Status of smptests ...?
Sebastian Huber
Tue Dec 11 14:39:51 UTC 2018
Hello Jiri,
On 11/12/2018 15:24, Sebastian Huber wrote:
> Hello Jiri,
> On 11/12/2018 15:15, Jiri Gaisler wrote:
>> What is the status of the smptests of RTEMS 5 ?
>> I have added SMP capability to the sis simulator, and have tested it
>> with the smptests from rtems git. I have noticed that the reference
>> output (*.scn) are not equivalent to what the simulator or real hardware
>> outputs. It seems that the cpus are numbered backwards compared to the
>> .scn files.
> the .scn files are not up to date. Also the test output is quite test
> dependent and repeated test runs my produce different output.
> The best method to check if a test passed is to check if the
> *** END OF TEST XYZ ***
> message is printed. Which real target did you use to run the tests? I
> will do a test run tomorrow on a N2X.
attached is a run of the smptests on a N2X board.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181211/6a5f5372/attachment-0001.bin>
