6:F:4:D:0.016637
B:test_eq_ptr
B:test_eq_nstr
Y:test_eq_nstr:N:9:F:4:D:0.025592
B:test_eq_mem
Y:test_eq_mem:N:6:F:4:D:0.024809
B:test_eq_long
Y:test_eq_long:N:6:F:4:D:0.016637
B:test_eq_ll
Y:test_eq_ll:N:6:F:4:D:0.016638
B:test_eq_iptr
B:test_eq_int
B:test_eq_i8
Y:test_eq_i8:N:6:F:4:D:0.017245
B:test_eq_i64
Y:test_eq_i64:N:6:F:4:D:0.017246
B:test_eq_i32
B:test_eq_i16
Y:test_eq_i16:N:6:F:4:D:0.017246
B:test_eq_char
Y:test_eq_char:N:6:F:4:D:0.017854
B:test_eq
Y:test_eq:N:6:F:4:D:0.016115
B:test_eno_success
Y:test_eno_success:N:4:F:3:D:0.014463
B:test_eno
Y:test_eno:N:4:F:3:D:0.015767
B:steps
Y:steps:N:3:F:0:D:0.007072
B:step
Y:step:N:2:F:1:D:0.006029
B:stat
B:rsc_success
Y:rsc_success:N:4:F:3:D:0.022898
B:rsc
B:quiet
Y:quiet:N:2:F:1:D:0.000030
B:plan_ok
Y:plan_ok:N:1:F:0:D:0.002378
B:plan_failed
B:now
L:0.000000640
Y:now:N:0:F:0:D:0.001333
B:normal
Y:normal:N:2:F:1:D:0.002812
Y:missing_region_delete:N:1:F:1:D:0.005672
Y:missing_part_delete:N:1:F:1:D:0.005934
B:missing_mq_delete
B:missing_free
Y:missing_extension_delete:N:1:F:1:D:0.005939
B:missing_close
Y:missing_close:N:1:F:1:D:0.005943
B:measure_runtime
M:B:Empty
M:V:ValidCache
M:N:1024
M:MI:0.000000000
M:Q1:0.000000000
M:Q2:0.000000000
M:Q3:0.000000001
M:MX:0.000000305
M:MAD:0.000000000
M:D:0.000001145
M:E:Empty:D:0.936180504
M:B:Empty
M:V:HotCache
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000007
M:MAD:0.000000000
M:D:0.000002508
M:B:Empty
M:V:DirtyCache
M:N:1024
M:MI:0.000000007
M:Q1:0.000000007
M:Q2:0.000000007
M:Q3:0.000000008
M:MX:0.000000287
M:MAD:0.000000000
M:D:0.000014962
M:E:Empty:D:0.260507383
M:B:Empty
M:V:Load
M:L:1
M:N:1024
M:MI:0.000000003
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000263
M:MAD:0.000000000
M:D:0.000003627
M:E:Empty:D:0.000008834
M:B:Empty
M:V:Load
M:L:2
M:N:1024
M:MI:0.000000002
M:Q1:0.000000004
M:Q2:0.000000004
M:Q3:0.000000004
M:MX:0.000000069
M:MAD:0.000000000
M:D:0.000004112
M:E:Empty:D:0.000009710
M:B:Empty
M:V:Load
M:L:3
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000004
M:MX:0.000000220
M:MAD:0.000000000
M:D:0.000003950
M:E:Empty:D:0.000009218
M:B:Empty
M:V:Load
M:L:4
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000450
M:MAD:0.000000000
M:D:0.000004027
M:E:Empty:D:0.000009147
M:B:Empty
M:V:Load
M:L:5
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000372
M:MAD:0.000000000
M:D:0.000004058
M:E:Empty:D:0.000009060
M:B:Empty
M:V:Load
M:L:6
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000038
M:MAD:0.000000000
M:D:0.000003445
M:E:Empty:D:0.000009447
M:B:Empty
M:V:Load
M:L:7
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000491
M:MAD:0.000000000
M:D:0.000004390
M:E:Empty:D:0.000009609
M:B:Empty
M:V:Load
M:L:8
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000279
M:MAD:0.000000000
M:D:0.000003944
M:E:Empty:D:0.000009583
M:B:Empty
M:V:Load
M:L:9
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000052
M:MAD:0.000000000
M:D:0.000003499
M:E:Empty:D:0.000009452
M:B:Empty
M:V:Load
M:L:10
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001176
M:MAD:0.000000000
M:D:0.000005242
M:E:Empty:D:0.000010440
M:B:Empty
M:V:Load
M:L:11
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001005
M:MAD:0.000000000
M:D:0.000005035
M:E:Empty:D:0.000010445
M:B:Empty
M:V:Load
M:L:12
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000893
M:MAD:0.000000000
M:D:0.000005295
M:E:Empty:D:0.000010457
M:B:Empty
M:V:Load
M:L:13
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000608
M:MAD:0.000000000
M:D:0.000004904
M:E:Empty:D:0.000010289
M:B:Empty
M:V:Load
M:L:14
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000649
