Unable to build m68k arch on 4.9
Shashvat Jain shashvatjain2002 at gmail.com
Mon Dec 10 12:55:45 UTC 2018
Hello ,
I was trying to build m68k with rtems-source-builder at branch 4.9
but i face an error different than the one described in the ticket #2581
https://devel.rtems.org/ticket/2581
One of the dowload links are unavailable , i have attached the log of the
report
in the attachments..the internet connection is working , this happens again
and again.
Please look into the issue
Thank you
Regards
--Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181210/05e058c9/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
 Build: error: downloading http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz: all paths have failed, giving up
 Command Line: ../source-builder/sb-set-builder --prefix=/home/shashvat/development/nrtems/4.9 4.9/rtems-m68k
 Python: 2.7.5 (default, Jul 13 2018, 13:06:57) [GCC 4.8.5 20150623 (Red Hat 4.8.5-28)]
 git://git.rtems.org/rtems-source-builder.git/origin/3266ec3e69c258bc77ee0eb11f635ddaeb5256b0
 Linux localhost.localdomain 3.10.0-862.14.4.el7.x86_64 #1 SMP Wed Sep 26 15:12:11 UTC 2018 x86_64
Tail of the build log:
test -z "/home/shashvat/development/nrtems/4.9/share/man/man1" || mkdir -p -- "/home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/man/man1"
 /usr/bin/install -c -m 644 '../../binutils-2.19.1/ld/ld.1' '/home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/man/man1/m68k-rtems4.9-ld.1'
make[4]: Leaving directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build/ld'
make[3]: Leaving directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build/ld'
make[2]: Leaving directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build/ld'
make[2]: Entering directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build/libiberty'
make[3]: Entering directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build/libiberty/testsuite'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build/libiberty/testsuite'
/bin/sh ../../binutils-2.19.1/libiberty/../mkinstalldirs /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/lib/`/usr/bin/gcc -O2 -pipe -I/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/home/shashvat/development/nrtems/4.9/include -g -O2 -print-multi-os-directory`
mkdir -p -- /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/lib/../lib64
/usr/bin/install -c -m 644 ./libiberty.a /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/lib/`/usr/bin/gcc -O2 -pipe -I/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/home/shashvat/development/nrtems/4.9/include -g -O2 -print-multi-os-directory`/./libiberty.an
( cd /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/lib/`/usr/bin/gcc -O2 -pipe -I/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/home/shashvat/development/nrtems/4.9/include -g -O2 -print-multi-os-directory` ; chmod 644 ./libiberty.an ;ranlib ./libiberty.an )
mv -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/lib/`/usr/bin/gcc -O2 -pipe -I/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/home/shashvat/development/nrtems/4.9/include -g -O2 -print-multi-os-directory`/./libiberty.an /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/lib/`/usr/bin/gcc -O2 -pipe -I/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/home/shashvat/development/nrtems/4.9/include -g -O2 -print-multi-os-directory`/./libiberty.a
if test -n ""; then \
  case "" in \
    /*)    thd=;; \
    *)     thd=/home/shashvat/development/nrtems/4.9/include/;; \
  esac; \
  /bin/sh ../../binutils-2.19.1/libiberty/../mkinstalldirs /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat${thd}; \
  for h in ../../binutils-2.19.1/libiberty/../include/ansidecl.h ../../binutils-2.19.1/libiberty/../include/demangle.h ../../binutils-2.19.1/libiberty/../include/dyn-string.h ../../binutils-2.19.1/libiberty/../include/fibheap.h ../../binutils-2.19.1/libiberty/../include/floatformat.h ../../binutils-2.19.1/libiberty/../include/hashtab.h ../../binutils-2.19.1/libiberty/../include/libiberty.h ../../binutils-2.19.1/libiberty/../include/objalloc.h ../../binutils-2.19.1/libiberty/../include/partition.h ../../binutils-2.19.1/libiberty/../include/safe-ctype.h ../../binutils-2.19.1/libiberty/../include/sort.h ../../binutils-2.19.1/libiberty/../include/splay-tree.h; do \
    /usr/bin/install -c -m 644 $h /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat${thd}; \
  done; \
fi
make[3]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build/libiberty'
make[1]: Nothing to be done for `install-target'.
