RSB Problem with gdb-7.11
Michael Westfall
mwestfal at gemini.edu
Tue Dec 11 12:52:00 UTC 2018
Hello,
I was trying to use RSB to build the cross compiler toolchain for rtems
4.10 / powerpc, and after a couple of hours working (mostly spent building
newlib), RSB failed with the following output:
config: tools/rtems-gdb-7.11-1.cfg
package: powerpc-rtems4.10-gdb-7.11-x86_64-linux-gnu-1
building: powerpc-rtems4.10-gdb-7.11-x86_64-linux-gnu-1
error: building powerpc-rtems4.10-gdb-7.11-x86_64-linux-gnu-1
Build FAILED
See error report:
rsb-report-powerpc-rtems4.10-gdb-7.11-x86_64-linux-gnu-1.txt
Build Set: Time 1:55:31.187692
Build FAILED
Looking at the referenced error report, I see:
checking whether to use python... yes
checking for python... /usr/bin/python
checking for python2.6... no
configure: error: python is missing or unusable
make[1]: *** [configure-gdb] Error 1
make[1]: Leaving directory
`/gem_sw/targetOS/RTEMS/rtems-4.10.2-devel/rtems-source-builder/rtems/build/powerpc-rtems4.10-gdb-7.11-x86_64-linux-gnu-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex
/gem_sw/targetOS/RTEMS/rtems-4.10.2-devel/rtems-source-builder/rtems/build/powerpc-rtems4.10-gdb-7.11-x86_64-linux-gnu-1/doit
So, it seems to be an error with finding Python, but /usr/bin/python exists
and is a hard link with /usr/bin/python2.6
Additionally /usr/bin/python2 exists and is a soft link to /usr/bin/python.
I don't understand why this is failing. Ideas?
Thanks
Mike Westfall
Control Systems Software Engineer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181211/29e887c1/attachment.html>