M:MAD:0.000000000
M:D:0.000005441
M:E:Empty:D:0.000010617
M:B:Empty
M:V:Load
M:L:15
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000195
M:MAD:0.000000000
M:D:0.000004878
M:E:Empty:D:0.000010740
M:B:Empty
M:V:Load
M:L:16
M:N:1024
M:MI:0.000000001
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000002136
M:MAD:0.000000000
M:D:0.000008610
M:E:Empty:D:0.000013503
M:B:Empty
M:V:Load
M:L:17
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001035
M:MAD:0.000000000
M:D:0.000006641
M:E:Empty:D:0.000012188
M:B:Empty
M:V:Load
M:L:18
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001013
M:MAD:0.000000000
M:D:0.000005763
M:E:Empty:D:0.000012429
M:B:Empty
M:V:Load
M:L:19
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000959
M:MAD:0.000000000
M:D:0.000007389
M:E:Empty:D:0.000012921
M:B:Empty
M:V:Load
M:L:20
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000001054
M:MAD:0.000000000
M:D:0.000006563
M:E:Empty:D:0.000012695
M:B:Empty
M:V:Load
M:L:21
M:N:1024
M:MI:0.000000001
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000542
M:MAD:0.000000000
M:D:0.000006062
M:E:Empty:D:0.000012730
M:B:Empty
M:V:Load
M:L:22
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000566
M:MAD:0.000000000
M:D:0.000006507
M:E:Empty:D:0.000013539
M:B:Empty
M:V:Load
M:L:23
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000681
M:MAD:0.000000000
M:D:0.000008217
M:E:Empty:D:0.000014577
M:B:Empty
M:V:Load
M:L:24
M:N:1024
M:MI:0.000000002
M:Q1:0.000000003
M:Q2:0.000000003
M:Q3:0.000000003
M:MX:0.000000921
M:MAD:0.000000000
M:D:0.000010838
M:E:Empty:D:0.000017645
M:B:ObjectsGetSuccess
M:V:ValidCache
M:N:1024
M:MI:0.000000258
M:Q1:0.000000463
M:Q2:0.000000570
M:Q3:0.000000616
M:MX:0.000001001
M:MAD:0.000000105
M:D:0.000566812
M:E:ObjectsGetSuccess:D:0.942259277
M:V:HotCache
M:N:1024
M:MI:0.000000028
M:Q1:0.000000029
M:Q2:0.000000029
M:Q3:0.000000029
M:MX:0.000000032
M:MAD:0.000000000
M:D:0.000029799
M:E:ObjectsGetSuccess:D:0.000067890
M:V:DirtyCache
M:N:1024
M:MI:0.000000039
M:Q1:0.000000277
M:Q2:0.000000540
M:Q3:0.000000578
M:MX:0.000001042
M:MAD:0.000000158
M:D:0.000492539
M:E:ObjectsGetSuccess:D:0.262732549
M:V:Load
M:L:1
M:N:1024
M:MI:0.000000027
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000000621
M:MAD:0.000000000
M:D:0.000029212
M:E:ObjectsGetSuccess:D:0.000035653
M:V:Load
M:L:2
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000000446
M:MAD:0.000000000
M:D:0.000029030
M:E:ObjectsGetSuccess:D:0.000035267
M:V:Load
M:L:3
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000001070
M:MAD:0.000000000
M:D:0.000030676
M:E:ObjectsGetSuccess:D:0.000036921
M:V:Load
M:L:4
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000001283
M:MAD:0.000000000
M:D:0.000032892
M:E:ObjectsGetSuccess:D:0.000039142
M:V:Load
M:L:5
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000001728
M:MAD:0.000000000
M:D:0.000036240
M:E:ObjectsGetSuccess:D:0.000042493
M:V:Load
M:L:6
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000001362
M:MAD:0.000000000
M:D:0.000043302
M:E:ObjectsGetSuccess:D:0.000049581
M:V:Load
M:L:7
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000002352
M:MAD:0.000000000
M:D:0.000055254
M:E:ObjectsGetSuccess:D:0.000061552
M:V:Load
M:L:8
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000002843
M:MAD:0.000000000
M:D:0.000048608
M:E:ObjectsGetSuccess:D:0.000054879
M:V:Load
M:L:9
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000002271
M:MAD:0.000000000
M:D:0.000049448
M:E:ObjectsGetSuccess:D:0.000055842
M:V:Load
M:L:10
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000002890