make[1]: Leaving directory `/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1/build'
+ /bin/rm -rf /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/info/configure.info
+ /bin/rm -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/info/dir
+ touch /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/info/dir
+ mkdir -p /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/locale
+ /bin/rm -f '/home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/lib/libiberty*'
+ test '!' -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/bin/m68k-rtems4.9-dlltool
+ /bin/rm -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/man/man1/m68k-rtems4.9-dlltool.1
+ test '!' -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/bin/m68k-rtems4.9-nlmconv
+ /bin/rm -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/man/man1/m68k-rtems4.9-nlmconv.1
+ test '!' -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/bin/m68k-rtems4.9-windres
+ /bin/rm -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/man/man1/m68k-rtems4.9-windres.1
+ test '!' -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/bin/m68k-rtems4.9-windmc
+ /bin/rm -f /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/man/man1/m68k-rtems4.9-windmc.1
==> %clean:
+ cd /home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1
+ echo '==> %clean:'
copy: /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat => /home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k
reporting: tools/rtems-binutils-2.19.1-1.cfg -> m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1.txt
making dir: /home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1-root-shashvat/home/shashvat/development/nrtems/4.9/share/rtems/rsb
reporting: tools/rtems-binutils-2.19.1-1.cfg -> m68k-rtems4.9-binutils-2.19.1-x86_64-linux-gnu-1.xml
config: tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
package: m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
script:  1: #!/bin/sh
script:  2: # ___build_pre in as set up in defaults.py
script:  3: # Save the original path away.
script:  4: export SB_ORIG_PATH=${PATH}
script:  5: # Directories
script:  6: SB_PREFIX="/home/shashvat/development/nrtems/4.9"
script:  7: SB_PREFIX_CLEAN=$(echo "/home/shashvat/development/nrtems/4.9" | /bin/sed -e 's/^\///')
script:  8: SB_SOURCE_DIR="/home/shashvat/development/nrtems/rsb/rtems/sources"
script:  9: SB_BUILD_DIR="/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1"
script: 10: # host == build, use build; host != build, host uses host and build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: SB_HOST_CFLAGS="-O2 -pipe "
script: 13: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 14: SB_HOST_LDFLAGS=" -L/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/${SB_PREFIX_CLEAN}/lib"
script: 15: SB_BUILD_CFLAGS="-O2 -pipe --std=gnu89 -I/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_CXXFLAGS="-O2 -pipe -I/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/${SB_PREFIX_CLEAN}/include"
script: 17: SB_BUILD_LDFLAGS=" -L/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/${SB_PREFIX_CLEAN}/lib"
script: 18: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 19: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 20: SB_ARCH="x86_64"
script: 21: SB_OS="linux"
script: 22: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 23: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 24: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 25: export SB_CFLAGS SB_CXXFLAGS
script: 26: # Documentation
script: 27: SB_DOC_DIR="/home/shashvat/development/nrtems/4.9/share/doc"
script: 28: export SB_DOC_DIR
script: 29: # Packages
script: 30: SB_PACKAGE_NAME="m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1"
script: 31: SB_PACKAGE_BUILDNAME="m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1"
script: 32: SB_PACKAGE_VERSION="4.3.2"
script: 33: SB_PACKAGE_RELEASE="1"
script: 34: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 35: # Build directories
script: 36: export SB_PREFIX
script: 37: SB_BUILD_DIR="/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1"
script: 38: SB_BUILD_ROOT="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1-root-shashvat"
script: 39: SB_BUILD_ROOT_BINDIR="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1-root-shashvat/${SB_PREFIX_CLEAN}/bin"
script: 40: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 41: SB_BUILD_CXC_DIR="/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1-cxc"
script: 42: SB_BUILD_CXC_ROOT="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1-shashvat-cxc"
script: 43: SB_BUILD_CXC_ROOT_BINDIR="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1-shashvat-cxc/${SB_PREFIX_CLEAN}/bin"
script: 44: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 45: SB_TMPROOT="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k"
script: 46: SB_TMPPREFIX="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/${SB_PREFIX_CLEAN}"
script: 47: SB_TMPBINDIR="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k/${SB_PREFIX_CLEAN}/bin"
script: 48: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 49: SB_TMPCXCROOT="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat/4.9/rtems-m68k"
script: 50: SB_TMPCXCPREFIX="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat-cxc/4.9/rtems-m68k/${SB_PREFIX_CLEAN}"
script: 51: SB_TMPCXCBINDIR="/home/shashvat/development/nrtems/rsb/rtems/build/tmp/sb-shashvat-cxc/4.9/rtems-m68k/${SB_PREFIX_CLEAN}/bin"
script: 52: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 53: # Extra path support
script: 54: SB_EXTRAPATH="/home/shashvat/development/nrtems/rsb/source-builder"
script: 55: # The compiler flags
script: 56:
script: 57:
script: 58: export CFLAGS_FOR_TARGET
script: 59: export CXXFLAGS_FOR_TARGET
script: 60: # Set up the path. Put the CXC path first.
