[PATCH] Implement POSIX API Signature Compliance Tests for uchar.h
Marçal Comajoan Cara
mcomajoancara at gmail.com
Fri Dec 7 18:24:21 UTC 2018
This header file is C11 and not currently supported by RTEMS.
See #3643.
This work was part of GCI 2018.
testsuites/psxtests/Makefile.am | 4 ++
testsuites/psxtests/psxhdrs/uchar/c16rtomb.c | 41 +++++++++++++++++++
testsuites/psxtests/psxhdrs/uchar/c32rtomb.c | 41 +++++++++++++++++++
testsuites/psxtests/psxhdrs/uchar/mbrtoc16.c | 42 ++++++++++++++++++++
testsuites/psxtests/psxhdrs/uchar/mbrtoc32.c | 42 ++++++++++++++++++++
5 files changed, 170 insertions(+)
create mode 100644 testsuites/psxtests/psxhdrs/uchar/c16rtomb.c
create mode 100644 testsuites/psxtests/psxhdrs/uchar/c32rtomb.c
create mode 100644 testsuites/psxtests/psxhdrs/uchar/mbrtoc16.c
create mode 100644 testsuites/psxtests/psxhdrs/uchar/mbrtoc32.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 887849368f..6092a079fc 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1613,6 +1613,10 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
## lib_a_SOURCES += psxhdrs/ucontext/makecontext.c See ticket #3640
## lib_a_SOURCES += psxhdrs/ucontext/setcontext.c See ticket #3640
## lib_a_SOURCES += psxhdrs/ucontext/swapcontext.c See ticket #3640
+## lib_a_SOURCES += psxhdrs/uchar/c16rtomb.c See ticket #3643
+## lib_a_SOURCES += psxhdrs/uchar/c32rtomb.c See ticket #3643
+## lib_a_SOURCES += psxhdrs/uchar/mbrtoc32.c See ticket #3643
endif
rtems_tests_PROGRAMS = $(psx_tests)
diff --git a/testsuites/psxtests/psxhdrs/uchar/c16rtomb.c b/testsuites/psxtests/psxhdrs/uchar/c16rtomb.c
new file mode 100644
index 0000000000..8e2bc29ddc
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/uchar/c16rtomb.c
@@ -0,0 +1,41 @@
+ * @file
+ * @brief c16rtomb() API Conformance Test. This is a C11 method.
+ * COPYRIGHT (c) 2018.
+ * Marçal Comajoan Cara
+ * Permission to use, copy, modify, and/or distribute this software
+ * for any purpose with or without fee is hereby granted.
+ * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <uchar.h>
+#include <stdlib.h>
+int test( void );
+int test( void )
+ char16_t* c16_str = u"Mar\u00E7al";
+ char out[MB_CUR_MAX];
+ mbstate_t mbs;
+ int result;
+ result = c16rtomb( out, *c16_str, &mbs );
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/uchar/c32rtomb.c b/testsuites/psxtests/psxhdrs/uchar/c32rtomb.c
index 0000000000..c98f7539f2
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/uchar/c32rtomb.c
@@ -0,0 +1,41 @@
+ * @file
+ * @brief c32rtomb() API Conformance Test. This is a C11 method.
+#endif
+#include <uchar.h>
+int test( void );
+int test( void )
+ char32_t* c32_str = U"Mar\u00E7al";
+ mbstate_t mbs;
+ int result;
+ result = c32rtomb( out, *c32_str, &mbs );
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/uchar/mbrtoc16.c b/testsuites/psxtests/psxhdrs/uchar/mbrtoc16.c
index 0000000000..93e9c363b2
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/uchar/mbrtoc16.c
@@ -0,0 +1,42 @@
+ * @file
+ * @brief mbrtoc16() API Conformance Test. This is a C11 method.
+#endif
+#include <uchar.h>
+int test( void );
+int test( void )
+ char16_t pc16;
+ char* str = u8"Mar\u00E7al";
+ mbstate_t mbs;
+ int result;
+ result = mbrtoc16( &pc16, str, MB_CUR_MAX, &mbs );
+ return result;
diff --git a/testsuites/psxtests/psxhdrs/uchar/mbrtoc32.c b/testsuites/psxtests/psxhdrs/uchar/mbrtoc32.c
index 0000000000..57e6beff57
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/uchar/mbrtoc32.c
@@ -0,0 +1,42 @@
+ * @file
+ * @brief mbrtoc32() API Conformance Test. This is a C11 method.
+#endif
+#include <uchar.h>
+int test( void );
+int test( void )
+ char32_t pc32;
+ mbstate_t mbs;
+ int result;
+ result = mbrtoc32( &pc32, str, MB_CUR_MAX, &mbs );
+ return result;
2.19.2
