[PATCH] c-user: rtems_scheduler_get_maximum_priority()
Fri Dec 7 14:05:23 UTC 2018
Close #3636.
 c-user/scheduling_concepts.rst | 37 +++++++++++++++++++++++++++++++++++++
 1 file changed, 37 insertions(+)
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index e088c62..5a2ce05 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -35,6 +35,8 @@ The directives provided by the scheduler manager are:
 - rtems_scheduler_ident_by_processor_set_ - Get ID of a scheduler by processor set
+- rtems_scheduler_get_maximum_priority_ - Get maximum task priority of a scheduler
 - rtems_scheduler_get_processor_set_ - Get processor set of a scheduler
 - rtems_scheduler_add_processor_ - Add processor to a scheduler
@@ -660,6 +662,41 @@ NOTES:
    \clearpage
+.. _rtems_scheduler_get_maximum_priority:
+SCHEDULER_GET_MAXIMUM_PRIORITY - Get maximum task priority of a scheduler
+CALLING SEQUENCE:
+    .. code-block:: c
+        rtems_status_code rtems_scheduler_get_maximum_priority(
+            rtems_id             scheduler_id,
+            rtems_task_priority *priority
+DIRECTIVE STATUS CODES:
+    .. list-table::
+     :class: rtems-table
+     * - ``RTEMS_SUCCESSFUL``
+       - Successful operation.
+     * - ``RTEMS_INVALID_ID``
+       - Invalid scheduler instance identifier.
+     * - ``RTEMS_INVALID_ADDRESS``
+       - The ``priority`` parameter is ``NULL``.
+DESCRIPTION:
+    Returns the maximum task priority of the specified scheduler instance in
+    ``priority``.
+NOTES:
+    None.
+.. raw:: latex
+   \clearpage
 .. _rtems_scheduler_get_processor_set:
 SCHEDULER_GET_PROCESSOR_SET - Get processor set of a scheduler
2.16.4