script: 61: if test -n "${SB_TMPBINDIR}" ; then
script: 62:  PATH="${SB_TMPBINDIR}:$PATH"
script: 63: fi
script: 64: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 65:  PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_EXTRAPATH}" ; then
script: 68:  PATH="${SB_EXTRAPATH}:$PATH"
script: 69: fi
script: 70:
script: 71:
script: 72: export PATH
script: 73: # Default environment set up.
script: 74: LANG=C
script: 75: export LANG
script: 76: unset DISPLAY || :
script: 77: umask 022
script: 78: cd "/home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1"
script: 79: echo "=> m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1:"
script: 80: echo "==> %prep:"
script: 81: build_top=$(pwd)
script: 82: gcc_source="gcc-4.3.2"
script: 83: source_dir_gcc=${gcc_source}
source setup: m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1: source gcc -q -n ${gcc_source}
making dir: /home/shashvat/development/nrtems/rsb/rtems/sources
download: (full) ftp://ftp.gnu.org/pub/gnu/gcc/gcc-4.3.2/gcc-core-4.3.2.tar.bz2 -> sources/gcc-core-4.3.2.tar.bz2
download: ftp://ftp.gnu.org/pub/gnu/gcc/gcc-4.3.2/gcc-core-4.3.2.tar.bz2 -> sources/gcc-core-4.3.2.tar.bz2
checksums: gcc-core-4.3.2.tar.bz2: 7fa7cfd57b3cb37990f41132037666d511a480df28d6d5a0620520501488abad89c7843067188bbe23f0c4d3eb5d113537a6a9375135596b58b3d7a848dc8a39 => 7fa7cfd57b3cb37990f41132037666d511a480df28d6d5a0620520501488abad89c7843067188bbe23f0c4d3eb5d113537a6a9375135596b58b3d7a848dc8a39
download: (full) ftp://ftp.gnu.org/pub/gnu/gcc/gcc-4.3.2/gcc-g++-4.3.2.tar.bz2 -> sources/gcc-g++-4.3.2.tar.bz2
download: ftp://ftp.gnu.org/pub/gnu/gcc/gcc-4.3.2/gcc-g++-4.3.2.tar.bz2 -> sources/gcc-g++-4.3.2.tar.bz2
checksums: gcc-g++-4.3.2.tar.bz2: b349344a9ea67418cca4b7465263e7c28b28008b9fbd76d7db2fb4ad38e63a943c601bc33e641319d48a48a8848562afff96c9ddaf90141d9ab835be6b955bb7 => b349344a9ea67418cca4b7465263e7c28b28008b9fbd76d7db2fb4ad38e63a943c601bc33e641319d48a48a8848562afff96c9ddaf90141d9ab835be6b955bb7
script: 84: cd /home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
script: 85: /bin/rm -rf ${gcc_source}
script: 86: /bin/bzip2 -dc /home/shashvat/development/nrtems/rsb/rtems/sources/gcc-core-4.3.2.tar.bz2 | /bin/tar -xvvf -
script: 87: cd /home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
script: 88: /bin/bzip2 -dc /home/shashvat/development/nrtems/rsb/rtems/sources/gcc-g++-4.3.2.tar.bz2 | /bin/tar -xvvf -
script: 89: cd ${gcc_source}
script: 90: /bin/chmod -R a+rX,g-w,o-w .
