[PATCH 2/3] rtems: Use object information to get config max
Tue Dec 11 15:41:09 UTC 2018
Use functions instead of macros.  Add missing
rtems_configuration_get_maximum_*() functions.
Update #3621.
 cpukit/Makefile.am                  |   1 +
 cpukit/include/rtems/config.h       |   3 +-
 cpukit/include/rtems/rtems/config.h |  22 ++++++--
 cpukit/libmisc/monitor/mon-config.c |  18 +++----
 cpukit/sapi/src/extension.c         |   2 +-
 cpukit/sapi/src/getconfigmax.c      | 102 ++++++++++++++++++++++++++++++++++++
 6 files changed, 131 insertions(+), 17 deletions(-)
 create mode 100644 cpukit/sapi/src/getconfigmax.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index c65048634b..b7a2d2bb11 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1023,6 +1023,7 @@ librtemscpu_a_SOURCES += sapi/src/extensiondelete.c
 librtemscpu_a_SOURCES += sapi/src/extensionident.c
 librtemscpu_a_SOURCES += sapi/src/fatal.c
 librtemscpu_a_SOURCES += sapi/src/fatalsrctext.c
+librtemscpu_a_SOURCES += sapi/src/getconfigmax.c
 librtemscpu_a_SOURCES += sapi/src/getversionstring.c
 librtemscpu_a_SOURCES += sapi/src/interrtext.c
 librtemscpu_a_SOURCES += sapi/src/io.c
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index a6b918c09b..36b20dba09 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -276,8 +276,7 @@ extern const rtems_configuration_table Configuration;
           (rtems_configuration_get_stack_allocator_avoids_work_space() ? \
             0 : rtems_configuration_get_stack_space_size()))
-#define rtems_configuration_get_maximum_extensions() \
-        (Configuration.maximum_extensions)
+uint32_t rtems_configuration_get_maximum_extensions( void );
 #define rtems_configuration_get_microseconds_per_tick() \
         (Configuration.microseconds_per_tick)
diff --git a/cpukit/include/rtems/rtems/config.h b/cpukit/include/rtems/rtems/config.h
index 77ee798d74..51b3dbe30f 100644
--- a/cpukit/include/rtems/rtems/config.h
+++ b/cpukit/include/rtems/rtems/config.h
@@ -126,11 +126,23 @@ extern rtems_api_configuration_table Configuration_RTEMS_API;
- *  This macro returns the number of Classic API semaphores configured.
-#define rtems_configuration_get_maximum_semaphores() \
-        rtems_configuration_get_rtems_api_configuration()->maximum_semaphores
+uint32_t rtems_configuration_get_maximum_barriers( void );
+uint32_t rtems_configuration_get_maximum_message_queues( void );
+uint32_t rtems_configuration_get_maximum_partitions( void );
+uint32_t rtems_configuration_get_maximum_periods( void );
+uint32_t rtems_configuration_get_maximum_ports( void );
+uint32_t rtems_configuration_get_maximum_regions( void );
+uint32_t rtems_configuration_get_maximum_semaphores( void );
+uint32_t rtems_configuration_get_maximum_timers( void );
+uint32_t rtems_configuration_get_maximum_tasks( void );
 #ifdef __cplusplus
diff --git a/cpukit/libmisc/monitor/mon-config.c b/cpukit/libmisc/monitor/mon-config.c
index bee7d2847f..852e780d04 100644
--- a/cpukit/libmisc/monitor/mon-config.c
+++ b/cpukit/libmisc/monitor/mon-config.c
@@ -34,15 +34,15 @@ rtems_monitor_config_canonical(
     rtems_api_configuration_table *r = &Configuration_RTEMS_API;
     canonical_config->work_space_size = c->work_space_size;
-    canonical_config->maximum_tasks = r->maximum_tasks;
-    canonical_config->maximum_timers = r->maximum_timers;
-    canonical_config->maximum_semaphores = r->maximum_semaphores;
-    canonical_config->maximum_message_queues = r->maximum_message_queues;