M:MAD:0.000000000
M:D:0.000079826
M:E:ObjectsGetSuccess:D:0.000086135
M:V:Load
M:L:11
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000001749
M:MAD:0.000000000
M:D:0.000081582
M:E:ObjectsGetSuccess:D:0.000087889
M:V:Load
M:L:12
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000003682
M:MAD:0.000000000
M:D:0.000082869
M:E:ObjectsGetSuccess:D:0.000089170
M:V:Load
M:L:13
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000003027
M:MAD:0.000000000
M:D:0.000065732
M:E:ObjectsGetSuccess:D:0.000072023
M:V:Load
M:L:14
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000003163
M:MAD:0.000000000
M:D:0.000084075
M:E:ObjectsGetSuccess:D:0.000090369
M:V:Load
M:L:15
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000003698
M:MAD:0.000000000
M:D:0.000084047
M:E:ObjectsGetSuccess:D:0.000090344
M:V:Load
M:L:16
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000002790
M:MAD:0.000000000
M:D:0.000086173
M:E:ObjectsGetSuccess:D:0.000092483
M:V:Load
M:L:17
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000004210
M:MAD:0.000000000
M:D:0.000109454
M:E:ObjectsGetSuccess:D:0.000115764
M:V:Load
M:L:18
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000003763
M:MAD:0.000000000
M:D:0.000068843
M:E:ObjectsGetSuccess:D:0.000075118
M:V:Load
M:L:19
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000006309
M:MAD:0.000000000
M:D:0.000094198
M:E:ObjectsGetSuccess:D:0.000100486
M:V:Load
M:L:20
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000004591
M:MAD:0.000000000
M:D:0.000082595
M:E:ObjectsGetSuccess:D:0.000088867
M:V:Load
M:L:21
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000004709
M:MAD:0.000000000
M:D:0.000075563
M:E:ObjectsGetSuccess:D:0.000081840
M:V:Load
M:L:22
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000004662
M:MAD:0.000000000
M:D:0.000094583
M:E:ObjectsGetSuccess:D:0.000100871
M:V:Load
M:L:23
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000006949
M:MAD:0.000000000
M:D:0.000113671
M:E:ObjectsGetSuccess:D:0.000119959
M:V:Load
M:L:24
M:N:1024
M:MI:0.000000028
M:Q1:0.000000028
M:Q2:0.000000028
M:Q3:0.000000028
M:MX:0.000005900
M:MAD:0.000000000
M:D:0.000096684
M:E:ObjectsGetSuccess:D:0.000102954
M:V:ValidCache
M:N:1024
M:MI:0.000000018
M:Q1:0.000000138
M:Q2:0.000000252
M:Q3:0.000000384
M:MX:0.000000511
M:MAD:0.000000116
M:D:0.000248309
M:E:ObjectsGetInvalidID:D:0.938719792
M:V:HotCache
M:N:1024
M:MI:0.000000010
M:Q1:0.000000011
M:Q2:0.000000011
M:Q3:0.000000011
M:MX:0.000000013
M:MAD:0.000000000
M:D:0.000011432
M:E:ObjectsGetInvalidID:D:0.000034896
M:V:DirtyCache
M:N:1024
M:MI:0.000000019
M:Q1:0.000000131
M:Q2:0.000000242
M:Q3:0.000000305
M:MX:0.000000712
M:MAD:0.000000111
M:D:0.000259142
M:E:ObjectsGetInvalidID:D:0.262141413
M:V:Load
M:L:1
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000318
M:MAD:0.000000000
M:D:0.000010421
M:E:ObjectsGetInvalidID:D:0.000018101
M:V:Load
M:L:2
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000478
M:MAD:0.000000000
M:D:0.000011187
M:E:ObjectsGetInvalidID:D:0.000018252
M:V:Load
M:L:3
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001052
M:MAD:0.000000000
M:D:0.000011384
M:E:ObjectsGetInvalidID:D:0.000020439
M:V:Load
M:L:4
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000894
M:MAD:0.000000000
M:D:0.000011040
M:E:ObjectsGetInvalidID:D:0.000022117
M:V:Load
M:L:5
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000000928
M:MAD:0.000000000
M:D:0.000011060
M:E:ObjectsGetInvalidID:D:0.000023069
M:V:Load
M:L:6
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001570
M:MAD:0.000000000
M:D:0.000011670