Creating source directory: patches
making dir: /home/shashvat/development/nrtems/rsb/rtems/patches
download: (full) https://git.rtems.org/rtems-tools/plain/tools/4.9/gcc/gcc-core-4.3.2-rtems4.9-20090825.diff -> patches/gcc-core-4.3.2-rtems4.9-20090825.diff
download: https://git.rtems.org/rtems-tools/plain/tools/4.9/gcc/gcc-core-4.3.2-rtems4.9-20090825.diff -> patches/gcc-core-4.3.2-rtems4.9-20090825.diff
checksums: gcc-core-4.3.2-rtems4.9-20090825.diff: d326372a756a7289404031eb16dcc51c15259342ea3f8697f23cfa754ee38305d5e6aaeef56c83f11cdd28c85711c430d894a87303ad932b024a17fa4aaa4f63 => d326372a756a7289404031eb16dcc51c15259342ea3f8697f23cfa754ee38305d5e6aaeef56c83f11cdd28c85711c430d894a87303ad932b024a17fa4aaa4f63
script: 91: /bin/cat /home/shashvat/development/nrtems/rsb/rtems/patches/gcc-core-4.3.2-rtems4.9-20090825.diff | /usr/bin/patch  -p1
script: 92: cd ${build_top}
script: 93: source_dir_newlib="newlib-1.16.0"
source setup: m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1: source newlib -q -D -n newlib-1.16.0
download: (full) ftp://sourceware.org/pub/newlib/newlib-1.16.0.tar.gz -> sources/newlib-1.16.0.tar.gz
download: ftp://sourceware.org/pub/newlib/newlib-1.16.0.tar.gz -> sources/newlib-1.16.0.tar.gz
checksums: newlib-1.16.0.tar.gz: 40eb96bbc6736a16b6399e0cdb73e853d0d90b685c967e77899183446664d64570277a633fdafdefc351b46ce210a99115769a1d9f47ac749d7e82837d4d1ac3 => 40eb96bbc6736a16b6399e0cdb73e853d0d90b685c967e77899183446664d64570277a633fdafdefc351b46ce210a99115769a1d9f47ac749d7e82837d4d1ac3
script: 94: cd /home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
script: 95: /bin/gzip -dc /home/shashvat/development/nrtems/rsb/rtems/sources/newlib-1.16.0.tar.gz | /bin/tar -xvvf -
script: 96: cd newlib-1.16.0
script: 97: /bin/chmod -R a+rX,g-w,o-w .
download: (full) https://git.rtems.org/rtems-tools/plain/tools/4.9/newlib/newlib-1.16.0-rtems4.9-20090324.diff -> patches/newlib-1.16.0-rtems4.9-20090324.diff
download: https://git.rtems.org/rtems-tools/plain/tools/4.9/newlib/newlib-1.16.0-rtems4.9-20090324.diff -> patches/newlib-1.16.0-rtems4.9-20090324.diff
checksums: newlib-1.16.0-rtems4.9-20090324.diff: 6222e85dc8a5f49089742b09348b4f9663861d8c41dba79227d0ff343d4a9f71a5a1d7aacd61567401b924c6453f0e44bc8045226f25ded2bd3fa8ede4c9742f => 6222e85dc8a5f49089742b09348b4f9663861d8c41dba79227d0ff343d4a9f71a5a1d7aacd61567401b924c6453f0e44bc8045226f25ded2bd3fa8ede4c9742f
script: 98: /bin/cat /home/shashvat/development/nrtems/rsb/rtems/patches/newlib-1.16.0-rtems4.9-20090324.diff | /usr/bin/patch  -p1
script: 99: cd ${build_top}
script:100: /bin/rm -f ${source_dir_gcc}/newlib
script:101: ln -s $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
script:102: source_dir_mpfr="mpfr-2.4.2"
source setup: m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1: source mpfr -q -D -n mpfr-2.4.2
download: (full) http://www.mpfr.org/mpfr-2.4.2/mpfr-2.4.2.tar.bz2 -> sources/mpfr-2.4.2.tar.bz2
download: http://www.mpfr.org/mpfr-2.4.2/mpfr-2.4.2.tar.bz2 -> sources/mpfr-2.4.2.tar.bz2
 redirect: https://www.mpfr.org/mpfr-2.4.2/mpfr-2.4.2.tar.bz2
checksums: mpfr-2.4.2.tar.bz2: c004b3dbf86c04960e4a1f8db37a409a7cc4cb76135e76e98dcc5ad93aaa8deb62334ee13ff84447a7c12a5e8cb57f25c62ac908c24920f1fb1a38d79d4a4c5e => c004b3dbf86c04960e4a1f8db37a409a7cc4cb76135e76e98dcc5ad93aaa8deb62334ee13ff84447a7c12a5e8cb57f25c62ac908c24920f1fb1a38d79d4a4c5e
script:103: cd /home/shashvat/development/nrtems/rsb/rtems/build/m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
script:104: /bin/bzip2 -dc /home/shashvat/development/nrtems/rsb/rtems/sources/mpfr-2.4.2.tar.bz2 | /bin/tar -xvvf -
script:105: cd mpfr-2.4.2
script:106: /bin/chmod -R a+rX,g-w,o-w .
script:107: cd ${build_top}
script:108: /bin/rm -f ${source_dir_gcc}/mpfr
script:109: ln -s $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
script:110: source_dir_mpc="mpc-0.8.2"
source setup: m68k-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1: source mpc -q -D -n mpc-0.8.2
download: (full) http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz -> sources/mpc-0.8.2.tar.gz
download: http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz -> sources/mpc-0.8.2.tar.gz
download: no ssl context
download: http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz: error: HTTP Error 500: Internal Server Error