-    canonical_config->maximum_partitions = r->maximum_partitions;
-    canonical_config->maximum_regions = r->maximum_regions;
-    canonical_config->maximum_ports = r->maximum_ports;
-    canonical_config->maximum_periods = r->maximum_periods;
-    canonical_config->maximum_extensions = c->maximum_extensions;
+    canonical_config->maximum_tasks = rtems_configuration_get_maximum_tasks();
+    canonical_config->maximum_timers = rtems_configuration_get_maximum_timers();
+    canonical_config->maximum_semaphores = rtems_configuration_get_maximum_semaphores();
+    canonical_config->maximum_message_queues = rtems_configuration_get_maximum_message_queues();
+    canonical_config->maximum_partitions = rtems_configuration_get_maximum_partitions();
+    canonical_config->maximum_regions = rtems_configuration_get_maximum_regions();
+    canonical_config->maximum_ports = rtems_configuration_get_maximum_ports();
+    canonical_config->maximum_periods = rtems_configuration_get_maximum_periods();
+    canonical_config->maximum_extensions = rtems_configuration_get_maximum_extensions();
     canonical_config->microseconds_per_tick = c->microseconds_per_tick;
     canonical_config->ticks_per_timeslice = c->ticks_per_timeslice;
     canonical_config->number_of_initialization_tasks = r->number_of_initialization_tasks;
diff --git a/cpukit/sapi/src/extension.c b/cpukit/sapi/src/extension.c
index 70246048a4..8e73030d29 100644
--- a/cpukit/sapi/src/extension.c
+++ b/cpukit/sapi/src/extension.c
@@ -33,7 +33,7 @@ static void _Extension_Manager_initialization(void)
     &_Extension_Information,
     OBJECTS_CLASSIC_API,                 /* object API */
     OBJECTS_RTEMS_EXTENSIONS,
-    rtems_configuration_get_maximum_extensions(),
+    Configuration.maximum_extensions,
     sizeof( Extension_Control ),
     OBJECTS_NO_STRING_NAME,    /* maximum length of an object name */
     NULL                       /* Proxy extraction support callout */
diff --git a/cpukit/sapi/src/getconfigmax.c b/cpukit/sapi/src/getconfigmax.c
new file mode 100644
index 0000000000..4d2779dc85
--- /dev/null
+++ b/cpukit/sapi/src/getconfigmax.c
@@ -0,0 +1,102 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 embedded brains GmbH
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/config.h>
+#include <rtems/extensionimpl.h>
+#include <rtems/rtems/barrierimpl.h>
+#include <rtems/rtems/dpmemimpl.h>
+#include <rtems/rtems/messageimpl.h>
+#include <rtems/rtems/partimpl.h>
+#include <rtems/rtems/ratemonimpl.h>
+#include <rtems/rtems/regionimpl.h>
+#include <rtems/rtems/semimpl.h>
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/rtems/timerimpl.h>
+#include <rtems/score/objectimpl.h>
+static uint32_t get_config_max( const Objects_Information *info )
+	if ( _Objects_Is_auto_extend( info ) ) {
+		return info->objects_per_block | RTEMS_UNLIMITED_OBJECTS;
+	return _Objects_Get_maximum_index( info );
+	return get_config_max( &_Barrier_Information );
+	return get_config_max( &_Extension_Information );
+	return get_config_max( &_Message_queue_Information );
+	return get_config_max( &_Partition_Information );
+	return get_config_max( &_Rate_monotonic_Information );
+	return get_config_max( &_Dual_ported_memory_Information );
+	return get_config_max( &_Region_Information );
+	return get_config_max( &_Semaphore_Information );
+	return get_config_max( &_Timer_Information );
+	return get_config_max( &_RTEMS_tasks_Information.Objects );
2.16.4