M:E:ObjectsGetInvalidID:D:0.000027410
M:V:Load
M:L:7
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001198
M:MAD:0.000000000
M:D:0.000011294
M:E:ObjectsGetInvalidID:D:0.000026425
M:V:Load
M:L:8
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001595
M:MAD:0.000000000
M:D:0.000011681
M:E:ObjectsGetInvalidID:D:0.000033687
M:V:Load
M:L:9
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001505
M:MAD:0.000000000
M:D:0.000011592
M:E:ObjectsGetInvalidID:D:0.000030209
M:V:Load
M:L:10
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002488
M:MAD:0.000000000
M:D:0.000012547
M:E:ObjectsGetInvalidID:D:0.000042002
M:V:Load
M:L:11
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002532
M:MAD:0.000000000
M:D:0.000012584
M:E:ObjectsGetInvalidID:D:0.000077948
M:V:Load
M:L:12
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002254
M:MAD:0.000000000
M:D:0.000012311
M:E:ObjectsGetInvalidID:D:0.000045479
M:V:Load
M:L:13
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002475
M:MAD:0.000000000
M:D:0.000012534
M:E:ObjectsGetInvalidID:D:0.000066660
M:V:Load
M:L:14
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000001312
M:MAD:0.000000000
M:D:0.000011367
M:E:ObjectsGetInvalidID:D:0.000053219
M:V:Load
M:L:15
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000003238
M:MAD:0.000000000
M:D:0.000013298
M:E:ObjectsGetInvalidID:D:0.000067014
M:V:Load
M:L:16
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000003037
M:MAD:0.000000000
M:D:0.000013087
M:E:ObjectsGetInvalidID:D:0.000064884
M:V:Load
M:L:17
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002509
M:MAD:0.000000000
M:D:0.000012549
M:E:ObjectsGetInvalidID:D:0.000071493
M:V:Load
M:L:18
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000003481
M:MAD:0.000000000
M:D:0.000013537
M:E:ObjectsGetInvalidID:D:0.000058562
M:V:Load
M:L:19
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000003288
M:MAD:0.000000000
M:D:0.000013333
M:E:ObjectsGetInvalidID:D:0.000049819
M:V:Load
M:L:20
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002622
M:MAD:0.000000000
M:D:0.000012662
M:E:ObjectsGetInvalidID:D:0.000079953
M:V:Load
M:L:21
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000004146
M:MAD:0.000000000
M:D:0.000014199
M:E:ObjectsGetInvalidID:D:0.000065905
M:V:Load
M:L:22
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000003905
M:MAD:0.000000000
M:D:0.000013951
M:E:ObjectsGetInvalidID:D:0.000069414
M:V:Load
M:L:23
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002468
M:MAD:0.000000000
M:D:0.000012513
M:E:ObjectsGetInvalidID:D:0.000069203
M:V:Load
M:L:24
M:N:1024
M:MI:0.000000009
M:Q1:0.000000010
M:Q2:0.000000010
M:Q3:0.000000010
M:MX:0.000002869
M:MAD:0.000000000
M:D:0.000012914
M:E:ObjectsGetInvalidID:D:0.000074838
Y:measure_runtime:N:3:F:0:D:5.441847
B:malloc_huge
Y:malloc_huge:N:1:F:0:D:0.002474
B:malloc_free
Y:malloc_free:N:1:F:0:D:0.002381
B:malloc_auto
B:log
Y:log:N:0:F:0:D:0.002467
B:is_main
P:0:0:UI1:test.c:64
Y:is_main:N:1:F:0:D:0.001856
B:fixture
L:setup begin
L:setup end
L:stop begin
L:stop end
L:teardown begin
L:teardown end
Y:fixture:N:8:F:1:D:0.031072
B:example
Y:example:N:5:F:4:D:0.020723
B:double_plan
Y:double_plan:N:0:F:1:D:0.004032
B:d
Y:d:N:6:F:0:D:0.016203
B:calloc_auto
Y:calloc_auto:N:2:F:0:D:0.004903
B:c
Y:c:N:1:F:1:D:0.004811
B:begin
L:time from test case begin 0.000000853
Y:begin:N:0:F:0:D:0.003598
B:b
Y:b:N:0:F:1:D:0.004206
B:assert2
L:setup
L:stop
L:teardown
Y:assert2:N:6:F:1:D:0.020376
B:assert
Y:assert:N:2:F:1:D:0.008118
B:a_test_case
Y:a_test_case:N:2:F:1:D:0.005510
B:a
Y:a:N:2:F:1:D:0.006205
Z:xyz:C:200:N:1028:F:649:D:9.326884
