[PATCH] Add pthread example
Marçal Comajoan Cara
mcomajoancara at gmail.com
Sun Dec 9 15:44:21 UTC 2018
Closes #2087.
This work was part of GCI 2018.
posix_api/Makefile | 1 +
posix_api/livermore/Makefile | 8 +++
posix_api/livermore/pthread/Makefile | 23 ++++++++
posix_api/livermore/pthread/README | 5 ++
posix_api/livermore/pthread/init.c | 80 ++++++++++++++++++++++++++++
posix_api/livermore/pthread/wscript | 14 +++++
posix_api/livermore/wscript | 10 ++++
posix_api/wscript | 1 +
8 files changed, 142 insertions(+)
create mode 100644 posix_api/livermore/Makefile
create mode 100644 posix_api/livermore/pthread/Makefile
create mode 100644 posix_api/livermore/pthread/README
create mode 100644 posix_api/livermore/pthread/init.c
create mode 100644 posix_api/livermore/pthread/wscript
create mode 100644 posix_api/livermore/wscript
diff --git a/posix_api/Makefile b/posix_api/Makefile
index 8af26dc..601246c 100644
--- a/posix_api/Makefile
+++ b/posix_api/Makefile
@@ -14,4 +14,5 @@ ifeq ($(RTEMS_HAS_POSIX_API),yes)
SUBDIRS += psx_pthread_report
SUBDIRS += psx_rwlock_report
SUBDIRS += psx_sched_report
+ SUBDIRS += livermore
endif
diff --git a/posix_api/livermore/Makefile b/posix_api/livermore/Makefile
new file mode 100644
index 0000000..d8695a1
--- /dev/null
+++ b/posix_api/livermore/Makefile
@@ -0,0 +1,8 @@
+include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
+include $(RTEMS_CUSTOM)
+include $(RTEMS_SHARE)/make/directory.cfg
+# If the POSIX API isn't enabled, we can't build these
+ifeq ($(RTEMS_HAS_POSIX_API),yes)
+ SUBDIRS = pthread
+endif
diff --git a/posix_api/livermore/pthread/Makefile b/posix_api/livermore/pthread/Makefile
index 0000000..fdd13dc
--- /dev/null
+++ b/posix_api/livermore/pthread/Makefile
@@ -0,0 +1,23 @@
+# RTEMS_MAKEFILE_PATH is typically set in an environment variable
+PGM=${ARCH}/pthread.exe
+# optional managers required
+MANAGERS=all
+# C source names
+CSRCS = init.c
+COBJS = $(CSRCS:%.c=${ARCH}/%.o)
+include $(PROJECT_ROOT)/make/leaf.cfg
+OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
+all: ${ARCH} $(PGM)
+$(PGM): $(OBJS)
+ $(make-exe)
\ No newline at end of file
diff --git a/posix_api/livermore/pthread/README b/posix_api/livermore/pthread/README
index 0000000..17cefd4
--- /dev/null
+++ b/posix_api/livermore/pthread/README
@@ -0,0 +1,5 @@
+This is a simple example which illustrates how to use the
+pthreads adapted from the Lawrence Livermore POSIX Pthreads
+tutorial: https://computing.llnl.gov/tutorials/pthreads/.
+Thanks to Christopher Kerl for providing the code.
diff --git a/posix_api/livermore/pthread/init.c b/posix_api/livermore/pthread/init.c
index 0000000..b77e733
--- /dev/null
+++ b/posix_api/livermore/pthread/init.c
@@ -0,0 +1,80 @@
+ * COPYRIGHT (c) 1989-2012.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+//Adapted from Lawrence Livermore Pthread Tutorial #1
+//https://computing.llnl.gov/tutorials/pthreads
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp.h> /* for device driver prototypes */
+#include <stdio.h>
+#include <stdlib.h>
+#include <pthread.h>
+#define NUM_THREADS 5
+/* forward declarations to avoid warnings */
+void *POSIX_Init(void *argument);
+void *Print_Hello(void *threadid);
+ long tid;
+ tid = (long)threadid;
+ printf("Hello World! It's me, thread #%ld!\n", tid);
+ //You must include the return 'NULL;' in your threads to make the compiler happy
+ pthread_exit(NULL);
+ return NULL;
+ pthread_t threads[NUM_THREADS];
+ int rc;
+ long t;
+ //Creates threads
+ for(t=0; t<NUM_THREADS; t++){
+ printf("In main: creating thread %ld\n", t);
+ rc = pthread_create(&threads[t], NULL, Print_Hello, (void *)t);
+ if (rc){
+ printf("ERROR; return code from pthread_create() is %d\n", rc);
+ exit(-1);
+ //Joins the child threads up to the main one.
+ pthread_join(threads[t],NULL);
+ /* Last thing that main() should do */
+ exit(NULL);
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+//NOTICE: These configuration variable MUST be initialized before using Pthreads. The will not work if you do not.
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 6 /////
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE /////
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/posix_api/livermore/pthread/wscript b/posix_api/livermore/pthread/wscript
index 0000000..8e0f266
--- /dev/null
+++ b/posix_api/livermore/pthread/wscript
@@ -0,0 +1,14 @@
+# Copyright 2018 Marçal Comajoan Cara
+# This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
+import rtems_waf.rtems as rtems
+def build(bld):
+ rtems.build(bld)
+ bld(features = 'c cprogram',
+ target = 'pthread.exe',
+ source = ['init.c'])
diff --git a/posix_api/livermore/wscript b/posix_api/livermore/wscript
index 0000000..da99c30
--- /dev/null
+++ b/posix_api/livermore/wscript
@@ -0,0 +1,10 @@
+def build(bld):
+ if rtems.check_posix(bld):
+ bld.recurse('pthread')
diff --git a/posix_api/wscript b/posix_api/wscript
index 66a351f..912063b 100644
--- a/posix_api/wscript
+++ b/posix_api/wscript
@@ -17,3 +17,4 @@ def build(bld):
bld.recurse('psx_pthread_report')
bld.recurse('psx_rwlock_report')
bld.recurse('psx_sched_report')
+ bld.recurse('livermore')
2.19.2
